Audi A4 2.0 TDI B8.5 Towbar Coding (and other potential problems)
debacle007
C?ID=604477
Hi all
I've installed a towbar and genuine electrics to my 2015 Audi A4 TDi Avant, B8.5.
Because Audi wanted £179 plus VAT to do the coding for it, I thought it prudent to add a VCDS to my toolbox. However, while getting the data is straight forward enough, what to do with it is a different kettle of fish.
Would someone be able to guide my hand with the below code and advise what is required to make everything work as it should please?
Kind Regards
Brian
Friday,07,February,2025,13:42:51:19109
VIN: WAUZZZ8K9FA172003   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6D 72
          AC
VIN: WAUZZZ8K9FA172003   Mileage: 138890km-86302miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CNHC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8285
   Revision: 85H23---    CVN: EDA62D3DC19C777138D3FF82
   Coding: 12194012242401080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021BQ 002006
   ROD: EV_ECM20TDI01104L906021BK_002.rod
   VCID: 75B03EFBB5459CF27CD-8020
   VINID: 9D196AAAA21B2564411C20000C392A1EF1
          U1113 00 [00100111] - -
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 13:40:27
                    Engine RPM: 0.00 /min
                    Coolant temperature: 5 °C
                    Intake air temperature: 5 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 11.640 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bits 0-7: 2
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 13:40:27
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 3F1DC401
   Shop #: WSC 06325 000 00000
   VCID: 074C4433DF299E621E1-8052
   Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
   Component: BCM2 2.0      H15 0711
   Coding: 03B24040000000000000
   VCID: 7F5CDCD387F9D6A2261-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0815000092900016
   Serial number: 3215000132029001
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 BA    HW: 8K2 820 043 BA
   Revision: D0000000    Serial number: 01120820152254
   Coding: 342400A000
   VCID: 6988628BE97D4812E85-803C
   Part No SW: 8K0 907 063 DC    HW: 8K0 907 063 DC
   Revision: 03016001    Serial number: 00001146963801
   Coding: 290000308034A7C00081000000001F1F001D060827080201000008004000020000000024000000
   VCID: 73B400E3BBB182C2529-8026
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110815  H06 0080
   Serial number: SWF15088115079
   Coding: 00FD11
   Serial number: 20500484
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002807151287
   Serial number: 6DB80FB7000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003KFDD291YO   Dataset Number: 8K0909602Q  0001
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 55802 001 1048576
   VCID: 48CE870F9237511AD7B-801C
   Serial number: 6334MSME5349371FK
   Serial number: 6344MSME530B121DA
   Serial number: 6352QSME7F58215EY
   Serial number: 6362QSME0E592074J
   Serial number: 63732SME1C523146X
   Serial number: 63832SME4B4E0440+
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OH6000CM
   Coding: 000017
   VCID: 48CE870F92B7511AD7B-801C
   Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 61+69XW7G
   Coding: 33A4100003012600010000
   VCID: 3928F2CBD95D3892585-806C
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 13:40:24
   Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0070
   Revision: 1Y090032    Serial number: 3241Y1570705D6
   Coding: 80CF07FF00
   VCID: 50FEAF6F6AE799DA8FB-8004
   Serial number: 5759487403
   Serial number: 15217002545011200181
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 13:40:28
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000158391713
   Coding: 011002204001410001
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0015031723 Dataset Number: 8K0909852L  0026
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E22E1D7C0F31FAA6D7-806A
   Revision: 00002001    Serial number: 0376232077
   Coding: 013B0622A0B930408320023680000047
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0511
   Revision:             Serial number: 0000160088052
   VCID: 4FFCAC1377D98622961-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000663571
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2AEDC7DCDB338A51F-806E
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109H10F8059463
   Coding: 010103020100000001
   VCID: 2D00D69B1D159432C4D-8078
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 1036
   Revision: --------    Serial number: 515HB0F7547795
   Coding: 0F0101010006A1ED01808B5E00000403E40000020000000000
   VCID: 42DA9527B48B7B4A09F-8016
   Subsystem 1 - Part No: 8R0 060 884 KL
   Component: EUR 2023  3600
   Component: DU7 High  H42 0104
   Serial number: A130HP0F3431407
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002335979
   Component: CD-Database  6208
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 13:40:27
                    Text: DUA130,Front,M,0,0,6
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000034128500
   Coding: 010002204001210001
   Shop #: WSC 06335 000 00000
   VCID: 43D49023AB917242029-8016
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: ConWys Trailer H09 0100
   Revision: 1A001001    Serial number: 00000161077413
   Coding: 0100000000000000
   Shop #: WSC 00007 223 57222
   VCID: 3632F9F7E843D7EAB57-8062
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E22E1D7C0731FAA6D7-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H56 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000157210971
   VCID: 46D2893798A3476A257-8012
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151961111 Dataset Number: 8K0909571G  0018
   ROD: EV_RDCMA00100.rod
   VCID: 2F3CCC931799E622F61-807A
End----(Elapsed Time: 01:49, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
debacle007
C?ID=604477
Ok, some youtube videos have got me into the CAN system to enable the trailer and into a couple of long codes to check as well in Engine and Trailer.
Still getting ECS, TPMS and Start Stop warnings on dash though. This is from the car on and includes an ABS warning now...
Friday,07,February,2025,15:28:06:19109
          AC
   Coding: 12194012243401080000
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:08:30
                    Engine RPM: 857.50 /min
                    Normed load value: 35.3 %
                    Coolant temperature: 38 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 14.460 V
                    Engine control module reset status-Bits 0-7: 48
                    Engine control module reset status-Bits 0-7: 5
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:08:30
   Coding: 3F1DC401
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:10:59
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0045
                    Hex Value: 0x03A1
                    Hex Value: 0x0000
   Coding: 342400A000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000017
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:11:29
   Coding: 80CF07FF00
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:08:30
End----------(Elapsed Time: 01:49, VBatt start/end: 13.4V/14.4V)-----------
debacle007
C?ID=604477
Absolutely outstanding, thank you Uwe.
Car has no more complaints. There are still 2 codes left, which are likely unrelated to the towbar as my more basic machine picked up an issue in the infotainment pre towbar. Any thoughts as to what the problem may be?
Kind Regards
Brian
Friday,07,February,2025,15:44:08:19109
          AC
   Coding: 3F9DC401
   Shop #: WSC 06325 123 12345
   Coding: 342400A000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000017
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:39:36
   Coding: 80CF07FF00
                    Reset counter: 172
                    Mileage: 138891 km
                    Date: 2025.02.07
                    Time: 15:39:38
End----(Elapsed Time: 01:46, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
I agree, those are unrelated.
The fault code in 17 is due to some mis-configuration of the service intervals.
The fault in 5F:
debacle007
C?ID=604477
Thank you again Uwe!
Hi guys,
I noticed this forum thread after I replied to the email. The body of that reply was:
Hi Brian,
Thanks for the scan.  The control modules that need to be configured for
Trailer Installed are:
* 19-CAN Gateway
Use the [Installation List] feature in VCDS, tick the box for 69-Trailer
and [Write Coding]
* 01-Engine
You can use the Long Coding Helper or paste this into the New Coding
line followed by Do it:
* 03-ABS Brakes requires Security Access 61378 first
You can use the Long Coding Helper or:
3F9DC401
* 09-Cent. Elect.
290000308034A7C00081000000001F1F001D260827080201000008004000020000000024000000
Make sure to clear all DTCs after coding and verify the trailer lights
are working correctly.
Best Regards,
Let us know if you want to dig into the SRI conflicts in address 17 but that's easiest to sort out when the oil change and inspection items are done and require resetting.
debacle007
C?ID=604477
Thanks Dana!
I’ll plug in tomorrow and double check my coding matches.
Kind Regards
Brian
OZDI
Australia
C?ID=386887
Reset counter: 172
Mileage: 138891 km
Date: 2025.02.07
Time: 15:08:30
In module 5F, BYTE 10, BIT5 try to change 0 ---> 1
