2025 Jetta GLI - all tweaks blocked by firewall?
   #21
SWohlers
C?ID=114674
Hopefully, this is the info you were looking for:
Sunday,16,March,2025,12:33:52:28258
VCDS Version: 25.3.0.3 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: 3VW1T7BU3SM014864 License Plate:
Mileage: 1720 Repair Order: adv meas values
Address 19: CAN Gateway (3Q0 907 530 BB)
12:33:19
IDE13754-IDE04447 Diagnosis filter: status-Function status Function active: SFD protected
IDE13754-MAS16866 Diagnosis filter: status-Odometer 0 km
IDE13754-MAS16867 Diagnosis filter: status-Reason for deactivation Not deactivated
IDE13754-MAS16875 Diagnosis filter: status-Filter status Filter active
   #22
Elder Moreira dos Santos
Brasil
C?ID=304355
Hi, just sharing a way I found to enable the rear view camera in some customer cars with SFD 2. I change the Gateway for another one without SFD2, change what I need in the multimedia and then return to the car's original gateway. I clear the faults and the car returns ok.
   #23
SWohlers
C?ID=114674
Not sure if this additional info will help, but looked interesting.
Sunday
16​
March
2025​
12:29:38:28258-VCID:70B9D5E0BA25F5AA7F0-8024 SFDVCDS Version: Release 25.3.0 (x64)Data version: 20250301 DS365.0
3Q0 907 530 BBADVMBGW 2023 CLA 542 5555
G566F0G567F0G568F0G569F0G000
MarkerTIMELoc. IDE13754-IDE04447TIMELoc. IDE13754-MAS16866TIMELoc. IDE13754-MAS16867TIMELoc. IDE13754-MAS16875
STAMPDiagnosis filter: status-Function statusSTAMPDiagnosis filter: status-OdometerSTAMPDiagnosis filter: status-Reason for deactivationSTAMPDiagnosis filter: status-Filter status
km
0.08​
0.09​
0​
0​
Not deactivated
0.03​
Filter active
0.2​
0.2​
0​
0.11​
Not deactivated
0.12​
Filter active
0.3​
0.31​
0​
0.22​
Not deactivated
0.23​
Filter active
0.41​
0.42​
0​
0.33​
Not deactivated
0.34​
Filter active
0.52​
0.53​
0​
0.44​
Not deactivated
0.45​
Filter active
0.63​
0.64​
0​
0.55​
Not deactivated
0.56​
Filter active
0.75​
0.75​
0​
0.66​
Not deactivated
0.67​
Filter active
0.85​
0.86​
0​
0.77​
Not deactivated
0.78​
Filter active
0.96​
0.97​
0​
0.88​
Not deactivated
0.89​
Filter active
1.07​
1.08​
0​
0.99​
Not deactivated
1​
Filter active
1.18​
1.19​
0​
1.1​
Not deactivated
1.11​
Filter active
1.29​
1.3​
0​
1.21​
Not deactivated
1.22​
Filter active
1.4​
1.41​
0​
1.32​
Not deactivated
1.33​
Filter active
1.53​
1.56​
0​
1.43​
Not deactivated
1.44​
Filter active
1.66​
1.68​
0​
1.57​
Not deactivated
1.59​
Filter active
1.78​
1.81​
0​
1.7​
Not deactivated
1.71​
Filter active
1.91​
1.93​
0​
1.82​
Not deactivated
1.84​
Filter active
2.04​
2.06​
0​
1.95​
Not deactivated
1.97​
Filter active
2.15​
2.15​
0​
2.07​
Not deactivated
2.09​
Filter active
2.26​
2.26​
0​
2.17​
Not deactivated
2.19​
Filter active
2.37​
2.37​
0​
2.28​
Not deactivated
2.29​
Filter active
2.48​
2.48​
0​
2.39​
Not deactivated
2.4​
Filter active
2.59​
2.59​
0​
2.5​
Not deactivated
2.52​
Filter active
2.7​
2.72​
0​
2.61​
Not deactivated
2.63​
Filter active
2.82​
2.83​
0​
2.74​
Not deactivated
2.75​
Filter active
2.93​
2.94​
0​
2.85​
Not deactivated
2.86​
Filter active
3.04​
3.05​
0​
2.96​
Not deactivated
2.97​
Filter active
3.16​
3.18​
0​
3.07​
Not deactivated
3.08​
Filter active
3.28​
3.3​
0​
3.2​
Not deactivated
3.21​
Filter active
3.41​
3.43​
0​
3.32​
Not deactivated
3.34​
Filter active
3.53​
3.55​
0​
3.44​
Not deactivated
3.46​
Filter active
Does that not produce lots of Component Protection faults?
Yes, that is helpful. We are still learning as we go with the latest cars using this PR-Code: NI8 Without UNECE CS (R155) and SU (R156)with Protection of Vehicle Diagnostics PVD2 control module
... but Address 19 has SFD. For that reason I believe you would need to unlock SFD in address 19 (using a token from a 3rd party source) so that this Adaptation channel can be changed:
[*IDE16611-ENG331831*] Diagnosis filter: temporary deactivation
When the diagnostic filter (AKA firewall) is temporary deactivated in address 19 some diagnostic operations may be possible however I get the impression that you would need yet another unlock token for address 09 to perform the tweaks because it also uses SFD.
If you want to experiment with this and do not have a source for tokens one of our German distributors offers offline SFD tokens:
https://shop.pci-diagnosetechnik.de/SFD-Unlock-Base-Rate-incl-1-Control-Unit
If you go with PCI it is more cost effective to purchase two tokens at one time (rather than two in different orders) but I'm not entirely sure if you need two of them. If so, that add-on order page of theirs is:
   #26
SWohlers
C?ID=114674
Hi Dana,
Thank you for your explanation. I am a little confused why my attempts at changes in a non SFD module (52) appears to be blocked - is it because the module is dependent upon the gateway(19), which is an SFD module?
I have some computer skills but not a programmer. I am a hobbyist that *really* appreciates your folks programming and the ability to make a car more usable or less annoying.
At this point, I don't want to spend 30 Euros or more for some of the minor tweaks I wish to do since I am also not especially confident that some of the tokens would permit me to do what I want. I look forward to the day that SFD modifications will be integrated into VCDS.
Spencer
   #27
Exactly. On older cars the diagnostic firewall was deactivated simply by opening the hood.
In this case the diagnostic firewall is not that simple. Instead, this is controlled by an adaptation channel in address 19 and the catch is SFD needs to be unlocked before you can change that ADP channel. :facepalm:
Based on the fact that addresses like 42 and 52 refused changes entirely I'm more confident that the two token song and dance (one for 19 and another for address 09) would be needed. Hopefully we have something to offer you before the car needs a SRI reset, rear brake pads or any similar service related operations. If we aren't ready at that time, my advice is to wait until the car needs something and bundle it with your tweak wish list into one SFD unlock session.
   #28
Brasil
C?ID=304355
Yes, while the car is with another gateway, several faults appear, but when I return to the original gateway, everything starts communicating again and I just clear the faults with VCDS.
I can make changes to the 5F without any problems.
   #29
Avetisov22
C?ID=530079
My 2025 GLI was the same story unfortunately. I recently sold it without ever changing anything on through VCDS. I have a Golf R now and am out of VIN slots for my HEXV2 😭
   #30
Avetisov22
C?ID=530079
You're aware that you can upgrade the license, right?
I’m aware, I’m just sad I used a vin slot and didn’t get to do anything with it. Haven’t scanned the R yet but fairly certain all the modules are locked. No reason to upgrade the license until I can make the tweaks I want to. I’m just waiting.
   #32
You should be able to run an Auto-Scan even if you have no VINs left on the license.
Avetisov22
C?ID=530079
For sure. I just haven’t because with all the modules locked down, there is nothing I can change atm.
