- Jan 28, 2025
- 9
- 2
- Oklahoma, USA
- C?ID=607143
Hello everyone,
Sorry I see i didn't follow the title procedure, and I don't see any way to edit it...
2015 Passat TDI, HVAC issues.
I've got a 2015 Passat TDI, with a "Electric manual climate control system", not the climatronic system.
See the picture.
The defrost has very low air flow, but the face and feet selection has good air flow.
But when moving the selection from defrost to the face of the feet, there's a short moment of very good air flow from the defrost vents before it changes to the face or feet.
There are no HVAC DTC codes showing in VCDS autoscan
I removed a bunch of the dash and I could see the air distributor door motor moving as I moved the knob to the different air flow locations.
One question I have is, is the air distribution door motor going to the correct position when defrost is selected?
How can I view the position sensor with VCDS and will it tell me if it's in the correct position or not?
Thank you,
Here is the scan
See the picture.
Thank you,
Here is the scan
Thursday,23,January,2025,10:36:56:02392
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 1VWBV7A3XFC037699 License Plate:
Mileage: 252040km-156610mi Repair Order: 1/23/25 B
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
62 72 75 77
VIN: 1VWBV7A3XFC037699 Mileage: 252040km-156610miles
37-Navigation -- Status: Cannot be reached 1100
75-Telematics -- Status: Cannot be reached 1100
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI X20 9466
Revision: 8AX20--- CVN: B12134C50000000000000000
Coding: 011D0012032410081000
Shop #: WSC 23116 035 00000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: EV_ECM20TDI01104L997016D.rod
VCID: 3436C3BEDEBBFA2A8B3-8060
VINID: 0669D2987443A164C00C71892489D6D6F1
Readiness: 0 0 0 1 1
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4518
Revision: 05652104 Serial number: 00001407241428
Shop #: WSC 09003 957 00200
VCID: 25102EFA69E193A20CD-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Mileage: 252041 km
Date: 2025.01.23.
Time: 18:27:28
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F549250001A31103ED92220042A1100012
VCID: 0456537ECE1B8AAA7B3-8050
Reset counter: 42
Mileage: 251949 km
Count: 2
Count: 14
Count: 4096
Count: 16390
Count: 42496
Count: 768
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 2
Mileage: 251949 km
Count: 3
Count: 14
Count: 20480
Count: 16401
Count: 42496
Count: 768
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0343473827 Dataset Number: 560116v____ 0002
Coding: 030C0C
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 372CF4B2CFCD1132AE1-8062
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1D60061A4D315B6254D-8048
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E1B802B2AD4098800010600854800F1A086448015B064806000AC70
Shop #: WSC 42399 001 1048576
VCID: 78AE378E82D3DE4A67B-802C
00985 - Right Tail Light (M2)
Fault Status: 00101010
Reset counter: 46
Mileage: 251951 km
Date: 2025.01.04.
Time: 18:28:08
Voltage: 14.10 V
Fault Status: 01101010
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:34
Voltage: 11.85 V
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD01EKH. Dataset Number: 560003v__A_ 0134
Coding: 00004D52
Shop #: WSC 00355 004 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 71B80AAAE1298F02A05-8024
Serial number: 6940000Y1400018FFA0L
Coding: 303044
Serial number: 3572MSME69080B47ZZZ
Serial number: 3582MSME41655B47ZZZ.
Serial number: 3516KSME40595B30ZZZQ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME57345B30ZZZS
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME36460431ZZZL
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME7B4B0431ZZZ-
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140625101406
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EA22196A077E07A2D7-802A
Component: E221__MFL-YVJ H07 0023
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0813
Coding: 231E01
VCID: 1E6201164037407A4D7-804A
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [10001001] - Internal Electronic Failure
[Steuerger�t defekt (SiWaLa)]
Mileage: 225085 km
Date: 2023.09.22.
Time: 00:00:07
10485824 - Internal Control Module Memory Check Sum Error
B2000 41 [10001001] - General Checksum Failure
[Steuerger�t defekt (EEPROM-Bereich Tachokennlinie)]
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 01101403000658
Coding: 461000
VCID: 005E5F6EDA03968A5FB-8054
01302 - Control Module for Telematic (J499)
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:14
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:14
01304 - Radio
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:14
Component: IMMO H04 0813
Coding: 000007
VCID: 6A8A1DC6CCFF7CDAE1F-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000208851005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303ECFAE2AA3C60AEFB-8064
Address 2E: Media Player 3
Address 37: Navigation
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008915953
Coding: 0404B5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE4480213A515526A9-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630140929233555
Coding: 800000
131584 - Motor for Rear Window Regulator
B11EE 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 44
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:10
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
VCID: 3928F28AF5590742585-806C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FBC0CD2F79D99F2B61-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011411902514
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008921598
Coding: 0404B4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE64B1E16AB126A633-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631140930123210
Coding: 800000
Reset counter: 44
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:13
Address 56: Radio
Address 75: Telematics
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666552062 Dataset Number: 5N0035729E 0001
Coding: 0000000000000000
Shop #: WSC 36135 005 1048576
ROD: EV_UHVUMI.rod
VCID: 323AC5A624AFF41A99F-8066
7 Faults Found:
9455635 - Telephone Microphone
B1048 13 [00001001] - Open Circuit
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
B104F 13 [00001001] - Short to GND
Reset counter: 4
Mileage: 251996 km
Date: 2025.01.19.
Time: 04:57:55
B104E 13 [00001001] - Short to GND
Reset counter: 4
Mileage: 251996 km
Date: 2025.01.19.
Time: 04:57:55
9458195 - Control Module for Cellular Telephone
B1052 13 [00001001] - Open Circuit
[Bedieneinheit f�r Handyvorbereitung (Drei Tasten Module): Unterbrechung]
Reset counter: 3
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
U1014 00 [00001001] - -
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
0022 - Radio
U1066 00 [00001001] - No Communication
[Steuerger�t Radio (RNS): kein
