Flash failed, car wont start
LN-TAL
Norway
C?ID=13729
Hi friends,
yup, it happend. I tried up flash software update to my Audi A3 engine ECU. After aprox. 30 sec. odis e told me that I should turn the ignition off and on again, and the flash has failed. In the flash log is a german fault message "flashen der datenblocke fehlgeschlagen".
Below is autoscan AFTER the flash has failed. The engine will not start, and the cooling fan is running at full speed. Does anyone have any inputs, hints, things to try etc ? Or can explain why it happened ? Is the ECU toast, or will a dealer with a geko connection probably get it back to work ? I can log into the engine ECU with vcds, but most of the functions are greyed out.
Tuesday,08,December,2015,22:24:27:62006
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUZZZ8P54A165042   License Plate: BR51499
Mileage: 168490km-104694mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 55 56 76 7D
VIN: WAUZZZ8P54A165042   Mileage: 168490km-104694miles
01-Engine -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 G    HW: 028 101 136 4
   Component: R4 2,0L EDC         5705
   Shop #: WSC 74565 000 00000
   VCID: 275754BD961F22060A-8072
No Faults Found
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023174
   Shop #: WSC 06435 000 00000
   VCID: 3A719DC975ADAFEE65-806E
   Part No SW: 8P0 820 043 E    HW: 8P0 820 043 E
   Component: KlimavollautomatH12 0150
   Revision: 015231      Serial number: 8P0820043E
   VCID: 2E59A199B9E5734EC9-807A
                    Fault Status: 01101000
                    Reset counter: 222
                    Mileage: 168490 km
                    Date: 2015.12.08
                    Time: 00:00:44
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 222
                    Mileage: 168490 km
                    Date: 2015.12.08
                    Time: 22:22:08
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
   Component: Bordnetz-SG 1.0 H30 0501
   Revision: 00030000    Serial number: 00000000690970
   Coding: 030ACE0083140600000000000000000000
   VCID: 3B7F98CD7A9796E67E-806E
   Subsystem 1 - Part No: 8P1 955 119 C  Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0180
   Coding: 16711696
   Shop #: WSC 12345
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
   Component: Airbag 8.4ED    H00 0140
   Coding: 0010602
   VCID: 438FE02D0267EE2636-8016
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenks‰ulenmodul 012 0030
   Coding: 0000042
   VCID: 3065BFE1A3D165BEDB-8064
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
   Component: KOMBIINSTR. VDO H25 0140
   Revision: D09         Serial number: 2243DD09053438
   Coding: 0004003
   Shop #: WSC 80093 222 69422
   VCID: 356B8EF55CB3409688-8060
Address 18: Aux. Heat        Labels: 1K0-815-005.clb
   Part No: 1K0 815 005 EF
   Component: Heizgeraet      H08 0040
   Revision:        A    Serial number: 09011596
   Coding: 0001112
   Shop #: WSC 38059 136 84162
   VCID: 6AD16D89458DDF6ED5-803E
02085 - Incorrect Control Module Installed
            000 -  -
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 2500104325011F
   Coding: 7D0F1F42070100
   Shop #: WSC 06435 123 12345
   VCID: 285557819B012D7E03-807C
                    Reset counter: 222
                    Mileage: 168490 km
                    Date: 2015.12.08
                    Time: 22:20:14
   Revision: D09         Serial number: AUX7Z0D3FN70K1
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 A
   Component: Tuersteuerger.  H10 0010
   Coding: 0000048
   VCID: 397382C570ABA4F66C-806C
   Part No: 1K1 909 144 F
   Component: EPS_ZFLS Kl.10      1301
                    Mileage: 8480 km
                    Temperature: 11.0∞C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 B
   Component:    KSG          H02 0040
   Coding: 188800186D288505484A016000
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001119925
   VCID: 70E57FE1635125BE9B-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 A
   Coding: 0000048
   Part No: 8P0 907 357 A
   Revision: 00000000    Serial number:
   Coding: 0000001
   VCID: 387587C14BA1BDFE93-806C
                    Fault Status: 11100100
                    Reset counter: 0
                    Mileage: 168488 km
                    Date: 2015.12.08
                    Time: 22:20:14
            008 - Implausible Signal - MIL ON
                    Reset counter: 0
                    Mileage: 168488 km
                    Date: 2015.12.08
                    Time: 22:20:14
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H53 0060
   Revision:      08S    Serial number: AUZ2Z3D2056623
   Coding: 0001001
   VCID: 6FE77C9D7E6F3A4682-803A
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283     HW: 8P0 919 283
   Component: Parkhilfe 4-Kan H06 0020
   Coding: 0000003
   VCID: 78F547C10B217DFE53-802C
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C5DAB918FF9015EE7-8078
End-------------------------(Elapsed Time: 01:44)--------------------------
If you can talk to the ECU with VCDS (and it appears you can) then the processor is still booting up and running. I would take that as a good sign.
However, since we don't do flashing (at all) (and here's one of big reasons why), I don't have any advice what your next step would be.
golfi_vend
Tartu, Estonia
C?ID=195131
You have COM via k-line. Thats a good start. I also see this is EDC16U1 ECU, they just die...for some reason.
You could try another flash session.
golfi_vend
Tartu, Estonia
C?ID=195131
Are we sure...But if you say so.
I had similar dead Touran ECU once. When connected to ECU VCDS showed KWP2000. This is K-line right?
I guess it was this autoscan... not the one found from web:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC 6246
Shop #: WSC 01324 785 00200
VCID: 67DD49D9566B5626359-8032
No Faults Found
LN-TAL
Norway
C?ID=13729
I have tried four more flash attempts, but still the same. After 13-30 sec. it stops and telling me to turn off and on ignition again.
I tried to flash software 9884, have also tried 7641. Maybe if someone has 5705 it will work ?
I disconnected the battey now and will let it stay overnight. Maybe that will help ?
Gone But Not Forgotten
The ecu is stuck in what is known as 85 mode ( programming mode ), that is why the fans are switched on, because the ecu isn't telling the fan controller to pull up the relay.
Better get a battery charger on there and unplug the fan so you don't have to listen to it. ( Make sure when done to plug back in )
Flash it with the same version that was in there before or start over with what you have.
You may have a bad file or a file that isn't supposed to be for that ecu hardware level.
God loves back ups via BDM before doing such things.......
I can help fix this .........
No Faults Found
Nope, that session was communicating via CAN as well. :)
NEtech
Denmark
C?ID=56995
To try over K-Line is one of the procedures from VAG, like for example in TPI 2010883/10
LN-TAL
Norway
C?ID=13729
Ok, so thats mean take the ECU out of the car, connect power and K line to my VAS5054 and try to flash again ? I also talked to a dealer here in norway which said that I could try to unplug the ABS module and the try to flash. The car has now been without power tonight, so I will try to flash again now.
Thanks for all suggestions.
LN-TAL
Norway
C?ID=13729
Hehe, ok, I did not now that was possible. Thanks again. Actually, now I have removed the ECU from the car (it only took about 20 min). So I will find the correct pins now, and hook it up.
Watch the newbie (with flashing) blow up his module :)
LN-TAL
Norway
C?ID=13729
And as we speak, the module is on my kitchen table, hooked up, and the flash has started ! :)
LN-TAL
Norway
C?ID=13729
Ahh, you want proof ? :)
Wednesday,09,December,2015,12:12:18:62006
   Component: R4 2,0L EDC G000SG  9884
   Revision: 12345678    Serial number: AUX7Z0D3FN70K1
   Coding: 0000072
   Coding: 0023174
   Coding: 16711696
   Shop #: WSC 12345
   Coding: 0010602
   Coding: 0000042
   Coding: 0004003
   Coding: 0001112
   Coding: 0000048
   Coding: 0000048
   Coding: 0000001
   Coding: 0001001
   Coding: 0000003
End-------------------------(Elapsed Time: 01:43)--------------------------
LN-TAL
Norway
C?ID=13729
And now when the smoke has started to clear, and the fire is out. I want to learn even more: how did you see that this session was communcation over CAN Uwe ?
What I experienced today, was that on the ECU connector I had in spare (taken from a scrapyard car some months ago when I installed CC), had NOT the k-line wire connected. There was NO wire at pin T94/72, and the hole for the plug was blocked by this black "things" that are installed in all the connector holes which is not in use. I did NOT check if the K-line was connected on my car, but maybe they have not connected the ECU K-line pin to the diagnostic port on these cars ?
golfi_vend
Tartu, Estonia
C?ID=195131
Uwe has told, that there is some sort of way to see K-line or CAN, but he won't discuss it. It was said last time.
LN-TAL
Norway
C?ID=13729
Hmm, ok, wonder why ? Then there is only one way to find out, I have to take two logs from several modules, one with only k-line, and one with CAN bus active, and then compare them :)
Nope......not that you didn't say it, however, I call BS that Uwe wouldn't discuss it, or cover something up.
Ahhh WD........ and scan seeing the gateway list verse no gateway list.........aren't both your scans with gateway list?
It is no secret and Uwe wasn't failing to discuss it...........that's a conspiracy theory I can't be a party to......... because it's bullshit!
Uwe just referenced what he sees and the platform it should of supported ......as you said there was no wire on K in the car....that's your fault for not checking WD.
You can also observe the communication layer you are in......... in the left upper corner of VCDS such as CAN KWP 2000 KW1281, KW2089 TP 1.6 or 2.0 and UDS etc....High or low speed selectable bauds........some flash tools support baud select change as does VCDS in blocks for TURBO MODE.
What was happening was probably the fan, low voltage in general......... RF noise such as cell phone or other clutter on the CAN was interrupting the flash session.
The ecu diagnostic stack supports both K and Can communication in these EDC16 ecu's .........some cars use the K line and some use the CAN.......... and some both!
It would of flashed fine on CAN or K line......... if the connections, and the tool were in proper order on the bench ........shit it was already in 85 mode.
K-line is used by most......... because in flash mode, it flashes faster on baud, for the tools out there in the industry.
Security access is your biggest enemy...........and that you have automatically, because you are stuck in it when in flash mode.
Glad it worked out.............
FACT!
The real story is......... that if the tools out there supported the flash speeds on the CAN, like the real OEM tools, the communication on CAN is far faster!
