2016 Touran trailer module now brake assist does not work
Stickystuff
Thatcham, UK
C?ID=555124
Afternoon All,
We fitted a dedicated towbar wiring kit 13 pin which worked without telling the car. We have now ticked the installation list for trailer module on 69, but we are still getting fault in module 13 which brings up on the dash no Auto cruise control and front assist not available.
In my A4 and Q5 I had to change the coding on the ABS module but this is not flagging any faults on the ABS.
Can you help with what I need to change to make it work please?
Full Scan below:
Thank you in advance
Saturday,08,February,2025,16:55:48:61788
VIN: WVGZZZ1TZGW589525   License Plate:
Chassis Type: 1T-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 69
VIN: WVGZZZ1TZGW589525   Mileage: 135388km-84126miles
Address 01: Engine (J623-DFEA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EB    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 1895
   Revision: B4H23---    CVN: CCE259BA4C6C0C4B
   Coding: 01190012034505082000
   ASAM Dataset: EV_ECM20TDI01104L906026EB 004003
   ROD: EV_ECM20TDI01104L906026EB_004.rod
   VCID: 6E85DC48001810BAB5F-803A
   VINID: 9E65EAAAA064A979C520914214DE17D050
17156 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 135388 km
                    Date: 2025.02.08
                    Time: 16:53:08
                    Engine RPM: 0.00 /min
                    Coolant temperature: 69 °C
                    Intake air temperature: 64 °C
                    Voltage terminal 30: 11.860 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 61136000002392
   Coding: 0CEA92A034288B75077C060241C82930492CD1E0608294F51460F078C002
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7EA5EC085078603A25F-802A
   Part No SW: 5G0 907 044 BF    HW: 5G0 907 044 BF
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 0812010420310001100510000010100A
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 6C81D6403604E2AA9BB-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Component: BCM PQ37BOSCH 028 0163
   Revision: --------    Serial number: 865829041600UC Dataset Number: V03935236NP 0001
   Coding: 03000842C24102F30FA44090B10403281080000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 005992F02A8C16CA573-8054
   Subsystem 1 - Part No SW: 5TC 955 119 A    HW: 5TB 955 119
   Component: WWS    160323  042 0608
   Serial number:         160411185324
   Component: RLHS  037 0059
   Serial number: S5Y16M05D06H11M45S23
   Coding: 90A8DD
   Serial number: 000000000ZY160321L73
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065496485
   Humidity sensor: interior:
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331612512369 Dataset Number: V03935233FH 0001
   Coding: 0071051801
   VCID: 44D15EE07E14CAEA33B-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Dataset Number: V03935229RV 0001
   Coding: 2A00608251FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34310E202EB47A6A83B-8060
1229 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FAULT_CODING_AAG]
                    Reset counter: 230
                    Mileage: 135388 km
                    Date: 2025.02.08
                    Time: 16:53:07
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 11.8 V
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR1RG0PL Dataset Number: V03935233ZN 0001
   Coding: 98CCC0C00C0000005C5450CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   VCID: 03539DFC3B9A0DD24A1-8056
   Left seat belt tensioner:
   Serial number: 5TC857705E0118Q01180
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5TC857706E0117Q00648
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 605 16
   Serial number: 35700000000AB3982B1R
   Subsystem 4 - Part No SW: -----------    HW: 480 000 605 16
   Serial number: 358000000005A3982B1M
   Subsystem 5 - Part No SW: -----------    HW: 480 412 104 16
   Component: SideSensor_Dr  003 0189
   Serial number: 351001A05FBBCF204F3R
   Subsystem 6 - Part No SW: -----------    HW: 480 412 104 16
   Component: SideSensor_Pr  003 0189
   Serial number: 352001A05FC445B4AEDW
   Subsystem 7 - Part No SW: -----------    HW: 480 402 604 16
   Serial number: 3550001B92100D45126P
   Subsystem 8 - Part No SW: -----------    HW: 480 401 803 20
   Component: PedP_Sensor_D  004 6149
   Serial number: 22800011662FAD66C408
   Subsystem 9 - Part No SW: -----------    HW: 480 401 803 20
   Component: PedP_Sensor_P  004 6149
   Serial number: 22900011862FAD625231
   Subsystem 10 - Part No SW: -----------    HW: 480 400 705 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001B5209F102B7E/
   Subsystem 11 - Part No SW: -----------    HW: 480 002 604 16
   Serial number: I0M000000006B7FCCA1S
   Subsystem 12 - Part No SW: -----------    HW: 480 002 604 16
   Serial number: I0N000000009B7FCCA1W
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 01051604220407
   Coding: 0400
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0D47BBC46DDE4BA22C5-8058
   Part No SW: 5TA 920 951     HW: 5TA 920 951
   Component: KOMBI         308 6421
   Coding: 27A401002780260001886B011400000000000000
   VCID: 04519EE03E940AEA73B-8050
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004818906 Dataset Number: V03935238XG 0001
   Coding: 030100041F087300FB00025C080F00010001050000000000000000000000
   GVL: 01543C0000000000C00C80000000480000000000000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79AFFF144956470210D-802C
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160000718030016145
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
   Component: J367-BDMHella  H10 9052
   Serial number: 3848060104
   Serial number: 210316ECJ0447A Dataset Number: 5TA222v____ 0016
   Coding: 003B0220D201048000001000
   VCID: 43D35DFC7B1ACDD20A1-8016
   Serial number: 00000000000009889206
   Coding: 0D0000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Dataset Number: V03935223WL 0001
   Coding: 8103
   Serial number: 110216EBA11553 Dataset Number: 5T0157v____ 0016
   Coding: 003B0020DE01048000801000
   VCID: 42DD58F86400C4DA017-8016
   Serial number: 00000000000009857529
   Coding: 050000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0624
   Serial number:                Dataset Number: V03935233XZ 0001
   Coding: 02730801FF00000051111101008808001F0106C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 30390230DAAC464AE73-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU015CT
   Subsystem 2 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789123456 Dataset Number: v12400160G0 0016
   Coding: 0100000202000000
   VCID: 3B23251C03EAB512421-806E
End----(Elapsed Time: 01:46, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
codes in the engine and
13 -- Auto Dist. Reg needs to be coded for Trailer. Use Long Coding Helper. It should be in Byte 3:
Control Module for Trailer Recognition installed
Stickystuff
Thatcham, UK
C?ID=555124
Thank you and sorry for the long wait to reply. I have changed the coding which has removed most of the faults but there is still a fault with the engine module. I can't change the coding on the ABS, and I Do I need to change the coding of any other module?
Monday,17,March,2025,18:35:14:61788
VIN: WVGZZZ1TZGW589525   Mileage: 136697km-84939miles
17156 - Databus
          U1123 00 [00100100] - Received Error Message
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 18:26:01
                    Coolant temperature: 50 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 11.720 V
   Revision: 00001K10
   Air quality sensor:
   Coding: 90A8DD
   Coding: 0071051801
   Coding: 2A00608A51FFC428949C804D
   Coding: 80000D
   Coding: 80000D
   Coding: 0400
   Generator:
   Coding: 2CFFFF
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
End----(Elapsed Time: 01:47, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Stickystuff
Thatcham, UK
C?ID=555124
So I've gone into the engine module and long coding bit 4, but it fails when I hit do it...
I can't paste the screen shot but it essentially says.
Coding rejected:
Error 32: request out of range.
Stickystuff
Thatcham, UK
C?ID=555124
Ok, so I changed the coding on the engine module to bit 4 trailer module, and the car has got acc with radar and it then caused a fault in the ABS module, engine and auto dist Reg module.
This is the current fault code status, with the trailer module ticked for the engine module but without front assist ACC.
It doesn't like the coding for with front assist which this car has as standard
Monday,17,March,2025,19:01:42:61788
   Coding: 01190012035505082000
17156 - Databus
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 18:59:25
                    Coolant temperature: 45 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.800 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 1
   Revision: 00001K10
   Air quality sensor:
   Coding: 90A8DD
   Coding: 0071051801
   Coding: 80000D
   Coding: 80000D
   Coding: 0400
   Generator:
   Coding: 2CFFFF
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
Stickystuff
Thatcham, UK
C?ID=555124
And this is the fault status with what I believe should be the correct code: it has trailer module and ACC with assist installed and it has more faults.
Monday,17,March,2025,19:06:30:61788
   Coding: 01190012037505082000
17156 - Databus
          U1123 00 [00100110] - Received Error Message
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 18:59:25
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [10100111] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:23
                    Coolant temperature: 43 °C
                    Intake air temperature: 33 °C
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 2
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 0
                    ACC variants (coding)-Bits 0-7: 3
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 63
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:22
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [00001001] - -
                    Reset counter: 23
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:24
   Revision: 00001K10
   Air quality sensor:
   Coding: 90A8DD
   Coding: 0071051801
1067 - Databus
          [FAULT_TIMEOUT_MOTOR_20]
                    Reset counter: 63
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:22
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 11.7 V
1088 - Databus
          [FAULT_TIMEOUT_TSK_06]
                    Reset counter: 63
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:22
2119 - Databus
          [FAULT_TSK_ACC_CODING_PLAUS_FAIL]
                    Reset counter: 23
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:23
2065 - Databus
          U1122 00 [00001000] - Implausible Message
          [FAULT_TSK_HANDSHAKE]
                    Reset counter: 63
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:23
                    Voltage terminal 15: 11.6 V
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 23
                    Mileage: 136697 km
                    Date: 2025.03.17
                    Time: 19:04:23
   Coding: 80000D
   Coding: 80000D
   Coding: 0400
   Generator:
   Coding: 2CFFFF
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
End----(Elapsed Time: 01:47, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
I would undo what you did with the Engine. That clearly made things worse.
Stickystuff
Thatcham, UK
C?ID=555124
So after I played about with the coding I reset it back to the original so currently the only thing I have changed is the 13 auto distance module and ticked bit3 with trailer module as you suggested.
For some reason it still doesn’t like it. There are no warning lights on the dash and the car drives normally it just doesn't allow ACC to work.
And the only fault codes are the ones in the engine module, where it says:
Drive coordinator: ACC fault status-Bits 0-7: 0
Drive coordinator: Brake fault status-Bits 0-7: 0
Drive coordinator: Brake function fault status-Bits 0-7: 0
It repeats a couple of the faults but there are no fault codes in the ABS or the cruise control module.
Any ideas? Thank you for your help so far!
Stickystuff
Thatcham, UK
C?ID=555124
So I have cleared the codes directly in all modules that have them but in the engine the fault code keeps coming back is:##
Monday,24,March,2025,20:35:06:61788
VCDS Version: Release 24.5.0 (x64) Running on Windows 11 x64
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 EB HW: 04L 907 309 M
Component and/or Version: R4 2.0l TDI H23 1895
Software Coding: 01190012035505082000
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01104L906026EB 004003 (VW37)
VCID: 6E85DC48019810BAB5F-803A
Fault Codes have been Erased
17156 - Databus
Mileage: 137020 km
Date: 2025.03.24
Time: 20:35:00
Coolant temperature: 80 °C
Intake air temperature: 61 °C
Voltage terminal 30: 12.000 V
I can't seem to clear this, and currently the car has got trailer module recognition in module 13 with ACC. I tried it without recognition in module 13 and put it in engine only but it makes the glowplug light flash and has another fault code that essentially said incorrect coding.
Do I need to change anything in the trailer module? Considering it's aftermarket
It gives me an option in bite 1 bits 4-7 either partiel network not active and partial network active. Currently it's set to not active.
Stickystuff
Thatcham, UK
C?ID=555124
So we went through it again yesterday. I changed the coding on the trailer module to partial network active. This didn’t appear to change anything however it took a while and my VCDS froze so I turned the ignition off and it then pinged up coding accepted.
We coincidentally disconnected the trailer module and got a fair few fault codes.
So reconnecting it and deleting fault codes in each individual module rather then through the auto scan it’s currently working. We think it could be a loose connection somewhere so just seeing how it goes.
Thank you for your help!
