Hi All.
Got in my Bentley yesterday and started it up and after about 5 minutes of idling it cut out and has not started since.
There are some weird behaviours going on:
I have done 2 scans - one when i got in today and cleared all the codes to see what was left:
I also took a scan once i had got it to crank with no start and the results are here:
My thoughts are power supply issue to the ECMs - but i have checked the fuses (i think all of them) and the Relays (i think all of them) and the fuses i have checked have continuity and the relays work when tested out of the car.
Question is...is the lack of power to the ECMs due to an immobiliser issue or maybe something more simple or really obscure?
Any help greatly appreciated.
Thanks all
Gaz
- Get in turn on ignition and the "press brake pedal to start engine" warning comes on...i press the brake pedal and the warning does not go away. After a minute or so the warning goes away and the car will crank (with foot on brake) but not start.
- Get out...close door and the car will lock with the key...have a think for a moment then unlock again. Open door (slam door) and the car will lock and stay locked.
Sunday,02,February,2025,09:31:15:54210
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: SCBCE63W44C023225 License Plate: PF04 WDT
Mileage: 63840km-39668mi Repair Order: Post Clear No Start
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W44C023225 Mileage: 63840km-39668miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 AC HW:
Component: BY-6.0L-TT G ª6238
Coding: 0000173
Shop #: WSC 01666 772 31000
VCID: 6695B8E1647AF11AC57-513C
VINID: 8D34935460E71044C00830821441D69136
17069 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 A HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1005
Coding: 0000101
Shop #: WSC 00083 000 00000
VCID: 2E0500C18C0A795AFD7-513C
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 B
Component: ESP 5.7 4WD H01 0011
Coding: 0007878
Shop #: WSC 00147 000 00000
VCID: 343112A96226538A8B3-51F2
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 L HW: 5WK 470 22
Component: 0M Kessy 6400
Coding: 0147693
VCID: 2E0500C18C0A795AFD7-5160
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 00147 106 57877
VCID: 47CB556503B0C812DE1-5160
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 M
Component: ZAB COCKPIT 0251
Coding: 0400335
VCID: 363528A1745A419AB57-5160
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000001
Shop #: WSC 00258 000 00000
VCID: 30391EB9963E6FAAEFB-5160
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 G
Component: STG.Bordnetz 5001
Coding: 0000107
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Coding: 0000173
Shop #: WSC 01666 772 36780
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2517FFEDD9FC3A020CD-5160
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
Address 17: Instruments Labels: 3Wx-920-xxx-17.clb
Part No: 3W0 920 840 M
Component: KOMBIINSTRUMENT RB8 0402
Coding: 0021400
VCID: 3E2530815C6A89DA6D7-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 86250 156 70962
VCID: 70B9DEB956BE2FAAAFB-5160
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
VCID: 77ABE5A533D078926E1-5160
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
Shop #: WSC 00147 106 59550
VCID: 3FDB4D855B6080D2661-5160
Address 37: Navigation Labels: None
Part No: 3W0 919 887 B
Component: NAVIGATION 0168
Coding: 0400000
VCID: 46D5586104BAD11A257-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0703
Coding: 0000157
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 F
Component: 1L HSG 0101
Coding: 0000032
Shop #: WSC 00999 444 64523
VCID: 333311B5672854B2929-4AE0
Subsystem 1 - Part No: 3W2 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W2 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Part No: 3W3 959 703
Component: Tuersteuergeraet HL 0702
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W5 035 456 A
Component: 12K-AUDIOVERST 0006
VCID: 372B25A57350B892AE1-5160
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022413
VCID: 35372FAD695C4A82BCD-5160
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Fault Status: 11110000
Reset counter: 1
Voltage: 10.25 V
Count: 86
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 30391EB9933E6FAAEFB-51CE
Address 57: TV Tuner Labels: 3D0-919-146.lbl
Part No: 3D0 919 146
Component: TV Tuner H07 1205
Coding: 0000010
VCID: 6597BFED997CFA02CCD-5160
Address 65: Tire Pressure Labels: 3D0-907-273-V1.clb
Part No: 3W0 907 273
Component: Reifendruckueberw. 0022
Coding: 0011344
VCID: 76B5E8A134DA019A757-5160
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W2 955 023 C
Component: Wische*
Shop #: WSC 00000 725 65552
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2313E1F5D7C8C432629-5160
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AADFC9100C265FA11F-5160
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
End----(Elapsed Time: 08:31, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
Address 03: DTCs cleared
Sunday,02,February,2025,13:02:15:54210
Mileage: 63840km-39668mi Repair Order: After crank
Coding: 0000173
19 Faults Found:
P0685 - 004 - Open Circuit - MIL ON
16660 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground
17955 - Boost Pressure Regulation Valve (N75)
P1547 - 002 - Short to Ground
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground
16645 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground
16651 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground
16657 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground
17702 - Map Controlled Engine Cooling Thermostat (F265)
P1294 - 002 - Short to Ground
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
16654 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground
17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1049 - 002 - Short to Ground
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground
17935 - Camshaft Timing Adj. Bank1 (N205)
P1527 - 002 - Short to Ground
16648 - Fuel Injector #2 (N31)
P0264 - 002 - Short to Ground
18334 - Relay for Aux Coolant Pump (J496)
P1926 - 002 - Short to Ground
16421 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground
17995 - Engine Mount Solenoid Valves (N144/N145)
P1587 - 002 - Short to Ground
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 002 - Internal Resistance too High
18068 - Coolant Fan Control 1
P1660 - 002 - Short to Ground - Intermittent
Coding: 0000101
18260 - Powertrain Data Bus
P1852 - 000 - Implausible Message ECU - Intermittent
(no units): 30.0
(no units): 148.0
Temperature: 7.0°C
T.B. Angle: 60.0°
Voltage: 11.44 V
Coding: 0007878
013 - Check DTC Memory
Coding: 0147693
Component: ELV XXXX
Coding: 0000002
Coding: 0400335
Coding: 0000001
01312 - Powertrain Data Bus
Coding: 0000107
Coding: 0000173
19 Faults Found:
16663 - Fuel Injector #7 (N85)
P0279 - 002 - Short to Ground
17898 - EVAP Canister Purge Valve 2 (N333)
P1490 - 002 - Short to GND
16678 - Fuel Injector #12 (N302)
P0294 - 002 - Short to Ground
16672 - Fuel Injector #10 (N300)
P0288 - 002 - Short to Ground
16666 - Fuel Injector #8 (N86)
P0282 - 002 - Short to Ground
17891 - Relay for Secondary Air Injection Pump 2 (J545)
P1483 - 002 - Short to Ground
16669 - Fuel Injector #9 (N299)
P0285 - 002 - Short to Ground
17461 - Bank2; Exhaust Cam Adjustment Valve 2 (N319)
P1053 - 002 - Short to Ground
17895 - Secondary Air Injection Valve 2 (N320)
P1487 - 002 - Short to Ground
17943 - Camshaft Timing Adj. Bank2 (N208)
P1535 - 002 - Short to Ground
16675 - Fuel Injector #11 (N301)
P0291 - 002 - Short to Ground
17697 - Boost Pressure Control Valve (N249)
P1289 - 002 - Short to Ground
16441 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground
19474 - Valve for Exhaust Flap 1 (N321)
P3018 - 002 - Short to Ground
16633 - Solenoid Valve 2 for Boost Pressure Control (N274)
P0249 - 002 - Short to Ground
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 001 - Open or Short to Plus
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 002 - Internal Resistance too High
28772 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 004 - - Intermittent
Coding: 0012368
Coding: 0000012
Coding: 0021400
Coding: 0000006
Coding: 0015500
Coding: 0000002
Coding: 0400000
Coding: 0000157
Coding: 0000032
00875 - Treble Speaker Front Right (R22)
007 - Short to Ground
Coding: 0022413
Reset counter: 1
Voltage: 10.25 V
Count: 86
Fault Frequency: 15
Reset counter: 59
Voltage: 11.28 V
Count: 241
VCID: 30391EB9933E6FAAEFB-51A8
Coding: 0000010
Coding: 0011344
Component: Wische*
End----(Elapsed Time: 06:51, VBatt start/end: 11.4V/11.4V. VIgn 0.0V)------
Thanks all
Gaz
