Would that be clocks gone ? Audi A3 8P.
Mar4ix
Ireland
C?ID=81710
My friends car Audi A3, 2006, 1.6 petrol, 5 speed manual gearbox, via diagnostics shows that number modules (abs, engine etc. ) no communications with cluster (clocks or other words speedometer ) .
Is that true, that it has to be replaced, or there is possible do something with it ?
thanks
Monday,07,December,2015,10:45:54:45963
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
Mileage: 164250km-102060miles
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 EH
   Component: SIMOS71 1.6l 2VG    8709
   Revision: --H02---    Serial number: AUX7Z0F2FNQ00V
   Coding: 0000071
   Shop #: WSC 06314 000 00000
   VCID: 69D2542140CA6976DC-803C
16897 - Incorrect Immobilizer Key
            P0513 - 008 -  - Intermittent
                    Voltage: 11.93 V
                    Bin. Bits: 00000001
                    Lambda: -100.0 %
                    Voltage: 11.83 V
                    Bin. Bits: 00000001
                    Lambda: -100.0 %
28827 - No Communication with Instrument Cluster
            U0155 - 009 -  - Intermittent
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 01010000
                    Absolute Pres.: 6.6 bar
Readiness: 0010 0101
   Revision: 00H11001
   Coding: 0019073
   Shop #: WSC 00499 941 80695
   VCID: 73EE36491206A3A666-8026
   Part No SW: 8P0 820 043 M    HW: 8P0 820 043 M
   Component: KlimavollautomatH18 0260
   Revision: 317057      Serial number: 8P0820043M
   VCID: 3668CF5D41F4F68E81-8062
                    Reset counter: 231
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000005567659
   Coding: E48C5F01B014100000160000160000000008FA175C0100
   Shop #: WSC 06314 000 08192
   VCID: 4084A9851330483E2B-8014
   Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH12 0090
   Coding: 00150573
   Shop #: WSC 06314
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
                    Reset counter: 236
                    Mileage: 160688 km
                    Date: 2004.09.22
                    Time: 00:17:00
                    Voltage: 11.55 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
   Component:    Airbag 9.41  H12 3760
   Revision: 91H12376    Serial number: 003620G01N8G
   Coding: 0070612
   VCID: 4280A38D1D3C5A2E3D-8016
                    Fault Frequency: 188
                    Reset counter: 236
                    Mileage: 160688 km
                    Date: 2004.09.22
                    Time: 00:17:22
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 G    HW: 1K0 907 951
   Component: J533__Gateway   H10 0140
   Revision:   H10       Serial number: 300010630184E0
   Coding: 3D3F034207002103
   VCID: 2B5EEE298AB6BB66EE-807E
                    Reset counter: 236
                    Date: 2004.09.22
                    Time: 00:17:22
                    Fault Frequency: 29
                    Reset counter: 236
                    Time Indication: 15
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
   Component: concert II EU   H52 0100
   Revision:      02S    Serial number: AUZ2Z3F3753562
   Coding: 0001001
   Shop #: WSC 06435 000 00000
   VCID: 3260F34DAD9CEAAEAD-8066
                    Reset counter: 236
                    Mileage: 160688 km
                    Date: 2004.09.22
                    Time: 00:17:22
Gone But Not Forgotten
Immobilizer issue ........check fuses?
Immo defeat is possible for this ecu.
Voltage low ?
Looks like an intermittent problem. Gateway shows "17-Instruments -- Status: OK 0000" while "No Communication with Instrument Cluster" codes are flagged "Intermittent". My best guess: A bad connection somewhere, either external in the wiring, or internal in the cluster.
Yup if cluster is half operational it may report back seen on gateway.............while Immo is fubar.
Has anyone been playing with clocking tools, or SKC pin extraction devices messing with the eeprom to Boot?
Mar4ix
Ireland
C?ID=81710
ok, thanks. so i guess , clocks been replaced without proper adaptation, or bad connection... what is best solution in that situation ? (apart check connections ).
