/// Malfunction 0010 /// ABS, Cent. Elect., CAN Gateway, Central Conv, Parking Brake, Information Electric
raceshop147
Connecticut
C?ID=559829
I am reaching out to inquire if anyone has insights into the root cause of Malfunction 0010, which I encountered for the first time today. The fault codes include:
ABS
• Central Electronics
• CAN Gateway
• Central Convenience
• Parking Brake
• Information Electric
This is the 10th scan I have performed, and these issues appeared for the first time today. I am unsure of their origin and would appreciate any guidance on how to reset, clear, or resolve these faults. Could it be related to the battery or possibly the MMO requiring a reset?
I have attached the scan data below for your reference.
Thank you in advance for your support. I look forward to your advice.
Best regards,
Nick
Monday,03,February,2025,16:29:05:39951
VIN: WAUDGAFL0FA014811   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUDGAFL0FA014811   Mileage: 193630km-120316miles
08-Auto HVAC -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---    CVN: 96197FE3
   Coding: 0A190034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS021_AU48.rod
   VCID: 3A2D236C0CD6592A51F-806E
   VINID: 9D19545D159C016440044201040B430CE7
Readiness: 1110 1101
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 281D1A01
   Shop #: WSC 06325 000 00000
   VCID: 094F8CA0193082B2085-805C
                    Fault Status: 00101101
                    Reset counter: 213
                    Mileage: 193518 km
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x001A
                    Hex Value: 0x099A
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 0F814040000000000000
   VCID: 04519D943E12DFDA7B3-8050
   Subsystem 1 - Part No SW: 8K0 959 754 BB    HW: 8K0 959 754 BB
   Serial number: 0814000086284002
   Serial number: 0214000108797008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01130620142186
   Coding: 6600228000
   VCID: 77ABFA587FC484426E1-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000838730601
   Coding: 26000035853CAFE0240249C300003D0DCF9C9308A2090221000008004000030100000030000000
   Shop #: WSC 06325 123 12345
   VCID: 78A9F96472DA8B3A67B-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA280414  H18 0461
   Serial number: 1404250701566
   Coding: 004577
   Serial number: 22759946
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000506141794
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R96EA03
   Serial number: 03484337000000000001
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:21:26
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD124HC2   Dataset Number: 8K0909602R  0001
   Coding: 303844354730383131304A55304C384B3053
   Shop #: WSC 56311 001 1048576
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4BC376A8534CD0A2FA9-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000GRPC
   Serial number: 6334MSME457A4027C
   Serial number: 6344MSME45393349E
   Serial number: 6352QSME7740485AM
   Serial number: 6362QSME30452050/
   Serial number: 63732SME63410944U
   Serial number: 63832SME32462160O
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NFC000HX
   Coding: 000016
   VCID: 44D15D947E921FDA3B3-8010
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAI7AN96F
   Coding: 83BD09008301D705020000
   VCID: 72BDCB4C14A6E16A59F-8026
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z146120578
   Coding: 80C303FF00
   VCID: 4CC175B456C2D79AF33-8018
   Serial number: 3142063603
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:21:21
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.90 s
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 000306140001035 Dataset Number: 8K0909104D  0025
   VCID: 2F3B0238C7948C82F61-807A
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000105596604
   Coding: 00581B00000000000000
   VCID: 3B232668036C60224A9-806E
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:21:26
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0336289139 Dataset Number: 8K0909535J  0029
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FDB527817F47C02661-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0337550543
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56F597DC980E9D4A557-8002
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H40 0509
   Revision: 00001000    Serial number: 0001646515 Dataset Number: 8K0909852K  0025
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3829396432DA4B3AA7B-806C
   Revision: 00002001    Serial number: 0338032396
   Coding: 0106143A00FA40458330013200000000
   Shop #: WSC 06324 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000849750
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:21:24
   Revision: 00005001    Serial number: 94813030966905
   VCID: 2D071830CD18FE92C4D-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Shop #: WSC 06342 000 00000
   VCID: 55F790D0850896525CD-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000461176
   ROD: EV_ParkiBrake_AU48.rod
131840 - Switch for Electric Parking Brake
          C100C 13 [00001000] - Open Circuit
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:23:03
                    Voltage terminal 30: 12.2 V
                    Internal Fault ID: 34
                    Network management state: Ready for busstat
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: No enabling
                    Status of parking brake button: Open circuit
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
197120 - Indicator Lamp in Controls
          C1014 14 [00001000] - Short to Plus
                    Fault Frequency: 16
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:23:03
                    Internal Fault ID: 57
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Revision: AB001007    Serial number: 156F.0E8022872
   Coding: 020007010000000001
   VCID: 2411FD149ED23FDA1B3-8070
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204FT0EB009331
   Coding: 110200000206E1EF55028B5E00000403140000000000000000
   VCID: 3A2D236C0C56592A51F-806E
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Serial number: A130FL0E3056313
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001896085
   Component: CD-Database  5950
00658 - Control Head
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:22:58
                    Voltage: 12.20 V
                    Fault Status: 00101100
                    Reset counter: 213
                    Mileage: 193518 km
                    Date: 2025.01.31
                    Time: 11:33:10
                    Voltage: 12.40 V
                    Bin. Bits:      011
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59EF9CE0E910B232785-800C
   Revision: --H09---    Serial number: 525PA8-J449148
   Coding: 1000006
   VCID: 382939643E5A4B3AA7B-806C
   Component: TSG HR        H07 0305
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140521202342
   VCID: 72BDCB4C1426E16A59F-8026
That's just the status that the Gateway has for a particular module in the Installation List. That is not a fault per-se. To find out what fault there actually is, you need to go down the scan to the module in question.
Many of the faults in that scan indicate that the Climatronic (HVAC) module is sporadically AWOL. Could be the module itself is dodgy, or there's an issue with power, ground, or the CAN connection to it.
raceshop147
Connecticut
C?ID=559829
Thanks for the clarification! That makes sense—sounds like a deeper look at the Climatronic module and its connections is needed. I'll check the power, ground, and CAN network, and see if there’s anything obvious before considering replacing the module itself. Appreciate the insight!
