2025 Jetta GLI - all tweaks blocked by firewall?
SWohlers
C?ID=114674
Hi Folks,
I just bought a 2025 GLI with a manual transmission. I am trying to do some basic tweaks I have done on my past VWs. If I try to just change the comfort blinker (I start with simple on a new vehicle), I get a message "The diagnostics firewall was ON when VCDS connected to this vehicle" "You should open the hood to perform advanced functions on this vehicle". I did open the hood after my first try at this (and left it open for a day) and retried the same modification, receiving the same "error" message. After the hood up message, I will also get a small box titled "error" with a code that says "unknown" and code # 0X00
I am hoping that this block is due to the newer systems not being incorporated into VCDS.
I will have later questions about some tweaks, but first I want to find out if there is something else I should be doing to get around this "firewall" issue, or do I need to wait until there is an VCDS update that communicates in such a way that this error does not occur?
Thanks!
Below is the scan:
Friday,24,January,2025,11:27:28:28258
VIN: 3VW1T7BU3SM014864   License Plate:
Mileage: 553km-343mi   Repair Order: newcar2
Chassis Type: BU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 14 15 17 19 32 36 3C 42 44 47 4B 52 5F 75
          A5 A9 BB BC CA
VIN: 3VW1T7BU3SM014864   Mileage: 553km-343miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DXSA)       Labels: None
   Part No SW: 5G0 906 259 AK    HW: 06K 907 425 J
   Component: R4 2.0l TFS   H13 0002
   Revision: --H13---    CVN: A60B2D42
   Coding: 091900122444002F3000
   Shop #: WSC 00066 790 00545
   ASAM Dataset: EV_ECM20TFS0205G0906259AK 001004
   ROD: EV_ECM20TFS0205G0906259AK.rod
   VCID: 77ABEEFCDF4BA2926E1-8022
   VINID: 0E69C19074A50E3740044206107159BB67
Readiness: 0000 0100
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H36 0114
   Revision: 00000000    Serial number: 60814000018445 Dataset Number: V03935432C  0001
   Coding: 70FB6BA150210970457F0206A0C7A90ED60A90A2400595361443F5D5D0A94B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76B5E3F8D841DB9A757-8022
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
                    Reset counter: 49
                    Mileage: 469 km
                    Date: 2025.01.23
                    Time: 14:58:54
Address 05: Acc/Start Auth. (J518)       Labels:* None
   Part No SW: 3Q1 959 435 C    HW: 3Q1 959 435 C
   Component: VWKESSYMQB    037 1501
   Revision: 00037000    Serial number: 0647582666 Dataset Number: V03935432CE 0001
   Coding: 132C0C0623
   Shop #: WSC 00066 790 00519
   ASAM Dataset: EV_KessyHellaMQBAB 004056
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3B2332CCA3E346F24A9-806E
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 2GJ 907 044 L    HW: 2GJ 907 044 L
   Component: Climatronic   H20 0306
   Dataset Number: V03935450RV 0001
   Coding: 0102001420011C0C0104000C1211D014
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002005
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 47CB5E3CEF2B1212DE1-8012
          B10CD 00 [00101000] - -
                    Mileage: 17 km
                    Date: 2024.12.22
                    Time: 14:43:40
                    Unlearning counter according OBD: 32
                    Control Module Voltage: 11.600 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
   Part No SW: 5Q1 937 085 B    HW: 5Q1 937 085 B
   Component: BCM MQBAB HLN H50 0618
   Serial number: 4222055501     Dataset Number: V03935449WL 0001
   ASAM Dataset: EV_BCMMQB 023001
   ROD: EV_BCMBOSCH_023.rod
   VCID: 392F28C4A9DF74E2585-806C SFD
   Subsystem 1 - Part No SW: 81D 955 555 A    HW: 81D 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 20171656X81D955555A0
   Coding: 8000DE
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 JC    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 0300130820240C200611
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0102
   Serial number: ESE4275430
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE4277450
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE4265865
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE4277911
204293 - Remote key 1
          B1479 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 41
                    Mileage: 179 km
                    Date: 2025.01.21
                    Time: 03:49:25
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.5 V
                    Outside temperature: -7.0  C
   Part No SW: 2Q0 907 567 B    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H04 0534
   Dataset Number: V03935448XJ 0001
   Coding: 280200C158FF8748949C812460409700000000000000004034
   Shop #: WSC 00066 790 00574
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
   VCID: 372B2EFC9FCB6292AE1-8062 SFD
   Part No SW: 5Q0 907 376 D    HW: 5Q0 907 376 D
   Component: DAEMPFUNGS-SG H18 0140
   Serial number: 23042441350110 Dataset Number: V03935285SE 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3A2D37C8ACD97FFA51F-806E
   Part No SW: 5Q0 959 655 CB    HW: 5Q0 959 655 CB
   Component: AirbagVW21    010 0421
   Serial number: 003J4M0RZENI Dataset Number: V03935447TP 0001
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 025D8F288489F73A49F-8056
   Component: BF-Gewichtss.  H17 0022
   Serial number: IBH00000000000N5A2II
   Coding: 30374E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 006 24
   Serial number: 35700000000A9BD4807Y
   Subsystem 3 - Part No SW: -----------    HW: 480 001 006 24
   Serial number: 3580000000099BD4807Y
   Subsystem 4 - Part No SW: -----------    HW: 480 052 006 24
   Component: SideSensor_Dr  000 0149
   Serial number: 3510000A0D38F80F2243
   Subsystem 5 - Part No SW: -----------    HW: 480 052 006 24
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000A0D38F80C6919
   Subsystem 6 - Part No SW: -----------    HW: 480 052 006 24
   Component: FrontSensor_D  000 0149
   Serial number: 3550000B4D122C5448D6
   Subsystem 7 - Part No SW: -----------    HW: 480 052 006 24
   Component: FrontSensor_P  000 0149
   Serial number: 3560000BCD122C4C447C
   Part No SW: 17A 920 420 E    HW: 17A 920 420 E
   Component: KOMBI         615 7851
   Dataset Number: V03935446UJ 0001
   Coding: 082408007788CF050288624B5000000880600802
   ASAM Dataset: EV_DashBoardVDDMQBA0 003060
   ROD: EV_DashBoardVDDMQBA0_003_VW27.rod
   VCID: 1F1BE65C173B3AD2461-804A SFD
   Part No SW: 3Q0 907 530 BB    HW: 3Q0 907 530 BA
   Component: GW 2023 CLA   542 5555
   Revision: --------    Serial number: 423702500242320 Dataset Number: V03935441YU 0001
   Coding: 0000800D0C00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
   GVL: 3D500000040040DC800000804C00100000000002000000000000000000000042
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 70B9D5E0BA25F5AAAFB-8024 SFD
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H11 9070
   Serial number: 3537911101
   Subsystem 3 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL            H03 0219
   Serial number: 17036218141902400161
   Subsystem 4 - Part No SW: 5H0 959 542 N    HW: 5H0 959 542 N
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA24197372503
8417280 - Unknown Error Code
          U17A0 00 [00101000] - -
          [Filter_is_not_active]
                    Reset counter: 28
                    Mileage: 14 km
                    Date: 2024.10.22
                    Time: 01:00:26
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00028.03.24 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7F681469A7BAB9F-8006
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 H    HW: 3Q0 959 760 H
   Component: SCU_FS        003 0114
   Serial number: YG007XBL0035500 Dataset Number: V03935426UU 0001
   Coding: 00080240000120400000010101000000000000010000000000000000044000
   ASAM Dataset: EV_SeatMemorDriveSideKo 001003
   ROD: EV_SeatMemorDriveSideKo.rod
   VCID: 40D94520CA05252A1FB-8014
9654612 - Motor for Lumbar Support Height Adjustment
          B1351 54 [00101111] - Missing Calibration / Basic Setting
                    Mileage: 14 km
                    Date: 2024.10.22
                    Time: 01:00:25
9655124 - Motor for Seat Tilt Adjustment
          B1353 54 [00101111] - Missing Calibration / Basic Setting
                    Mileage: 14 km
                    Date: 2024.10.22
                    Time: 01:00:25
          U1400 00 [00100000] - -
          [supply_voltage_too_low_functional_limitation]
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 11230078419335  Dataset Number: V03935424TY 0001
   Coding: 5694C640
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FDB46DCB7FB5AD2661-806A
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 11230077966369
   Part No SW: 5Q4 959 593 Q    HW: 5Q4 959 593 Q
   Component: TSG FS        016 0920
   Serial number: 26045423500987 Dataset Number: V03935412FR 0001
   Coding: 003D1B200200028000000000
   Shop #: WSC 00066 790 00679
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001023
   VCID: 53F37A6C2B73AEB2B29-8006
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000020675440
   Coding: 011000
   Part No SW: 3WA 907 145 E    HW: 3WA 907 145
   Component: BASGEN1MQB37  503 1122
   Serial number: 03341454 Dataset Number: V03935435QA 0001
   Coding: 01000000010000010000020101000100000001000100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017_VW27.rod
   VCID: 4ACD6708FC39EF7AC1F-801E SFD
   Part No SW: 5H0 035 456     HW: 5H0 035 456
   Component: AMPeth12C     H04 3333
   Serial number: A1129A00300336  Dataset Number: V03935442RE 0001
   Coding: 24000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW27.rod
   VCID: 6491A9B07EDD590ADB3-8030
   Part No SW: 3Q0 907 338 P    HW: 3Q0 907 338 R
   Component: FCM MQB High  H09 0408
   Serial number: 14082400841249 Dataset Number: V03935425KG 0001
   Coding: 000000000800450A00000000000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiMQBCl 001009
   ROD: EV_MultiModulContiMQBCl.rod
   VCID: 42DD4F28C409373A09F-8016
   Part No SW: 5Q4 959 592 Q    HW: 5Q4 959 592 Q
   Component: TSG BFS       016 0920
   Serial number: 27045423700593 Dataset Number: V03935419DH 0001
   Coding: 003D13200200028000000000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001023
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000020705657
   Coding: 091000
   Part No SW: 3G8 035 842     HW: 3G8 035 842
   Component: MU-O-NS-US    H04 5422
   Serial number: WG8LGM060724003 Dataset Number: V03935448LU 0001
   Coding: 23710000000210000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 002001
   ROD: EV_MUOIMQB_002_VW37.rod
   VCID: 6889BD8082F53D6AF7B-803C SFD
   Subsystem 1 - Part No SW: 5NN 919 605 C    HW: 5NN 919 605 C
   Component: ABT_Std-2      290 8310
   Serial number: VWZ6ZMC2355274
   Subsystem 2 - Part No: V03 959 821 P
   Component: NAR 2025       2119
12301 - Ethernet Databus Branch 4
          U122F 00 [00001000] - No Communication
                    Mileage: 265 km
                    Date: 2025.01.21
                    Time: 04:43:23
                    Ethernet counter checksum error: branch 4: 0
                    Ethernet counter connection interruptions: branch 4: 0
0021 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Voltage terminal 30: 11.6 V
   Part No SW: 2GA 035 285     HW: 2GA 035 285
   Component: OCUClas2023_H H11 0615
   Serial number: 0000000407VIQSG Dataset Number: V03935433ZN 0001
   Coding: 02020500000100211000010013002E07111112111012011110
   ASAM Dataset: EV_OCUClass2023 001063
   ROD: EV_OCUClass2023_VW27.rod
   VCID: 71BFD0E4B12FFCA2A05-8024 SFD
   Part No SW: 2Q0 980 653 G    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1505
   Serial number: ED3659904241860 Dataset Number: V03935428SC 0001
   Coding: 00000A88016E4020089F00000020002000418000E00000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007057
   Part No SW: 5G0 907 159 F    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 240612292801
   VCID: 313F10E471AFBCA2E05-8064
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4K8 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_1     010 0010
   Dataset Number: V03935394WW 0001
   Coding: 00800073710B
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 7EA5FBD8F07193DA2D7-802A
End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.2V)-----------
Address 09,5Q1 937 085 B,channel ENG141649-ENG116587-Au enlicht_Blinker-Komfortblinken Blinkzyklen,adapted from,3 ,to,5 ,
UDS Adaptation Channel (10B): ENG141649-ENG116587-Au enlicht_Blinker-Komfortblinken Blinkzyklen
Stored value 3
Not the firewall per se.
The bad news: Modules that show SFD at the end of VCID will need to be unlocked to make any changes.
The good news is that VCDS isn't running in 'R' mode, so this car doesn't have what's (improperly) called "SFD-2", which locks down everything behind it.
SWohlers
C?ID=114674
Thank you for your insight. I was hoping it would be something simple like needing to put a charger on the battery since it seems to complain about having 12.2 volts. For others that may search\read this, because you don't mention how to unlock SFD, I assume it is not something that is easy to do or can be currently performed with the VCDS program. I look forward to an update that will work through the SFD annoyance. Makes me *really* miss my 2017 GLI.
I guess I should count the small blessings of not having "SFD-2"
Spencer
It's something we're working on, and have spent a princely sum pursuing, but is not ready yet.
Yes. In fact, I'm not sure I'd ever buy a car with that nonsense.
SWohlers
C?ID=114674
Quick update. I attempted to access a couple of the modules (36 and CA) without an SFD designation and after clicking on adaptation, received the same "The diagnostics firewall was ON when VCDS connected to this vehicle" "You should open the hood to perform advanced functions on this vehicle". The hood was open prior to hooking up and turning on the ignition. I also had a 6 amp charger on the battery in case there may be voltage issues. FWIW, it was drawing 4 amps, with the lights and fan turned off. Hope the additional info helps.
Try changing something anyway in a non-SFD module.
SWohlers
C?ID=114674
As you suggested, I bypassed the hood warning and attempted to change a values in a couple of modules that I thought would be fairly benign. (03-ABS Brakes (I think) for hill hold from standard to max) and 42-Door Elect, Driver) In both cases, in the case of the hill hold, I rec'd "This appears to be an uninitialized control module; valid WSC/Importer/Equipment data may be required". I backed out as I was uncomfortable going further. For #42, I attempted to change the reversing threshold for the window from 90% to 91% as a test. It failed as well, but with a slightly different message: "This workshop identification: WSC 00066, Importer 790, Equipment 00679 was rejected by the control module. The command will probably fail, please change your values". I stopped there, not wanting to force something and I was freezing. It just feels like I should wait for an update, though there may be ways around it with a little help.
  • Informative
Dr Sheldon
Windsor UK
C?ID=334979
I wouldn't waste any time on that !!
The potential to get no where or force a non reversible fault would not leave you in happiness.
Avetisov22
C?ID=530079
How does one tell precisely is SFD2 is present? I had uploaded an auto scan of my ‘25 GLI as well and could never figure out if it was just locked or has SFD2.
Avetisov22
C?ID=530079
See post #2.
Thank you. I saw that but still wasn’t sure what exactly to look for after looking at my own scan, meaning how to tell if I’m in R mode or not.
You're not.
Actually, you can't be because you're using Release 24.7. If your car had "SFD2", 24.7 would only talk to your Gateway. R mode was introduced in Beta 24.8:
Avetisov22
C?ID=530079
You're not.
That makes a lot more sense now. I appreciate it. I’ll update and try again on my next day off.
SWohlers
C?ID=114674
Hi, with the software update (25.3) and the firmware update, I was hoping some of the roadblocks I am having to making modifications were lessened. I recognize there is still the SFD issue that has yet to be resolved and am resigned to waiting for Ross-Tech's negotiations to come to fruition. I recognize there may be a work around with either purchasing an unlock code or possibly using ODIS software as described in https://www.ross-tech.com/vcds/tour/sfd.php . I am not confident enough to go that route. In the mean time, I tested the new software (25.3) in the same non SFD module as before to confirm whether or not I would have luck making modifications. I was met with the same errors as before in trying a simple change in a reversing threshold for a rear window in module 52. When I select module 52, I still get "The diagnostics firewall was ON when VCDS connected to this controller. You should open the hood to perform advanced functions on this car." (The Hood Was Opened an hour before I did anything). If I push forward and ignore the message, change the threshold from 90% to 95% (or anything else). I get an Adaptation Error pop up saying that "This appears to be an initialized control module. Valid WSC/Importer/Equipment Data may be required. Click Yes to use VCDS default values, etc. After clicking Yes for the default values, I receive an Adaptation Error message telling me to change the values and a non de script error of (OX00).
So, my question is this failing because of the initial error not recognizing the hood is open, could the vehicle actually be SFD2 or could there be some other reason?
My hope is once this is successful I can make minor attempts at what I would really like to tweak elsewhere.
Below is the recent scan with the 25.3 software.
Thank you.
Friday,07,March,2025,12:38:23:28258
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
Mileage: 2257km-1402mi   Repair Order: new software test
          A5 A9 BB BC CA
VIN: 3VW1T7BU3SM014864   Mileage: 2257km-1402miles
   VCID: 77ABEEFCDF4BA292BEA-8022
   ROD: EV_Brake1UDSContiMK100IPB_049_VW37.rod
   VCID: 76B5E3F8D841DB9AA5C-8022
   Coding: 132C0C0623
   VCID: 3B2332CCA3E346F29A2-806E
   VCID: 47CB5E3CEF2B12120EA-8012
          B10CD 00 [00100000] - -
   VCID: 392F28C4A9DF74E288E-806C SFD
   Coding: 8000DE
   ROD: EV_ACCMRRCONTIUNECEMQB_VW37.rod
   VCID: 372B2EFC9FCB62927EA-8062 SFD
196740 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SENSOR_BLOCKAGE]
                    Reset counter: 139
                    Mileage: 2056 km
                    Date: 2025.03.01
                    Time: 11:53:28
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 22  C
                    Vehicle speed: 19.09 m/s
                    Longitudinal acceleration: 0.53 m/s
                    Adaptive distance regulation: status: ACC_StandBy
   VCID: 3A2D37C8ACD97FFA814-806E
   VCID: 025D8F288489F73A994-8056
   Coding: 30374E
   VCID: 1F1BE65C173B3AD296A-804A SFD
   VCID: 70B9D5E0BA25F5AA7F0-8024 SFD
   Generator:
2428957 - Generator
          U1052 00 [00100000] - No Communication
                    Fault Frequency: 0
                    Reset counter: 0
8417280 - Diagnostic Filter
          U17A0 00 [00100000] - Not Activated
                    Fault Frequency: 0
                    Reset counter: 0
   Coding: 0001
   VCID: 52FD7F681469A7BA694-8006
   VCID: 40D94520CA05252ACF0-8014
                    Mileage: 14 km
                    Date: 2024.10.22
                    Time: 01:00:25
                    Mileage: 14 km
                    Date: 2024.10.22
                    Time: 01:00:25
   Coding: 5694C640
   VCID: 3FDB46DCB7FB5AD2B6A-806A
   VCID: 53F37A6C2B73AEB2622-8006
   Coding: 011000
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 4ACD6708FC39EF7A114-801E SFD
   VCID: 6491A9B07EDD590A0B8-8030
   ROD: EV_MultiModulContiMQBCl_VW27.rod
   VCID: 42DD4F28C409373AD94-8016
   Coding: 091000
   ROD: EV_MUOIMQB_002_VW27.rod
   VCID: 6889BD8082F53D6A270-803C SFD
                    Mileage: 265 km
                    Date: 2025.01.21
                    Time: 04:43:23
                    Fault Priority: 9
   ROD: EV_OCUClass2023_VW37.rod
   VCID: 71BFD0E4B12FFCA270E-8024 SFD
1126519 - Databus
          [RDR1_Header_RDR1_relev_Nichtverfuegbarkeit]
                    Reset counter: 37
                    Mileage: 2027 km
                    Date: 2025.03.01
                    Time: 11:53:28
   VCID: 313F10E471AFBCA230E-8064
   VCID: 7EA5FBD8F07193DAFDC-802A
End----------(Elapsed Time: 01:24, VBatt start/end: 12.0V/12.0V)-----------
------------------------------10 Faults Found------------------------------
Address 52,5Q4 959 592 Q,channel ENG117300-Reversing_Threshold_Passenger_Side_Rear,adapted from,90 %,to,95 %,
I don't think so. VCDS is not in "-R" mode reading your modules, and your Gateway does not mention "UNECE".
Let's have a look at some measuring values in your Gateway, specifically all the ones that start with:
IDE13754 ... Diagnosis filter
I think there should be four of them.
SWohlers
C?ID=114674
OK, I am going to need a little help providing that information, as this is not a part of VCDS I have ventured into. Searching the manual, is it: https://www.ross-tech.com/vcds/tour/m-blocks.php ?
If so, may I assume that I would select 52 and then select Meas. Blocks and save to the log or are you looking for some other values? Where will I find IDE13754?
Thank you!
No, this is a UDS module so you won't have Measuring Blocks. You need Advanced Measuring Values.
Type (or copy & paste) it into the search/filter box of the selection window (were somebody typed time in this screen-shot):
SWohlers
C?ID=114674
Hi,
I was unable to find IDE13754 or anything that mentioned a diagnosis filter.
I tried to copy\paste the screen grab, but didn't have much luck. It jumped from IDE13421 to IDE13865 - 421 was the status for the seat position and 865 was the switch for the inside door handle.
Spencer
Did you look in the Gateway at address 19?
