I think my ecu is fried (2007 GTI)
RayB
C?ID=586649
please help. went to a shop for blower motor and this happen
Friday,07,February,2025,21:44:18:47462
VCDS Version: 24.7.1.0 (x64)
VIN: WVWGV71K57W073168   License Plate:
Mileage: 321910km-200025mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 62 65 72
VIN: WVWGV71K57W073168   Mileage: 321910km-200025miles
15-Airbags -- Status: Malfunction 1010
1C-Position Sensing -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 1010
55-Headlight Range -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Not registered 0001
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH14---    Serial number: VWZ7Z0F8118010
   Coding: 0403010A18070160
   Shop #: WSC 08156 444 54304
   VCID: 2B5519968ABC56CE4E-807E
   VINID: 9E69D798705B1479C01C30462086CC1820
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 320293 km
                    Time: 07:36:34
                    Temperature: 14.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 004 - Signal too High (Rich) - Intermittent
                    Fault Status: 00110100
                    Mileage: 320342 km
                    Time: 06:47:40
                    RPM: 1046 /min
                    Load: 29.4 %
                    Speed: 5.0 km/h
                    Temperature: 91.0°C
                    Temperature: 30.0°C
                    Voltage: 13.970 V
000291 - Throttle Position Sensor (G69)
               P0123 - 001 - Signal too High - Intermittent
                    Fault Status: 00110001
                    Mileage: 321912 km
                    Temperature: 9.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.192 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 001 - Signal too High - Intermittent
                    Fault Status: 00100001
                    Temperature: 13.0°C
                    Temperature: 6.0°C
                    Voltage: 12.192 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 12345 111 45799
   VCID: 73E5C1F6120C4E0EC6-8026
            013 - Check DTC Memory
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70EFCEFA631A75163B-8024
9 Faults Found:
00757 - Right Vent Temp Sensor (G151)
            010 - Open or Short to Plus
00797 - Sunlight Photo Sensor (G107)
00709 - Sunlight Photosensor 2 (G134)
00716 - Air recirculation Flap Positioning Motor (V113)
            009 - Open or Short to Ground
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000006107341
   Coding: 050ECEB14002015A02320000320A3200328810A1024000
   Shop #: WSC 12345 111 45725
   VCID: 377D35E646F4E22E3A-8062
   Component: Wischer 230207 020  0501
   Coding: 00038805
   Shop #: WSC 12345
10 Faults Found:
02402 - Control Circuit for Terminal 15 for Interior
                    Fault Status: 00101010
                    Fault Frequency: 39
                    Reset counter: 212
                    Mileage: 321677 km
                    Voltage: 12.95 V
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Reset counter: 212
                    Mileage: 321913 km
                    Voltage: 11.95 V
01834 - Bulb for Side-Blinkers; Left (M18)
                    Fault Status: 01111100
                    Reset counter: 172
                    Mileage: 319816 km
                    Voltage: 14.20 V
01835 - Bulb for Side-Blinkers; Right (M19)
                    Reset counter: 172
                    Mileage: 319812 km
                    Voltage: 14.30 V
                    Reset counter: 172
                    Mileage: 319808 km
                    Voltage: 14.30 V
                    Reset counter: 172
                    Mileage: 319808 km
                    Voltage: 14.30 V
00984 - Left Tail Light (M4)
                    Reset counter: 172
                    Mileage: 319808 km
                    Voltage: 14.30 V
00985 - Right Tail Light (M2)
                    Reset counter: 172
                    Mileage: 319808 km
                    Voltage: 14.30 V
                    Reset counter: 172
                    Mileage: 321677 km
                    Voltage: 12.40 V
00576 - Terminal 15
                    Fault Status: 01101100
                    Reset counter: 172
                    Mileage: 319808 km
                    Voltage: 14.30 V
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D06H72M
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 6CD7DA8A4F3291F607-8038
   Subsystem 1 - Part No: 000 000 000 000
   Component: BF-Gewichtsens. 000 0000
   Subsystem 2 - Serial number: 6332MSME1308246E9
   Subsystem 3 - Serial number: 6342MSME131C12765
   Subsystem 4 - Serial number: 6352QSME157A4851I
   Subsystem 5 - Serial number: 6362QSME0F317819M
   Subsystem 6 - Serial number: 63727SME0B10172B-
   Subsystem 7 - Serial number: 63827SME0B104329Y
8 Faults Found:
00003 - Control Module
            014 - Defective - MIL ON
02511 - Control Module for Seat Occupied Recognition (J706)
            012 - Electrical Fault in Circuit - Intermittent - MIL ON
            008 - Implausible Signal - Intermittent - MIL ON
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
00589 - Airbag Igniter 1; Passenger Side (N131)
01587 - Igniter 2 for Airbag; Drivers Side (N250)
00590 - Igniter 2 for Passenger Airbag (N132)
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0003022
   VCID: 7AFBECD235663F4685-802E
01426 - Controls in Steering Wheel (E221)
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0F8118010
   Coding: 0000107
   Shop #: WSC 11111 111 45799
   VCID: 31690BFEA8903C1E74-8064
                    Fault Frequency: 116
                    Reset counter: 172
                    Mileage: 319808 km
                    Time: 15:46:21
                    Reset counter: 201
                    Mileage: 321677 km
                    Time: 14:55:26
                    Reset counter: 212
                    Mileage: 321913 km
                    Time: 02:57:44
                    Reset counter: 212
                    Mileage: 321913 km
                    Time: 00:02:15
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001068240AE2
   Coding: 7D3F03400F000002
   VCID: 2C571A8A8FB251F647-8078
7 Faults Found:
                    Reset counter: 88
                    Mileage: 319808 km
                    Time: 15:46:23
                    Reset counter: 90
                    Mileage: 319808 km
                    Time: 15:46:27
                    Reset counter: 201
                    Mileage: 321677 km
                    Time: 14:55:27
                    Reset counter: 164
                    Mileage: 321757 km
                    Time: 00:00:01
                    Reset counter: 212
                    Mileage: 321913 km
                    Time: 02:57:45
                    Reset counter: 212
                    Mileage: 321913 km
                    Reset counter: 212
                    Mileage: 321913 km
                    Time: 00:02:16
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1225223T1J0S02
   VCID: 7DF1E7CE2448087EA0-8028
                    Reset counter: 212
                    Mileage: 321913 km
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0971
   Coding: 0001205
   Shop #: WSC 01279 785 00105
   VCID: 387F36DA4BEAED5633-806C
00105 - Signal Central Locking SAVE/LOCK Drivers Side
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 346702EA578209361F-8060
                    Mileage: 321900 km
                    Temperature: 9.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 139006C85103283F5B04058FB008CF0488DC00
   VCID: 74E7C2EA17024936DF-8020
8 Faults Found:
00896 - Trunk Lock Unit (F256)
                    Reset counter: 212
                    Mileage: 319816 km
                    Time: 16:50:16
00830 - Convertible Top Control Module (J256)
                    Reset counter: 212
                    Reset counter: 212
                    Reset counter: 212
                    Reset counter: 212
00317 - Rear Lid Control Module (J605)
                    Reset counter: 212
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 212
                    Fault Status: 01101101
                    Reset counter: 172
   Coding: 0001204
   Shop #: WSC 01279 785 00200
   VCID: 397933DE70E0F45ECC-806C
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 55: Headlight Range
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       017 0035
   Revision: 00017000    Serial number: VWZ5Z7F2103233
   Coding: 0040401
   VCID: 2447F2AAE76299B68F-8070
02218 - Satellite Radio (R146)
                    Reset counter: 172
                    Mileage: 321913 km
                    Time: 00:00:18
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0913
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
   Component:    RDK              0420
   Coding: 0100101
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000192
00935 - Electric Window Motor; Rear Right (V27)
00123 - Outside Warning Light/Door Exit Light; Rear Right
00103 - Rear Right Interior Locking Button (E311)
End-------------------------(Elapsed Time: 02:00)--------------------------
EuroX
Northern NJ USA
C?ID=208579
And what leads you to believe the ecm is fried? I see nothing here that would indicate that the ecm is the issue.
RayB
C?ID=586649
all modules are non-comm. Just frustrated i jumped on that conclusion. My apologies.
EuroX
Northern NJ USA
C?ID=208579
Clear all faults, make sure battery is fully charged and post updated auto scan.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
I would agree with EuroX.
Good Luck
Not according to the scan in post #1... :confused:
I see plenty of miscellaneous problems in that scan, but most modules are communicating.
RayB
C?ID=586649
i brought the car to a mechanic (not certified) for a fuse check because fuse 4 is popping fuse as soonas i turn the ignition on. After a couple of hours he called and said that he cant find the source of the ground. I took the car home. Following day, i wanted to trace fuse 4 wires to look for the ground. I found out that fuse 4 wire is toasted. I opened the wire bundle to isolate and re-wire the burnt wire but it broke by the firewall. And i cant find the wire to the otherside of the firewall. Damage a couple of wires too. My question are, will that burnt wire damage any modules as per scan and anybody had remove the dashboard support crossmember to have better access to the wires?
where do i begin to diagnose the problem?
The car starts and run,boost only 5psi.
Tuesday,18,February,2025,21:20:21:47462
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
Mileage: 321920km-200031mi   Repair Order:
VIN: WVWGV71K57W073168   Mileage: 321920km-200031miles
   VCID: 2B5519968ABC561E14-807E
                    Mileage: 321929 km
                    Time: 20:04:12
                    Temperature: 66.0°C
                    Temperature: 12.0°C
                    Voltage: 11.557 V
000566 - Manifold Pressure / Boost Sensor (G31)
               P0236 - 004 - Implausible Signal
                    Mileage: 321929 km
                    Time: 20:04:16
                    Temperature: 66.0°C
                    Temperature: 12.0°C
                    Voltage: 11.557 V
   Revision: 00H11001
   Coding: 0021122
   VCID: 73E5C1F6120C4EDE9C-8026
   VCID: 70EFCEFA631A75C661-8024
00457 - Control Module for Network (J519)
            000 -  -
   VCID: 377D35E646F4E2FE60-8062
   Coding: 00038805
   Shop #: WSC 12345
10 Faults Found:
                    Reset counter: 213
                    Mileage: 321929 km
                    Voltage: 13.00 V
                    Reset counter: 213
                    Mileage: 321929 km
                    Voltage: 13.00 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.80 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 14.15 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 14.15 V
00156 - Control Circuit for Windshield Washer Pump
                    Fault Status: 01101001
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 01101010
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
                    Reset counter: 174
                    Mileage: 321929 km
                    Voltage: 11.30 V
00576 - Terminal 15
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
   Coding: 0013644
   VCID: 6CD7DA8A4F3291265D-8038
8 Faults Found:
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Coding: 0003022
   VCID: 7AFBECD235663F96DF-802E
   Coding: 0000107
   VCID: 31690BFEA8903CCE2E-8064
                    Reset counter: 174
                    Mileage: 321928 km
                    Time: 20:16:41
   VCID: 2C571A8A8FB251261D-8078
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:42
            000 -  -
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:46
   VCID: 7DF1E7CE244808AEFA-8028
   Coding: 0001205
   VCID: 387F36DA4BEAED8669-806C
   VCID: 346702EA578209E645-8060
   VCID: 74E7C2EA170249E685-8020
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:41
   Coding: 0001204
   VCID: 397933DE70E0F48E96-806C
   Coding: 0040401
   VCID: 2447F2AAE7629966D5-8070
                    Fault Status: 01110100
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:48
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100101
   Coding: 0000192
End-------------------------(Elapsed Time: 01:57)--------------------------
RayB
C?ID=586649
I cant scan anything because dash have no service lights but have backlight. No crank no start
RayB
C?ID=586649
Change maf and map sensors. I thought i start there since the car starts and run but misfiring. Sounds like an intake leak. Other than that i havent done anything yet. Was planning to do it on the weekend
Westbury, UK
No crank no start
Did you fix the burnt and damaged wires?
Is it running or not - your last two posts are contradictory?
EuroX
Northern NJ USA
C?ID=208579
I don't mean to be rude but yes start with the common sense issues. What you know to be no good and make those repair first. Otherwise this will turn into a parts cannon situation.
RayB
C?ID=586649
It is running but have multiple misfire. I tried to look for the burnt wire but it broke before the firewall. I tried to remove the dash crossmember. Cnt find the bolts in the mid-section.I did fix the damage wires.
RayB
C?ID=586649
Done fixing the wires. Just looking for that burnt wire but i dont have enough access to trace it thru the firewall. Also looking as to how can i fix the damages.
RayB
C?ID=586649
This are the latest scan. If ever something change.
                    Mileage: 321929 km
                    Time: 20:04:12
                    Temperature: 66.0°C
                    Temperature: 12.0°C
                    Voltage: 11.557 V
                    Mileage: 321929 km
                    Time: 20:04:16
                    Temperature: 66.0°C
                    Temperature: 12.0°C
                    Voltage: 11.557 V
   Revision: 00H11001
   Coding: 0021122
            000 -  -
   Coding: 00038805
   Shop #: WSC 12345
10 Faults Found:
                    Reset counter: 213
                    Mileage: 321929 km
                    Voltage: 13.00 V
                    Reset counter: 213
                    Mileage: 321929 km
                    Voltage: 13.00 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.80 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 14.15 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 14.15 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
                    Reset counter: 174
                    Mileage: 321929 km
                    Voltage: 11.30 V
00576 - Terminal 15
                    Reset counter: 174
                    Mileage: 321928 km
                    Voltage: 13.95 V
   Coding: 0013644
8 Faults Found:
   Coding: 0003022
   Coding: 0000107
                    Reset counter: 174
                    Mileage: 321928 km
                    Time: 20:16:41
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:42
            000 -  -
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:46
   Coding: 0001205
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:41
   Coding: 0001204
   Coding: 0040401
                    Reset counter: 173
                    Mileage: 321928 km
                    Time: 20:16:48
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100101
   Coding: 0000192
Monday,24,February,2025,00:12:10:47462
                    Mileage: 321929 km
                    Time: 00:05:58
                    Temperature: 8.0°C
                    Temperature: 6.0°C
                    Voltage: 12.446 V
                    Mileage: 321929 km
                    Time: 00:06:01
                    Temperature: 8.0°C
                    Temperature: 7.0°C
                    Voltage: 12.319 V
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 12345
                    Fault Status: 01111001
                    Reset counter: 175
                    Mileage: 321929 km
                    Voltage: 12.30 V
                    Reset counter: 175
                    Mileage: 321929 km
                    Voltage: 12.30 V
                    Reset counter: 175
                    Mileage: 321929 km
                    Voltage: 12.30 V
                    Fault Status: 01111010
                    Reset counter: 175
                    Mileage: 321929 km
                    Voltage: 12.30 V
                    Reset counter: 175
                    Mileage: 321929 km
                    Voltage: 12.30 V
00576 - Terminal 15
                    Reset counter: 175
                    Mileage: 321929 km
                    Voltage: 12.30 V
   Coding: 0013644
8 Faults Found:
   Coding: 0003022
   Coding: 0000107
                    Reset counter: 175
                    Mileage: 321929 km
                    Time: 00:06:05
                    Reset counter: 175
                    Mileage: 321929 km
                    Time: 00:06:06
                    Reset counter: 175
                    Mileage: 321929 km
                    Time: 00:06:10
   Coding: 0001205
                    Reset counter: 175
                    Mileage: 321929 km
                    Time: 00:06:06
   Coding: 0001204
   Coding: 0040401
                    Reset counter: 175
                    Mileage: 321929 km
                    Time: 00:06:12
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100101
   Coding: 0000192
End-------------------------(Elapsed Time: 01:52)--------------------------
RayB
C?ID=586649
Put the old ones back on !!
Old ones back on? Please enlighten me.
Idle was better when i replaced both sensors.
But will do tomorrow as suggested.
