Audi S3 8V PFL side assist FL retrofit
fOomad
France
C?ID=606999
I have a pre-facelift Audi A3 8V that I have modified with a facelift rear bumper.
I want to install blind spot sensors (Side Assist).
I've installed FL sensors (3Q0), but I'm getting a few error messages and so the function is unavailable.
The LEDs in mirrors come on when I start the vehicle or when I do a test with VCDS.
According to this post: https://forums.ross-tech.com/index.php?threads/36746/ i need a BCM ending in AJ, I've just updated my BCM (I had AA before) but that didn't solve the problem.
The only difference I can see is that his Gateway ends in AM whereas mine is M. We both have the HW ending in F.
So I wanted to update to AM but the file is nowhere to be found, in the flash files there are only these:
FL_5Q0907530AD
FL_5Q0907530AF
FL_5Q0907530AG
FL_5Q0907530AJ
FL_5Q0907530K_
FL_5Q0907530N_
FL_5Q0907530Q_
FL_5Q0907530__
How do I know which one can be used for my Gateway?
Perhaps you see another way of solving the problem?
I would also like to know if it is possible to flash an ECU when it has an error code on it?
For the record, I don't have a camera or ACC, the option is only for blind spots, not for lane keeping.
Thanks for help :)
Tuesday,04,February,2025,19:28:48:28804
VIN: WAUZZZ8V0EA059968   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 29 39 3C 42 44 52 55 5F BB BC D6
          D7
VIN: WAUZZZ8V0EA059968   Mileage: 254359km-158051miles
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---    CVN: 8E8F2B5D
   Coding: 02190012032401082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79A8357A595E5A82185-802C
   VINID: 9D196AAAA22601544014924620DAC97DE8
   Revision: 00000000    Serial number: 62423000000137
   Coding: 12F162A224250A750380060641CB2948462450C0608294F7026100748508
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 7BA42F72536268920A9-802E
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001694632 Dataset Number: 8V0909862C
   Coding: 03000004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76B23E46684035FA757-8022
   Humidity sensor: exterior:
   Serial number: 83E8C3C6000000000001
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0137
   Serial number: 00011324001398 Dataset Number: 8V0909514C  0063
   Coding: 04000C46C24106FD43844004001C07A8000C000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005E589E3A840B4A5FB-8054
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130811  041 0580
   Serial number:         130822204837
   Coding: 0A47F7
   Serial number: 21670469
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 28 03 2017  00000113
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231221909091 Dataset Number: 5G0039v__A_ 0002
   Coding: 0000051001
   Shop #: WSC 00028 028 00306
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3A2AEA761CD8919A51F-806E
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R02WVKA Dataset Number: 8V0909602C  0007
   Coding: 98CCC0000C0000005C540000004800000065
   VCID: 4BC4BFB243421812FA9-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 408 13
   Serial number: 35767000000745881D0V
   Subsystem 2 - Part No SW: -----------    HW: 480 001 408 13
   Serial number: 35867000000352C88D0.
   Subsystem 3 - Part No SW: -----------    HW: 480 403 008 13
   Serial number: 3516502991088B1260C3
   Subsystem 4 - Part No SW: -----------    HW: 480 403 008 13
   Serial number: 3526502991088B14301Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 908 13
   Serial number: 3556502C710EDE4350DQ
   Subsystem 6 - Part No SW: -----------    HW: 480 401 908 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502A310EDE41B1BM
   Subsystem 7 - Part No SW: -----------    HW: 480 401 908 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B710EDE42D08R
   Subsystem 8 - Part No SW: -----------    HW: 480 401 908 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502B51088B13611V
   Part No SW: 8V0 953 521 B    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 03091308490038 Dataset Number: ----------
   Coding: A418
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 3928F57A19DE9A82585-806C
   Part No SW: 8V0 920 870 H    HW: 8V0 920 870 H
   Component: KOMBI         H03 2212
   Coding: 07A509002B8800080304AA08400000
   VCID: 40DE989E7A04CB4A1FB-8014
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000952340 Dataset Number: 8V0909515C  0044
   Coding: 030100040B0876005B000248080B00000001000000000000000000000000
   GVL: 01543C0000000000404C10000000480000000000000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B24EF7213E2A8924A9-806E
   Generator:
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051867310
8782084 - Tiptronic Downshift Switch/Paddle in Steering Wheel
          B114E 96 [00001001] - Component Internal Failure
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:56
                    Terminal 30 power supply: 14.3 V
                    Terminal 15: On
8782085 - Tiptronic Upshift Switch/Paddle in Steering Wheel
          B114F 96 [00001001] - Component Internal Failure
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:56
                    Terminal 30 power supply: 14.5 V
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0016
   ASAM Dataset: EV_LCMLeftCONTIAU426 001008
   VCID: 42DA92967408D95A09F-8016
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   ASAM Dataset: EV_LCMRightCONTIAU426 001008
0610 - LED Turn Signal Lights
          C11BF F1 [00001001] - Current Coding Implausible
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:55
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------    Dataset Number: 8V0909535G  0006
   Coding: 000003
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:55
                    Control Module temperature: 48 °C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 14.20 V
1188161 - Databus
          [databus message missing ESP]
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:55
1183998 - Databus
          [databus message missing - Personalisierung_01]
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:55
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 07101304080671 Dataset Number: 8V0909872D  0027
   Coding: 001C86205C00040000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 3FDC9B6207FAB4B2661-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Dataset Number: 8V0909852F  0015
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D20E16A0DF6A6A274D-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 24051303110769 Dataset Number: 8V0909873D  0024
   Coding: 001C86205E00040000001000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3E22E66600F0BDBA6D7-806A
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       H01 0234
   Coding: 0ECA00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 864 B    HW: 8V0 035 864 B
   Component: MU-S-N-ER     040 0420
   Serial number: A3F00309131403 Dataset Number: 8V1909545B  0032
   Coding: 01730301FF0A000021110001000A00002F0002440100010006
   Shop #: WSC 17873 123 50804
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   Subsystem 1 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000010071300020300
5716 - Mechanism for Mulimedia Display Unit 1
          B1401 13 [00001001] - Open Circuit
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:55
                    Voltage terminal 30: 14.4 V
6660 - No Communications with Display Unit 1 for Multimedia
          U10E2 00 [00001001] - -
          [Display 1: no signal/communication]
                    Reset counter: 84
                    Mileage: 254359 km
                    Date: 2025.02.04
                    Time: 18:52:58
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 25071301100114 Dataset Number: 8V0909897B  0012
   Coding: 000C86200000040000001000
   ROD: EV_DCURearDriveMAXKLO.rod
   VCID: 41D89D9A710EC242105-8014
   Component: TSG HBFS      010 0006
   Serial number: 25071302090115 Dataset Number: 8V0909896B  0012
   ROD: EV_DCURearPasseMAXKLO.rod
   Dataset Number: 8V0909471D  0007
   VCID: 176C13C24F0AACF28E1-8042
   Dataset Number: 8V0909472D  0007
End----------(Elapsed Time: 01:40, VBatt start/end: 14.4V/14.4V)-----------
fOomad
France
C?ID=606999
I hadn't really noticed that.
It's the slave of 3C, I thought it was going to activate itself, because the 3C module activated itself, I didn't need to go and activate it in the installation list.
I'll go and activate it.
fOomad
France
C?ID=606999
I've just activated it and it doesn't appear ‘No communication’.
The modules were bought second-hand but both came from the same vehicle.
I've followed the ElsaWin wiring, which should normally be correct. I'll have to check.
But if it wasn't wired correctly, the LEDs in the mirrors wouldn't work? Each LED is connected to a different module.
fOomad
France
C?ID=606999
I've just found my wiring diagram... And I've just realized that I forgot to put the wires connecting the 2 modules ..... :facepalm:
fOomad
France
C?ID=606999
Thanks my friend, I'll take care of it this weekend and come back to let you know what happens :)
Good night
fOomad
France
C?ID=606999
I've reconnected the modules properly, and CF is now displayed :)
I still had the 2 errors on 3C
1188161 - Databus
and
1183998 - Databus
I flashed the gateway with AJ and one of the errors disappeared but there's still this:
1188161 - Databus
Do you have any ideas?
I enclose a new scan and the adaptations of 09, 19 and 3C.
Saturday,08,February,2025,18:04:38:28804
Scan: 01 03 08 09 10 15 16 17 19 29 39 3C 42 44 52 55 5F BB BC CF
          D6 D7
VIN: WAUZZZ8V0EA059968   Mileage: 254465km-158117miles
   Coding: 0A47F7
   Coding: 00006C
   Coding: 0000051001
   Coding: A418
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1244
   Coding: 030100040B0876005B0002681C0B00000000000000000000000000000000
   GVL: 01543C0000000000404C10000000480000040000000000000000000000000000
   ROD: EV_GatewLear_013.rod
   Generator:
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:55:17
                    Terminal 15: On
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:55:17
                    Terminal 30 power supply: 14.6 V
                    Terminal 15: On
1025 - invalid data record
          B2005 00 [00001001] - -
          [ungültiger Datensatz: Funktion "Fahrprofilauswahl"]
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:55:17
                    Terminal 15: On
1548 - Data Set Implausible
          B2012 00 [00001001] - -
          [unplausibler Datensatz: Funktion "Müdigkeitserkennung"]
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:55:17
                    Terminal 15: On
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:17:05
   Coding: 000003
1188161 - Databus
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:56:12
                    Control Module temperature: 47 °C
   Coding: 81
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:17:05
                    Voltage terminal 30: 12.0 V
                    Reset counter: 89
                    Mileage: 254465 km
                    Date: 2025.02.08
                    Time: 17:17:07
                    Voltage terminal 30: 11.9 V
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 000003
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 382EF07E22D4838AA7B-806C
End----------(Elapsed Time: 01:43, VBatt start/end: 14.5V/14.3V)-----------
09 :
    SW:5Q0-937-084-AJ   HW:5Q0-937-084-AA ---  Cent. Elect.
    Component:BCM MQBAB H   H14 0137, Coding:04000C46C24106FD43844004001C07A8000C000000000000000000000000
    EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    Saturday,08,February,2025,18:07:04:28804
    VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,1000 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1000 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,1000 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,1000 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1000 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,12
IDE01550-Service position,133.20 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,4
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,3
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,100 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,90 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,100 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.25 °,14
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,OFF ,14
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,90 °,14
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,14
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,32.00 km/h,14
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.25 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,1.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,separate ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,6400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,20 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,driver door contact thatcham ,4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,1 Alarm ,4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,not active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,active ,8
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,37 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,41 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1C ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,00 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,100 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,100 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,127 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,127 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,127 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,30 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,30 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,127 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,100 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,30 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,30 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,100 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,100 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,127 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,127 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,127 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,100 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,100 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,127 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,30 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,30 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,100 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,100 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,1E ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,1F ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,03 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,04 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,not active ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,not active ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,not active ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,39 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,39 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,46 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,6 - LED Lichtmodul ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,6 - LED Lichtmodul ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,46 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,46 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,30 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,20 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,26 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,45 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,46 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,8 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,8 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,8 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,3 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,5 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,30 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,3 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,5 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,30 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,9 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,10 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,30 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,30 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,30 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,9 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,20 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,20 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,10 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,63 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,6 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,7 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,6 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,7 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,560
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,560
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,10 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.00 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.00 °C,24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten,not active ,8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM,active ,8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten,active ,8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert,90 %,8
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag,Daytime running lamps ,4
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,4
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,4
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,21.20 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,not active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,8
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,8
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,8
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,8
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,8
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,8
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,8
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,8
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,8
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,8
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,8
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,8
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,8
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,8
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,8
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,8
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,8
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,8
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,8
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,8
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,8
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,8
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,800 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,not installed ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,not installed ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,active ,4
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time,No Response From Subnet Component,4
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function,No Response From Subnet Component,4
IDE09377-IDE03007-Multi contour seat driver's side-Component location,No Response From Subnet Component,4
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time,No Response From Subnet Component,4
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function,No Response From Subnet Component,4
IDE09378-IDE03007-Multicontour seat passenger side-Component location,No Response From Subnet Component,4
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,4
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,4
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,4
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,not installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,18.20 °,2
IDE10299-Alternating park position 2,21.20 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
MAS05055-lower turn position,26.20 °,2
MAS05056-upper turn position,166.20 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,No Response From Subnet Component,60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,No Response From Subnet Component,60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,No Response From Subnet Component,60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,No Response From Subnet Component,60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,No Response From Subnet Component,60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,No Response From Subnet Component,60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,No Response From Subnet Component,60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,No Response From Subnet Component,60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,No Response From Subnet Component,60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,No Response From Subnet Component,60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,No Response From Subnet Component,60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,No Response From Subnet Component,60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,No Response From Subnet Component,60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,No Response From Subnet Component,60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,No Response From Subnet Component,60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,No Response From Subnet Component,60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,No Response From Subnet Component,60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,No Response From Subnet Component,60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,No Response From Subnet Component,60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,No Response From Subnet Component,60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,No Response From Subnet Component,60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,No Response From Subnet Component,60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,No Response From Subnet Component,60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,No Response From Subnet Component,60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,No Response From Subnet Component,60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,No Response From Subnet Component,60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,No Response From Subnet Component,60
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,11
ENG125594-ENG125682-Driver_failure_detection_multi-contour_seat-s_GrobleckerkennungDauer,No Response From Subnet Component,11
ENG125594-ENG125680-Driver_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,11
ENG125594-ENG125681-Driver_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,11
ENG125594-ENG125678-Driver_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,11
ENG125594-ENG125679-Driver_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,11
ENG125588-ENG125667-Driver_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125666-Driver_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125668-Driver_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125673-Driver_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125672-Driver_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125674-Driver_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125670-Driver_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125669-Driver_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125671-Driver_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125676-Driver_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125675-Driver_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125677-Driver_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125664-Driver_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125663-Driver_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125665-Driver_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125667-Driver_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125666-Driver_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125668-Driver_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125673-Driver_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125672-Driver_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125674-Driver_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125670-Driver_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125669-Driver_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125671-Driver_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125676-Driver_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125675-Driver_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125677-Driver_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125664-Driver_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125663-Driver_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125665-Driver_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125667-Driver_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125666-Driver_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125668-Driver_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125673-Driver_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125672-Driver_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125674-Driver_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125670-Driver_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125669-Driver_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125671-Driver_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125676-Driver_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125675-Driver_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125677-Driver_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125664-Driver_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125663-Driver_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125665-Driver_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125667-Driver_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125666-Driver_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125668-Driver_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125673-Driver_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125672-Driver_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125674-Driver_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125670-Driver_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125669-Driver_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125671-Driver_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125676-Driver_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125675-Driver_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125677-Driver_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125664-Driver_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125663-Driver_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125665-Driver_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125667-Driver_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125666-Driver_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125668-Driver_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125673-Driver_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125672-Driver_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125674-Driver_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125670-Driver_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125669-Driver_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125671-Driver_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125676-Driver_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125675-Driver_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125677-Driver_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125664-Driver_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125663-Driver_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125665-Driver_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125667-Driver_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125666-Driver_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125668-Driver_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125673-Driver_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125672-Driver_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125674-Driver_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125670-Driver_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125669-Driver_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125671-Driver_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125676-Driver_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125675-Driver_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125677-Driver_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125664-Driver_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125663-Driver_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125665-Driver_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125596-ENG125687-Driver_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,11
ENG125596-ENG125689-Driver_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125685-Driver_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,11
ENG125596-ENG125688-Driver_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125686-Driver_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,11
ENG125595-ENG125684-Driver_pressure_values_multi-contour_seat_driver-s_DruckschwelleNachlauf,No Response From Subnet Component,11
ENG125595-ENG126855-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126854-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126856-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126857-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG126863-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,11
ENG125595-ENG126862-Driver_pressure_values_multi-contour_seat_driver-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,11
ENG125595-ENG126859-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126858-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126860-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126864-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_Massage,No Response From Subnet Component,11
ENG125595-ENG126861-Driver_pressure_values_multi-contour_seat_driver-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG125683-Driver_pressure_values_multi-contour_seat_driver-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,11
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,6.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,6.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,16.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,30.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,60.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG126651-ENG115658-Kennlinie Abdimmen-x0,No Response From Subnet Component,10
ENG126651-ENG101574-Kennlinie Abdimmen-X1,No Response From Subnet Component,10
ENG126651-ENG115664-Kennlinie Abdimmen-x10,No Response From Subnet Component,10
ENG126651-ENG99557-Kennlinie Abdimmen-X2,No Response From Subnet Component,10
ENG126651-ENG102140-Kennlinie Abdimmen-X3,No Response From Subnet Component,10
ENG126651-ENG102936-Kennlinie Abdimmen-X4,No Response From Subnet Component,10
ENG126651-ENG103548-Kennlinie Abdimmen-X5,No Response From Subnet Component,10
ENG126651-ENG113992-Kennlinie Abdimmen-X6,No Response From Subnet Component,10
ENG126651-ENG115661-Kennlinie Abdimmen-x7,No Response From Subnet Component,10
ENG126651-ENG115662-Kennlinie Abdimmen-x8,No Response From Subnet Component,10
ENG126651-ENG115663-Kennlinie Abdimmen-x9,No Response From Subnet Component,10
ENG126651-ENG115659-Kennlinie Abdimmen-y0,No Response From Subnet Component,10
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,No Response From Subnet Component,10
ENG126651-ENG115668-Kennlinie Abdimmen-y10,No Response From Subnet Component,10
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,No Response From Subnet Component,10
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,No Response From Subnet Component,10
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,No Response From Subnet Component,10
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,No Response From Subnet Component,10
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,No Response From Subnet Component,10
ENG126651-ENG115665-Kennlinie Abdimmen-y7,No Response From Subnet Component,10
ENG126651-ENG115666-Kennlinie Abdimmen-y8,No Response From Subnet Component,10
ENG126651-ENG115667-Kennlinie Abdimmen-y9,No Response From Subnet Component,10
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,100 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37 ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,100 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41 ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,127 ,16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,127 ,16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,127 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Daytime running lamps ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Coming Home oder Leaving Home aktiv ,16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,Parking light right ,16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,100 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Coming Home oder Leaving Home aktiv ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,8 - allgemeine Glühlampe 12W ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,8 - allgemeine Glühlampe 12W ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,30 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,30 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,100 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,30 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Daytime running lamps ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,30 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,30 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,100 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,30 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lamps ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,100 ,16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,100 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,Blinken links aktiv (beide Phasen) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,100 ,16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,100 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,03 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,46 - LED Kleinleistung ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Ambientelicht 1 ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,04 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,46 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Ambientelicht 2 ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG125607-ENG126865-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,12
ENG125607-ENG126867-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,12
ENG125607-ENG126866-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,12
ENG125607-ENG126868-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,12
ENG125607-ENG125690-Passenger_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,12
ENG125604-ENG125693-Passenger_failure_detection_multi-contour_seat-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,12
ENG125604-ENG125680-Passenger_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,12
ENG125604-ENG125681-Passenger_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,12
ENG125604-ENG125678-Passenger_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,12
ENG125604-ENG125679-Passenger_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,12
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,12
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,12
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125667-Passenger_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125666-Passenger_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125668-Passenger_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125673-Passenger_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125672-Passenger_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125674-Passenger_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125670-Passenger_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125669-Passenger_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125671-Passenger_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125676-Passenger_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125675-Passenger_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125677-Passenger_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125664-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125663-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,12
ENG125603-ENG125665-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,12
ENG125606-ENG125687-Passenger_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,12
ENG125606-ENG125689-Passenger_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,12
ENG125606-ENG125685-Passenger_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,12
ENG125606-ENG125688-Passenger_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,12
ENG125606-ENG125686-Passenger_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,12
ENG125605-ENG126871-Passenger_pressure_values_multi-contour_seat-s_Druckschwelle_Nachlauf,No Response From Subnet Component,12
ENG125605-ENG126855-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_m,No Response From Subnet Component,12
ENG125605-ENG126854-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_o,No Response From Subnet Component,12
ENG125605-ENG126856-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_u,No Response From Subnet Component,12
ENG125605-ENG126857-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,12
ENG125605-ENG126863-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,12
ENG125605-ENG126870-Passenger_pressure_values_multi-contour_seat-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,12
ENG125605-ENG126859-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_m,No Response From Subnet Component,12
ENG125605-ENG126858-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_o,No Response From Subnet Component,12
ENG125605-ENG126860-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_u,No Response From Subnet Component,12
ENG125605-ENG126864-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Massage,No Response From Subnet Component,12
ENG125605-ENG126869-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,12
ENG125605-ENG125683-Passenger_pressure_values_multi-contour_seat-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,12
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,8
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,8
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,8
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,8
19 :
    SW:5Q0-907-530-AJ   HW:5Q0-907-530-F ---  CAN Gateway
    Component:GW MQB High   125 1244, Coding:030100040B0876005B0002681C0B00000000000000000000000000000000
    EV_GatewLear,013020,EV_GatewLear_013.rod
    Saturday,08,February,2025,18:06:07:28804
    VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
    VCID: 79A8357A595E5A82185-802C
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,Not coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,coded ,32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,Not coded ,32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer, ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number, ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start/stop function,Mode not active ,1
IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,384
IDE06425-MAS06026-Dynamometer mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Dynamometer mode: functional-Malfunction states,No malfunction ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE08624-MKE Check box,not activated ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,40 ,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,10000 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,2000 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,10000 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118779-IDE02583-Multi_function_steering_wheel_control_module Coding Value-Steering wheel Tiptronic switch,No Response From Subnet Component,12
ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Variant,No Response From Subnet Component,12
ENG118779-MAS09758-Multi_function_steering_wheel_control_module Coding Value-Temperature sensor,No Response From Subnet Component,12
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,No Response From Subnet Component,12
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,No Response From Subnet Component,12
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
3C :
    SW:3Q0-907-566-F   HW:3Q0-907-566 ---  Lane Change
    Component:MRR1Rear      H21 0610, Coding:000003
    EV_RearRadarS1BoschVW48X,001007,EV_RearRadarS1BoschVW48X_AU37.rod
    Saturday,08,February,2025,18:05:29:28804
    VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
    VCID: 3B24EF7213E2A8924A9-806E
IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning,not active ,3
IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,1
IDE05394-Brightness characteristic of warning display,Bright ,1
downtime
Finland
C?ID=280813
Did you code RCTA to ABS? Byte 29 bit 7 if I remember correctly
fOomad
France
C?ID=606999
I can't, I've got code 31
iichel
Netherlands, Operation Market Garden
C?ID=284912
so 12F162A224250A750380060641CB2948462450C0608294F7026100748508 to 12F162A224250A750380060641CB2948462450C0608294F7026100748588
fOomad
France
C?ID=606999
Yes, that's the code I entered, but it's been rejected ☹️
Do I need to change the ABS pump?
fOomad
France
C?ID=606999
I saw that it wasn't very expensive, at 20 euros there are plenty of second-hand ones but changing this one for an A3 8V seems complicated. I've had a look under the bonnet and the ABS pump is stuck, do you have to remove the DFP to get the pump out?
downtime
Finland
C?ID=280813
On diesels yes. Unless you can access it behind the wheel arch.
fOomad
France
C?ID=606999
I just saw the technical review on Elsawin, apparently i have to go underneath... Well I know what I have to do, I'll come and update here once I've changed the pump. Thanks to all :)
