We managed to retrofit the Kessey system into a MK6 TDI Golf...
We still have loads of error's in some of the modules.
System at this point only works with the key right next to the start button...
Curious if there are some wiring guro's maybe can look at the error's and tell us what they think might be wired up wrong to the ELV or anything else.
Sunday,06,December,2015,19:56:36:59093
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWPF7AJ3CW345442 License Plate:
Mileage: 139740km-86830mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 1C 25 2B 2E 37 42 44 46 52 56
77
VIN: WVWPF7AJ3CW345442 Mileage: 139740km-86830miles
15-Airbags -- Status: Not registered 0011
Part No SW: 03L 906 019 DA HW: 03L 906 019 DA
Component: R4 2,0L EDC G000SG 9144
Revision: 12H08--- Serial number: 00000000000000
Coding: 0050072
Shop #: WSC 09460 444 999999
VCID: 6D9201D574772B5686-8038
U0155 - 003 - - Intermittent - MIL ON
Fault Status: 10100011
Fault Frequency: 22
Mileage: 139741 km
Date: 2015.12.24
Time: 17:46:07
Temperature: 6.3°C
Voltage: 12.16 V
Bin. Bits: 00000000
Torque: 219.0 Nm
Temperature: 17.1°C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
VCID: 74A414B1D75DFA9E49-8020
Reset counter: 49
Count: 2
Count: 20992
Count: 195
Count: 49408
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0174037823
Coding: 000C0F
ROD: EV_KESSYPQ35G.rod
VCID: 3424D4B19FDDBA9E89-8060
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AH HW: 3C8 907 336 AH
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 73A617ADDA53FDA650-8026
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 89
Mileage: 139741 km
Date: 2015.12.24
Time: 00:00:21
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 L HW: 1K0 937 086 L
Component: BCM PQ35 M 104 0615
Revision: 00104 AE
Coding: 6D180A3BCA272A0400480081100009CC46712080536D8160E48020240040
VCID: 393AE585B0BF47F65A-806C
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 21071 21 0512
Coding: 009795
Component: RLS 010814 05 54 0403
Coding: 0330AD
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35811405801780
Coding: 100001
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 3326D7AD9AD3BDA690-8066
12670224 - Databus
Reset counter: 89
Mileage: 139741 km
Date: 2015.12.24
Time: 00:00:21
12658720 - Databus
Reset counter: 45
Mileage: 139532 km
Date: 2015.12.21
Time: 23:24:05
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00UCXZ
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 393AE585B8BF47F65A-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005BEQ200
Serial number: 3572MSME596C5155ZZZ+
Serial number: 3582MSME49532057ZZZT
Serial number: 3512QSME18415F6FZZZ3
Serial number: 3522QSME3E036964ZZZ.
Serial number: 35527SME504D0223ZZZ5
Serial number: 35627SME0E467D2FZZZ
B1000 1B [136] - Resistance Too High
Mileage: 139532 km
Date: 2015.12.21
Time: 23:22:04
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Fault Frequency: 31
Reset counter: 89
Mileage: 139741 km
Date: 2015.12.24
Time: 00:00:21
12854016 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [009] - -
Reset counter: 45
Mileage: 139532 km
Date: 2015.12.21
Time: 23:22:10
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JGQ000A2
Coding: 108A140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72A812A9A549F4AE5B-8026
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H06 0022
Serial number: 00000000000000423921
Coding: E20000
147462 - Terminal 15
B1148 12 [009] - Short to Plus
Fault Frequency: 44
Reset counter: 49
Mileage: 139532 km
Date: 2015.12.21
Time: 23:29:17
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H03 0406
Coding: 270B01
VCID: 2F2EDBDD76FB9946F4-807A
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
Coding: 270B01
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 230710F2000417
Coding: 69A01F0640161203000000
Mileage: 139741 km
Date: 2015.12.06
Time: 00:24:07
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R9STC06
Coding: 0000002
VCID: 7EB036992911A0CE2F-802A
Component: IMMO H03 0406
Coding: 000007
Shop #: WSC 88979 011 1048576
VCID: 6A980AC98D993C6EE3-803E
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 139741 km
Date: 2015.12.24
Time: 00:02:19
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 12000080888001
Coding: 0100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E10C6D971F1904EFF-807A
1048842 - Terminal 50
B11A4 12 [137] - Short to Plus
Reset counter: 49
Mileage: 139741 km
Date: 2015.12.06
Time: 00:18:31
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668432740
VCID: 271E33FD560BC1063C-8072
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C8 035 684 E
Component: RNS-MID H61 3680
Revision: AB001001 Serial number: VWZ6Z7L5365073
Coding: 04010400010000860005
Shop #: WSC 00020 790 12345
VCID: 2D12C1D574F7EB56C6-8078
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 312ADDA5A8CF8FB6E2-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
000 - - - MIL ON
Fault Status: 11100000
Mileage: 139741 km
Date: 2015.12.06
Time: 00:24:06
Battery Volts: 13.7 V
DU
Temperature: 15.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 3228D2A9ADC9B4AE9B-8066
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666607492
Coding: 0A10040000010100
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D32F195AC977BD676-8068
U0155 00 [008] - -
Reset counter: 89
Mileage: 139741 km
Date: 2015.12.24
Time: 00:01:01
End-------------------------(Elapsed Time: 01:43)--------------------------
