VW GOLF MK7 U0428 U0212 U140A P068A U0212 B1168 MULTI LAMPS ON DASH NO STEERING WHEEL FUNCTION BUTTONS
gogomotors
Barnstaple, UK
C?ID=214637
HOPE THIS HELPS. WE HAD THIS MK7 GOLF IN DUE TO THE ISSUES WE NEW IT WOULD BE A BROKEN CLOCK SPRING BUT ALSO SUSPECTED A SQUIB UNIT AS SO MANY OTHER FAULTS AND COMMS SEE DETAILS BELOW, BUT AFTER FIXING THE CLOCK SPRING ALL OTHER ISSUES RESOLVED . WITH THIS WE HAD TO RESET STEERING ANGLE AND JUST FOR REFERENCE WE DID THIS WITH ENGINE RUNNING THE COMPUTER SAYS RUNNING BUT DID NOT RESET WE HAD TO CYCLE IGNITION THEN ALL THE LAMMPS WENT OUT AND THE CAR SORTED.
Tuesday,28,January,2025,13:48:38:41533
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZAUZFP508085   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP508085   Mileage: 154363km-95916miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7545
   Revision: 83H22---    CVN: 85F484AE
   Coding: 111D0032036505082000
   Shop #: WSC 00028 028 00075
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AFBE25EFD7D644685-802E
   VINID: 9E69EAAAA465A9680500800814D9DDA23D
          U0428 00 [00100000] - -
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:28
                    Engine RPM: 0.00 /min
                    Coolant temperature: 65 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 12.160 V
                    Unlearning counter according OBD: 7
4714 - Steering Column Control Module
          U0212 00 [00101111] - No Communications
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 09:12:28
                    Coolant temperature: 76 °C
                    Intake air temperature: 61 °C
                    Voltage terminal 30: 11.880 V
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
17262 - Terminal 30
          U140A 00 [00100000] - Open Circuit
                    Vehicle speed: 255 km/h
                    Intake air temperature: -40 °C
                    Voltage terminal 30: 12.440 V
                    Limitation: torque: 0.0 Nm
                    Accelerator pedal travel: raw value: 0.00 %
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.00 %
4629 - ECM Power Relay Load Circuit
          P068A 00 [00100000] - Opens Too Early
                    Coolant temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
   Part No SW: 0D9 300 041 P    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4507
   Revision: 03252204    Serial number: TFK01405200068 CVN: 000092A8
   Shop #: WSC 00028 028 00066
   ROD: EV_TCMDQ250021.rod
   VCID: 2541E12224433BBE98-8070
21222 - Steering Column Control Module
          U0212 00 [00001011] - No Communications
                    Fault Frequency: 137
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 09:12:29
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61514000000978
   Coding: 04FA8AA1242009740377060841C82920512490C0608294F3F862507AC202
   Shop #: WSC 00028 028 00240
   VCID: 468346AEF905D0A6B1-8012
0297 - Steering angle sensor
          B1168 16 [00001000] - Voltage Too Low
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:29
          C1146 02 [00001000] - Signal Failure
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:38
16401 - Tire Pressure Warning
          C102D 00 [10001001] - -
                    Reset counter: 210
                    Mileage: 154064 km
                    Date: 2025.01.21
                    Time: 13:13:42
32948 - Comfort limitation
          C10D7 00 [00001000] - -
                    Reset counter: 228
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08    Dataset Number: 0000
   Coding: 02120104202100011005000000101000
   VCID: 73E5CF7ADA17150EC6-8026
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
                    Fault Frequency: 26
                    Reset counter: 2
                    Mileage: 153561 km
                    Date: 2025.01.09
                    Time: 08:21:57
                    Voltage terminal 30: 13.8 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 2
                    Auxiliary heater: in stages-Act.val.: 2
                    Auxiliary heater: in stages-Target value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [00001000] - -
                    Fault Frequency: 26
                    Reset counter: 4
                    Mileage: 153561 km
                    Date: 2025.01.09
                    Time: 08:26:24
                    Voltage terminal 30: 13.7 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 3
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 15:30:46
                    Voltage terminal 30: 10.8 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580406141366 Dataset Number: 5G9063v____ 0001
   Coding: 03001846C24102FB0BA44080B11C07281000000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79F9FD52F87B6F5E8C-802C
   Component: WWS    140508  042 0551
   Serial number:         140521054706
   Component: RLFS  024 0042
   Serial number: Y14M06D12H05M31S26S6
   Coding: 00A8DD
   Serial number: 000000000ZY141182QL3
   Serial number: 00000000000059791571
   Humidity sensor: interior:
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431414100395 Dataset Number: 5G0039v__B_ 0078
   Coding: 0131061051
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 428B5ABED52DEC869D-8016
1112852 - Side Front Right Parking Aid Sensor
          B10FB 14 [00001000] - Open or Short to Ground
                    Reset counter: 6
                    Mileage: 154178 km
                    Date: 2025.01.24
                    Time: 12:15:06
13637426 - Databus
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:29
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 04061403210743 Dataset Number: 5g0114v____ 1017
   Coding: 001C1300FE0739
   VCID: 387F385683F1B65633-806C
1058 - Databus
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:29
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:29
1078 - Databus
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:30
0269 - Databus
                    Reset counter: 188
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 09:12:30
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 11.7 V
1043 - Automatic Distance Control
          B10E7 F0 [00001001] - Disconnected
                    Reset counter: 218
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 09:12:30
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR063095 Dataset Number: 5G0003v____ 0094
   Shop #: WSC 00028 028 00054
   VCID: 7F0D134AE65F416EB2-802A
   Left seat belt tensioner:
   Serial number: 34169677B04061440410
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676B04061471258
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 805 14
   Serial number: 357670000002B775EF03
   Subsystem 4 - Part No SW: -----------    HW: 480 000 206 14
   Serial number: 3586700000023DCCDF0D
   Subsystem 5 - Part No SW: -----------    HW: 480 400 206 14
   Serial number: 3516502C315C421421F+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 206 14
   Serial number: 3526502C315C4214A0E5
   Subsystem 7 - Part No SW: -----------    HW: 480 402 605 14
   Serial number: 3556502AB156EA0220AB
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 09:08:40
1050117 - Databus
                    Reset counter: 228
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:02:30
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20130812400086
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F8D534AA6DF816EF2-806A
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         204 4270
   Coding: 27A411082790260001886A011400000000000000
   VCID: 66C3A62E99C5F0A651-8032
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 26051410802237 Dataset Number: 5G0067v____ 1821
   Coding: 030100040B087300EF00025C1C0F00010001050000000000000000000000
   GVL: 01543C0000000000400C80000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   Generator:
   Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Serial number: 3561053603
197169 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
                    Reset counter: 221
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 09:12:35
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000105915653  Dataset Number: 5G0222v____ 0058
   Coding: 003B0220D001028000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 44875CA6CF39E2B6AF-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005591670
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  122 1043
   Dataset Number: 5G0074v____ 0354
   Coding: 8303
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 418955B2D02BF79E84-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000105652333  Dataset Number: 5G0157v____ 0055
   Coding: 003B0020DE01028000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 43855FBACA37E58E96-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005586870
   Coding: 050000
65654 - Motor for mirror fold-in
          B11F6 13 [00001001] - Open Circuit
                    Fault Frequency: 8
                    Reset counter: 216
                    Mileage: 153544 km
                    Date: 2025.01.08
                    Time: 00:24:03
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    041 0430
   Serial number: V7F00206143170 Dataset Number: 5G0CV1v____ 0001
   Coding: 02730201FF00000021111201000800001F0100060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 67DDAB2A9ECFE9AE6A-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS401K8Q
   Subsystem 2 - Part No SW: 5G0 919 866 AF    HW: -----------
   Component:  ECE 2017/18  --- 0067
6145 - Display and Control Head 1 for Information Electronics
          B129E 07 [00001001] - Mechanical Failure
                    Reset counter: 196
                    Mileage: 153769 km
                    Date: 2025.01.12
                    Time: 10:08:22
                    Voltage terminal 30: 13.4 V
End-------------------------(Elapsed Time: 04:16)--------------------------
Address 01: DTCs cleared
Address 16,5Q0 953 521 P,recoded (Long Coding),from,0400,to,0400,(01357/011/00200),
Address 02: DTCs cleared
Address 19: DTCs cleared
Address 15: DTCs cleared
Gateway Installation List: 5Q0 907 530 T
Are you looking for help with anything or is this just an informational post?
