GOLF U0100
oleary
Australia
V2-2H
hey every one just having an issue with this car. it came in as an intermitted non start found fault in wiring loom going to ECU (literally just move the loom car would stalled) i have found the culprit which was pin connections on K84 and K56. just looking for some other input to help me along thanks.
Monday,10,February,2025,15:54:48:24285
VIN: WVWZZZAUZJW124574   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 3C 42 44 52 5F A5
VIN: WVWZZZAUZJW124574   Mileage: 81310km-50523miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---    CVN: 65239CB2
   Coding: 0125003224641D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87356F0D1413B284D-8038
   VINID: 9E69EAAAA465A9A9C108414710FC15515E
Readiness: 0010 0001
   Part No SW: 0CW 300 041 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501710227958 CVN: 31830427
   ROD: EV_TCMDQ200021.rod
   VCID: 43D3B3D77B1035C2029-8016
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 62937000000109
   Coding: 01FA8AA124222170477C060740C72980512484E26002947338225038C2A2430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 035373D73B90F5C2429-8056
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120004200100001100000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 7AAD0E334C5AB40A11F-802E
   Part No SW: 5Q0 937 084 CM    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H36 0253
   Serial number: 01001730400496 Dataset Number: V03935271WR 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 05576DCF35A4CBF26CD-8050
   Component: WWS    150627  042 0551
   Serial number:         150728223131
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S9Y17M10D19H22M01S21
   Coding: 00A8DD
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617289 Dataset Number: V03935270DR 0001
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50F98C9BBA66DE5A8FB-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Dataset Number: V03935259QS 0001
   Coding: 330067C115FFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E25C22310F2582A6D7-806A
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR3JF124 Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C000000008800000065
   VCID: 094F61FF19BCAF92085-805C
   Left seat belt tensioner:
   Serial number: 34169677E22101750066
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E26101750919
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 211 17
   Serial number: 35700000000E50B0492H
   Subsystem 4 - Part No SW: -----------    HW: 480 003 010 17
   Serial number: 35800000000EFC3CF629
   Subsystem 5 - Part No SW: -----------    HW: 480 400 211 17
   Serial number: 3510001BD27CABF6859X
   Subsystem 6 - Part No SW: -----------    HW: 480 400 311 17
   Serial number: 3520001B327CABF3047A
   Subsystem 7 - Part No SW: -----------    HW: 480 400 211 17
   Serial number: 3550001BD27CABF4566U
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 30101704221554
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
   Component: KOMBI         202 1440
   Coding: 27A429086788000801882B0B5401000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009008
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 26150A43E862E0EA057-8072
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0006964799 Dataset Number: V03935268GC 0001
   Coding: 030100347F085700FB00005C1C0F00010001070000000000000000000000
   GVL: 01543C000000000040CC80000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3829D43B32D6661AA7B-806C
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29170002337110077422
   Coding: 2CFFFF
   Serial number: 3634625704
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00001000] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 103
                    Mileage: 81306 km
                    Date: 2025.02.09
                    Time: 03:38:42
                    Terminal 30 power supply: 12.4 V
                    Terminal 15: OFF
   Component: HRE_Master    H12 0080
   Serial number: 0458073975 Dataset Number: V03935258DF 0001
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C52F1DF4433274D-8068
   Component: HRE_Slave  H12 0080
   Serial number: 0458245474
   Coding: 020112
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 011017EIU35491 Dataset Number: V03935272MD 0001
   Coding: 003003208001048000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 41DFB9DF610C27D2105-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000017308206
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Dataset Number: V03935273GU 0001
   Coding: 93170000
   Shop #: WSC 00017 666 01817
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B323176B30C542529-8026
   Serial number: 231017EJN03471 Dataset Number: V03935267WT 0001
   Coding: 003001208E01048000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 42DDB6D3640A3CCA09F-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000017127014
   Coding: 150000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      722 0867
   Serial number:                Dataset Number: V03935272JM 0001
   Coding: 02731000FF00000051510001000808001F0500D60120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D07F56FCD94D3B2C4D-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT3015566
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 26101712K22347 Dataset Number: V03935265PP 0001
   Coding: 000307000000010100020054C150A90088000E000000
   VCID: 3C21C82B06EE4A3A433-8068
End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.4V)-----------
I would try to clear this fault in the Module itself (Address 19: CAN Gateway (J533)) and rescan to see if it returns.
Getting verified here on the forum would be a good idea also.
oleary
Australia
V2-2H
I have cleared fault didn't come back instantly but after a test drive it came back there is no lights on the dash.
Sorry pretty sure I was how do I do that again ?
Bruce
Near Philadelphia, PA, USA
See the Blue bar at the top of the page... "How To"....
