B7 RS4 no start
dangel1321
NYC, USA
C?ID=242645
Friday,20,December,2024,17:11:20:50072
VCDS Version: 24.7.1.0 (x64)
VIN: WUARU78E97N906264   License Plate: RS412/20/24
Mileage: 154100km-95753mi   Repair Order:
          67 69 75 76 77
VIN: WUARU78E97N906264   Mileage: 154100km-95753miles
Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560 A    HW: 8E1 907 560
   Component: 4.2L V8/4V FSI     ª0060
   Revision: 57H15---    Serial number: XXXXXXXXXXXXXX
   Coding: 01040009180F0160
   Shop #: WSC 08221 444 57795
   VCID: 2447AF88E71867B68F-8070
   VINID: 9E5462947215247789006086106F3A5073
001796 - Clutch Switch (F36)
               P0704 - 004 - Implausible Signal
                    Mileage: 152231 km
                    RPM: 2262 /min
                    Load: 18.4 %
                    Speed: 30.0 km/h
                    Temperature: 94.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.208 V
012424 - Starter Relay
               P3088 - 001 - Electrical Malfunction
                    Fault Status: 01100001
                    Mileage: 154101 km
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 10.922 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Mileage: 154101 km
                    Temperature: 1.0°C
                    Temperature: 5.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.557 V
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Component: ESP8 quattro    H06 0150
   Coding: 0004533
   Shop #: WSC 06335 000 00000
   VCID: 2B5544B48AC6A8CE4E-807E
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6DD18AAC275266FE10-5104
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 01023
   Shop #: WSC 06335
   VCID: 3D717AEC37B2367EE0-4AE4
            30-00 - Open or Short to Plus
Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 004 - Open Circuit - Intermittent
                    Mileage: 152175 km
                    RPM: 203 /min
                    Load: 99.2 %
                    Temperature: 21.0°C
                    Temperature: 21.0°C
                    Voltage: 10.541 V
               P0300 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 153263 km
                    RPM: 769 /min
                    Load: 25.1 %
                    Temperature: 75.0°C
                    Temperature: 53.0°C
                    Voltage: 13.970 V
000773 - Cylinder 5
               P0305 - 001 - Misfire Detected - Intermittent
                    Mileage: 153263 km
                    RPM: 769 /min
                    Load: 25.1 %
                    Temperature: 75.0°C
                    Temperature: 53.0°C
                    Voltage: 13.970 V
000776 - Cylinder 8
               P0308 - 001 - Misfire Detected - Intermittent
                    Mileage: 153263 km
                    RPM: 769 /min
                    Load: 25.1 %
                    Temperature: 75.0°C
                    Temperature: 53.0°C
                    Voltage: 13.970 V
000775 - Cylinder 7
               P0307 - 001 - Misfire Detected - Intermittent
                    Mileage: 153263 km
                    RPM: 769 /min
                    Load: 25.1 %
                    Temperature: 75.0°C
                    Temperature: 53.0°C
                    Voltage: 13.970 V
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H13 4240
   Revision: 91H13424    Serial number: 0036N0G0V452
   Coding: 0432607
   VCID: 3C7777E87FA83F76D7-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3J695
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ† 63
   Subsystem 4 - Serial number: 000000ÿ† 6332DRB404B24E2BVÿ† 63
   Subsystem 5 - Serial number: 24E2BVÿ† 6342DRB404AD0D0AYÿ† 63
   Subsystem 6 - Serial number: D0D0AYÿ† 6352ARB4020FF4FD3ÿ† 63
   Subsystem 7 - Serial number: FF4FD3ÿ† 6362ARB4020A786DTÿ† 63
   Subsystem 8 - Serial number: A786DTÿ† 63729RB40221C834Fÿ† 63
   Subsystem 9 - Serial number: 1C834Fÿ† 63829RB40221C6C3Mÿ
   Subsystem 10 - Serial number: 1C6C3Mÿ
Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
   Part No: 8E0 953 549 T
   Component: Lenksáulenmodul     0301
   Coding: 04441
   Shop #: WSC 06335
   VCID: 44870F08545847B6AF-4AE4
01304 - Radio
            49-00 - No Communications
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 982 R    HW: 8E0 920 982 R
   Component: KOMBI+WFS 4     H14 0100
   Revision: 0100        Serial number: 00000000000000
   Coding: 0023208
   Shop #: WSC 40816 444 59144
   VCID: 3D717AEC67B2367EE0-5122
01304 - Radio
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0023208
   VCID: 3D717AEC67B2367EE0-5104
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71E996DC3B6A821E34-4AE4
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 11880
   Shop #: WSC 06335
   VCID: 78FFABF85810D356F3-4AE4
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 2959BEBC803ABADEBC-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H04 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH04 0020
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062523
   Shop #: WSC 02197 785 00200
   VCID: 2A5B41B0863CB1C6B5-5122
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802030703
   Coding: 0000304
   VCID: 316956DCABEAC21E74-5122
End-------------------------(Elapsed Time: 06:01)--------------------------
Log-RS412-20-24-WUARU78E97N906264-154100km-95753mi.txt
Displaying Log-RS412-20-24-WUARU78E97N906264-154100km-95753mi.txt.
EuroX
Northern NJ USA
C?ID=208579
Please specify crank no start? Or no crank no start? Any water in ebox?
Given the Clutch Switch (F36) - Implausible Signal and Starter Relay - Electrical Malfunction fault codes, my money would be on No Crank.
Any water in ebox?
Or elsewhere in the electrical bits..?
dangel1321
NYC, USA
C?ID=242645
no crank, no start. I have yet to find the starter relay location. But can a bad clutch switch prevent the car from starting or just allow the car to start without the need to depress the clutch?
I believe so, although in that case, I'd expect a "Press clutch to start" message in the display area of the instrument cluster.
EuroX
Northern NJ USA
C?ID=208579
Starter relay is in the ebox.
dangel1321
NYC, USA
C?ID=242645
Thank you all for your timely responses. I had an inkling but didn't want to start taking things apart just to come up empty handed. Hopefully the starter relay is the culprit.
Westbury, UK
On the B7 RS4 a bad clutch switch can require you to hold the START button until the engine starts instead of the usual short tap on the START button.
It also stops cruise control working.
I had to replace the clutch switch twice on my previous B7 RS4.
  • Informative
