Passat 2020 keyless kessy entry sensor check? is it there?
ursl55
Berlin, Germany
Hi folks,
i have a passat 2020 elegance with keyless go and what it seems a kessy doorknob just on the drivers side. i was wondering if that means that i can somehow activate the keyless entry option?
I am very new to the vcds world and quite a noob.
first two things i tried was in the controller 5 there where two options to activate as seen in the screenshots... after doing just so it didnt work, but im stil not sure if the hardware is even integrated.
here is the autoscan of yesterday.
any experts help appreciated :)
thanks!
Montag,27,Januar,2025,12:46:16:55125
VCDS -- Windows-basierter VAG/VAS-Emulator l‰uft auf Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version DRV 24.7.1.0 (arm64)  HEX-V2 CB: 0.4643.4
Datenstand: 20241105 DS356.3
www.Ross-Tech.de
Kilometerstand: 62399km   Reparaturauftrag: Leo
Fahrzeugtyp: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 47 4B 52 5F
          69 6C 6D 75 A5 BB BC D6 D7
01-Motorelektronik -- Status: Fehler 0010
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: Fehler 0010
05-Zugangs-/Startber. -- Status: Fehler 0010
08-Klima-/Heizungsel. -- Status: Fehler 0010
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: Fehler 0010
13-Distanzregelung -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
23-Bremskraftverst. -- Status: Fehler 0010
2B-Lenks‰ulenverrieg. -- Status: i.O. 0000
3C-Spurwechsel -- Status: Fehler 0010
42-T¸relektr. Fahrer -- Status: Fehler 0010
44-Lenkhilfe -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
52-T¸relektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
69-Anh‰nger -- Status: i.O. 0000
6C-R¸ckfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
75-Telematik -- Status: Fehler 0010
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
BB-T¸relektronik hinten links -- Status: i.O. 0000
BC-T¸relektronik hinten rechts -- Status: i.O. 0000
D6-Lichtsteuerung links 2 -- Status: Fehler 0010
D7-Lichtsteuerung rechts 2 -- Status: Fehler 0010
Adresse 01: Motorelektronik (J623-DSRB)       Labeldatei:. 05L-907-309-V1.clb
   Teilenummer SW: 05L 906 022 BK    HW: 05L 907 309 B
   Bauteil: R4 2.0l TDI   H30 9971
   Revision: E3H30---    CVN: 0CAFA393644B2C53FDCF42ED644B2C5343FB2DAA
   Codierung: 0125043204741D0830000000000000000000000000000000
   Betriebsnr.: WSC 31788 004 1048576
   ASAM Datensatz: EV_ECM20TDI01105L906022BK 006007
   ROD: EV_ECM20TDI01105L906022BK_006.rod
   VCID: 71BE2F9D51246FD2A05-8025
   VINID: 9E69EAAAA0D3A9C540185206143A9CB36E
1 Fehler gefunden:
17156 - Datenbus empfangener Fehlerwert
          U1123 00 [00100000] - -
          Sporadisch - unbest‰tigt - gepr¸ft seit letzter Lˆschung
             Umgebungsbedingungen:
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Kilometerstand: 62394 km
                    Datum: 2025.01.22
                    Zeit: 18:24:10
                    Motordrehzahl: 1058.00 /min
                    Normierter Lastwert: 6.7 %
                    Fahrzeuggeschwindigkeit: 0 km/h
                    K¸hlmitteltemperatur: 89 ∞C
                    Ansauglufttemperatur: 4 ∞C
                    Umgebungsluftdruck: 1000 mbar
                    Spannung Klemme 30: 11.980 V
                    Verlernz‰hler nach OBD: 40
                    Triebstrangkoordinator: ACC Fehlerstati-Bits 0-7: 0
                    Triebstrangkoordinator: Bremse Fehlerstatus: 0
                    Triebstrangkoordinator: Bremse Funktionszustand-Bits 0-7: 0
                    Beschleunigung: 0.000 m/s≤
Adresse 02: Getriebe (J743)       Labeldatei: DRV\0BH-927-711.clb
   Teilenummer SW: 0GC 300 046 D    HW: 0GC 927 711 H
   Bauteil: GSG DQ381     H06 2402
   Revision: 00H06V10    CVN: AC91F53A
   Codierung: 0014
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2B02FDF5B3884502DA9-807F
   Keine Subsysteme:
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\5Q0-907-379-IPB-V1.clb
   Teilenummer SW: 5Q0 614 517 DN    HW: 5Q0 614 517 BR
   Bauteil: ESC           H82 0113
   Revision: 00000000    Seriennummer: 60100000002890
   Codierung: 0FEC7A8FA1263B71477F060660C849F05E85DCE2600692713862F078D2A24A0B0003000012121212B835351919323200
   ASAM Datensatz: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW48.rod
   VCID: 00587A596A8E765A5FB-8055
1 Fehler gefunden:
16401 - Reifendruckwarnung
          C102D 00 [00001000] - -
          Sporadisch - best‰tigt - gepr¸ft seit letzter Lˆschung
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 176
                    Kilometerstand: 62074 km
                    Datum: 2025.01.22
                    Zeit: 13:15:19
Adresse 05: Zugangs-/Startber. (J518)       Labeldatei:| DRV\5Q0-959-435.clb
   Teilenummer SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Bauteil: VWKESSYMQB    027 1307
   Revision: 00027000    Seriennummer: 0536646191 Datenstand-Nummer: V03935300GL 0001
   Codierung: 012F0F0723
   Betriebsnr.: WSC 05311 115 00323
   ASAM Datensatz: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 44D0B6493E16AA7A3B3-8011
2 Fehlercodes gefunden:
1052935 - Sensor f¸r T¸rauflengriffber¸hrung Fahrerseite
          B116B 11 [00001001] - Kurzschluss nach Masse
                    Fehlerpriorit‰t: 4
                    Fehlerh‰ufigkeit: 2
                    Verlernz‰hler: 136
                    Kilometerstand: 62399 km
                    Datum: 2025.01.26
                    Zeit: 15:26:26
                    Terminal_15_Kessy_specified_value: aus
                    Terminal_15_Kessy_actual_value: aus
                    Terminal_15_central electric_actual_value: aus
                    Terminal_15red_Kessy_specified_value: aus
                    Terminal_15red_Kessy_actual_value: aus
                    Terminal_S_Kessy_specified_value: ein
                    Terminal_S_Kessy_actual_value: ein
                    Terminal_S_central electric_actual_value: ein
                    Terminal_50_Kessy_specified_value: aus
                    Terminal_50_Kessy_actual_value: aus
                    ZAT_pressed: ein
                    W‰hlhebelstellung Parken: eingerastet und verriegelt
                    Anfrage aktiv: Bedingung nicht erf¸llt
                    Freigabe Lenks‰ulenverriegelung: Bedingung nicht erf¸llt
                    Freigabe Wegfahrsperre: Bedingung nicht erf¸llt
                    Kein aktiver Fehlermode: Bedingung erf¸llt
                    Schl¸sselsignatur G¸ltigkeit: Bedingung erf¸llt
                    Control Module Voltage: 11.485 V
                    Fahrerinformation Schl¸sselpositionsnachbildung Werkstatt: nicht aktiv
                    Fahrerinformation Rollwarnung: nicht aktiv
                    Fahrerinformation Notabschaltung: nicht aktiv
                    Fahrerinformation Komfortabschaltung: nicht aktiv
                    Fahrzeuggeschwindigkeit: 0.0 km/h
                    Motordrehzahl: 0.0 /min
                    Status der Fahrzeugverriegelung: Fahrzeug entriegelt
                    Ann‰herung auf der Innenseite: nicht aktiv
                    Bet‰tigung auf der Innenseite: nicht aktiv
                    Ann‰herung auf der Auflenseite: nicht aktiv
                    Bet‰tigung auf der Auflenseite: nicht aktiv
                    Zugbet‰tigung T¸raussengriff: nicht aktiv
                    Codierungsinformation: codiert
                    Codierungsinformation: Nicht codiert
                    Fahrert¸r: geschlossen
                    Beifahrert¸r: geschlossen
                    T¸r hinten links: offen
                    T¸r hinten rechts: geschlossen
                    Active_LF_scans: Init
                    ID-Sensor 1 Authentifizierung: Status: keine Antwort
                    ID-Sensor 2 Authentifizierung: Status: keine Antwort
                    ID-Sensor 3 Authentifizierung: Status: keine Antwort
                    ID-Sensor 4 Authentifizierung: Status: keine Antwort
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
1052936 - Sensor f¸r T¸rauflengriffber¸hrung Fahrerseite
          B116B 29 [00001001] - unplausibles Signal
                    Fehlerpriorit‰t: 4
                    Fehlerh‰ufigkeit: 2
                    Verlernz‰hler: 136
                    Datum: 2025.01.26
                    Zeit: 15:26:26
                    ZAT_pressed: aus
                    Control Module Voltage: 11.554 V
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:| DRV\5G0-907-044.clb
   Teilenummer SW: 5G0 907 044 FH    HW: 5G0 907 044 FH
   Bauteil: Climatronic   H04 2401
   Revision: 00001K10
   Codierung: 12020104202414011115100E8010D836
   Betriebsnr.: WSC 00015 115 08193
   ASAM Datensatz: EV_ACClimaBHBVW37X 006151
   VCID: 72BC2091542254CA59F-8027
   Steuerger‰t f¸r Frischluftgebl‰se (vorn):
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Sensor f¸r Luftg¸te:
   Geber f¸r Luftfeuchtigkeit: auflen:
1 Fehler gefunden:
1048835 - Funktionseinschr‰nkung durch Motorsteuerger‰t
          P1719 00 [00001000] - -
          [PTC-Reduzierung durch MSG]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 175
                    Kilometerstand: 62049 km
                    Datum: 2025.01.16
                    Zeit: 07:09:07
                    Spannung Klemme 30: 14.0 V
                    Luftzusatzheizung: stufig-Freigabe f¸r Zuheizbetrieb: Freigabe Stufe 3
                    Luftzusatzheizung: stufig-Istwert: 2
                    Luftzusatzheizung: stufig-Sollwert: 3
                    Luftzusatzheizung: stufig-Sollwert der Regelung: 3
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\5Q0-937-08X-V2.clb
   Teilenummer SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
   Bauteil: BCM PQ37BOSCH 038 0303
   Revision: --------    Seriennummer: J53F171219001P Datenstand-Nummer: V03935318QL 0001
   Codierung: 000000000000000000000000000000000000000000000000000000000000
   ASAM Datensatz: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 7F5AF9A5177009A2261-802B
   Steuerger‰t f¸r Wischermotor:
   Subsystem 1 - Teilenummer SW: 3G1 955 119 A    HW: 3G1 955 119   Labeldatei: DRV\5QX-955-119-V1.CLB
   Bauteil: WWS    191030  042  0607
   Seriennummer:         191126155952
   Codierung: 0E4DDD
   Sensor f¸r Regen- und Lichterkennung:
   Subsystem 2 - Teilenummer SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Bauteil: RLHSS  051  0207
   Seriennummer: S6Y20M01D09H03M15S36
   Codierung: 0008EE
   Lichtschalter:
   Subsystem 3 - Teilenummer SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Bauteil: E1 - LDS MQB  H01  0032
   Seriennummer: 27 10 2019  10000165
   Geber f¸r Luftfeuchtigkeit: innen:
   Lenkstockschalter:
   Subsystem 5 - Teilenummer SW: 5Q1 953 521 AC    HW: 5Q1 953 569 B
   Bauteil: Lenks.Modul  H23  0170
   Seriennummer: 0100070120200C301375
Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\5Q0-919-298.clb
   Teilenummer SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Bauteil: PLA 3.0 12K   H08 0061
   Seriennummer: 000150057220009 Datenstand-Nummer: V03935305GY 0001
   Codierung: 0271267951
   Betriebsnr.: WSC 05311 115 00074
   ASAM Datensatz: EV_EPHVA2CAU3700000 009048
   VCID: 55F67B0DC58C23F25CD-8001
1 Fehler gefunden:
13688835 - Datenbus empfangener Fehlerwert
          U1123 00 [00001000] - -
          [Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 2
                    Verlernz‰hler: 174
                    Kilometerstand: 62042 km
                    Datum: 2025.01.09
                    Zeit: 06:14:36
Adresse 13: Distanzregelung (J428)       Labeldatei:| 5Q0-907-572-V2.clb
   Teilenummer SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Bauteil: ACC BOSCH MQB H01 0771
   Datenstand-Nummer: V03935308RK 0001
   Codierung: 32057F5B5DFFC728949C812481400680000000000000000066
   ASAM Datensatz: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 46D4AC41082A986A257-8013
1122 - Datenbus unplausible Botschaft
          U1122 00 [00001000] - -
          [FAULT_TSK_TO_PASSIVE_PLAUS_FAIL]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 176
                    Datum: 2025.01.22
                    Zeit: 18:24:10
                    Steuerger‰tetemperatur: 21 ∞C
                    Spannung Klemme 15-Voltage: 12.0 V
                    Fahrzeuggeschwindigkeit: 0.00 m/s
                    L‰ngsbeschleunigung: 0.00 m/s≤
                    Adaptive Abstandsdistanzregelung: Status: ACC_activ_controlled
2071 - Datenbus unplausible Botschaft
          [FAULT_VDIS_PLAUS_FAIL]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 174
                    Datum: 2025.01.09
                    Zeit: 00:15:30
                    Steuerger‰tetemperatur: 35 ∞C
                    Spannung Klemme 15-Voltage: 14.4 V
                    Adaptive Abstandsdistanzregelung: Status: ACC_Off_MainSwitch_Off
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5Q0-959-655.clb
   Teilenummer SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Bauteil: Airbag VW21   006 0720
   Revision: --------    Seriennummer: 003Z4PS8TEU4 Datenstand-Nummer: V03935300VT 0001
   Codierung: 88CCC000000000005C5400CF000840000065
   Betriebsnr.: WSC 05311 000 08193
   ASAM Datensatz: EV_AirbaVW21TS6VW48X 001014
   VCID: 0E44546120DA102ADD7-805B
   Gurtstraffer links:
   Subsystem 1 - Teilenummer SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Bauteil: BeltPretRevFL  106 1040
   Seriennummer: 3G0857705B0350T01686
   Codierung: 80000D
   Gurtstraffer rechts:
   Subsystem 2 - Teilenummer SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Bauteil: BeltPretRevFR  106 1040
   Seriennummer: 3G0857706B0013U00590
   Codierung: 80000D
   Crashsensor f¸r Seitenairbag Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 454 003 011 19
   Bauteil: SideSensor_Df  008 0887
   Seriennummer: 3570000000026034B345
   Codierung: 2D2D2D
   Crashsensor f¸r Seitenairbag Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 454 003 011 19
   Bauteil: SideSensor_Pf  008 0887
   Seriennummer: 35800000000D1C09C34R
   Codierung: 2D2D2D
   Crashsensor f¸r Seitenairbag hinten Fahrerseite:
   Subsystem 5 - Teilenummer SW: -----------    HW: 454 802 411 19
   Bauteil: SideSensor_Dr  301 0148
   Seriennummer: 3510016AB891A000000M
   Codierung: 2D2D2D
   Crashsensor f¸r Seitenairbag hinten Beifahrerseite:
   Subsystem 6 - Teilenummer SW: -----------    HW: 454 802 411 19
   Bauteil: SideSensor_Pr  301 0148
   Seriennummer: 352000982751A0000009
   Codierung: 2D2D2D
   Crashsensor f¸r Frontairbag Fahrerseite:
   Subsystem 7 - Teilenummer SW: -----------    HW: 454 801 811 19
   Bauteil: FrontSensor_D  304 0149
   Seriennummer: 35500DB18901A000000N
   Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5G0-920-XXX-17.clb-SRI3
   Teilenummer SW: 3G0 920 320 A    HW: 3G0 920 320 A
   Bauteil: KOMBI         503 4193
   Codierung: 05A408186F8C00080188624B1001000880700100
   Betriebsnr.: WSC 05311 115 00291
   ASAM Datensatz: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 1B622D35E328B582AA9-804F
1 Fehler gefunden:
16711681 - Ethernet-Datenbus
          U11C4 00 [00001000] - keine Kommunikation
                    Fehlerpriorit‰t: 4
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 176
                    Kilometerstand: 62223 km
                    Datum: 2025.01.22
                    Zeit: 16:23:23
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
   Teilenummer SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Bauteil: GW MQB High   442 4388
   Revision: --------    Seriennummer: 0000253055 Datenstand-Nummer: V03935313SG 0001
   Codierung: 0B0900345F087300F910425E180F00000001070000000000000000000000
   GVL: 01463C0008000608C0CC80008082C80000000000000200000000000000000000
   ASAM Datensatz: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B82A995A2E66DAAFB-8025
   Generator:
   Bauteil: 4-01-09-01-04
   Steuerger‰t f¸r Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 3G0 959 442 K    HW: 3G0 959 442 K  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-PR6  H06 0110
   Seriennummer: PR6-0440066346190238
   Codierung: 2F0B00
   Steuerger‰t f¸r Batterie¸berwachung:
   Subsystem 3 - Teilenummer SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Bauteil: J367-BDMConti  H03 1051
   Seriennummer: 75886003002001080AD0
   Wechselrichter f¸r Netzsteckdose:
   Subsystem 4 - Teilenummer SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Bauteil: U13DCAC  H27 0810
   Seriennummer: 3140605
Adresse 23: Bremskraftverst. (J539)       Labeldatei:. 5QE-909-059.clb
   Teilenummer SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Bauteil: EBKV          H06 0069
   Seriennummer: BPA085090120013
   Codierung: 0102C100340000C618638C31000049922449920400
   ASAM Datensatz: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW37.rod
   VCID: 3B22CDB543E8D5824A9-806F
1 Fehler gefunden:
172400 - Spannungsversorgung
          P0562 00 [00101000] - Spannung zu klein
          [PSCUnderVoltageLevel1]
                    Fehlerpriorit‰t: 3
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 5
                    Datum: 2025.01.27
                    Zeit: 12:21:31
Adresse 2B: Lenks‰ulenverrieg. (J764)       Labeldatei:| DRV\1EA-905-861.clb
   Teilenummer SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Bauteil: ELV-MQBB      H05 0020
   Seriennummer: 19000352633009
   Codierung: 0800000000000000
   ASAM Datensatz: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3332E5956BB81DC2929-8067
Adresse 3C: Spurwechsel (J1086)       Labeldatei:* Umleit. fehlgeschl.!
   Teilenummer SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Bauteil: HRE3_Kl15_Mst H06 0150
   Seriennummer: 00000536276347  Datenstand-Nummer: V03935303MB 0001
   Codierung: 62A54640
   ASAM Datensatz: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392ED7BD49D4E792585-806D
   Steuerger‰t 2 f¸r Spurwechselassistent:
   Subsystem 1 - Teilenummer SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Bauteil: HRE3_Kl15_Slv  H06 0150
   Seriennummer: 00000536388065
1 Fehler gefunden:
2240558 - Datenbus empfangener Fehlerwert
          [databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 2
                    Verlernz‰hler: 39
                    Datum: 2025.01.09
                    Zeit: 06:14:35
Adresse 42: T¸relektr. Fahrer (J386)       Labeldatei:| 5QX-959-X93-42.clb
   Teilenummer SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Bauteil: TSG FS002 0330
   Seriennummer: YE007SL323158 Datenstand-Nummer: V03935310MJ 0001
   Codierung: 00350B20D000028000001000
   ASAM Datensatz: EV_DCU2DriveSideMAXHKLO 001018
   VCID: 49CEA77D19347712C85-801D
1 Fehler gefunden:
196660 - Motor f¸r Fensterheber
          B1487 54 [00001000] - keine Grundeinstellung
                    Fehlerpriorit‰t: 5
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 174
                    Datum: 2025.01.09
                    Zeit: 00:14:08
Adresse 44: Lenkhilfe (J500)       Labeldatei:| 5Q0-910-143.clb
   Teilenummer SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Bauteil: MQB_VWBS_GEN2 212 2211
   Seriennummer: 037007 00  Datenstand-Nummer: V03935290ME 0001
   Codierung: 0101001100400010
   Betriebsnr.: WSC 00015 115 00323
   ASAM Datensatz: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
Adresse 47: Soundsystem (J525)       Labeldatei:* Keine
   Teilenummer SW: 3G0 035 466     HW: 3G0 035 466
   Bauteil: AMPeth16C     H07 3027
   Seriennummer: A1130A00011679  Datenstand-Nummer: V03935304LL 0001
   Codierung: 24020000000000000000000000000000000000000000000000
   ASAM Datensatz: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW48.rod
   VCID: 629C50D184C2C44A29F-8037
Adresse 4B: Multifunktionsstg. (J745)       Labeldatei:* Keine
   Teilenummer SW: 3Q0 907 338 F    HW: 3Q0 907 338 F
   Bauteil: FCM MQB High  004 0370
   Seriennummer: 12121910802837 Datenstand-Nummer: V03935307YR 0001
   Codierung: 000000070B0003CA00000F11000300040000000000000000000000000000
   ASAM Datensatz: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 3828D2B972DEFE9AA7B-806D
   Antenne f¸r Nahbereichskommunikation:
   Subsystem 1 - Teilenummer SW: 3G1 959 121     HW: 3G1 959 121
   Bauteil: R350 NFCTGS  701 0509
   Seriennummer: 0000000000B34B5201CE
   Antenne 2 f¸r Nahbereichskommunikation:
   Subsystem 2 - Teilenummer SW: 3G0 980 611     HW: 3G0 980 611
   Bauteil: J524 NFCMIKO  H09 0059
   Seriennummer: 32000000000000093785
Adresse 52: T¸relektr. Beifahr. (J387)       Labeldatei:| 5QX-959-X92-52.clb
   Teilenummer SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Bauteil: TSG BFS002 0330
   Seriennummer: YE007SKU1297E Datenstand-Nummer: V03935310MD 0001
   Codierung: 00350120DC00028000001000
   ASAM Datensatz: EV_DCU2PasseSideMAXHKLO 001018
   VCID: 48C8A279023E8E1AD7B-801D
Adresse 5F: Informationselek. I (J794)       Labeldatei:| DRV\3G5-035-MIB-HGH3.clb
   Teilenummer SW: 3G5 035 816 B    HW: 3G5 035 816
   Bauteil: MU-O-ND-EU    H12 0324
   Seriennummer: VWZAZ2X0510930  Datenstand-Nummer: V03935352YP 0001
   Codierung: 24820000000020000000000000000000000000000000000000
   ASAM Datensatz: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW48.rod
   VCID: 280802F9A27E6E1A37B-807D
   Anzeige- und Bedienungseinheit 1 f¸r Informationselektronik:
   Subsystem 1 - Teilenummer SW: 5G6 919 606     HW: 5G6 919 606
   Bauteil: ABT_High-2     H61 9214
   Seriennummer: VWZ6ZJX0143534
   Datentr‰ger:
   Subsystem 2 - Teilenummer: V03 959 806 MG
   Bauteil: EU 2019/04     1004
Adresse 69: Anh‰nger (J345)       Labeldatei:| DRV\5Q0-907-383.clb
   Teilenummer SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Bauteil: Anhaenger     H27 0264
   Revision: 8A001003    Seriennummer: 0536621138 Datenstand-Nummer: V03935259HF 0001
   Codierung: 0100000202000000
   ASAM Datensatz: EV_TrailFunctGener2Hella 001008
   VCID: 42DCB0512402A44A09F-8017
Adresse 6C: R¸ckfahrkamera (J928)       Labeldatei:* Keine
   Teilenummer SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Bauteil: Areaview 2    H13 0608
   Seriennummer: C854707JG069268 Datenstand-Nummer: V03935306JD 0001
   Codierung: 01840201E30F200000204014
   ASAM Datensatz: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Adresse 6D: Heckklappe (J605)       Labeldatei:| DRV\5Q0-959-107.clb
   Teilenummer SW: 5Q0 959 107 R    HW: 5Q0 959 107 H
   Bauteil: HDSG-Modul    H13 0271
   Revision: --------    Seriennummer: A2-C737-6331-8 Datenstand-Nummer: V03935316ZS 0001
   Codierung: 0280
   ASAM Datensatz: EV_DeckLidCONTIAU736 001017
   ROD: EV_DeckLidCONTIAU736_VW48.rod
   VCID: 47CAA1450F208162DE1-8013
Adresse 75: Telematik (J949)       Labeldatei:* Keine
   Teilenummer SW: 5WA 035 284 G    HW: 5WA 035 284
   Bauteil: OCUGen3High   H20 0143
   Seriennummer: 0000000909VIUQ4 Datenstand-Nummer: V03935450DD 0001
   Codierung: 024820001968A8209005460160502607
   ASAM Datensatz: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACC98711C327C0AC1F-801F
1 Fehler gefunden:
0081 - Datenbus fehlende Botschaft
          U1121 00 [00001000] - -
          [Ethernet Databus missing message - Infotainment Unit]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 40
                    Datum: 2025.01.22
                    Zeit: 16:23:26
                    Spannung Klemme 30: 13.2 V
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| 2Q0-980-653.clb
   Teilenummer SW: 2Q0 980 653     HW: 2Q0 980 653
   Bauteil: MQB MFK 3.0   H11 1029
   Seriennummer: E33417011200130 Datenstand-Nummer: V03935317TQ 0001
   Codierung: 00000898217CC020109E10001030008000410000000000000000000000000000
   ASAM Datensatz: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
Adresse BB: T¸relektronik hinten links (J388)       Labeldatei:* Keine
   Teilenummer SW: 5Q0 959 395 K    HW: 8W1 959 395 D
   Bauteil: TSG HFS004 0330
   Seriennummer: YE007SKK24332 Datenstand-Nummer: V03935306SB 0001
   Codierung: 000001200100028000001000
   ASAM Datensatz: EV_DCU2RearDriveMAXHKLO 001018
Adresse BC: T¸relektronik hinten rechts (J389)       Labeldatei:* Keine
   Bauteil: TSG HBFS004 0330
   Seriennummer: YE007SKK24351 Datenstand-Nummer: V03935306RQ 0001
   ASAM Datensatz: EV_DCU2RearPasseMAXHKLO 001018
Adresse D6: Lichtsteuerung links 2 (A31)       Labeldatei: 7PP-941-572.clb
   Teilenummer SW: 992 941 572 CA    HW: 992 941 572 C
   Bauteil: LED1L         H08 9002
   ASAM Datensatz: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 649056C99ED6CA7ADB3-8031
1 Fehler gefunden:
131353 - Datenbus fehlende Botschaft
          U1121 00 [00101000] - -
          [CAN message Klemmenstatus_01 missing]
                    Fehlerpriorit‰t: 4
                    Fehlerh‰ufigkeit: 2
                    Verlernz‰hler: 10
                    Kilometerstand: 62323 km
                    Datum: 2025.01.22
                    Zeit: 17:29:10
Adresse D7: Lichtsteuerung rechts 2 (A27)       Labeldatei: 7PP-941-572.clb
   Bauteil: LED1R         H08 9002
   ASAM Datensatz: EV_LLPGen3RKEBODPO68X 001003
1 Fehler gefunden:
                    Fehlerpriorit‰t: 4
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 10
                    Datum: 2025.01.22
                    Zeit: 17:29:10
Ende--(Dauer: 02:16, Batt.-Spannung Start/Ende: 11.4V/11.4V. VIgn 11.5V)---
I'm not sure I understand. If the car only has a Kessy door handle installed ("verbaut") on the driver's door, you can't install one on the passenger side just by telling it that car there there is one now.
PS: Please use the standard English version to post data in this forum. You can download it from this page and it will happily coexist on your PC with the German translation you are currently using.
This Car has only keyless start, No keyless entry.
OK, then what I wrote applies to both door handles, not just the passenger side, right?
2kaa52
Ceska Republica, Praha
C?ID=319193
To get keyless entry working, kessy door handles ( Front or Front+ rear ) must retrofited, incl. Another kessy ECU, rear kessy antenna and wiring . Immo Adaption and dataset must be done.
I have a solution to get it working with only one kessy door handle. Most people use kessy 95% at the Driver door.
ursl55
Berlin, Germany
Hi peeps. thanks yes that was the information i was looking for. i wanted to know if i can somehow activate keyless entry just for the drivers side as there is the handle. but if its like @2kaa52 said, then thats it.
im not looking to retrofit it, just thought i would be able to activate it for the drivers side.
sorry for the german log. will post in english in the future!
2kaa52
C?ID=319193
Not possible by simple coding
iichel
Netherlands, Operation Market Garden
C?ID=284912
3Q0 959 435 M is a kessy module that will support four kessy door handles and keyless entry
siLc
Tallinn, Estonia
C?ID=330192
If kessy door handles are desired, then something like this is in store.
