- Jan 26, 2025
- 23
- 0
- Hawaii, USA
- C?ID=608815
Recently replaced my ABS module and after coding and going for a test drive my parking brake won't release. Any assistance would be appreciated. Here is my last scan.
Wednesday,05,February,2025,23:43:00:30448
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: WAUACGFF5F1035116 License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 30 42 44 52 55 5F BB BC
VIN: WAUACGFF5F1035116 Mileage: 147906km-91904miles
30-Special Function II -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNSB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 A HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13--- CVN: EDFAED27
Coding: 0A1D00122424000F2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0208V0906264A 001002
ROD: EV_ECM18TFS0208V0906264A.rod
VCID: 3A2AED739CD8F6DA51F-806E
VINID: 9D19514D75961560400C504118579FC85A
15446 - Blocking Valve for Coolant (N82)
P1889 00 [00100111] - Open or Short to Ground
Mileage: 147906 km
Date: 2025.01.28
Time: 00:11:30
Engine RPM: 0.00 /min
Coolant temperature: 25 °C
Intake air temperature: 28 °C
Voltage terminal 30: 12.109 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 101 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 800.0 kPa
17178 - Databus
U1123 00 [00100111] - Received Error Message
Mileage: 147906 km
Date: 2025.01.28
Time: 00:11:28
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
Part No SW: 0D9 300 041 R HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4508
Revision: 05852204 Serial number: TFK01405110382 CVN: 0000AECF
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 270C24077F6A7B323E1-8072
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61494000003566
Coding: 13FF6A9234230A710178020181C929C8562C5080408194B4024100588608
ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
VCID: 45D08E8FE52689222CD-8010
0297 - Steering angle sensor
B1168 16 [10001001] - Voltage Too Low
Reset counter: 39
Date: 2025.01.28
Time: 00:10:49
C1146 02 [10001001] - Signal Failure
Reset counter: 39
Mileage: 147906 km
Date: 2025.01.28
Time: 00:11:01
32830 - Parking Brake Motors
C10E1 29 [10001001] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
Reset counter: 39
Date: 2025.01.28
Time: 00:10:49
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000357162
Coding: 03000014010000000000000000001400
VCID: 323AC55344A80E9A99F-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 92294137000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0134
Serial number: 01011416200389 Dataset Number: 8V0909514G 0079
Coding: 04141A42C04122F541C04004510007000000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 79A8327FD95E3DC2185-802C
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140607 042 0585
Serial number: 140616042700
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 22746910
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Serial number: 13 04 2014 00000957
Serial number: 00000000000030053394
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO30179122
Coding: 101F00
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR00FANK Dataset Number: 8V0909602F 0003
VCID: 47CC8487DF2A9B32DE1-8012
Left seat belt tensioner:
Component: BeltPretRevFL H35 0341
Serial number: 34178311A20061470019
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H35 0341
Serial number: 34178312A16061440719
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 C HW: 5C6 959 339 C
Component: BF-Gewichtss. H10 0047
Serial number: 6940000Y1400015N720A
Coding: 303434
Subsystem 4 - Part No SW: ----------- HW: 480 001 106 14
Serial number: 35700000000B6BB4201I
Subsystem 5 - Part No SW: ----------- HW: 480 001 106 14
Serial number: 35800000000CEAB4201R
Subsystem 6 - Part No SW: ----------- HW: 480 400 406 14
Serial number: 3510002B7156EA0161F2
Subsystem 7 - Part No SW: ----------- HW: 480 400 406 14
Serial number: 3520002BF156EA02E3DK
Subsystem 8 - Part No SW: ----------- HW: 480 401 004 14
Serial number: 3550002B51524DC3740$
Subsystem 9 - Part No SW: ----------- HW: 480 401 004 14
Component: FrontSensor_P 001 6149
Serial number: 3560002B51524DC072E6
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 39
Mileage: 147906 km
Date: 2025.01.28
Time: 00:06:58
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 15061404400924
Coding: A018
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 7CA62B6BD66C08EA033-8028
Address 17: Instruments
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 12061410800439 Dataset Number: 8V0909515E 0055
Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
GVL: 01503C0000080000400C10000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 42DA9593F408BE1A09F-8016
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 10 06 2014 E0022415
131627 - Control Module for Special Functions 2
U1146 00 [00001001] - No Communications
[Timeout Knoten 0x2B / 30 - Steuergerät für Sonderfunktion 2]
Reset counter: 39
Mileage: 147906 km
Date: 2025.01.28
Time: 00:08:02
Terminal 30 power supply: 12.2 V
Terminal 15: On
Address 30: Special Function II
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 08061406071579 Dataset Number: 8V0909872E 0030
Coding: 00100F204100048000000002
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 3E22E16380F0DAFA6D7-806A
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Dataset Number: 8V0909852H 0019
Coding: 0102
ROD: EV_SteerAssisMQB_010.rod
VCID: 41D89A9FF10EA502105-8014
16130 - Steering Angle Sensor
B1168 F2 [00001001] - Not Initialized
Reset counter: 39
Mileage: 147906 km
Date: 2025.01.28
Time: 00:09:03
Motor status: 00
Supply voltage: 12.00 V
Temperature: 36.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 12.11 V
uAdSensI_SwitchedKl30_xdu16: 12.11 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 01061401101573 Dataset Number: 8V0909873E 0029
Coding: 001007204100048000000002
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 3D20E66F8DF6C1E274D-8068
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0038
Coding: 011A000101000000
VCID: 75B03E4FF54659A27CD-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 HW: 8V0 035 844
Component: MU-S-S-US 013 0626
Serial number: A7A00806142229 Dataset Number: 8V1909545C 0038
Coding: 01730100FF0A000011220001001A00002F0001040100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 76B23943E84052BA757-8022
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY3045ZH
Subsystem 2 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000018041400010362
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 10061406071274 Dataset Number: 8V0909897C 0017
Coding: 000007204000048000000002
ROD: EV_DCURearDriveMAXKLO.rod
VCID: 40DE9F9BFA04AC0A1FB-8014
Component: TSG HBFS 020 0025
Serial number: 10061401101279 Dataset Number: 8V0909896C 0017
ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.2V)-----------
