- Dec 19, 2024
- 4
- 1
- New Jersey, USA
- C?ID=137065
Hi everyone. Thank you for taking the time to check this post out.
Auto-scan posted below.
2016 Audi TTS (not RS, think like an S3), 109k Miles. Stage 2 Unitronic tune. IE High flow catted downpipe, IE V2 Intake.
I was driving home on the highway last night, going between 60 and 70MPH. RPM's were between 2-3k. Suddenly, the car shuddered a little bit. I felt a low frequency vibration, but it quickly went away. We immediately started looking for a gas station to stop at, and the shuddering happened again, and again, and again. Nothing violent, just a shudder. We pulled into a Sunoco, I popped the hood, and started investigating. As the car was idling, I heard a knock, just one, and the engine started idling really rough and died. After looking at the engine bay for a few minutes, I saw that the bolt holding the turbo inlet was loose. I was able to hand screw it off. I went to the mechanic shop at the Sunoco, borrowed some tools, and reseated the turbo inlet pipe and tightened the bolt. We started the car back up, and everything seemed fine for a few seconds, then it shuddered again, followed by a dreaded repeating knock/tick sound. Then the car shut off before I could turn it off. It sounds plasticky, and when I felt around the engine bay with my hand to see if I could locate where exactly it's coming from, I felt the tick in the PCV the most. There was no vibration felt when I put my hand on the head towards the back of the engine by the turbo, and I checked in as many spots as possible.
I had the car towed to my garage, and I plan on removing the PCV to see if there is any visible damage on the intake valves/springs, followed by removing the head to check for damage. Also planning on buying a borescope and looking at the pistons. Before I get too in over my head, I'm looking for some advice on how to go about this, as I've never dealt with an engine knock in the past.
The sound is fast, consistent, and increases in speed with the RPM's. The speed is like a snare drum roll, with two distinct sounds in the knock, like an "in" and "out." This is the best way I can describe it without turning my car on and risking more damage. Oil level is fine. Coolant level is fine. No leaks except for a tiny drip from the oil pan seal that releases a drop maybe two times a day. Spark plugs are just about due for a change, and we were planning on doing a timing service at the 110k service interval. When the car was on, I pulled the oil fill cap, and there was plenty of vacuum pulling it back in.
When asking my mechanic friend on facetime while the car was running, he mentioned it sounds like the intake valves over-extending, and not so much like valve to piston interference. My friend recommended that plan with the PCV and borescope.
Any advice where to start or pointers on diagnosing? Has anyone dealt with this before?
Sunday,09,February,2025,12:27:27:49950
VCDS Version: 24.7.1.0 (x64)
VIN: TRUC1AFV1G1027852 License Plate: M59MYR
Mileage: 176720km-109808mi Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 52 55 5F 6C
A5 A9
VIN: TRUC1AFV1G1027852 Mileage: 176720km-109808miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 259 C HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: 7BE9F791
Coding: 0A1D00322426000E3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208S0906259C 001004
ROD: EV_ECM20TFS0208S0906259C.rod
VCID: 3D7B3CB9ACB2B07EE0-8068
VINID: 9229530515A6057040087205083F773CD5
8 Faults Found:
20662 - Oxygen (Lambda) Sensor B1 S1
P0131 00 [01100101] - Signal too Low
Mileage: 176720 km
Date: 2025.02.08
Time: 15:36:48
Engine RPM: 825.50 /min
Normed load value: 3.5 %
Coolant temperature: 83 °C
Intake air temperature: 35 °C
Voltage terminal 30: 12.070 V
Engine: operating status: IS
STATE_LS_SAE[1]: CL
T_AST_SAE: 1 s
MAP_MES_SAE: 29 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 0.000 V
TTIP_MES_LS_UP[1]: 643.1250 °C
TEG_DYN_LS_UP[1]: 277.6000 °C
14955 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2097 00 [01100000] - Too Rich
Mileage: 173271 km
Date: 2024.12.27
Time: 18:46:41
Engine RPM: 1806.00 /min
Normed load value: 17.6 %
Vehicle speed: 59 km/h
Coolant temperature: 95 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.687 V
Unlearning counter according OBD: 36
Engine: operating status: PL
LAMB_DELTA_I_LAM_ADJ[1]: 0.02905
Lambda probe correction: duty cycle offset: bank 1: 0.04077
VLS_DOWN_SAE[1]: 0.490 V
LAMB_DELTA_SUM_LAM_ADJ_AD[1]: 0.03967
TTIP_MES_LS_UP[1]: 785.0000 °C
Lambda probes actual: bank1: 0.9199
29388 - Internal Control Module
P060C 00 [00100000] - Main Processor Performance
15125 - Cylinder 1
P0301 00 [01100100] - Misfire Detected
Mileage: 176709 km
Date: 2025.02.08
Time: 14:45:41
Engine RPM: 2819.00 /min
Normed load value: 13.7 %
Vehicle speed: 69 km/h
Coolant temperature: 94 °C
Intake air temperature: 15 °C
Voltage terminal 30: 14.707 V
N_TOOTH: 2804 /min
T_AST_SAE: 3951 s
Engine oil temperature: 105.0 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 15440.0 kPa
FUP_EFP_MES: 11000.8 hPa
15131 - Cylinder 3
P0303 00 [01100100] - Misfire Detected
Mileage: 176717 km
Date: 2025.02.08
Time: 14:50:33
Engine RPM: 2170.00 /min
Normed load value: 18.8 %
Vehicle speed: 86 km/h
Intake air temperature: 18 °C
Voltage terminal 30: 14.804 V
N_TOOTH: 2117 /min
T_AST_SAE: 4243 s
STATE_LS_SAE[1]: CL
FUP_H_SAE: 14330.0 kPa
15134 - Cylinder 4
P0304 00 [01100100] - Misfire Detected
Mileage: 176708 km
Date: 2025.02.08
Time: 14:44:49
Engine RPM: 2453.50 /min
Normed load value: 24.7 %
Vehicle speed: 80 km/h
Coolant temperature: 93 °C
Intake air temperature: 12 °C
N_TOOTH: 2452 /min
T_AST_SAE: 3900 s
STATE_LS_SAE[1]: CL
FUP_H_SAE: 15710.0 kPa
15128 - Cylinder 2
P0302 00 [11101101] - Misfire Detected
Mileage: 176709 km
Date: 2025.02.08
Time: 14:45:41
N_TOOTH: 2804 /min
T_AST_SAE: 3951 s
STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [01100100] - -
Mileage: 176709 km
Date: 2025.02.08
Time: 14:45:41
N_TOOTH: 2804 /min
T_AST_SAE: 3951 s
STATE_LS_SAE[1]: CL
Readiness: 0010 0001
Part No SW: 0D9 300 013 D HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4905
Revision: 06253104 Serial number: TFK01601221616 CVN: 0000684A
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1835CD2DE350B55613-804C
Part No SW: 8S0 907 379 D HW: 8S0 907 379 D
Component: ESC H42 0522
Revision: 00000000 Serial number: 60376000000342
Coding: 24AA608D0A9B15B0009908698293910623240650A80010418960C4
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 42814F45D54CCF869D-8016
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0395649367 Dataset Number: 8S0909577D 0001
Coding: 030C0C1720
ROD: EV_KessyHellaMQBAB.rod
VCID: 3A7137A5BD9C8746C5-806E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0030
Revision: 20009000 Serial number: 16220000009000
Coding: 400040100001041100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6CDDC1FD8748E9F607-8038
Humidity sensor: exterior:
Rear A/C Control Head 2:
Subsystem 2 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000025357
Rear A/C Control Head 3:
Subsystem 3 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Rear A/C Control Head 4:
Subsystem 4 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
263681 - Exterior Air Quality/Humidity Sensor
B137A 04 [00001000] - Internal System Fault
Reset counter: 177
Mileage: 174312 km
Date: 2025.01.09
Time: 19:19:39
Outside temperature: -1.0 °C
Voltage terminal 30: 14.5 V
System run time-Engine running time: 20 s
System run time-Terminal 15 on: 21 s
Air quality status: Measuring value not available
414977 - A/C Display/Control Head 1
B1494 29 [00001000] - Signal Implausible
Reset counter: 177
Mileage: 172097 km
Date: 2024.11.23
Time: 12:41:40
Outside temperature: 12.5 °C
Voltage terminal 30: 11.6 V
414996 - A/C Display/Control Head 5
B1498 31 [00001001] - No Signal
Fault Frequency: 246
Reset counter: 137
Mileage: 172097 km
Date: 2024.11.23
Time: 12:41:40
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061603800167 Dataset Number: 8S0909514H 0041
Coding: 040D5C46C00106FD41444004531007A80080000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 040D895D8FD801B6EF-8050
Subsystem 1 - Part No SW: 8S1 955 119 B HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 160202 038 0371
Serial number: 00000001601280307385
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 61358461
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 01 12 2015 00001513
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0040
Serial number: 0000009600335Z0N3Q02
Coding: 150000
Garage door opener control head:
Subsystem 5 - Part No SW: 8S0 959 719 HW: 8S0 959 719
Component: GTO BF H05 0010
Serial number: 20160126180900 00369
Subsystem 6 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000065093232
11786 - Bulb for Rear Left Fog Light
B12C7 15 [00001000] - Open or Short to Plus
Reset counter: 145
Mileage: 175603 km
Date: 2025.01.25
Time: 18:37:42
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 14.7 V
Outside temperature: 3.5 °C
204546 - Remote key 2
B147A 18 [00001000] - Current Too Low
Reset counter: 143
Mileage: 175299 km
Date: 2025.01.24
Time: 22:00:08
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.4 V
Outside temperature: -6.0 °C
786954 - Heater for Spray Nozzles
B1224 15 [00001001] - Open or Short to Plus
Reset counter: 199
Mileage: 171180 km
Date: 2024.11.03
Time: 16:43:55
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.5 V
Outside temperature: 10.0 °C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391604802908 Dataset Number: 8S0909526C 0018
Coding: 0070150011
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 438F4A41CA56C68E96-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 180216066 Dataset Number: 8S0909554D 0012
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
2117647 - Front Right Ride-Height Sensor
C1035 07 [00001000] - Mechanical Failure
Fault Frequency: 8
Reset counter: 174
Mileage: 175654 km
Date: 2025.01.25
Time: 19:10:38
COM: 14 24 13 C7 00 74 F3 15 00 00
Voltage terminal 30: 14.8 V
Terminal 15 status via CAN: Terminal 15 on
AMR state: 0
Damping adjustment indicator lamp: OFF
Vehicle level sensor: supply voltage-Voltage 1: 5.0 V
Vehicle level sensor: supply voltage-Voltage 2: 5.0 V
Vehicle level sensor: frequency-Left front: 810 Hz
Vehicle level sensor: frequency-Right front: 800 Hz
Vehicle level sensor: frequency-Left rear: 800 Hz
Vehicle level sensor: frequency-Right rear: 800 Hz
ESP automatic engagement: not activated
Fall-back level: 44 00 04 0E
Vehicle level sensor: raw value-Left front: 19.6 %
Vehicle level sensor: raw value-Right front: 34.0 %
Vehicle level sensor: raw value-Left rear: 32.8 %
Vehicle level sensor: raw value-Right rear: 62.4 %
6291467 - Terminal 15
U1405 00 [00001000] - Implausible signal
Reset counter: 145
Mileage: 175654 km
Date: 2025.01.25
Time: 19:10:47
COM: 14 24 13 D7 00 75 17 2D 00 00
Terminal 15 status via CAN: Terminal 15 off
AMR state: 6
Damping adjustment indicator lamp: On
ESP automatic engagement: activated
Part No SW: 5Q0 959 655 R HW: 5Q0 959 655 R
Component: AirbagVW20 010 0830
Serial number: 003M9R0032D- Dataset Number: 8S0909602B 0011
Coding: BFCCF0C000800000A000001FC24800000065
VCID: 4FA77671161E32EE02-801A
Subsystem 1 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H10 0021
Serial number: IBH000000000004MCNO2
Coding: 303332
Subsystem 2 - Part No SW: ----------- HW: 480 002 502 16
Serial number: 357000000001A4615919
Subsystem 3 - Part No SW: ----------- HW: 480 002 502 16
Serial number: 358000000002A461591B
Subsystem 4 - Part No SW: ----------- HW: 480 010 402 16
Component: SideSensor_Dr 004 0108
Serial number: 351001A05D3A9C84EC5T
Subsystem 5 - Part No SW: ----------- HW: 480 402 010 15
Serial number: 3550002A91CF1D138259
Subsystem 6 - Part No SW: ----------- HW: 480 402 010 15
Component: FrontSensor_P 001 6149
Serial number: 3560002A91CF1D13C2BK
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8S0 907 129 AN HW: 8S0 907 129 AN
Component: Lenks. Modul H07 0140
Revision: -------- Serial number: 91335OLD01149
Coding: 2858
ASAM Dataset: EV_SMLSKLOMQB 019002
ROD: EV_SMLSKLOMQB_010_SE37.rod
VCID: 06099355B9E433A6F1-8052
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 A HW: 8S0 920 790 A
Component: FBenRDW H35 0265
Coding: 082F0841798900080221ECC09800800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 37772E918E8E9A2E3A-8062
Part No SW: 8S0 907 468 C HW: 8S0 907 468
Component: GW MQB TT3 012 0244
Revision: -------- Serial number: 20021610801118 Dataset Number: 8S0909515B 0017
Coding: 0301000424025A004B000228B80000000000000000000000000000000001
GVL: 01D43C100000040040CC10000002CC0000000000000000000000000000000000
ASAM Dataset: EV_GatewContiAU33X 011003
ROD: EV_GatewContiAU33X_011.rod
VCID: 4085454DDB40DD968B-8014
Generator:
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20160218115828 01395
Subsystem 3 - Part No SW: 8S0 915 181 A HW: 8S0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 8041799103
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7754
Serial number: HA1-00001.02.16 Dataset Number: v1260x015G0 0000
Coding: 0101
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 458B5459C462F8BEB8-8010
Part No SW: 8S0 907 566 HW: 4H0 907 566 F
Component: SWA Master H08 0050
Serial number: 0392791067 Dataset Number: 8S0909535A 0017
Coding: 030211
ROD: EV_LaneChangAssis_VW52.rod
VCID: 7CFDF1BDF728797697-8028
Subsystem 1 - Part No SW: 8S0 907 568 HW: 4H0 907 568 F
Component: SWA Slave H08 0050
Serial number: 0395058009
Coding: 030211
Component: TSG FS 020 0041
Serial number: 130116EA906868 Dataset Number: 8S0909872D 0020
Coding: 001E53224000040100000402
ROD: EV_DCUDriveSideEWMAXKLO.rod
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Dataset Number: 8S0909852B 0008
Coding: 9102
VCID: 397328A9B89A8C5ECC-806C
Component: TSG BFS 020 0041
Serial number: 230116EAL05807 Dataset Number: 8S0909873D 0020
Coding: 001E53224C00040100000402
ROD: EV_DCUPasseSideEWMAXKLO.rod
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Revision: -------- Serial number: -------------- Dataset Number: 8S0909865D 0024
Coding: 0362001123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 366923958984632621-8062
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8S0 035 025 Q HW: 8S0 035 025
Component: MU-H-LNS-US 043 0414
Serial number: A263B0GB002219 Dataset Number: 8S0909545D 0026
Coding: 01335402FF08000011220001041A00002F0000E0007000047E
VCID: 3B7F32A1B2A6BE4EDE-806E
Subsystem 1 - Part No SW: V03 959 801 GE HW: -----------
Component: NAR 2016 --- 0048
Subsystem 2 - Part No SW: 8S0 919 614 L HW: 8S0 919 614 L
Component: ControlUnit_H H22 0136
Serial number: APVAK119121500010022
Compact disc data bank:
Component: Gracenote2 --- 3007
Reset counter: 247
Mileage: 164609 km
Date: 2024.07.27
Time: 15:27:26
Voltage terminal 30: 14.3 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Part No SW: 5Q0 980 556 A HW: 5Q0 980 556
Component: RVC Compact H08 0172
Dataset Number: 8S0909460A 0005
Coding: 0233540102002001000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: 38752DAD8390955633-806C
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000511892 Dataset Number: 8S0909466B 0016
Coding: 0100000000010305000501010000000100
ROD: EV_MFKBoschAU370.rod
VCID: 3C7D31BDB7A8B976D7-8068
Part No SW: 8S0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0005
Serial number: 151212201031
End-------------------------(Elapsed Time: 05:49)--------------------------
