- Jan 21, 2023
- 30
- 0
- Netherlands
- C?ID=533456
Hi all,
Does anyone know how to disable te original US sidemarkers (i dont mean the turnsignals).
Thanks in advance.
Thanks in advance.
Saturday,25,January,2025,16:38:22:52471
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUB8GFF8G1006314 License Plate: JAAP
Mileage: 87630km-54450mi Repair Order: scan 1
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C BB
BC
VIN: WAUB8GFF8G1006314 Mileage: 87630km-54450miles
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13--- CVN: 77B58FDE
Coding: 0A1D00124426000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F3A126D17918302F61-807A
VINID: 9D19522175962170400060C110307810EC
21406 - EVAP Emission Control Sys
P0441 00 [00100000] - Incorrect Flow
Part No SW: 0D9 300 013 B HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01505102413 CVN: 000019E2
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1674C789880B52CA957-8042
13 Faults Found:
21153 - Gear 1
P072C 00 [00000010] - Not Selectable
21154 - Gear 2
P072D 00 [00000010] - Not Selectable
21155 - Gear 3
P072E 00 [00000010] - Not Selectable
21156 - Gear 4
P072F 00 [00000010] - Not Selectable
21157 - Gear 5
P073A 00 [00000010] - Not Selectable
21158 - Gear 6
P073B 00 [00000010] - Not Selectable
21159 - Gear R
P072B 00 [00000010] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [00000010] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [00000010] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [00000010] - Implausible Signal
21207 - Pressure Control Solenoid 3
P0797 00 [00000010] - Stuck ON
10906 - Cooling Oil Valve
P179D 00 [00000010] - Electrical Malfunction
P1734 00 [00000010] - -
Part No SW: 3Q0 907 379 K HW: 3Q0 907 379 F
Component: ESC H42 0622
Revision: 00000000 Serial number: 61275000000772
Coding: 13FF6A9234200A72017A030181C729C8562C5080C08194B4024100588208
ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
VCID: 42DC4BD9B4031E6A09F-8016
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 244
Mileage: 71346 km
Date: 2023.09.28
Time: 05:36:27
Revision: 00021000 Serial number: 0367950814 Dataset Number: 8V0909577C 0009
Coding: 030C0C
VCID: 3A2C3339DCD356AA51F-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000650194
Coding: 03000014010000000000000000001400
VCID: 33321E1DFBB9A7E2929-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 843949A7000000000001
328964 - Motor for Front Air Distribution Flap
B1091 71 [00001000] - Actuator Stuck
Fault Frequency: 114
Reset counter: 113
Mileage: 80277 km
Date: 2024.04.13
Time: 03:36:37
Voltage terminal 30: 14.1 V
Inside temperature: 24.4 °C
Outside temperature: 19.5 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 100.0 %
Air distribution door front - Specified value: 92
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0173
Serial number: 01061513200080 Dataset Number: 8V0909514R 0093
Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7F5A022D8771B382261-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150512 042 0585
Serial number: 150521160655
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23972616
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 10 03 2015 00000107
Serial number: 00000000000062591035
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000BE7ZV00000
Coding: 101F00
B1263 01 [00001001] - Electrical Failure
Reset counter: 201
Mileage: 68741 km
Date: 2023.07.02
Time: 04:27:36
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 12.5 V
Outside temperature: 33.0 °C
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 142
Mileage: 72513 km
Date: 2023.10.17
Time: 17:58:00
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.6 V
Outside temperature: 6.5 °C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391513509997 Dataset Number: 8V0909526E 0042
Coding: 0010150011
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 43D24EDDAB191762029-8016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR026M13 Dataset Number: 8V0909602G 0003
VCID: 47CA5ACD9F213B42DE1-8012
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B21051571566
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B22051540129
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 C HW: 5C6 959 339 C
Component: BF-Gewichtss. H10 0047
Serial number: 6940000Y150001CHCP0/
Coding: 303435
Subsystem 4 - Part No SW: ----------- HW: 480 001 905 15
Serial number: 3570000000027639A41E
Subsystem 5 - Part No SW: ----------- HW: 480 001 905 15
Serial number: 3580000000037639A41G
Subsystem 6 - Part No SW: ----------- HW: 480 400 405 15
Serial number: 3510002B31A8787281B2
Subsystem 7 - Part No SW: ----------- HW: 480 401 805 15
Serial number: 3520002BF1B0CB322093
Subsystem 8 - Part No SW: ----------- HW: 480 402 502 15
Serial number: 3550002C719DB8B4E28T
Subsystem 9 - Part No SW: ----------- HW: 480 402 502 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C719DB8B541FR
Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 21051508491352
Coding: A018
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 055690C5E5ADE9526CD-8050
Part No SW: 8V0 920 960 M HW: 8V0 920 960 M
Component: KOMBI H03 6420
Coding: 0BE418192B80D7050200A8001800000000000000
VCID: 45D650C5A52D29522CD-8010
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 23051510801950 Dataset Number: 8V0909515J 0062
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
GVL: 01D43C0000000600400C10000002C80000000000000000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 75B6E005B54DF9D27CD-8020
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 18 05 2015 C0038198
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00015.04.15 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 46D457C9982B224A257-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000129161001
Coding: 5D00000000000000
VCID: 34301D01FEB7A0DA8B3-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 090515BE814655 Dataset Number: 8V0909872G 0035
Coding: 00101B204000048000000002
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 41DE44D5B1050572105-8014
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Dataset Number: 8V0909852K 0022
Coding: 0102
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 100515BEA00494 Dataset Number: 8V0909873G 0035
Coding: 001013204000048000000002
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 40D841D1BA0F0C7A1FB-8014
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0039
Coding: 012A000101000000
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 013 0660
Serial number: A7A02205151053 Dataset Number: 8V1909545D 0042
Coding: 01730100FF0A000011220001001A00002F0001440100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 392E2C35D9D55DB2585-806C
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30B58M
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000004031500010102
Reset counter: 200
Mileage: 68741 km
Date: 2023.07.01
Time: 23:35:13
Voltage terminal 30: 12.7 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Dataset Number: 8V0909460C 0017
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE_AU37.rod
VCID: 303811110AAF9CFAEFB-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 030515BE21677B Dataset Number: 8V0909897E 0021
Coding: 000013204000048000000002
ROD: EV_DCURearDriveMAXKLO.rod
Component: TSG HBFS 020 0041
Serial number: 030515BE216775 Dataset Number: 8V0909896E 0021
ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:43, VBatt start/end: 14.7V/14.7V)-----------
