Aggressive Multi-Cylinder Misfires on Deceleration with partial Throttle
Alexcxcb
Nevada, USA
C?ID=610104
Hello everyone,
(Auto-Scan is posted below)
I have unfortunately been chasing a multi-cylinder misfire issue for about a year now. It has been to shop several times without resolution.
I pulled the engine last year to give it a decent refresh, most notably timing chains and intake value cleaning as well as some performance upgrades.
Prior to doing any work I started getting a rough idle, and CEL for Cylinder 2 Camshaft Adjuster Solenoid B (which was replaced).
Fast forward, I replaced a bunch of old parts and added some upgrades like the APR Stage 3 DTR6054 Turbocharger & Tune.
After the shop installed the tune, seemed to run great for a few weeks. Then the rough idle came back and things just progressively worsened to now
very aggressive muti-cylinder misfires.
The misfires are only occurring during deceleration with partial throttle... Releasing the throttle fully immediately stop misfire.
Light & WOT acceleration almost never see a misfire.
Rough idle exists but almost never see a misfire either.
The car does not feel sluggish, plenty of power and will burn the tires.
In addition to misfire codes you'll see in the Auto-Scan, I'm also getting an Air-Fuel Ratio Imbalance code that hasn't re-trigger yet since the last clear.
The last time it was at the shop, they diagnosed a bad Oxygen Sensor before the cat and replaced it. Slight improvement to the rough idle but no change to the misfires.
Prior to getting VCDS some things I noticed with OBDeleven after an hour drive:
Fuel Low Pressure, actual value (11.003 bar never changes) while specified is like ~5 bar
(Fuel High Pressure seems to match its specified value)
Long-term fuel trim bank 1 at idle (0.42 mg/stroke)
Number of high pressure incursions (5)
----QUESTION FOR THE FORUM----
With VCDS Data Logging, what specific data points should I log during a run to help determine the misfire cause?
I'm hearing to keep good data resolution you shouldn't add more than 8 data points at a time, so I'm doing multiple runs with different data points.
Vehicle:
2017 VW GTI Sport w/ Performance Package
APR Stage 3 DTR 6054 Turbocharger Tune w/ stock fuel
2.0 TSI EA888 Gen 3
210,000 miles!
Oil changes every 5,000 mi, engine internals look perfect
---ISSUE----
Aggressive Multi-Cylinder Misfires on Deceleration with partial throttle (Full throttle release = no misfires)
Occasionally Multi-Cylinder Misfires during cruise with partial throttle but less aggressive
Zero Misfires on light & WOT acceleration
---Some Practice Data Logging that shows the issue (sorry if they suck, they are my first):
datazap.me Misfire count with oxygen sensors
datazap.me Misfire count with knock sensors
---Additional Performance Data Logging:
datazap.me 2k RPM, 3rd Gear, lambda, STFT, IGN, knock, IAT, Boost
datazap.me 2k RPM, 3rd Gear, Boost, IT, HPFP, Lambda, STFT, Mean Air Mass
datazap.me 2k RPM, 123Gear, IAT, EGT, Mean Air Mass, IGN, Lambda, STFT, IT
---Smoke Test for Leaks---
I have a smoke tester and have checked for leaks.
It does appear to have a leak somewhere as the flow gauge never drops below (~3 LPM)
With a good pen LED light or a red laser I have not found any smoke escaping.
Smoke injection through intake before turbo.
Secondary Air Injection blocked off.
Exhaust end blocked off.
---Compression Test Results:
Cyl # 1 (170 psi/ 11.7 bar)
Cyl # 2 (169 psi/ 11.6 bar)
Cyl # 3 (160 psi/ 11.0 bar)
Cyl # 4 (166 psi/ 11.4 bar)
---AIR CHANGES----
-New Parts:
CTS Air Intake Upgrade
APR Stage 3 DTR6054 Turbocharger Upgrade w/ Tune w/o fuel upgrade
Intercooler Upgrade (ECS Tuning)
MAP Sensor on Charged Air Pipe (OEM)
MAP Sensor on Intake Manifold (OEM)
Intake Manifold Gasket
PCV (OEM)
Oxygen Sensor Before Cat (OEM)
-Services Performed:
Intake Values Cleaned
Intake Manifold & Runners Cleaned
Throttle Body Cleaned
Vacuum Pump Inspected & Cleaned
-ECU Adaptations:
Throttle Body Alignment Adaptation
----FUEL CHANGES----
-New Parts:
Racing Spark Plugs (APR Heat Range 9 / 0.024" Gap)
Ignition Coils (APR)
Fuel Injectors w/ O-rings (OEM)
HPFP Inspected and Cleaned (Good)
Fuel Rail Cleaned
----TIMING CHANGES----
-New Parts:
Camshaft Timing Chain and Guides (OEM)
Camshaft Timing Chain Tensioner (OEM / New revision)
Balance Chain and Guides (OEM)
Balance Chain Tensioner (OEM)
Intake Camshaft Adjuster Magnet (OEM)
Exhaust Camshaft Adjuster Magnet (OEM)
Upper Timing Cover w/ Gaskets (OEM)
Lower Timing Cover w/ Gasket Sealant (OEM)
4x Camshaft Variable Value Lift Solenoids (OEM)
-ECU Adaptations:
Timing Chain Reset Adaptation
----OTHER CHANGES----
-New Parts:
Water Pump & Thermostat Housing w/ Union Coupler (OEM)
Rear Main Seal (034)
2 Stage Performance Clutch / Single Mass Flywheel (ECS Tuning)
Engine Mount (034)
Transmission Mount (034)
Transmission Dog bone Insert (034)
A/C Condenser
A/C EVAC & Charge
Coolant System Flush
-ECU Adaptations:
Thermostat Adaptation
---AUTO-SCAN---
Thursday,06,February,2025,18:59:16:06137
VIN: 3VW547AU6HM026564   License Plate:
Mileage: 339615km-211026mi   Repair Order: -02.06.2025
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 32 42 44 52 55 5F 75 A9
VIN: 3VW547AU6HM026564   Mileage: 339615km-211026miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---    CVN: 410C94FA
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00074
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 372CF41CEFCCFB22AE1-8062
   VINID: 0E69C510746519874008614610644AC8BF
15125 - Cylinder 1
          P0301 00 [01100100] - Misfire Detected
                    Mileage: 339602 km
                    Date: 2025.02.06
                    Time: 17:42:53
                    Engine RPM: 2516.00 /min
                    Normed load value: 9.0 %
                    Vehicle speed: 124 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 27 °C
                    Ambient air pressure: 890 mbar
                    Voltage terminal 30: 14.042 V
                    Engine: operating status: PL
                    N_TOOTH: 2506 /min
                    T_AST_SAE: 1502 s
                    Engine oil temperature: 102.0 °C
                    STATE_LS_SAE[1]: CL
                    FUP_H_SAE: 8310.0 kPa
                    FUP_EFP_MES: 11000.8 hPa
15131 - Cylinder 3
          P0303 00 [01100100] - Misfire Detected
                    Mileage: 339602 km
                    Date: 2025.02.06
                    Time: 17:42:53
                    N_TOOTH: 2506 /min
                    T_AST_SAE: 1502 s
                    STATE_LS_SAE[1]: CL
15134 - Cylinder 4
          P0304 00 [01100100] - Misfire Detected
                    Mileage: 339602 km
                    Date: 2025.02.06
                    Time: 17:42:53
                    N_TOOTH: 2506 /min
                    T_AST_SAE: 1502 s
                    STATE_LS_SAE[1]: CL
15128 - Cylinder 2
          P0302 00 [01100100] - Misfire Detected
                    Mileage: 339602 km
                    Date: 2025.02.06
                    Time: 17:42:53
                    N_TOOTH: 2506 /min
                    T_AST_SAE: 1502 s
                    STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [01100100] - -
                    Mileage: 339602 km
                    Date: 2025.02.06
                    Time: 17:42:53
                    N_TOOTH: 2506 /min
                    T_AST_SAE: 1502 s
                    STATE_LS_SAE[1]: CL
Readiness: 0000 0100
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 52556000000335
   Coding: 01FA6BA154220972407C020641C76880D62A90024082163600430051C00903
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
   VCID: 75B03E14B54049327CD-8020
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0415846569 Dataset Number: V03935230CZ 0006
   Coding: 032C0C
   VCID: 3B24E82CD3E4DF424A9-806E
   Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 00020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 48CE87E0923284DAD7B-801C
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865821091601W8 Dataset Number: V03935240CJ 0001
   Coding: 00010A464041A04169E44000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AAA2D289C5E264A11F-802E
   Component: WWS    150612  043 0551
   Serial number:         150703131225
12307 - License Plate Light
          B12CA 01 [00001000] - Electrical Failure
                    Reset counter: 130
                    Mileage: 339392 km
                    Date: 2025.02.02
                    Time: 17:18:20
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 14.3 V
                    Outside temperature: 15.5 °C
204546 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 86
                    Mileage: 339403 km
                    Date: 2025.02.02
                    Time: 17:32:43
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Low beam: Not operated
                    Voltage: 12.5 V
                    Outside temperature: 22.5 °C
   Serial number: 003GCR05V008 Dataset Number: 5GM003V____ 0046
   VCID: 47CC84DC9F2C8BA2DE1-8012
   Serial number: IBH000000000005XZ9WV
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 209 16
   Serial number: 35700000000868349B1M
   Subsystem 3 - Part No SW: -----------    HW: 480 000 209 16
   Serial number: 35800000000C04702C1B
   Subsystem 4 - Part No SW: -----------    HW: 480 403 008 16
   Serial number: 3510002A5215E1E4B34%
   Subsystem 5 - Part No SW: -----------    HW: 480 403 008 16
   Serial number: 3520002A7215E1E2C21/
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 16
   Serial number: 3550002A5229A2E2516/
   Subsystem 7 - Part No SW: -----------    HW: 480 401 609 16
   Serial number: 3560002A5229A2E5A166
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160912501105
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045653D0EE9A60BA7B3-8050
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BAD0912A980CF0502086A001000000000000000
   VCID: 2D00D6741D9041F2C4D-8078
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 05091610800853 Dataset Number: V03935242HR 0001
   Coding: 0101000830085900FB00002B080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   GVL: 01503C5000000600400C10008000480000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA62B30966A187A033-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001934390096411
   Coding: 30FFFF
   Revision: 00000000    Serial number: 16000160017005
   Coding: 5500000000000000
   VCID: 3436C310FEBA103A8B3-8060
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00006.09.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 141016060506S7 Dataset Number: V03935249RC 0001
   Coding: 003E13200000020000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 43D490CCAB14A782029-8016
   Serial number: 00000000000014086655
   Coding: 011000
   Dataset Number: V03935242JU 0001
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2AED28DCDEE64A51F-806E
   Serial number: 14101606050941 Dataset Number: V03935249RE 0001
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 42DA95C8B40EAE8A09F-8016
   Serial number: 00000000000014071462
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021801010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40DE9FC0BA02BC9A1FB-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Serial number:                Dataset Number: V03935247DB 0001
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW01AZE
                    Reset counter: 84
                    Mileage: 339266 km
                    Date: 2025.02.01
                    Time: 12:06:35
                    Voltage terminal 30: 14.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 136 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Component: OCULowMQBUS   007 0568
   Dataset Number: V03935236TB 0001
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 160725201617
   VCID: 6B84186CE3048FC29A9-803E
End----------(Elapsed Time: 01:24, VBatt start/end: 12.5V/12.4V)-----------
Dr Sheldon
Windsor UK
C?ID=334979
Really !! I am under the impression that fuel injection is paralysed on deceleration, hence a "misfire" cannot occur !!
Has this got a "Pop & Bang" Map ??
That there is your starting point - The Rough Idle - Perhaps the variation in Con Rod Speeds and rate of acceleration is just not enough to throw you a P0300 or P030x and the o2 is happy that combustion has taken place "to a fashion"
Never mind all that - A rough idle needs to be put right first ??
I see OEM in your post - What do mean by that ? Where are these parts from ??
Do you have that Scan Saved ?? I would like to see the FREEZE FRAME data associated with that DTC
For example - From Your Scan
15125 - Cylinder 1
Date: 2025.02.06
Time: 17:42:53
15131 - Cylinder 3
Date: 2025.02.06
Time: 17:42:53
15134 - Cylinder 4
Date: 2025.02.06
Time: 17:42:53
15128 - Cylinder 2
Date: 2025.02.06
Time: 17:42:53
Date: 2025.02.06
Time: 17:42:53
All those codes have been set at exactly the same moment !! 2516 RPM
Now that is not RANDOM !!
Would a Fuel, Air, Compression Issue cause such a clinically timed Misfire ???
Not even a drop of 1 rpm - Remember they dont all fire at once !!
And the first to misfire did not cause that engine to drop just 1 rpm by the time the 4th one misfired ??
More I think about that the more I think that is a reporting characteristic of that ECU.
Back to the rough idle.
and
Dr Sheldon
Windsor UK
C?ID=334979
He did say,
Part-throttle deceleration does not cut off fuel.
Indeed he did.
Can we see a Graph of:
RPM
Throttle Position - Just Sensor 1
Wheel / Car Speed
Misfire Counter - Just Cylinder 1
Injector Duration
Air Mass
Alexcxcb
Nevada, USA
C?ID=610104
Indeed he did.
RPM
Wheel / Car Speed
Injector Duration
Air Mass
First off, thank you both for looking into this!
Secondly, I can hardly believe this myself, but believe I just "unintentionally" resolved the issue. Kind of feel like an idiot now, but at the same time no shop figured it out either.
Resolution: New Tires...
All of my shocks have leaked out and need to be replaced. By the time I had the money to buy a full set of shocks, my tires were out of round and as you could imagine creating a fair deal of vibration... That is also the time the rough idle started.
Not seeing the two were connected, I focused on the rough idle, which lead to the engine refresh project.
The vibration has become too much to bare on the freeway, so I got some dirt cheap tires on Amazon and had those installed yesterday evening.
I setup VCDS to log the graph you requested (below) and drove around all day today trying to replicate the misfire event, which I prior to yesterday could replicate every attempt.
Requested Graph
I believe the vibration from the tires were interfering with the knock sensors.
For comparison, here are the knock sensors before (with misfires):
Knock Sensors (Bad Tires)
And after new tires (not a single misfire):
Knock Sensors (New Tires)
I will start driving the GTI to work now and keep an eye on it. If the issue returns I'll come back to this post.
Dr Sheldon
Windsor UK
C?ID=334979
Well Well
I have known drivetrain vibrations to mess with the crank sensor and cause havoc !
Does that go some way to explaining my headache ? Which was:
Alexcxcb
Nevada, USA
C?ID=610104
Well Well
Headache indeed! Not random at all, more like a super human mutant was playing jokes on me as I drove by LOL.
I just got home from a 3 hour drive in the GTI. Uphill, downhill, flat land, WOT, decel with partial throttle and every other variation I could think of. Not a single misfire.
