Steering Module Update 2016 S8+
EricVonHa
Philly Burbs, USA
C?ID=31481
Hi, thanks for trying to assist ahead of time! Some background.. "DO NOT DRIVE THE CAR" red death warning. Makes sense, when the module is dead, the car is next to impossible to steer. Got another module (used) from a reputable source of the same part # and suffix.
- I can interrogate both modules (44) and they both have the same label file 4G0-909-144.clb
- The original unit coding is 011001010000
- The new unit coding is 101001010001
- Attempting to re-code the new unit yields "Error 31: Request out of Range"
- It goes without saying, the end-stops cannot be calibrated
As a result, the new module wreaks havoc on a bunch of other modules (air susp, sport diff, ABS, etc.) However, the car is drive-able albeit with most lights on in the cluster, but the steering works.. so keep this in mind when reviewing the below. The car is clean with the original module in place. Inserting the new module causes many errors.
What to do? How to re-code a steering module? Thanks!
Saturday,01,February,2025,17:30:09:45452
VCDS Version: 23.3.1.0
VIN: WUAJ5AFD8GN900246   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 65 6C 6D 6F 72 81 82 85 88 89
          8B 8E 8F 90 A9 BA
VIN: WUAJ5AFD8GN900246   Mileage: 132762km-82494miles
1B-Active Steering -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------DDTA)       Labels:. 079-907-560-CFS2.clb
   Part No SW: 4H0 907 557 H    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0001
   Revision: NCH63---    CVN: 7DCD887F
   Coding: 022A00326546000E3000
   ASAM Dataset: EV_ECM40TFS0114H0907557H 001002
   ROD: EV_ECM40TFS011_AU64.rod
   VCID: 356AA03C94F0FA3B28-8060
   VINID: 9E545A15159421778900008418D1F65639
Readiness: 1110 1101
   Part No SW: 4H1 927 158 FF    HW: 0BK 927 156 AD
   Component: 0BK 40TFSIUSA H19 1006
   Revision: --H19---    CVN: A6E5DB22
   VCID: 79F26C0CF868DE5B8C-802C
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: D2FD82004BBF4100E200
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71E2542CA018961B34-8024
0188 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 2E
                    F-Type: 33
                    Uz: 9C
0679 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 2C
                    F-Type: 2E
                    Uz: 9C
   Part No SW: 4H0 907 064 GD    HW: 4H0 907 064 GD
   Component: BCM2 2.0      H37 0572
   Coding: 0D876F4E000000000000
   VCID: 71E2542CA818961B34-8024
   Serial number: 3215000126642013
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000171538217
   Coding: C018320085043201010001010101112131313333283333
   VCID: 356AA03C9CF0FA3B28-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 688120B85C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D5A885C7CA0B2FB50-8078
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:37
   Part No SW: 4H0 907 063 EB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0367
   Revision: 19020001    Serial number: 00001215215001
   Coding: 01050095043C9FF2F90048C4A00038000098D308AA08022180000894710017000060002D0B0000
   VCID: 6CDC45588F3A7BF307-8038
   Subsystem 1 - Part No SW: 4H1 955 119 D    HW: 4H1 955 119 A
   Component: WWS641 150925  H38 0100
   Serial number:         151026100101
   Coding: 0045F7
   Serial number: 60902456
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 F    HW: 4H0 941 531 F
   Component: E1 - LDS  H01 0044
   Serial number: 02 11 2015  00000152
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z021719C5
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA121418000014967635
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 0B9809D7000000000001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0032
   Serial number: 00000000000000 Dataset Number: 4H0909863E  0038
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002024
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B5E864442B4BCCB4E-807E
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 12.378 V
138752 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:10
                    Voltage terminal 15: 12.379 V
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
   Part No SW: 4H0 959 655 G    HW: 4H0 959 655 G
   Component: Airbag10.43   H63 0093
   Revision: --------    Serial number: 003KC001BYC7 Dataset Number: 4H0909602H  0007
   Coding: 303331323130303231384A55304C34483053
   VCID: 3A70B300BDEE1543C5-806E
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R159250D1C8
   Serial number: 3575HRB404R3N3J88H1K
   Serial number: 3585HRB404P3N3J82GHS
   Serial number: 3515JRB405N3K16078J
   Serial number: 3525JRB405N3K16078P2
   Serial number: 3554VRB4004554Q2H0E
   Serial number: 3564VRB4012555N0GOGG
          B13BC F2 [137] - No function
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:25
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 01335OKD0012M
   Coding: 0004FC
   VCID: 3874A9088BE2075333-806C
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 13 10 2015  G0031216
   Part No SW: 4H0 920 880 R    HW: 4H0 920 880 R
   Component: TBenUSAACCNV- H53 0803
   Revision: 38081206    Serial number: 658131115592009
   Coding: 0B4F0803BF51D705020100
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 3972AC0CB8E81E5BCC-806C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 P    HW: 4H0 919 204 P
   Component: Analoguhr D4  H05 0225
   Serial number: 2151012002684
   Part No SW: 4H0 907 468 AG    HW: 4H0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002043308 Dataset Number: 4H0909515L  0089
   Coding: 80E1034804
   GVL: FF8FEDCCFEEBE8CDD1000000
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 76E86730C976B123E1-8022
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 62306201151911969227
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 090000
   VCID: 3A70B300B5EE1543C5-806E
                    Fault Status: 00100101
                    Reset counter: 194
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:59:00
                    Count: 40
                    Count: 1
                    Hex Value: 0x05CA
                    Hex Value: 0x05CD
                    Hex Value: 0x1399
                    Hex Value: 0x7B00
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:59:00
                    Count: 56
                    Count: 1
                    Hex Value: 0x007A
                    Hex Value: 0x7C1A
                    Hex Value: 0x0000
                    Hex Value: 0xFFFF
                    Reset counter: 194
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:59:00
                    Count: 47
                    Count: 52
                    Hex Value: 0xFA34
                    Hex Value: 0x781A
                    Hex Value: 0x0000
                    Hex Value: 0x0000
   Part No SW: 4H0 857 511 A    HW: 4H0 857 511 A
   Component: FLA           H04 0021
   Revision: AB001001
   Coding: 04018B6B74745D545420363E00
   VCID: 285479485B4297D3A3-807C
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 000111150001005 Dataset Number: 4H0909104C  0033
   VCID: 28547948534297D3A3-807C
0121 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 7
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
0122 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 7
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 7
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
0117 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 47
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:59:00
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 3874A90883E2075333-806C
   Dataset Number: 4H0909553H  0038
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F66925476ACC0EB62-807A
0085 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:10
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:10
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000171536977
   Coding: C0183B0085053201010001010101112131313333203333
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7100SBFD
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H08 0040
   Serial number: 0393415022 Dataset Number: 4H0909535D  0019
   Coding: 040211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 336E9E249A84E40B06-8066
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0040
   Serial number: 0393562358
   Coding: 040211
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000173164746
   Coding: 011F1F005E0062C202003017
   VCID: 4894D9C8FB0277D343-801C
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000069625 Dataset Number: 4H0909852L  0027
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
5258753 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 17:08:09
                    Write only channel
4215041 - Control Module
          C109F 00 [137] - Incorrect Version Installed
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 17:08:09
                    Write only channel
   Revision: 00002001    Serial number: 0384871378
   Coding: 0106063A00FA7185B230C7C0020316000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0081
   Serial number: 00000000000000320419
   Subsystem 3 - Part No SW: 4H0 959 591 B    HW: 8V3 959 591 A
   Component: J245 PS50.402  H03 0004
   Serial number: 0000FST000MPVIO00000
   Coding: 101F00
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H13 0080
   Serial number: A2015000000000855731
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO1000EW3O
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93463591
   Part No SW: 4H1 035 465 B    HW: 4H1 035 465
   Component: BO G3 D4 ANC  H03 0150
   Revision: 11000000    Serial number: 0016797
   Coding: 020101
   VCID: 26487770515681A391-8072
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 01910150030806
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000172749057
   Coding: 011F1F005E0062C202003006
   VCID: 3C7CB518BFDA2B73D7-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001654718 Dataset Number: 4H0909522D  0017
   ROD: EV_ParkiBrake_VW51.rod
   Revision: --------    Serial number: -------------- Dataset Number: 4H0909865F  0021
   Coding: 02720A1122600400
   VCID: 346C9D389F8AE3331F-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00200
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E00200
Address 56: Radio (R)       Labels: None
   Part No SW: 4GD 035 082 G    HW: 4GD 035 082
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 315KY0F2501438
   Coding: 020007010000000001
   Part No SW: 4H0 035 746 L    HW: 4H0 035 746 J
   Component: H-BNT-NA      H43 0949
   Revision: --------    Serial number: 503KT0F7520023
   Coding: 03020000020BFDEF7D12CF1E00000003140001000000000000
   VCID: 3162942C6898D61B74-8064
   Subsystem 1 - Part No: 8R0 060 884 DG
   Component: NAR 2016  1302
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDFY900MCFN
   Subsystem 3 - Part No SW: 4H1 919 600 M    HW: 4H1 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000206829
   Component: CD-Database  6890
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000173165696
   Coding: 010F1F00400062C202003006
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000021968 Dataset Number: 4H0909850C  0008
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A5083404D4EA5C3B5-807E
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0125316
   Coding: 020F000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 307501473 Dataset Number: 4H0909541F  0008
   Coding: 021004C120
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FE65254B62C80EB22-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000197835 Dataset Number: 4F0000000__ U001
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63CE2E646AE4348BB6-8036
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000173165697
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H09 0083
   Revision: 0L0D5015    Serial number: SN151015  0569
   ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4H0 919 617     HW: 4H0 919 617
   Component: HeadUpDisplay H18 0023
   Coding: C20000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 6DDA485CBC2072FB10-8038
   Component: DPC-SG        H27 0081
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547G  0047
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C5C855847BABBF347-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00023847056701 Dataset Number: 4H0909880E  0020
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00023847090301 Dataset Number: 4H0909881E  0020
   Coding: 364FF2
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 29527C4C4848AEDBBC-807C
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:09
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 12.367 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1112 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:10
                    Voltage terminal 15: 12.375 V
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621311157 Dataset Number: 4H0909548K  0035
   Coding: 01C19A030121
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:10
                    Outside temperature: 13.5 °C
                    Voltage terminal 15: 12.6 V
                    Control Module temperature: 22.0 °C
0049 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:26
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 23.0 °C
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:10
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:18
   Component: RGS-VL        H14 0080
   Dataset Number: 4H0909614C  0003
   Coding: 0066F609031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3162942C6098D61B74-8064
   Component: RGS-VR        H14 0080
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 32609B20659EED030D-8066
   Part No SW: 4H0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0003
   Serial number: 151020201714
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813006019401 Dataset Number: 4H0909578B  0014
   ROD: EV_AEMLearAU64X.rod
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 154
                    Mileage: 132762 km
                    Date: 2025.02.01
                    Time: 16:56:13
MasterTommy
Amsterdam
C?ID=295586
Is the part number the same in the scan before and after? Also look at the dataset number (4H0909852L in your current scan).
As MasterTommy implied above......
What is the PN of the original module ?
Dr Sheldon
Windsor UK
C?ID=334979
We need to see some Logic in this process !!
First I do not see a reason to condemn the original J500.
No testing is noted in the thread - Just on a wing and a prayer OP has thrown a new/dubious J500 at the car and is now wondering why his wishes have not come true. Reckless at best !!
Post a scan with the old one connected !
On top of that he has the wrong VCDS for his needs today !!
If this ends well it will be luck but never good judgement !!
Dr Sheldon
Windsor UK
C?ID=334979
Does this belong in Retrofits ??
EricVonHa
Philly Burbs, USA
C?ID=31481
Good find on the dataset #'s:
Old: 4H0909852H 026
New: 4H0909852L 027
Rewind a sec, in troubleshooting the root problem, the original unit was able to be scanned and had position feedback after the rack went full manual with no steering boost. However, it had a "30A open circuit" related to J500. This is a common symptom in these units where the rack goes to full manual Arnold-mode. Audi extended the warranty for 10 years or 125k miles on *most cars. For whatever reason, the S8+ models were excluded even though this hardware model crosses into many many other 4 door sedans.
Effectively, for the logic inclined, the module spins up high-current to a motor and monitors torque and position based on input from the clock-spring G85, etc. If an alternate module allows the rack to function, the first module is dead. Parts bin throw-it-at the problem in effect for good reason. These module failures are widespread with the same error.
Now, back to the software coding and such trying to get a seemingly slightly updated module to be retrograded into the car.
It's obvious the replacement module isn't of the same dataset -- can the re-code be accomplished? I'm stuck at "Error 31: Request out of Range" when attempting a re-code
I'm not sure and it is the weekend for RT staff ; they may be able to check PL24 just to make sure your replacement is compatible here and then advise you on the dataset as I'm not sure VCDS can do that.
I would guess your post will be spotted on Monday. However, others may chime in regarding the dataset question.
MasterTommy
Amsterdam
C?ID=295586
I checked PL24 on his VIN, but got zero results, not even anything close to his part #. I starting to doubt what he had replaced, but the power steering unit that is supposed to be in the car is 4G1 423 055 BJ, which has been superseded by 4G1 423 055 EC.
Dr Sheldon
Windsor UK
C?ID=334979
Old: 4H0909852H 026
New: 4H0909852L 027
4G1 423 055 BJ,
4G1 423 055 EC.
OP ?
WTF ?? Can you explain this mismatch ?
EricVonHa
Philly Burbs, USA
C?ID=31481
The part numbers in the quote are for the entire steering rack. We are only working on the module that plugs into the rack.
The steering control module is a separate part number and is 4G0 909 144 (as listed in the scan).
Still stuck at at "Error 31: Request out of Range" when attempting a re-code. Security log-in is no problem.
Will update VCDS later today and report back.. Thanks for any and all input!
MasterTommy
Amsterdam
C?ID=295586
I figured i missed something somewhere, ill have another look.
EricVonHa
Philly Burbs, USA
C?ID=31481
VCDS has been updated.. same "Error 31: Out of range error" when attempting to re-code the steering module
This is simple stuff. Same physical module part number with a different data set (duh, the out-of-box coding is different for a car with different features).
I suppose the question at this point is.. does VCDS have the capability of re-coding '44' steering modules? HEX-CAN *should be able to do it as this interface has updated other modern-ish UDS modules in the past. Or, should it not?
Going down the rabbit hole, I'm seeing things in alternate universes where .FNF files are being separately flashed to these steering modules.
MasterTommy
Amsterdam
C?ID=295586
Lets start with the fundamentals. What was the part number of the old part?
Didn’t read.
EricVonHa
Philly Burbs, USA
C?ID=31481
Old module won't accept coding either. Part #'s are the same, different datasets obviously, hence the need to "re-code"
Error 31 out of range error from VCDS is still an issue.
What are the chances that the .FNF firmware must match the feature code? I'm thinking at this point that this is the only likely answer.
I found a video from MSG where they hook up these modules to their test rig and they do both (firmware and coding). They use Autel and some unknown firmware flashing tool.
On the hunt for a mobile ODIS service provider. If anyone knows of one near Zip Code 19446, greatly appreciated! This is SE PA.
Thanks again!
Westbury, UK
Coding and dataset loading are quite different things.
EricVonHa
Philly Burbs, USA
C?ID=31481
Yes, hence the request for a mobile ODIS programmer to take care of the issue. VCDS can't touch the .fnf firmware files.
If anyone has ever successfully re-coded a steering module in a D4 or any of the other 15 Audi sub-models that this steering module part is used on -- chime in here, please.
EricVonHa
Philly Burbs, USA
C?ID=31481
Circling back here to advise owners that are desperately seeking to repair their Audi electric power steering on what to do and not what to do.
The original symptom is the red icon of death on the cluster and no steering at all and a VCDS code related to J0500.
Audi has issued a 10 year to 125k mile extended warranty on *most 4-door sedans. However, the S8 Plus models are excluded. Why, no answer other than they were built in a different factory BUT they still have a base rack part number that goes into the A6's so go figure.
Because of the 10 year extended warranty on most cars, this has effectively quashed the aftermarket repair of the electric steering modules and killed a potential brain-trust of the required programming and compatibility.
What to do? There are 3 USA-based repair centers that say that they repair these modules and send your original back to you. Mine was returned to me as a still failed unit with a checksum error so I went on the search for other compatible modules.
The need to find an exact match WITH the DYNAMIC STEERING option is of paramount importance (if your car has dynamic steering). If you contact any of the 3 aforementioned repair centers -- they have no idea if you have dynamic steering or not -- they are merely re-flowing solder into/onto components that *mostly takes care of the dead module syndrome -- but in my case they fubared the original completely. So, none of these companies are mentioned here because they cannot help you in identifying anything about your car's compatibility or incompatibility with various modules. Only one of these companies has a test rack (at time of this writing)
How to find a module with a module with the proper dynamic steering option? First, the engraved part number on the module must be the same and, secondly, the SUFFIX on the DECAL must be the same or be within 2 rev's backward. For example, if your original module decal suffix is "BG" you would need a "BH" or BI" module.
Or, you could contact a European supplier that will take your VIN and send you a module that is *mostly compatible. "Mostly" is the key operative word because the actual programming of the module MUST be on the same level as your ABS, Airbag, Suspension, Sport-Diff and other systems. They all work together and there's no getting around using ODIS (factory tool) and downloading and installing the proper software into the modules to all be compatible together.
ODIS terms the above as "SVM" (Software Versioning Manager) and a high-end tech will know exactly what to do.
VCDS "coding" is entirely another issue. When I received the correct module from Europe, I was able to properly "code" the module to the car. However, the rest of the car systems were still shut down and the cluster was a Christmas tree until my ODIS guru leveled all of the modules onto the same software versions.
Through these processes, I spoke with a couple dealers and attempted to have their service departments and parts guys help me and the best they could do was to "bring the car in" because there's obviously a ton of voodoo going on. USA based dealers do not have the versioning manager parts references. They are accustomed to only replacing the full steering rack and coding and programming from there. This process was always estimated at more than $6k. So, why you are reading this is because, you're like me, dealer = stealer and the right to work on my own stuff is my preference.
My European connection helped tremendously and we got it right on the first try. They remain anonymous because someone needs to start this business in the USA and MASGA (Make Audi Steering Great Again). Seriously, there is next to zero aftermarket support on these steering issues in the USA because of the factory 10 year 125k mile warranty extension. As far as I've been told, this warranty does not exist in Europe and their aftermarket repair and programming resources are exceptional as a result.
I can tell you that there is a Ukrainian company that is able to convert modules to almost any model Audi by writing to the firmware of the modules, they sell a test jig for the modules and have the software to manipulate the programming. Once the first USA repair center is established with their next-level tools, life will be easy. You'll see some of this activity on MHH Auto -- but proceed at your own risk (I never went down this path)
Till then, you have 2 options -- drop it off at the dealer for a $6k repair OR buy several modules as I did until you get the right one. You will still need an ODIS guru to finalize the software.
Through all of this, because of the incompatibilities and module suffix mismatching, if you go through the same thing I went through with VCDS -- you will always get an "Out of Range" error when attempting to code an incompatible module to your existing rack.
  • Informative
