- May 8, 2014
- 132
- 84
- Rossendale, Lancashire, UK
- C?ID=159389
With lots of options ......
Sunday,27,September,2015,19:42:29:16648
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: TMBKJ9NE0F0104172 License Plate:
Mileage: 26050km-16186mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
A5
VIN: TMBKJ9NE0F0104172 Mileage: 26050km-16186miles
Address 01: Engine (J623-CKFC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7545
Revision: 83H22---
Coding: 111D0032046501091000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
ROD: EV_ECM20TDI01104L906021DT_SK37.rod
VCID: 7AF1C4CAFD9E51EE13-802E
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4507
Revision: 03253104 Serial number: TFK01409080569
ROD: EV_TCMDQ250021_AU37.rod
VCID: 254BC7B624A00E160E-8070
P1734 00 [002] - -
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 62724000001129
Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
VCID: 4689603AF9E6E50E27-8012
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0347141964
Coding: 030C0C
Shop #: WSC 73430 790 00000
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7104CABD1E91EE53-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 N HW: 5E0 907 044 N
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 02110104000100011005000100101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 306526E26B625BBEED-8064
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86581310140746
Coding: 0F511B7642C722FB0FA44086B11C17280808000000000000000000000000
Shop #: WSC 73430 790 12345
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_AU37.rod
VCID: 79F3DBC6F8985AF61A-802C
Slave 1:
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140911 041 0570
Serial number: 140919232831
Coding: 065DDD
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y14M10D13H14M19S10
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141272BD5
Serial number: 00000000000060534409
Subsystem 5 - Part No SW: 5E9 959 591 HW: 7P0 959 591 B
Component: J245 PS24.011 H01 0008
Serial number: WOO3215520Z
Coding: 991900
Subsystem 6 - Part No SW: 5E9 959 591 A HW: 7P0 959 591 C
Component: J394 PS24.011 H01 0008
Serial number: WOO32246742
Coding: 991900
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Mileage: 25444 km
Date: 2015.09.22
Time: 16:53:57
565764 - LED Light Bar
B1664 31 [009] - No Signal
Reset counter: 183
Mileage: 24658 km
Date: 2015.09.12
Time: 13:41:53
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431426502437
Coding: 0131161051
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_SK37.rod
VCID: 42817C2AD5CED92E0B-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 26091403210306
Coding: 00081600FE0739
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 38751EC2831283FEA5-806C
Part No SW: 3Q0 959 655 AA HW: 3Q0 959 655 AA
Component: Airbag VW20 012 0200
Revision: -------- Serial number: 003NYPLJ7PWH
Coding: 98FCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X_SK37.rod
VCID: 7DFBCFD6ECB066D636-8028
Seat belt tensioner; left:
Component: BeltPretRevFL H35 0341
Serial number: 34169595B01101441286
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H35 0341
Serial number: 34169594B01101440818
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 454 002 609 14
Serial number: 3576U0000006A741411%
Subsystem 4 - Part No SW: ----------- HW: 454 002 709 14
Serial number: 3586U0000000B070211V
Subsystem 5 - Part No SW: ----------- HW: 454 802 709 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R4C40B204000000-
Subsystem 6 - Part No SW: ----------- HW: 454 802 909 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RB940DC04000000A
Subsystem 7 - Part No SW: ----------- HW: 454 800 109 14
Component: FrontSensor_D 114 0149
Serial number: 3556VC8E29804000000L
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EJ HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 17081404400903
Coding: 6C10
ROD: EV_SMLSKLOMQB_SK37.rod
VCID: 0201BC2A954E192E4B-8056
Part No SW: 5E0 920 911 HW: 5E0 920 911
Component: KOMBI 304 4270
Coding: 27AD0A186D94A60001887A031000000000000000
Shop #: WSC 00123 123 12345
VCID: 60C596A27B02AB3E3D-8034
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002531914
Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear.rod
Subsystem 2 - Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H05 0130
Serial number: 000000000C1182020914
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 5298644603
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000267752001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346D2AF29F7A679E89-8060
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006NHK10076
Coding: 001400000000010001A081808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_SK37.rod
VCID: 3B7F01CEB224A8E648-806E
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000121334006
Coding: 001D0820DE01048000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 448D7A32CFDAD71E39-8010
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000004020570
Coding: 1D0200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 9302
ROD: EV_SteerAssisMQB.rod
VCID: 41837326D0C8C23612-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000121631170
Coding: 001D0020DE01048000001100
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 438F792ECAD4D02600-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000003981447
Coding: 050200
65639 - Motor for Window Regulator
B1487 29 [008] - Signal Implausible
Mileage: 24774 km
Date: 2015.09.15
Time: 09:09:32
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03CE02003F010000
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40857622DBC2CB3E1D-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Part No SW: 5E0 035 020 C HW: 5E0 035 020 C
Component: MU-H-ND-EU H43 0390
Serial number: A313I0EB012483
Coding: 03730201000000001111120200A800002F0003F601000100FE
ASAM Dataset: EV_MUHig6C3HBAS 001041
ROD: EV_MUHig6C3HBAS_SK37.rod
VCID: 1737FD7EEECCAC868C-8042
Media Player Position 1:
Subsystem 1 - Part No SW: 5E0 919 606 HW: 5E0 919 606
Component: ABT_High H60 0030
Serial number: SKZ8Z9PT6007AK
Engine Control Module 2:
Subsystem 2 - Part No SW: V03 959 800 ME HW: -----------
Component: ECE 2015/2016 --- 0123
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001 Serial number: 277400848
Coding: 1233074002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2A51348A4DBE216E23-807E
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000141271
Coding: 0101010001030303000400000100010100
ROD: EV_MFKBoschAU370_AU37.rod
End-------------------------(Elapsed Time: 04:59)--------------------------
Address 09:5Q0 937 086 AA recoded (Long Coding) from 0F511B7642C722FB0FA44086B11C17280808000000000000000000000000 to 0F511B76424722FB0FA44086B11C17280800000000000000000000000000 (73430/790/12345)
