my headlights are on all the time along with the DRL
lanceborg
C?ID=247830
My headlights are on all the time.
When I have the switch off during the daytime the headlights and the drl's are on. At night when I switch the headlights on the drl's go off but the headlights remain. So the headlights are on all the time. How do i shut them off during the day so only my drl's are the only thing on. Thank You in advance
Is this in the same car as your previous thread?
If so, please post a current Auto-Scan because your BCM was more-or-less out to lunch during the scan you posted there and that module is what controls your lighting.
lanceborg
C?ID=247830
Sunday,06,December,2015,22:11:17:27097
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: 3VWTL7AJ0AM63XXXX   License Plate: LANCE
Mileage: 253740km-157666mi   Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 65
          72 77
VIN: 3VWTL7AJ0AM63XXXX   Mileage: 253740km-157666miles
   Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000AG  7967
   Revision: 12H02---    Serial number:
   Coding: 0050078
   Shop #: WSC 84352 290 591400
   VCID: 78FFAC0F0BBA92FE65-802C
001136 - Exhaust Pressure Sensor 1 (G450)
               P0470 - 000 - Malfunction - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 244523 km
                    Date: 2015.07.30
                    Time: 21:21:53
                    RPM: 828 /min
                    Temperature: 29.7°C
                    Temperature: 85.5°C
                    Temperature: 84.0°C
                    Pressure: 326 mbar
                    Pressure: 26 mbar
001025 - EGR System
               P0401 - 000 - Insufficient Flow - Intermittent
                    Fault Frequency: 18
                    Mileage: 252565 km
                    Date: 2015.11.14
                    Time: 00:39:40
                    RPM: 1242 /min
                    Speed: 62.0 km/h
                    Voltage: 13.53 V
                    Load: 66.7 %
                    Load: 100.0 %
                    Mass Air / Rev.: 240.0 mg/str
                    Mass Air / Rev.: 330.0 mg/str
Readiness: 1 2 0 0 0
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1920
   Revision: 04944002    Serial number: 00000909241430
   Shop #: WSC 02069 000 90108
   VCID: 51A931ABC880E3B682-8004
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 114B600C49250002880F06E492220042B100
   Shop #: WSC 00066 000 00000
   VCID: 000FC4EF936ADA3E5D-8054
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00008001
   Coding: 0000000000
   Shop #: WSC 00066 000 00187
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 387F6C0F833A52FEA5-806C
   Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
   Component: BCM PQ35 B++  008 3019
   Revision: BI008001
   Coding: 6D380E1F902F3EC480C800054000008401000086535D8560648020000000
   Shop #: WSC 00066 123 12345
   VCID: 33655B23925CB1A690-8066
   Component: Wischer 24110  21  0501
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 89
                    Mileage: 251257 km
                    Date: 2015.10.22
                    Time: 09:28:18
                    Voltage: 13.65 V
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D07G70J
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 3979690BB8304BF65A-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0004WV4400
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME2358054CZZZW
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME1E6B014BZZZ%
   Serial number: 3511HSME456E641DZZZY
   Serial number: 3521HSME5C5C641DZZZ/
   Serial number: 35527SME64711F1DZZZO
   Serial number: 35627SME0D04711CZZZF
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001734
   VCID: 76E3A23701AEE48E77-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
   Part No SW: 5K0 920 970 L    HW: 5K0 920 970 L
   Component: KOMBI         H08 0021
   Revision: V0008011    Serial number:
   Coding: 270F00
   Shop #: WSC 00066 000 00147
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 377D6F338E245D86AC-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AB    HW: 1K0 907 951
   Component: J533  Gateway   H06 0081
   Revision:   H06 01    Serial number: 071009F2002831
   Coding: ED807F07001613002002
   VCID: 67DDFF7356040D06FC-8032
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T6DFG04
   Coding: 0000002
   VCID: 7EF3BA17299EACCE2F-802A
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   ROD: EV_ImmoUDSMM9RM10_SE25.rod
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667603433
   VCID: 2643B277518ED40E07-8072
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1525
   Revision: 72009005    Serial number: 00000638799113
   Coding: 0001205
   VCID: 6FED97537EF4D546B4-803A
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   VCID: 2F6D5753BE749546F4-807A
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0081
   Coding: 050B0500
   VCID: 66C3F277910E140EC7-8032
   Component: J245EE19SKB12  H01 0220
   Component: J394EE19SKB12  H01 0220
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1525
   Revision: 72009005    Serial number: 00000510499031
   Coding: 0001204
   VCID: 70EF942F63CACABEAD-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Fault Status: 00101100
                    Reset counter: 227
                    Mileage: 245944 km
                    Date: 2015.08.12
                    Time: 10:59:12
                    Fault Status: 00111000
                    Reset counter: 227
                    Mileage: 245977 km
                    Date: 2015.08.12
                    Time: 13:32:49
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7J3043363
   Coding: 0100040004
   VCID: 61C9E16B7820733632-8034
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000004457365
   Coding: 0001168
                    Fault Frequency: 27
                    Reset counter: 214
                    Mileage: 252575 km
                    Date: 2015.11.14
                    Time: 08:14:45
                    Reset counter: 214
                    Mileage: 252575 km
                    Date: 2015.11.14
                    Time: 08:14:44
Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
                    Mileage: 245847 km
                    Date: 2015.08.11
                    Time: 00:44:45
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000004459513
   Coding: 0001168
   VCID: 77FDAF3306A49D866C-8022
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668437363
   Coding: 0A00000000010100
   Shop #: WSC 05314 115 00000
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 326B5E276546B8AE9B-8066
End-------------------------(Elapsed Time: 02:53)--------------------------
lanceborg
C?ID=247830
just a like. do you have any input.
If I did, I would have posted it. :)
langers2k
C?ID=224085
Check the long coding for the BCM, I think there is a 'Permanent Running Light (PRL) via Low Beam active' setting somewhere, possibly in bit 2 in byte 11?
Bits for DRL activation suppressed, Audi DIS, PRL (per the above suggestion), DRL in addition to one that isn't documented appear to be tweaked from a normal factory config. You can either paste the last known original or functional coding back into that controller based on the oldest Auto-Scan or try this:
6D380E1F902F3EC480080001400000C401000086535D8560648020000000
