Long Coding for CAN gateway
   #21
golfi_vend
Tartu, Estonia
C?ID=195131
The battery managemnt code will also flag up when very new can is installed in old car and can gw superseeding isn't followed.
Reason is that older wirings have GND in place where newer cans have battery management LIN wire. It is needed to remove GND from there and you're fault free.
Also, although the 61 is in Installation List, it is not in autoscan. - Please go to 61 directly and see fault and clear them.
enrico
Italy
C?ID=125918
Well... I put 359002 as long code, cleared the faukts did the scan.
VCDS Version: Release 15.7.2 Running on Windows Vista x86
Data version: 20151124
Saturday,12,December,2015,10:47:46:41339
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WV...............   Mileage: 60070km-37325miles
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 T    HW: 028 101 195 6
   Component: R4 2,0L EDC 0000SG  7001
   Revision: 12345678    Serial number: VW.......
   Coding: 0000072
   Shop #: WSC 01392 785 00200
   VCID: 34484E90579A149EBF-8060
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023282
   VCID: 3A5460A875FEE2EE65-806E
   Part No: 1K0 907 044 AF
   Component: ClimatronicPQ35 066 0505
   VCID: 6BFA95EC4A248B66AE-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 0000000.........
   Coding: 01890F2600041800000A00000F00000000085D035C
   Subsystem 1 - Part No: 5M0 955 119
   Component: Wischer VW359  012  0402
   Coding: 00065493
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 1M AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033.......
   Coding: 0012621
   Shop #: WSC 01372 785 00200
   VCID: 2C7856F08FAA4C5EE7-8078
   Subsystem 1 - Serial number: 6332MSME085610281
   Subsystem 2 - Serial number: 6342MSME08394B6CP
   Subsystem 3 - Serial number: 6351HSME06401118V
   Subsystem 4 - Serial number: 6361HSME062E5A75H
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - Intermittent - MIL ON
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenksäulenmodul 521 0050
   Coding: 0002012
   VCID: 364C749841E6068E81-8062
   Component: Lenkradmodul    007 0050
   Part No: 1K0 920 861 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003103
   Shop #: WSC 30562 264 68225
   VCID: 2870AAE09B52607E03-807C
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 111213F1002338
   Coding: 359002
   VCID: 7BDAA5ACFA441BE63E-802E
                    Reset counter: 46
                    Mileage: 60078 km
                    Time: 10:33:48
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0167
   Coding: 0000052
   Shop #: WSC 01287 785 00200
   VCID: 30404280A38228BEDB-8064
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 00C802087F2D8404084F01E010CC
   VCID: 79D6BFA4307829F62C-802C
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 31464784A88821B6D4-8064
   Part No SW: 5J0 035 161 G    HW: 5J0 035 161 G
   Component: Radio-SWING   006 0005
   Revision: -----09S    Serial number: SKZ4Z2R1132598
   Coding: 0D0004000006
   Shop #: WSC 33361 790 00099
   VCID: 266CA4D85146760E31-8072
00856 - Radio Antenna
                    Reset counter: 32
                    Mileage: 59040 km
                    Time: 19:13:38
                    Reset counter: 46
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 6
                    Mileage: 59949 km
                    Time: 14:18:58
                    Reset counter: 2
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0220
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D7E5BF4B4B04556F0-8078
End-------------------------(Elapsed Time: 01:14)--------------------------
enrico
Italy
C?ID=125918
I omitted the serial numbers only for a matter of privacy.
I am worried of the remaining faults... Except for the radio because I need a radio antenna cable adapter.
What about the battery regulator? Do I have really to weld the groud in a different way?
Address 61: Battery Regul. Labels: 1K0-907-534.clb
Control Module Part Number: 7N0 907 534 HW: 7N0 907 530 AM
Component and/or Version: Batt.regelung H55 1642
Software Coding: F000185A
Work Shop Code: WSC 12345 123 12345
VCID: 71C68784A80861B694-8024
02071 - Local Databus
Fault Status: 01101100
Reset counter: 6
Mileage: 60078 km
Time: 10:52:58
Thanks again for your tips.
   #24
Sebastian
Magdeburg, Germany
HN0-nnnnnn
#09 The gateaway you installed isn't exactly compatible to the central electronics, it will likely keep flagging those codes. Install a proper gateway to fix this.
#19 See comments on #56.
#56 A Skoda Fabia/Roomster Radio in a Golf will never run free of faults, you may be able to reduce them but that's about it. Install a proper radio to fix this.
#61 Since your car doesn't have battery management (and the relating sensors), but the Gateway (that isn't meant for your car) looks for them - there is nothing you can do, other than installing a proper gateway. If if you retrofitted the sensor etc., the remaining vehicle systems would have no idea what to do with the information. IMO not worth it...
golfi_vend
Tartu, Estonia
C?ID=195131
61 fault will flag up because LIN wire is short to ground, not because the can has it listed.
   #26
enrico
Italy
C?ID=125918
But then... Can I solve the problem opening the CAN gateway and unwelding the LIN... or it is better to give up??
   #27
golfi_vend
Tartu, Estonia
C?ID=195131
Yes cut pin or remove wire. But you have others faults to address.
   #28
enrico
Italy
C?ID=125918
Well, no... Better to stop this kind of troubleshooting on the car I own. Today I put back the old gateway and RCD300 radio.
I thought it was much simpler upgrading a radio, even the volume control on steer does not work.
But thank you for your support. Now I have much clear the use of VCDS. :)
Bye
