- Oct 27, 2014
- 5,221
- 4,854
- Arandjelovac, Serbia
- C?ID=57300
Our user:
Using a fine tool, I calculated: 01FA62A120200972007D060940C72980460490006002947200410070C002
@iichel, what do you think? If any corrections are needed, please do so.
I accidentally clicked on abs, in basic settings, on factory reset, and I lost the code, I guess the long one...
Thursday,06,February,2025,11:46:45:43219
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WVWZZZAUZEW106694 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZEW106694 Mileage: 435938km-270879miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 6456
Revision: 83H22--- CVN: E0897EB2
Coding: 011D0032030401082000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01104L906021DT 002006
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: FAA61ECD3C5554EA91F-80AE
VINID: 9E69EAAAA465A959C100618910C5F79F30
4716 - No Communications with Parking Brake Control Module
U0128 00 [00101111] - -
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:05
Engine RPM: 772.50 /min
Normed load value: 18.8 %
Coolant temperature: 75 °C
Intake air temperature: 50 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 13.300 V
selected gear-Bits 0-7: 0
Part No SW: 0D9 300 040 K HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4028
Revision: 05652104 Serial number: TFK01307041428 CVN: 0000D49B
ROD: EV_TCMDQ250021.rod
VCID: 9F100F59C737D1C2C61-80CA
P1734 00 [00000010] - -
21221 - No Communications with Parking Brake Control Module
U0128 00 [00001011] - -
Fault Frequency: 14
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:05
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62353000000124
VCID: FBA81BC9336F6DE28A9-80AE
10 Faults Found:
0195 - Control module not coded
U1013 00 [10001001] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
C1017 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
C1079 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
0279 - Brake Pressure Sensor 1
C107A 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
0295 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
8290 - Coding Not Possible
U10BC 00 [10001001] - -
[FCAN: Unplausible VIN number]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:44:18
8306 - Databus
U1122 00 [10001001] - Implausible Message
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:44:18
8308 - Control Module Incorrectly Coded
U1014 00 [00001000] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Reset counter: 217
Mileage: 435893 km
Date: 2025.02.05
Time: 18:32:55
32848 - Control Module for Electric Parking Brake
C10E2 F1 [10001001] - Switches/Motors Detected
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
32951 - Control Module for Electronic Parking Brake
C10E2 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 18:05:53
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0705
Revision: 00001K06
Coding: 00020104202100011005000000101000
VCID: B822C4C542D986FA27B-80EC
Air quality sensor:
327943 - Position Sensor for Left Temperature Flap Motor
B1094 15 [00001000] - Open or Short to Plus
Fault Frequency: 13
Reset counter: 219
Mileage: 435692 km
Date: 2025.01.24
Time: 15:14:57
Voltage terminal 30: 13.7 V
Outside temperature: 10.0 °C
Inside temperature: 25.7 °C
Left temperature flap - actual value: 206
Left temperature flap - actual value: 85.5 %
Temperature door left - Specified value: 206
328197 - Motor for Right Temperature Flap
B108D 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 144
Mileage: 435000 km
Date: 2025.01.17
Time: 15:51:42
Voltage terminal 30: 11.2 V
Outside temperature: 3.5 °C
Inside temperature: 16.2 °C
Right temperature flap: actual value: 204
Right temperature flap: actual value: 100.0 %
Temperature door right - Specified value: 205
328964 - Motor for Front Air Distribution Flap
B1091 71 [00001000] - Actuator Stuck
Fault Frequency: 32
Reset counter: 217
Mileage: 435000 km
Date: 2025.01.17
Time: 15:51:42
Front air distribution flap: actual value: 0.0 %
Front air distribution flap: actual value: 236
Air distribution door front - Specified value: 128
328965 - Motor for Front Air Distribution Flap
B1091 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 144
Mileage: 435000 km
Date: 2025.01.17
Time: 15:51:42
1048834 - Functional Limitation due to Energy Management
B10CD 00 [00001001] - -
[PTC-Reduzierung durch BCM]
Fault Frequency: 9
Reset counter: 179
Mileage: 435000 km
Date: 2025.01.17
Time: 15:51:42
Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Target value: 3
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [00001000] - -
[PTC-Reduzierung durch MSG]
Fault Frequency: 138
Reset counter: 219
Mileage: 435000 km
Date: 2025.01.17
Time: 16:32:23
Voltage terminal 30: 13.6 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 3
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011323800025 Dataset Number: 5G0063v____ 0001
Coding: 00001A42C20122FB4B644000000C07081000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: F7A007F90F474982EE1-80A2
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130808 042 0551
Serial number: 130817085130
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M08D26H00M25S30S4
Coding: 00A8DD
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [00001001] - Voltage Supply Open or Short to Plus
Reset counter: 144
Mileage: 435000 km
Date: 2025.01.17
Time: 15:51:46
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: operated
Voltage: 12.0 V
934149 - Rain/Light Recognition Sensor
B1366 76 [00001000] - Incorrect Mounting Position
Fault Frequency: 16
Reset counter: 219
Mileage: 435659 km
Date: 2025.01.24
Time: 12:16:49
CAN-Bus_aktiv: On
OFF: Not operated
Low beam: operated
Voltage: 14.5 V
Outside temperature: 6.0 °C
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131322600509 Dataset Number: 5G0039v__B_ 0006
Coding: 0031061051
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: BD2CD5D16DFBA3D2F4D-80E8
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [00001001] - Open Circuit
Reset counter: 144
Mileage: 435000 km
Date: 2025.01.17
Time: 15:51:51
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:05
13697024 - Control Module
U110F 00 [00001001] - I'm sorry Dave; I'm afraid I can't do that!
[Steuergerät für Bremse - ESP_02.ESP_Status_ESP_PLA - PLA-Codierung in Bremse prüfen]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:48
13637426 - Databus
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:05
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0058N1 Dataset Number: 5G0003v____ 0091
VCID: C1D4A9211103C732905-8094
Subsystem 1 - Part No SW: ----------- HW: 480 001 708 13
Serial number: 35767000000597488D0$
Subsystem 2 - Part No SW: ----------- HW: 480 001 408 13
Serial number: 35867000000CE1396D01
Subsystem 3 - Part No SW: ----------- HW: 480 402 308 13
Serial number: 3516502BB10EDE44E3AZ
Subsystem 4 - Part No SW: ----------- HW: 480 402 308 13
Serial number: 3526502C910EDE45327L
Subsystem 5 - Part No SW: ----------- HW: 480 402 408 13
Serial number: 3556502B51088B1162C6
B13BC F2 [10001001] - No function
Mileage: 435893 km
Date: 2025.02.05
Time: 18:17:01
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0085
Revision: FF026026 Serial number: 20130821500258
Coding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001011
ROD: EV_SMLSVALEOMQB.rod
VCID: BFD0AFD967F7B1C2E61-80EA
Part No SW: 5G0 920 861 A HW: 5G0 920 861 A
Component: KOMBI 204 3390
Coding: 03A501082B90000800086A00040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: A70017B99F671902BE1-80F2
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:05
16776973 - Databus
[RKA_01 keine Kommunikation]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:09
1048578 - No Basic Setting
B2010 00 [00001000] - -
[Steuergerät keine oder falsche Grundeinstellung]
Fault Frequency: 13
Reset counter: 217
Mileage: 435000 km
Date: 2025.01.17
Time: 16:31:46
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 212
Mileage: 435562 km
Date: 2025.01.21
Time: 21:17:16
16777022 - Function Restricted due to Interrupted Communications
[BAP_NAV SD_0x32 keine Kommunikation]
Reset counter: 207
Mileage: 435824 km
Date: 2025.01.31
Time: 09:49:29
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000717247 Dataset Number: 5G0067v____ 1407
Coding: 030100040B087300EF00064A1C0F00010001000000000000000000000000
GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: BB28DBC973EFADE2CA9-80EE
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 H HW: 5G0 959 442 H Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H14 0035
Serial number: 27130001292600083333
Coding: 25FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 7819151103
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Component: TSG FS 012 0006
Serial number: 08081301100159 Dataset Number: 5G0222v____ 0042
Coding: 003003208000040100001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Dataset Number: 5G0074v____ 0130
Coding: 03
ROD: EV_SteerAssisMQB_008.rod
19204 - Databus
[ESP_02 Botschaft - SNA_Check]
Reset counter: 179
Mileage: 435893 km
Date: 2025.02.05
Time: 18:32:56
Motor status: 01
System status: Driving mode
Supply voltage: 12.00 V
Temperature: 16.0 °C
KFC: 4B
KFA: 00 04
Freeze frame conditions: 7F
uAdSensI_U5VFiltered_xdu16: 5.05865 V
uioUdNotFilt_xdu16: 12.11 V
uAdSensI_SwitchedKl30_xdu16: 12.11 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 15081303110619 Dataset Number: 5G0157v____ 0045
Coding: 003001208E00040100801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: BE2ED2DD60FDB8CAED7-80EA
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0015
Coding: 029A00000B000200
ROD: EV_HeadlRegulVWAFS_VW37.rod
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 040 0421
Serial number: V1F02808132211 Dataset Number: 5G0CV1v____ 0001
Coding: 02730001FF00000011110001000800001F0100840100010045
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ900KPB
6919 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:51
Voltage terminal 30: 13.1 V
6950 - Function Restricted due to Missing Message(s)
[Brake (0x26) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:52
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:54
BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 177
Mileage: 435893 km
Date: 2025.02.05
Time: 17:14:57
Voltage terminal 30: 13.2 V
End----------(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V)-----------
