New ABS module will not code, even using ODIS (MK100ESP)
slowmoalfonso
New York, USA
C?ID=347623
I have a 2018 GTI here that I am getting the Coding rejected Error 31, when trying to code the ABS control unit. There's a backstory on this car that it went to a VW dealership that swapped the ABS module and couldn't get it to code using ODIS. I have Databus codes all over this vehicle and haven't done much other than trying to code it with this coding.
01FA6AA12423216E4080060540C62980562484026002947200215030C002430000000012121212B835351919323200
I've included a full log from the vehicle below if anyone has any ideas where to begin. I went through all the fuses and checked wiring everywhere I could.
Thursday,06,February,2025,11:17:19:04996
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
Workshop Code: 210 01369 040505
VIN: 3VW447AU3JM263109   License Plate:
Mileage: 152222km-94586mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F A9
VIN: 3VW447AU3JM263109   Mileage: 152222km-94586miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---    CVN: 6CF13A04
   Coding: 491D00124424012F2004
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 373ED6508E5E002E3A-8062
   VINID: 0E69C41074650DA74218304024CCBC942F
21388 - Valve for Exhaust Flap 1 (N321)
          P3019 00 [01101101] - Open Circuit
                    Mileage: 150336 km
                    Date: 2025.01.03
                    Time: 22:08:25
                    Engine RPM: 1230.25 /min
                    Normed load value: 11.4 %
                    Coolant temperature: 10 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 12.050 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 1 s
                    MAP_MES_SAE: 47 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 5150.0 kPa
21399 - Valve for Exhaust Flap 2 (N322)
          P3023 00 [01101101] - Open Circuit
                    Mileage: 150336 km
                    Date: 2025.01.03
                    Time: 22:08:25
                    T_AST_SAE: 1 s
                    MAP_MES_SAE: 47 kPa
17178 - Databus
          U1123 00 [01101101] - Received Error Message
                    Mileage: 150336 km
                    Date: 2025.01.04
                    Time: 05:31:21
                    Engine RPM: 0.00 /min
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 12.207 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
19875 - No Communication with ABS Brake Control Module
          U0121 00 [10101111] - -
                    Fault Frequency: 103
                    Mileage: 150336 km
                    Date: 2025.01.03
                    Time: 22:08:01
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 12.070 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 9.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 1449 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    T_AST_SAE: 0 s
Readiness: 0010 0101
   Part No SW: 0D9 300 043 F    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5204
   Revision: 06454104    Serial number: TFK01707132035 CVN: 0000FA07
   Shop #: WSC 00066 790 00235
   ROD: EV_TCMDQ250021.rod
   VCID: 1D7224F80CA24A7EC0-8048
          P1734 00 [00000010] - -
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 62647000000073
   Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
   VCID: 004C7D8C9B108796CB-8054
13 Faults Found:
0195 - Control module not coded
          U1013 00 [10001001] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
0398 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
          [Vehicle equipped with vacuum sensor but no vacuum sensor coded]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:22:49
4161 - Coding invalid
          U10DA 00 [00001000] - -
          [mismatch between VIN on CAN and VIN in coding word]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:30
8279 - Engine Control Module Incorrectly Coded
          P1612 00 [10001001] - -
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
8280 - Engine Control Module Incorrectly Coded
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
8286 - Databus
          U1123 00 [10001001] - Received Error Message
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
8299 - Databus
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
8306 - Databus
          U1122 00 [10001001] - Implausible Message
          [FCAN: Unplausible VIN number]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:19
8308 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:21:17
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110001000000000000006
   Shop #: WSC 01383 790 50316
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4CD499BCE7D893F667-8018
131073 - Supply voltage
          U1012 00 [00001000] - Voltage too High
          [Versorgungsspannung - oberer Grenzwert überschritten]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:28:26
                    Voltage terminal 30: 16.0 V
                    Outside temperature: 8.0 °C
                    Engine RPM: 0 /min
                    System run time-Terminal 15 on: 255 s
393477 - Air Blower
          B10BE 17 [00001000] - Voltage Too High
          [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Überspannung Abschaltung]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:28:36
                    Voltage terminal 30: 16.3 V
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C86407091701W7 Dataset Number: V03935274HK 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B565AA0A256D4CEAE-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170710  043 0551
   Serial number: 97022066170725225529
   Coding: 004DDD
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S9Y17M07D28H00M14S43
   Coding: 00A8DD
131329 - Supply voltage
          [Versorgungsspannung - oberer Grenzwert überschritten >]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:44:28
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 16.9 V
                    Outside temperature: 9.5 °C
131585 - Function Restricted due to Excessive Voltage
          U1401 00 [00001001] - -
          [Funktionseinschränkung durch Überspannung - oberer Grenzwert überschritten >]
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:26:34
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 16.0 V
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001000] - Open or Short to Plus
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [00001000] - Open or Short to Plus
                    Reset counter: 36
                    Mileage: 151599 km
                    Date: 2025.01.25
                    Time: 22:59:22
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.4 V
                    Outside temperature: 9.0 °C
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [00001000] - Open or Short to Plus
                    Reset counter: 36
                    Mileage: 151599 km
                    Date: 2025.01.25
                    Time: 23:04:19
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.7 V
                    Outside temperature: 10.0 °C
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [00001000] - Voltage Supply Open or Short to Plus
                    Fault Frequency: 9
                    Reset counter: 36
                    Mileage: 151599 km
                    Date: 2025.01.25
                    Time: 22:59:23
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.4 V
   Serial number: 003GCR08GKFV Dataset Number: V03935251DQ 0001
   VCID: 47DEA690FEBE70AE4A-8012
   Serial number: IBH000000000007HPI8Z
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 307 17
   Serial number: 35700000000E8139C52Q
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 17
   Serial number: 35800000000D3139C52L
   Subsystem 4 - Part No SW: -----------    HW: 480 400 208 17
   Serial number: 3510001BD26D7C0575DI
   Subsystem 5 - Part No SW: -----------    HW: 480 402 607 17
   Serial number: 3520001B32600D35458S
   Subsystem 6 - Part No SW: -----------    HW: 480 401 107 17
   Serial number: 3550002B324F3851A1E6
   Subsystem 7 - Part No SW: -----------    HW: 480 401 107 17
   Serial number: 3560002B524F385241D3
          B13BC F2 [10001001] - No function
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:17:36
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16081704220529
   Coding: 0410
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 02487784951C9586DD-8056
136193 - Supply voltage
          [Versorgungsspannung - oberer Grenzwert überschritten>]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:48:56
                    Operating time: 198693 min
                    Terminal 30 power supply: 16.8 V
                    Voltage at switch: 5.02 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 5G1 920 856 C    HW: 5G1 920 856 C
   Component: KOMBI         342 0310
   Coding: 0BBD098A2180CF0502002F041000000020000000
   VCID: 2E10F3347104C1E669-807A
13636096 - Supply voltage
          [Versorgungsspannung - oberer Grenzwert überschritten Versorgungsspannung Spannung dauerhaft zu hoch]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:42:58
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 123
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:20
16776989 - Databus
          [RDK_02 keine Kommunikation]
                    Reset counter: 10
                    Mileage: 146569 km
                    Date: 2024.11.23
                    Time: 04:21:10
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5304
   Serial number: 19091700841331 Dataset Number: V03935266ZJ 0001
   Coding: 030100047F085900FB0000681C0F00010001070000000000000000000000
   Shop #: WSC 00066 790 07025
   GVL: 01503C1000000000400C00000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3228E744653CE5060D-8066
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170001435440087272
   Coding: 31FFFF
   Serial number: 1429723304
66565 - Diagnostic Databus
          U1202 00 [00001000] - Malfunction
          [Bus defekt CAN-Diagnose]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 09:24:18
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
1281 - Supply voltage
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:42:58
                    Terminal 30 power supply: 16.5 V
                    Terminal 15: On
   Serial number: 5038724503878  Dataset Number: V03935265HB 0001
   Coding: 003E03200000020000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Serial number: 00000000000006902104
   Coding: 011000
65547 - Supply voltage
          U1012 00 [00001001] - Voltage too High
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 09:20:47
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Dataset Number: V03935245KK 0001
   Coding: 8107
   Shop #: WSC 31280 004 1048576
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C5459BCA758D3F6A7-8058
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 74
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:16
                    Motor status: 00
                    Supply voltage: 14.75 V
                    Temperature: 8.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 14.81 V
                    uAdSensI_SwitchedKl30_xdu16: 14.81 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
20992 - Databus
          [ESP_24 Botschaft - CAN-Timeout]
                    Reset counter: 163
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:16
                    Motor status: 00
                    Temperature: 8.0 °C
                    KFC: 52
                    KFA: 00 00
                    Freeze frame conditions: 20
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Reset counter: 163
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:16
                    Motor status: 00
                    Temperature: 8.0 °C
                    KFC: 5A
                    KFA: 00 00
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Reset counter: 163
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:16
                    Motor status: 00
                    System status: Driving mode
                    Temperature: 8.0 °C
                    KFC: 57
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.78 V
                    uAdSensI_SwitchedKl30_xdu16: 14.78 V
11520 - Supply voltage
          [Warnung vor dauerhaft zu hoher Versorgungsspannung  Anzeige von Überspannung]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:44:28
                    Motor status: 00
                    Supply voltage: 16.75 V
                    Temperature: 19.0 °C
                    KFC: 2D
                    KFA: 00 00
                    Freeze frame conditions: 25
                    uioUdNotFilt_xdu16: 17.13 V
                    uAdSensI_SwitchedKl30_xdu16: 17.12 V
11008 - Function Restricted due to Excessive Voltage
          U1401 00 [00001000] - -
          [Abschaltung aufgrund Überspannungsreduzierung Globaler KFA für Überspannungs-Reduzierung]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:45:53
                    Motor status: 00
                    KFC: 2B
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 17.02 V
                    uAdSensI_SwitchedKl30_xdu16: 17.02 V
   Serial number: 6038725401616  Dataset Number: V03935265HC 0001
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 46C0AB94F9B469A6B1-8012
   Serial number: 00000000000007027519
   Coding: 091000
                    Reset counter: 34
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:22:01
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      671 8395
   Serial number: 05061700020164 Dataset Number: V03935300ZL 0001
   Coding: 02730000FF00000041220001001000009F0203D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 70AC2D4CABB097163B-8024
1536 - Supply voltage
          [Supply voltage - upper limit value exceeded]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:42:58
                    Voltage terminal 30: 17.0 V
                    Reset counter: 16
                    Mileage: 151804 km
                    Date: 2025.01.30
                    Time: 13:47:31
                    Voltage terminal 30: 14.5 V
6919 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 123
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:19
                    Voltage terminal 30: 14.9 V
6950 - Function Restricted due to Missing Message(s)
          [Brake (0x26) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 123
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:07:19
                    Voltage terminal 30: 15.1 V
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 123
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:16:37
                    BAP-BAP_Function_ID: 00
7206 - Function Restricted due to Missing Message(s)
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 123
                    Mileage: 148999 km
                    Date: 2024.12.21
                    Time: 11:16:37
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 170720200829
0001 - Supply voltage
          [Versorgungsspannung - oberer Grenzwert überschritten--> Versorgungsspannung Spannung dauerhaft zu hoch]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:42:58
0003 - Function Restricted due to Excessive Voltage
          [Funktionseinschränkung durch Überspannung--> funktionelle Einschränkungen aufgrund vorübergehender Überspannung in der Versorgung.]
                    Reset counter: 74
                    Mileage: 152222 km
                    Date: 2025.02.04
                    Time: 10:42:58
End----------(Elapsed Time: 01:22, VBatt start/end: 16.0V/15.9V)-----------
Just curious: Where did you get that coding?
slowmoalfonso
New York, USA
C?ID=347623
I figured I'd get roasted for the voltage. I guess I switched the charger to 50amp on accident when I connected it. It didn't live there long, but I already hit the scan button. The code was a reach and I grabbed it off from https://vagcode.info/components/7875af0b9e1a68ad20cece7103d1af28.html. I didn't expect it to love it but starting from the zeros, I took a shot as it was coming off from the same part/hardware number.
I would not use any charger that tries to put 16V into a car. There's no excuse for that, no matter how many amps a charger is capable of delivering or is set to.
Is the ABS module that's installed the correct, appropriate one for the car?
slowmoalfonso
New York, USA
C?ID=347623
The dealer installed it and I verified that it was the correct part number and correct for the vin.
EuroX
Northern NJ USA
C?ID=208579
Suggestions Find competent dealer. If the part number has changed dealer will need to run SVM code for abs module replacing in order to code module if the part number has drastically changed. Most likely SVM code XCHG03A001 or something similar. Again I feel your pain and good help is damn near impossible to find.... even at the dealer.
slowmoalfonso
New York, USA
C?ID=347623
According to the dealer it was installed at, it was the same part number came out of the car that was installed into it. The tech who did the work originally, left the dealer in December and he was literally their only master tech. Next nearest dealer to me is 70 miles away, and the word competent doesn't accurately describe their abilities.
EuroX
Northern NJ USA
C?ID=208579
Is this a recent thing? As I see nothing on Vw's server or any record of the vehicle being at the dealer recently. Last time it was as the dealer was 04/12/2024. When coding a module an log is automatically generated. I see no such recent log. So I would question everything that was done to start to be honest.
Also note that is not the correct coding for the vehicle. I can provide the correct coding per vin if you're in a rush for a small fee.
slowmoalfonso
New York, USA
C?ID=347623
The repair order was written on Friday April 12, 2024 and pickup was Thursday October 12, 2024. I know the coding isn't correct that I was inputting. I was trying to see if it would even try to code the thing, because I was originally told by the dealer that it wouldn't even try. I could use the correct code so I can see what happens.
Dr Sheldon
Windsor UK
C?ID=334979
Really !!
What kind of dealer ?? Was he driving a flash car playing Rap Music with a Moll in the passenger seat??
Dealer installed the ABS module and then they gave you the car back in this state !!!!
Post a copy of the Invoice from the Dealer !!
Dr Sheldon
Windsor UK
C?ID=334979
Who is the Franchised VW Importer to the USA ??
Why you not banging that door down ??
slowmoalfonso
New York, USA
C?ID=347623
I'm not posting a picture of the repair order because it's got the owner's information on it, and it's not going to change anything. I'm not banging down their door because they apparently don't have the capacity to fix this guy's car correctly and no amount of outrage is going to change that. I have a good relationship with their parts department, and I'm being paid to repair the car. I'm no less stuck than they were, but I'm seeking solutions that they were unwilling to find. If it turns out that the module is corrupt, no big deal, they've got one sitting over there for me which will be warrantied.
EuroX
Northern NJ USA
C?ID=208579
Do you have the correct coding for the module? Does the module take the coding? If not what error does it give you?
slowmoalfonso
New York, USA
C?ID=347623
No, I don't have the correct coding, partially why I came here. The car came in showing all zeros and codes for control module not coded. The incorrect coding give me the rejected Error 31, but it at least tries to do something, which is contrary to the story I got out of the dealer. The claim from them is that the module wouldn't even communicate. As you can see from the scan, that's not the case.
slowmoalfonso
New York, USA
C?ID=347623
All set. Coding from EuroX worked. Traction control light is staying on, but come to find out this guy has a Integrated Engineering OBD Tune installed he "forgot" to tell me about until I noticed the CAN shut down every time I ran the car. Thanks for the help.
EuroX
Northern NJ USA
C?ID=208579
Basic settings may be needed.
slowmoalfonso
New York, USA
C?ID=347623
Performed all the basic settings in ABS & Steering Assist. One code remained, but it was because he checked something in his tune.
EuroX
Northern NJ USA
C?ID=208579
Ok so all lights are gone correct? One and done?
