Resolved 2014 Passat TDI - Multiple turbo trouble codes
Resolved
CapnMatt
Virginia, USA
C?ID=575390
Hi everyone.
I'm looking for some guidance on this please.
I've owned my 2014 Passat TDI for several years. I've only really had one issue with it until now. The original issue was related to the MAP sensor. It had became fouled with gunk from an intercooler that needed to be cleaned out. Once the intercooler was cleaned and the sensor replaced the car was OK until now. This issue was only about a year ago.
I am not a mechanic but do know my way around vehicles. I am not super familiar with how turbos work, but have owned diesel tractors - so I do understand their basics.
I have also owned VCDS for a couple years. I do know the basics of how to operate the software but am by no means an expert with it.
I feel I need to mention that the car did a regeneration / clean cycle the night before the issues started. The car started like normal the following morning, but once it got up to speed the check engine and engine management lights came on. The car went into limp mode and the turbo went off line. I pulled the original MAP sensor and inspected the intercooler. The sensor and intercooler appeared clean. I probed the intercooler with a camera and do not see any build up or restrictions.
The codes it is listing are:
P1592 - implausible signal
P0238 - boost sensor signal too high
P0113 - intake air temp
P0234 - turbo overboost condition
I went ahead and purchased a new MAP sensor. It is a Walker automotive brand. It was one of two types available to me. After installing it - it did not fix any of the issues. I went ahead and purchased another sensor - A Standard Motor Products brand. Again no changes by swapping out the sensors. I am wandering if some of my issues could be alleviated by purchasing an OEM Bosch sensor? Regardless I did check the wiring and voltages and did not find any discrepancies. So the original Bosch sensor, nor the two new sensors purchased had no bearing on clearing any of the codes.
I next checked the vacuum and vacuum solenoid. I also did a VCDS test of the solenoid and wastegate. I did notice what appeared to be smooth and full articulation of the turbo wastegate arm.
I also pulled the air intake pipe off and probed with a camera the turbo impeller. The impeller spins, is quiet, and the bearings appear to be fine. There appears to be no issues as the shaft spins freely from what I was able to see.
The vacuum pump seems to be producing enough vacuum.
I believe the P0013 air intake code is related to me removing the air box. It was not one of the original trouble codes.
Below is the VDCS Summary:
I also attempted to run a graph of the turbo pressure. I am including that below as well.
My fear is there is an issue with the turbo internals.
Either that or possibly something with the exhaust? (But their doesn't appear to be any related codes)
I also inspected as many vacuum lines and tubes as I could reach and find no issues.
From what I've researched pulling the turbos on these vehicles requires a lift and is extremely time consuming, and having it done by a shop will possibly cost more than the car is worth.
Please let me know what I am missing and where to turn next.
Thanks in advance
Wednesday,05,February,2025,20:40:09:34255
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: 1VWCN7Axxxxxxxxx License Plate:
Mileage: 235110km-146090mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7Axxxxxxx Mileage: 235110km-146090miles
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9981
Revision: 71H24--- Serial number: CVN: C4051C7CD45710C1
Coding: 001D0012042400008000
Shop #: WSC 04917 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004004
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B2320AFF3EDFC224A9-806E
VINID: 0669D37874431D54C01891C3206340B808
5168 - Altitude Sensor / Boost Pressure Sensor
P1592 00 [01100101] - Implausible Correlation
Mileage: 235113 km
Date: 2025.02.05.
Time: 07:57:05
Engine RPM: 0.00 /min
Coolant temperature: 58 C
Intake air temperature: -40 C
Voltage terminal 30: 12.840 V
Charge air pressure: actual value: 1201 hPa
Engine status: COENG_READY
5169 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [10100111] - Signal too High
Mileage: 235113 km
Date: 2025.02.05.
Time: 08:07:03
Engine RPM: 1956.00 /min
Normed load value: 99.6 %
Vehicle speed: 21 km/h
Coolant temperature: 70 C
Intake air temperature: 23 C
Voltage terminal 30: 14.200 V
Charge air pressure: actual value: 3000 hPa
Engine status: COENG_RUNNING
5282 - Intake Air Temp. Sensor (G42)
P0113 00 [00100100] - Signal too High
Mileage: 235113 km
Date: 2025.02.05.
Time: 07:55:51
Engine RPM: 832.50 /min
Normed load value: 59.6 %
Coolant temperature: 55 C
Voltage terminal 30: 14.040 V
Exhaust gas temperature sensor 4: 98.0 C
Specified value of low pressure exhaust flap: 100.00 %
Actual value of low pressure exhaust flap: 100.01 %
Low-pressure exhaust flap: offset closed: 1.42 %
Low-pressure exhaust flap: status-Bits 0-7: 55
Low-pressure exhaust flap: status-Bits 0-7: 0
Low-pressure exhaust flap: status-Bits 0-7: 8
Low-pressure exhaust flap: status-Bits 0-7: 66
Exhaust flap: actual value: 4300.8 mV
12899 - Boost Pressure Regulation
P0234 00 [00100111] - Limit Exceeded (Overboost Condition)
Mileage: 235113 km
Date: 2025.02.05.
Time: 08:05:16
Engine RPM: 897.50 /min
Normed load value: 26.3 %
Vehicle speed: 7 km/h
Coolant temperature: 63 C
Intake air temperature: 21 C
Voltage terminal 30: 14.100 V
Charge air pressure: specified value: 1026 hPa
Charge air pressure: actual value: 2699 hPa
Air mass: actual value (mg/stroke): 295.2 mg/stroke
EGR Solen.val.: actual value: 48.33 %
Throttle valve adapter: actual value: 100.00 %
Charge air pressure actuator: acknowledgment: 84.41 %
Mean injection quantity: 9.43 mg/stroke
Component: GSG DSG AG6 521 9437
Revision: 05652104 Serial number: 00001311130515
Shop #: WSC 09003 957 00200
VCID: 1471AB13B273D35AEB3-8040
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F549280003A31203E792210042A1100012
VCID: 7EA5E9BBA0FF290A2D7-802A
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0194647317 Dataset Number: 5K0116v____ 560E
Coding: 130C0C
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 34310B93DEB3335A8B3-8060
Part No SW: 561 907 044 AF HW: 561 907 044 AF
Component: Climatronic H03 0606
Revision: 00001K02
Coding: 0030019012
VCID: 5BE3802F13ADDC226A9-800E
9481748 - High Pressure Sensor
B10AE 14 [00001001] - Open or Short to Ground
Reset counter: 46
Mileage: 226230 km
Date: 2024.05.10.
Time: 15:25:24
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [00001001] - Open or Short to Plus
Reset counter: 27
Mileage: 226230 km
Date: 2024.05.10.
Time: 15:25:48
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: E7200E3B983908D4098802012600854800F1A086458015B064806000BC70
VCID: 78A9FFA382DB173A67B-802C
00956 - Key 2
Fault Status: 01100101
Reset counter: 46
Mileage: 226230 km
Date: 2018.10.01.
Time: 15:25:03
Voltage: 12.15 V
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM03YMFO Dataset Number: 560003v__A_ 0126
Coding: 00004D4A
Shop #: WSC 24035 003 1048576
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B7F69795496A527CD-8020
Serial number: 6940000Y130001149N09
Coding: 303047
Serial number: 3572MSME6A6E227EZZZB
Serial number: 3582MSME4109347EZZZ-
Serial number: 3516KSME05401D29ZZZN
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME1D445829ZZZ-
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME09131F2AZZZZ
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME641C212AZZZX
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20131123201562
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EA5E9BBA07F290A2D7-802A
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 231E01
VCID: 1E65C93B403F890A4D7-804A
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 13011403000042
Coding: 461000
VCID: 7BA3E0AFB3ED3C220A9-802E
_____________________________________________________________________________________________________________________________________
Wednesday,05,February,2025,20:45:28:34255
Address 01: Engine (03L 997 009 J)
20:45:03
IDE00190 Charge air pressure: specified value 1013 hPa
IDE00191 Charge air pressure: actual value 2620 hPa
IDE00362 Charge Pressure Actuator: activation 10.00 %
IDE00396 Charge air pressure actuator: acknowledgment 10.03 %
Westbury, UK
Upon adding code tags it's clear that what you have posted is a partial Auto-Scan since it stops part way through 19.
Please post the complete scan.
Under what conditions was that data obtained? Engine speed, load...?
Let's start real simple
Mileage: 235113 km
Date: 2025.02.05.
Time: 07:57:05
Do you notice anything?
Either the turbo has become a perpetual motion machine, a limitless source of free energy, or ECU is getting a false reading of charge pressure.
That's why I asked what I did in post #3.
Oh I know.... I threw in the towel at the first code... didn't even read the rest of the post\scan.
TL;DR ;)
I'm not the one who needs that link... there's another chap around here who's google is broken... might want to link him ;)
CapnMatt
Virginia, USA
C?ID=575390
Wow thank you for so many responses.
And yes my bad.... I thought I cut and pasted the full scan....
Let me try again. It looks like the bottom was cut off:
Here is the FULL scan with nothing redacted
VIN: 1VWCN7A37EC069738   License Plate:
          52 56 62 72 75 77
VIN: 1VWCN7A37EC069738   Mileage: 235110km-146090miles
                    Mileage: 235113 km
                    Date: 2025.02.05.
                    Time: 07:57:05
                    Mileage: 235113 km
                    Date: 2025.02.05.
                    Time: 08:07:03
                    Mileage: 235113 km
                    Date: 2025.02.05.
                    Time: 07:55:51
                    Mileage: 235113 km
                    Date: 2025.02.05.
                    Time: 08:05:16
   Revision: 00H46001
   Coding: 130C0C
   Revision: 00001K02
   Coding: 0030019012
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:24
                    Reset counter: 27
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:48
   Revision: BL122001
00956 - Key 2
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2018.10.01.
                    Time: 15:25:03
                    Voltage: 12.15 V
   Coding: 00004D4A
   Coding: 303047
   Coding: 000A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2018.10.01.
                    Time: 15:25:08
01304 - Radio
                    Reset counter: 67
                    Mileage: 226230 km
                    Date: 2018.10.01.
                    Time: 15:29:60
   Coding: 000007
   VCID: 6A8DD5EBCCF7B5AAE1F-803E
   Revision: 00000000    Serial number: 13000241245004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 303907832AAB0F7AEFB-8064
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000078574089
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 221DFDCB74C7ADEA69F-8076
Address 37: Navigation
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0007727290
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C61C33356239B1AA33-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630131216135524
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 392F3AA7F551CE32585-806C
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0088526 Dataset Number: 560050v____ 5607
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 2615E1DB186F51CA057-8072
9637138 - Loudspeaker 2 in Double-Subwoofer
          B130D 12 [00001001] - Short to Plus
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:03
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBBC4FFF7955082B61-803A
   Serial number: 53388786011322902379
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0007780813
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67CE374D39921254D-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140110094718
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 189
                    Mileage: 231716 km
Address 56: Radio
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140512
   Coding: 02140102C2423A007F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53F3680F7B7D1462B29-8006
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 27
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:06
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 27
                    Mileage: 235113 km
                    Date: 2025.02.05.
                    Time: 08:13:43
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007664899591 Dataset Number: 5N0035729A  0001
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E0519FB309F198AFD7-807A
9455635 - Telephone Microphone
          B1048 13 [00001001] - Open Circuit
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:02
          B104F 13 [00001001] - Short to GND
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:02
          B104E 13 [00001001] - Short to GND
                    Reset counter: 46
                    Mileage: 226230 km
                    Date: 2024.05.10.
                    Time: 15:25:02
End----(Elapsed Time: 01:18, VBatt start/end: 14.2V/14.1V. VIgn 0.0V)------
CapnMatt
Virginia, USA
C?ID=575390
The full scan was completed during engine idle.
The data specific to charge air pressure actual / specified was from idle up to around 2300 RPM.
Non aggressive acceleration.
I noticed I can clear the codes and the engine management light goes out.
Once I hit somewhere a little over 2000 rpm the computer cuts off the turbo, it goes into limp mode and the engine management light comes back on.
Every time - it isn't intermittent.
Hope this helps and THANK YOU again for your input.
Matt
I'm pretty confident you have a sensor problem, not a problem with the turbo itself.
* There's no possible way to have ~1200 mbar of manifold pressure when the engine isn't running.
* I can't think of any plausible way to have ~2600 mbar of manifold pressure without a load on the engine.
CapnMatt
Virginia, USA
C?ID=575390
Well to my untrained eye I notice two issues. RPM states is zero. I did the full scan at idle.
Also major difference between atmospheric pressure and charge pressure.
CapnMatt
Virginia, USA
C?ID=575390
So to summarize: I'm shooting myself in the foot by purchasing non OEM sensors? I had put that in my original post that I purchased a Walker brand and a SMP off amazon. No auto parts stores around me carried any of these sensors. So are you in agreement I should purchase an OEM MAP? go with Bosch or NKK? any recommendations? Anything else you're picking up on looking at the codes?
CapnMatt
Virginia, USA
C?ID=575390
NAPA has an "Echlin" brand for $99.
Any knowledge of this brand. The napa sight states it is OEM??
Part #: CRB 227084
Line: Echlin Fuel System
Price
$99.99
The FF data is from when the fault took place.
The fact that your engine was at idle or whatever has no relation to the RPM value shown.
The zero RPM confirms that your engine is OFF.
The atmospheric pressure differs from the charge pressure, but the engine is OFF..... so what's pressurizing your system?
This is where the lightbulb in your head goes on and you say, it's impossible.
So, to summarize:
- you don't need a turbo, because the turbo isn't in use when the engine is off, but the fault is there
- you can't have a change in your pipes, because of previous point
- you have a sensor issue (cheap crap as per own admission)
Also, two cheap sensors could be crap, but seems odd.
Swap sensors and check MVBs to see if one reads better than another.
RTFM and you'll know how to test them, if you wish to do that before spending on OEM units.
CapnMatt
Virginia, USA
C?ID=575390
Savagesoot blunt -- simple but brilliant point!! What you say makes 100% sense. Ill compare readings between the sensors. Ill report back either late afternoon or this evening.
