Have the V159 Right Flap Error code
Pyper70
Greece or Los Angeles
C?ID=251291
In a 3C 2008 Passat 1.4L
I had it a few weeks ago, checked it through VCDS, found the fault, reset it but i came back over the weekend. I am reading on the net that some owners have replaced the actuator motors but nothing has changed, One person changed the control head and the same thing happened. Some users have said that the basic settings of the flap actuator have been wiped. Is there a way I can re-program the settings back into the system through VCDS?
Pyper70
C?ID=251291
Tuesday,08,December,2015,17:43:30:11381
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZ3CZ9P035411   License Plate:
Mileage: 101640km-63156mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9P035411   Mileage: 101640km-63156miles
Address 01: Engine (CAX)       Labels: 03C-906-022-CAX.clb
   Part No SW: 03C 906 022 AJ    HW: 03C 906 022 J
   Component: MED17.5.20      G   2341
   Revision: D5H06---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 64E95AADA777CA1ED9-8030
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786105156
   Coding: 0000307
   VCID: 2B7BF1918A294566D8-807E
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 73CB29F112995DA650-8026
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 -  -  - Intermittent
                    Fault Status: 00110000
                    Fault Frequency: 8
                    Reset counter: 240
                    Mileage: 101094 km
                    Time: 09:45:54
   Revision: 00H54000    Serial number: 00000004936026
   Coding: 01840F0700041A00470A00000F00000000095D435C000100000000000000
   VCID: 334BE9F152191DA690-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 100708 003  0205
   Coding: 00046997
   Shop #: WSC 00028
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPHY5WW+
   Coding: 0012341
   VCID: 3B5BC1D17A49D5E648-806E
   Subsystem 1 - Serial number: 6333FTS640602468
   Subsystem 2 - Serial number: 6343FTS651052478
   Subsystem 3 - Serial number: 6353ETS6KKJUUVNR
   Subsystem 4 - Serial number: 6363ETS6O8JUUVNJ
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AN
   Coding: 0000011
   VCID: 6CF9328D4FA7825E91-8038
   Part No SW: 3C0 920 853 H    HW: 3C0 920 853 H
   Component: KOMBIINSTRUMENT VD1 1222
   Revision: V0003000    Serial number: 00000000000000
   Coding: 0005105
   Shop #: WSC 00011 888 96745
   VCID: 29770B9980D557762A-807C
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P08826010F
   Coding: F9807F064002021002
   VCID: 266D00A591CB780E07-8072
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 06402 785 00200
   VCID: 3957DBD97075E7F65A-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 P
   Component: RNS-MID       H04 5274
   Revision: AB001001    Serial number: VWZ6Z749331161
   Coding: 04000440040000800000
   Shop #: WSC 43770 133 92736
   VCID: 3753DDE18661F186AC-8062
   Component: EU West V12  8195
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000772488818
   Coding: 0000181
   VCID: 6FC325817EB17946B4-803A
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.080 0401
   Revision: 1AH02234    Serial number: 00081640492602
   Coding: 0000258
   VCID: 364DD0E5416B088EB7-8062
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 18910A0001860E7630049C1C70084F0B607CA1
   Shop #: WSC 08224 211 56823
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000769088822
   Coding: 0000180
   VCID: 70C126FD638F66BEAD-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000126943
   Coding: 0000057
   VCID: 28710E9D9BDF6E7E35-807C
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000595392
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000607707
   Coding: 0000144
   VCID: 71C723F968856FB6A2-8024
End-------------------------(Elapsed Time: 01:24)--------------------------
Gone But Not Forgotten
Thank you for posting an auto-scan.......
If the system is still with sporadic DTC after a proper ADP, the V159 and wiring should be authenticated; using WD via repair manual, ......metered or with aid of VCDS "ADVMB" advanced measuring blocks.
New Acronym..........
marinescuv
Romania
C?ID=171632
V159 change
Pyper70
C?ID=251291
what does ADP and a WD stand for?
Hover your cursor over those terms.
Pyper70
C?ID=251291
I feel dumb now....I didn't think they were definitions or links....sorry
I have cleared the codes. This is the second time. If it does this again....is it in fact a V159 change ? I am waiting on the repair manual but it wont be here for another few weeks. I took it to my service guy General Service and he says he doesnt mess with it because its allot of labor and he sends it to the electrician at the Air Conditioning shop.
