2008 Passat B6 (BPY) Windscreen Wiper Controller (wipers not working, no code)
LeBron
Arizona, USA
C?ID=606674
Boring question perhaps, but will a fault code be generated if there is an issue with the wiper controller or motor (front, no rear). Had windscreen (shop manual terminology for windshield), and when rain finally came, wipers went up, dithered, and did not return. I turned them off and pushed them back down out of my view and didn't mess with it since I was due for a warranty windshield due to rear view mirror falling off. Haven't had the windshield replaced on warranty yet and bonded mirror myself with VW primer and adhesive since rear view fell off on two windshields in a row by this repair company. Requested factory glass, and not sure they will honor. Regardless, I have no fault codes related, nothing happens on output test for wiper motor if it is supposed to run the motor, and not active message received on wipers to return point output test. Again, boring maybe, but help appreciated. Wondering if there could still be a bad motor etc. And SB31 fuse is good. Sorry, didn't save autoscan in my rush this time.
Derek
UK (ilexa)
C?ID=56983
The autoscan will help tell us what type of wiper motor/controller the car has, and what the output test options will be so please post the scan
The fact that you could push the wipers down makes me wonder if this is a mechanical problem with the linkage, are you sure the motor is not running when you turn them on?
Best regards
Derek
Reactions: Jef
Whether you explicitly save it or not, VCDS makes a backup copy in your Scans sub-folder. :cool:
LeBron
Arizona, USA
C?ID=606674
Best regards
Derek
@ Uwe, thanks for the reminder that the autoscans are going to the scan folder. I was tired and impatient. @ Derek, scan below. All mechanical links in tact under the firewall cowl cover. And linkage rod appears to be in the "wipers down" position. But yea, I can't move that linkage now. Scan below. I mean, I rebuilt this engine and transmission with my own paws, and for some reason I just don't want to take the wiper motor/control unit out if I don't need to. Something always breaks it seems. This is copy/paste. If I should be posting scans some other way, just let me know. Thank you.
Monday,10,February,2025,07:32:56:32592
VIN:    License Plate: PASSAT
Mileage: 257360km-159916mi   Repair Order: Feb 10 2025
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 36 42 44 46 52 53 62 65 72
          76
VIN: WVWEK73C28P051615   Mileage: 257360km-159916miles
   Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 00028 028 00001
   VCID: 303ECF9A8624A68AEFB-8064
   VINID: 9E69D56C70D3088800141181144723D9FB
Readiness: 0010 0101
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 HJ
   Component: AQ 250 6F           1068
   Revision: 00H69000    Serial number:
   Coding: 0000584
   VCID: 005E5F5A7604F60A5FB-8054
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000776120319
   Coding: 0000348
   VCID: 1F1C3C26EBBA29F2461-804A
Address 08: Auto HVAC        Labels: 3C0-907-044.clb
   Part No SW: 3C0 907 044 BP    HW: 3C0 907 044 BP
   Component: ClimatronicPQ46 122 0707
   Revision: 00122021    Serial number: 00000000000000
   VCID: 70BE0F9A46A4E68AAFB-8024
00710 - Defroster Flap Positioning Motor (V107)
                    Fault Status: 01110000
                    Fault Frequency: 163
                    Reset counter: 233
                    Mileage: 255767 km
                    Date: 2024.10.22
                    Time: 09:18:59
01810 - Actuating Motor for Temperature Flap; Right (V159)
                    Reset counter: 15
                    Mileage: 257102 km
                    Date: 2024.11.30
                    Time: 15:14:08
                    Reset counter: 241
                    Mileage: 256573 km
                    Date: 2024.11.13
                    Time: 11:47:09
                    Fault Frequency: 8
                    Reset counter: 7
                    Mileage: 256700 km
                    Date: 2024.11.14
                    Time: 14:39:22
   Revision: 00H54000    Serial number: 01000005099467
   Coding: F5848F0340041A00470000000F00000000285D435C000100000000000000
   VCID: 71B80A9E4DAEEF82A05-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 070807 003  0205
   Coding: 00046997
   Shop #: WSC 00028
   Component: RLS     210907 046  0204
   Coding: 00208933
   Shop #: WSC 00028
                    Fault Status: 00101010
                    Reset counter: 18
                    Mileage: 257358 km
                    Date: 2024.12.06
                    Time: 05:36:00
                    Voltage: 12.60 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0144829
   VCID: 2E02D1E29C10B07AFD7-807A
                    Reset counter: 157
                    Mileage: 255767 km
                    Date: 2024.10.22
                    Time: 09:04:08
01304 - Radio
                    Reset counter: 233
                    Mileage: 257360 km
                    Date: 2024.12.06
                    Time: 16:13:05
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 17 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2PJFP4EW
   Coding: 0012599
   VCID: 3138CA9E8D2EAF82E05-8064
   Subsystem 1 - Part No: 3C0 959 339 B
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 0000000003NVL1
   Subsystem 3 - Serial number: 0001.01.000000700000000000  63
   Subsystem 4 - Serial number: 000000  6332MSME162427070  63
   Subsystem 5 - Serial number: 427070  6342MSME172C3049A  63
   Subsystem 6 - Serial number: C3049A  6351HTS61CGC94P68  63
   Subsystem 7 - Serial number: C94P68  6361HTS61CGS86J6K  63
   Subsystem 8 - Serial number: S86J6K  63727TS61CGSG7V6X  63
   Subsystem 9 - Serial number: SG7V6X  63827TS61CGSG1I6F
   Subsystem 10 - Serial number: SG1I6F
   Part No SW: 3C0 953 549 K    HW: 3C0 953 549 K
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C5953507BG
   Coding: 0001211
   VCID: 3436C38A723C9AAA8B3-8060
   Part No SW: 3C0 920 971 F    HW: 3C0 920 971 F
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 12345 111 45725
   VCID: 280E27FABEF4EE4A37B-807C
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P0790300E0
   Coding: FD80FF0F0001021002
   VCID: 231430D6C7D20D12629-8076
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 06402 785 00200
   VCID: 73B4009637B2DD92529-8026
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F3CCCE69B1AB972F61-807A
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1131
   Revision: 31008001    Serial number: 00000030078915
   Coding: 0001463
   VCID: 3C26EBAA5A6C52EA433-8068
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   VCID: 3530FE8E794683A2BCD-8060
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13910F8001862E521004141FF08A8F0E085800
   Shop #: WSC 00137 211 56823
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1131
   Revision: 31008001    Serial number: 00000042578907
   Coding: 0001462
   VCID: 3D20E6AE41765BE274D-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000171972
   Coding: 0000057
   VCID: 290822FEA5FED742285-807C
   Component: J388   TUER-SG HL   1118
   Revision: 12006001    Serial number: 00000002364457
   Coding: 0001168
   VCID: 3E22E1A24C7040FA6D7-806A
   Coding: 0100101
   Component: J389   TUER-SG HR   1118
   Revision: 12006001    Serial number: 00000002375230
   Coding: 0001168
   VCID: 3FDC9CA64B7A49F2661-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90630726011245
   Coding: 0001114
End----------(Elapsed Time: 01:36, VBatt start/end: 13.8V/13.7V)-----------
LeBron
Arizona, USA
C?ID=606674
And now I see the CODE tag to use... will next time.
Derek
UK (ilexa)
C?ID=56983
Coding: 00046997
Shop #: WSC 00028
This data in the autoscan shows the wiper motor details which I feel unless it's being particularly tricky shows the LIN bus is OK and the motor is powered up.
Check the live data in central electrics module (09) to make sure the switch is working correctly
Do you have aftermarket bulbs in the car?
Best regards
Derek
EuroX
Northern NJ USA
C?ID=208579
If the wipers do not park in the correct position the linkage at the motor needs to be adjusted. But if you had a windshield put in I would check and make sure the wiper arm taper threads are tight and not stripped.
LeBron
Arizona, USA
C?ID=606674
Coding: 00046997
Shop #: WSC 00028
Best regards
Derek
Thank you. I will check 09 live data. Not aftermarket bulbs, but new headlight assemblies that may have loose/intermittent connector. This is a new fault, and I haven't noticed an issue with the lights, but the light assemblies.... well, not OEM. Will need to check that out.
LeBron
Arizona, USA
C?ID=606674
I have the wipers off for the time being, and correct that initially, the window shop may not have properly torqued wipers. Problem currently being that without wipers installed, motor isn't running. Motor position is at wipers down. Do you know if there is a "service" position for the motor below the "wipers down" position that puts it in a inoperable state? That is the case on some cars, but I didn't see anything about that in the workshop manual. I did try the
LeBron
Arizona, USA
C?ID=606674
Can't get motor to go into "service/winter" position either. Included the APP just in case I end up needing to remove the motor, but hoping not. From the manual...
General description:
The wiper motor control unit - J400- and the windscreen wiper
motor - V- are combined to form one unit.
To remove the wiper blades, the wiper arms should be placed in
the “service/winter position”. The “service/winter position” is acti‐
vated within 10 seconds after ignition is switched off by pressing
windscreen wiper lever in “tip wipe” position ⇒ Operating manual
of vehicle .
Fault detection and fault display:
The wiper motor control unit - J400- is equipped with self-diag‐
nosis, which makes fault finding easier.
For fault finding, use the systems described in chapter “Vehicle
diagnosis, testing and information system” in “Guided Fault Find‐
ing” mode ⇒ page 409 .
1.1 Deactivating APP function of wiper mo‐
tor
The windscreen wiper system is equipped with an APP function
(alternating park position).
With the APP function, the wiper is moved up slightly once it has
reached the lowest position. This occurs every second time the
wiper system is switched off.
To fit the motor crank on the wiper motor, it is necessary for the
motor to be in the lowest park position. To ensure this position is
reached, the APP function must be deactivated.
Derek
UK (ilexa)
C?ID=56983
I was really hoping this would be an easy one and the linkage had fallen off or come loose at the motor spindle, but it's proving much harder to find the fault.
I think you'd hear the wiper motor even if the linkage was loose at the motor spindle or the gear box had failed so it does look more like electrical
I'm not sure if you checked the live data to make sure the wiper switch is sending the right signals yet, but also check the bonnet switch as many cars have the wipers are disabled if the car thinks the bonnet is open to prevent the arms scraping along the edge (Also. that's important when you're testing so if you need to do tests with the bonnet open, click the bonnet catch/s shut with a screwdriver)
DON'T touch the linkage with the battery connected!
Oh and the headlamps. If they are HID or LED, it's worth disconnecting them to test as I'm pretty sure I saw mention that some can affect the central electrics controller
Best regards
Derek
EuroX
Northern NJ USA
C?ID=208579
On some vw and audi vehicles wipers will not run if the hood is open. To test latch hood latch and check if it makes a difference. Service position is a thing but varies by model you can normally engage service position by either MMI or cluster depending on vehicle and model.
LeBron
Arizona, USA
C?ID=606674
Best regards
Derek
Derek,
Thanks. I checked live data (09 various like wiper motor, bonnet, and ran output test and could hear motor trying), so I removed the linkage assembly and motor, popped the controller off, and found a busted output gear (plastic, cracked all the way through). So VCDS led me down the path to the end necessity which I was trying to avoid, but alas she is broken. And from the behavior I saw originally after windscreen replacement (wipers went up and just got stuck there dithering a bit) it was either cracked somehow during the windshield repair, or (I think unlikely) the planets aligned and it was compromised and broke on the first stroke after the repair and would have happened anyway. Regardless, I will ask the windscreen shop if they can offer any help with costs. I'll likely be at the local pull-a-part again this weekend. Thanks again to all.
Derek
UK (ilexa)
C?ID=56983
Glad you got to the bottom of the problem
Best regards
Derek
