- Feb 6, 2025
- 20
- 6
- Virginia, USA
- C?ID=575390
Took some time this evening to re-run the scans with the three different MAP sensors to compare readings. Significant differences between MAP sensors. I do notice that while completing the scans at idle the data reflects 000 engine RPM. That is not accurate as the engine IS running. Do you know what causes that? I would think I should see engine RPM listed correctly? Otherwise:
Sensor 1 Walker
5168 - Altitude Sensor / Boost Pressure Sensor
P1592 00 [10100111] - Implausible Correlation
Mileage: 235114 km
Date: 2025.02.06.
Time: 09:26:10
Engine RPM: 0.00 /min
Coolant temperature: 36 C
Intake air temperature: 19 C
Voltage terminal 30: 11.800 V
Charge air pressure: actual value: 2637 hPa
Engine status: COENG_READY
_______________________________________________________________________
Sensor 2 OEM
5170 - Manifold Pressure / Boost Sensor (G31)
P0237 00 [10101111] - Signal too Low
Mileage: 235114 km
Date: 2025.02.06.
Time: 08:36:10
Coolant temperature: 29 C
Intake air temperature: 17 C
Voltage terminal 30: 12.040 V
Charge air pressure: actual value: 200 hPa
Readiness: 1 1 0 1 1
___________________________________________________________________________
Sensor 3 SMP
Mileage: 235114 km
Date: 2025.02.06.
Time: 08:58:06
Intake air temperature: -40 C
Voltage terminal 30: 11.920 V
Charge air pressure: actual value: 1182 hPa
5282 - Intake Air Temp. Sensor (G42)
P0113 00 [10100111] - Signal too High
Mileage: 235114 km
Date: 2025.02.06.
Time: 08:58:06
Exhaust gas temperature sensor 4: 52.7 C
Specified value of low pressure exhaust flap: 100.00 %
Actual value of low pressure exhaust flap: 100.01 %
Low-pressure exhaust flap: offset closed: 1.37 %
Low-pressure exhaust flap: status-Bits 0-7: 55
Low-pressure exhaust flap: status-Bits 0-7: 0
Low-pressure exhaust flap: status-Bits 0-7: 12
Low-pressure exhaust flap: status-Bits 0-7: 66
Exhaust flap: actual value: 4300.8 mV
Readiness: 0 0 0 1 1
SUMMARY: what do you all think? trying to learn from you all - It looks to me that sensors 1 & 3 are bad. If the OEM sensor is actually working correctly then we have an underboost problem. Maybe the bypass valve is bad?
Sensor 1 Walker
Mileage: 235114 km
Date: 2025.02.06.
Time: 09:26:10
Sensor 2 OEM
Mileage: 235114 km
Date: 2025.02.06.
Time: 08:36:10
Sensor 3 SMP
Mileage: 235114 km
Date: 2025.02.06.
Time: 08:58:06
Mileage: 235114 km
Date: 2025.02.06.
Time: 08:58:06
