VW Passat 2013 help needed to code 22-AWD after replacement from aftermarket
asids
Riga, Latvia
C?ID=90884
Hello!
I need to recode 22-AWD module for manual transmission. Donor car has automatic transmission and now I have in 22-AWD DTC - no communications with AT module!
Could some one help me to do propper codding for this module?
Car full scan follows !
Many thanks,
Andris.
Friday,24,January,2025,13:33:12:02010
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4658.4
VIN: WVWZZZ3CZEE030879   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 4F 52 53 56 61 62 72
VIN: WVWZZZ3CZEE030879   Mileage: 479820km-298146miles
   Part No SW: 03L 906 018 PS    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number: 00000000000000 CVN: 00DB13E8
   Coding: 00190012042601080000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PS 003008
   ROD: EV_ECM20TDI01103L906018PS.rod
   VCID: 0A4D5FD2ACBF34FA01F-805E
   VINID: 9E69EAAAA0D3A955400C020724552EDEA6
15 Faults Found:
4875 - Coolant Pump 2
          P261A 00 [00100000] - Open circuit
                    Mileage: 479287 km
                    Date: 2025.01.19.
                    Time: 15:55:41
                    Engine RPM: 0.00 /min
                    Coolant temperature: 8 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 12.140 V
                    Unlearning counter according OBD: 35
                    Coolant temperature at radiator outlet: actual value: -40.0 °C
                    Bypass valve for EGR cooler: status-Bits 0-7: 0
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 0
                    EGR cooling function: status-Bits 0-7: 1
                    exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
                    Temp sensor for EGR after cooler: raw value: -270.6 °C
                    Exhaust gas temperature sensor 1: 15.0 °C
5132 - Valve for Fuel Metering (N290)
          P0090 00 [00100000] - Open Circuit
                    Mileage: 479287 km
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 12.240 V
                    Engine status: COENG_READY
5177 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [00100000] - Open Circuit
                    Mileage: 479287 km
4238 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
          P2185 00 [00100000] - Signal too High
                    Mileage: 479287 km
                    Date: 2025.01.19.
                    Time: 15:55:37
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside temperature: 4.5 °C
                    Fuel consumption: 0.00 l/h
                    Fuel temperature: 6.6 °C
                    Engine oil temperature: 56.0 °C
5134 - Valve for Fuel Metering (N290)
          P0091 00 [00100000] - Short to Ground
                    Mileage: 479287 km
5179 - Fuel Pressure Regulator Valve (N276)
          P2295 00 [00100000] - Short to Ground
                    Mileage: 479287 km
5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [00100000] - Open Circuit
                    Mileage: 479287 km
                    Charge Pressure Actuator: activation: 10.00 %
                    Charge air pressure actuator: acknowledgment: 14.07 %
                    Turbocharger boost control: offset closed: -2.50 %
                    High press turbocharger actuator: status-Bits 0-7: 0
                    High press turbocharger actuator: status-Bits 0-7: 8
                    High press turbocharger actuator: status-Bits 0-7: 7
                    High press turbocharger actuator: actual uncond volt value: 3403.4 mV
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [01100000] - Electrical Fault
                    Mileage: 479287 km
                    Date: 2025.01.19.
                    Time: 15:55:39
                    Voltage terminal 30: 12.160 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 28
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 2500 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 6
                    Glow cycles above temperature threshold-Bits 0-7: 212
                    Glow cycles below temperature threshold-Bits 0-7: 8
                    Glow cycles below temperature threshold-Bits 0-7: 130
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [01100000] - Electrical Fault
                    Mileage: 479287 km
                    Date: 2025.01.19.
                    Time: 15:55:39
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [01101101] - Electrical Fault
                    Mileage: 477554 km
                    Date: 2024.12.22.
                    Time: 10:25:24
                    Coolant temperature: 3 °C
                    Intake air temperature: 2 °C
                    Voltage terminal 30: 12.120 V
                    Glow cycles above temperature threshold-Bits 0-7: 211
                    Glow cycles below temperature threshold-Bits 0-7: 99
                    Outside temperature: 1.5 °C
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [01100000] - Electrical Fault
                    Mileage: 479287 km
                    Date: 2025.01.19.
                    Time: 15:55:39
4713 - No Communication with ABS Brake Control Module
          U0121 00 [00100000] - -
          [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                    Mileage: 477625 km
                    Date: 2024.12.27.
                    Time: 14:12:07
                    Engine RPM: 831.50 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 64 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.820 V
                    Unlearning counter according OBD: 21
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
4716 - No Communications with Parking Brake Control Module
          U0128 00 [00100000] - -
                    Mileage: 477625 km
                    Date: 2024.12.27.
                    Time: 14:12:07
7934 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [00100000] - Implausible Signal
                    Mileage: 477346 km
                    Date: 2024.12.21.
                    Time: 03:38:06
                    Engine RPM: 981.00 /min
                    Normed load value: 19.2 %
                    Coolant temperature: 70 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 14.900 V
                    Unlearning counter according OBD: 19
                    Charge Pressure Actuator: activation: 99.17 %
                    Charge air pressure actuator: acknowledgment: 47.50 %
                    Turbocharger boost control: offset closed: -0.54 %
                    High press turbocharger actuator: status-Bits 0-7: 55
                    High press turbocharger actuator: status-Bits 0-7: 4
                    High press turbocharger actuator: actual uncond volt value: 2341.0 mV
9127 - Actuator Module for Turbocharger 1
          P00AF 00 [00100000] - Stuck
                    Mileage: 477346 km
                    Date: 2024.12.21.
                    Time: 03:38:20
                    Engine RPM: 996.50 /min
                    Normed load value: 18.0 %
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.860 V
                    Charge Pressure Actuator: activation: 99.01 %
                    Charge air pressure actuator: acknowledgment: 12.32 %
                    High press turbocharger actuator: status-Bits 0-7: 63
                    High press turbocharger actuator: actual uncond volt value: 3396.6 mV
Readiness: 0 0 0 0 X
   Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
   Component: J104   C2 450M V46F 0030
   Revision: --H07---    Serial number: 00000007242385
   Coding: 0002486
   Shop #: WSC 05311 000 00000
   VCID: 7BA30A16FFE51D720A9-802E
01324 - Control Module for All Wheel Drive (J492)
                    Fault Frequency: 39
                    Reset counter: 150
                    Mileage: 477591 km
                    Date: 2019.05.16.
                    Time: 13:25:60
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 256
                    Hex Value: 0x0000
00576 - Terminal 15
                    Reset counter: 132
                    Mileage: 477680 km
                    Date: 2019.05.21.
                    Time: 11:33:34
                    Hex Value: 0x0000
                    Voltage: 14.75 V
                    Bin. Bits: 00111110
                    Count: 128
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 BB    HW: 3AA 907 044 BB
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 061400C803
   Shop #: WSC 00015 115 00000
   VCID: 71BF283EA1296722A05-8024
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2024.12.27.
                    Time: 14:12:07
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 P    HW: 3AA 937 087 P
   Component: BCM PQ47 H    422 0474
   Revision: BB422001
   Coding: 0008000000000000009800805400816403510088406C85606480C7200041
   VCID: 47CBA6E6FFAD8992DE1-8012
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 21061  10  0603
   Coding: 00B795
   Component: RLS 270613 05  54  0403
   Coding: 02302A
7 Faults Found:
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:09
                    Voltage: 14.90 V
                    Fault Status: 00101010
                    Reset counter: 150
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 13:42:42
                    Voltage: 14.65 V
                    Reset counter: 150
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 13:55:48
                    Voltage: 14.95 V
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:09
                    Voltage: 14.90 V
01800 - Light Switch (E1)
                    Reset counter: 142
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:17
                    Voltage: 14.95 V
                    Fault Status: 01101010
                    Reset counter: 89
                    Mileage: 477346 km
                    Date: 2019.05.14.
                    Time: 03:32:29
                    Voltage: 12.60 V
                    Reset counter: 91
                    Mileage: 477346 km
                    Date: 2019.05.14.
                    Time: 03:32:29
                    Voltage: 12.60 V
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__10H VW10 HI   2318
   Revision: 27019000    Serial number: 003N5PCCL0R%
   Coding: 0012360
   VCID: 00597DFA96037EAA5FB-8054
   Subsystem 1 - Serial number: 6332MTS635961553
   Subsystem 2 - Serial number: 6342MTS655521543
   Subsystem 3 - Serial number: 6351HTS66MGD3CKJ
   Subsystem 4 - Serial number: 6361HTS645P42CKR
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:08
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BP    HW: 5K0 953 569 AA
   Revision: FF010042    Serial number: 20130510301902
   Coding: 4180250000
   VCID: 74B1212ADE3B520A4B3-8020
336900 - Databus
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2024.12.27.
                    Time: 14:12:07
   Part No SW: 3AA 920 870 P    HW: 3AA 920 870 P
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   VCID: 3FDBBE06A7FDC152661-806A
12656896 - Function Restricted due to Missing Message(s)
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2024.12.27.
                    Time: 14:12:07
12658688 - Function Restricted due to Missing Message(s)
          [Steuergerät für elektrische Parkbremse: keine Kommunikation]
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2024.12.27.
                    Time: 14:12:07
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 290613F1001031
   Coding: 461006
   Shop #: WSC 12345 123 61029
   VCID: 7BA30A16F3E51D720A9-802E
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000006
   Shop #: WSC 12345 111 45799
   VCID: 46D5ABE2F4A7909A257-8012
                    Reset counter: 138
                    Mileage: 477346 km
                    Date: 2019.05.14.
                    Time: 03:07:42
02248 - Valve for Controlling Clutch Operating Angle (N373)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 168
                    Mileage: 477348 km
                    Date: 2019.05.14.
                    Time: 18:02:44
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0407
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 3829D51A8E53F66AA7B-806C
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0007212940
   Coding: 0200B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
   VCID: 3537DC2E95C10B02BCD-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0502
   Serial number: 00000003553901
   Coding: 010090
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.310 1202
   Revision: 1BH04737    Serial number: 00131760003901
   Coding: 0000258
   VCID: 3FDBBE06AB7DC152661-806A
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:08
                    RPM: 831 /min
                    Speed: 50.0 km/h
                    (no units): 7.0
                    Voltage: 14.90 V
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:08
                    RPM: 831 /min
                    Speed: 50.0 km/h
                    (no units): 7.0
                    Voltage: 14.90 V
00576 - Terminal 15
                    Reset counter: 132
                    Mileage: 477680 km
                    Date: 2019.05.21.
                    Time: 11:33:34
                        Term 15 Off
                    RPM: 980 /min
                    (no units): 7.0
                    Voltage: 14.90 V
   Component:    KSG PQ47 ELV 043 0645
   Coding: 01910A0002860E76340494157C084FCE705C00
   Component: Neigungssensor  004 0611
                    Reset counter: 131
                    Mileage: 477624 km
                    Date: 2019.05.20.
                    Time: 13:31:23
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 131
                    Mileage: 477624 km
                    Date: 2019.05.20.
                    Time: 13:31:23
                    Reset counter: 131
                    Mileage: 477624 km
                    Date: 2019.05.20.
                    Time: 13:31:23
00625 - Vehicle Speed Signal
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:08
   Component: EZE_2         H55 1642
   Coding: 00000008
   VCID: 6FBB2E46B79D71D2B61-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0007235764
   Coding: 0200B6
   VCID: 3635DB2288C7001AB57-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0502
   Serial number: 00000003559936
   Coding: 010090
   Revision:   H19       Serial number: 00000001191155
   Coding: 0022167
   VCID: 3635DB228447001AB57-8062
02779 - Databus for Electric Parking Brake
                    Reset counter: 131
                    Mileage: 477625 km
                    Date: 2019.05.20.
                    Time: 14:12:07
                    Voltage: 14.80 V
                    Count: 62
                    Hex Value: 0x1260
                    Hex Value: 0x0082
                    Hex Value: 0x0101
                    Fault Status: 00101101
                    Reset counter: 132
                    Voltage: 14.70 V
                    Count: 160
                    Hex Value: 0x1270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
00576 - Terminal 15
                    Reset counter: 92
                    Mileage: 477680 km
                    Date: 2019.05.21.
                    Time: 11:33:31
                    Voltage: 14.80 V
                    Count: 52
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: RCD310 EU     H04 5006
   Revision: -----08S    Serial number: VWZ4Z2N1248061
   Coding: 05000400040010
   Shop #: WSC 05314 000 00000
   VCID: 72BD2732A4AF5C3A59F-8026
                    Reset counter: 89
                    Mileage: 477346 km
                    Date: 2019.05.14.
                    Time: 03:07:46
00856 - Radio Antenna
                    Fault Status: 00101011
                    Fault Frequency: 58
                    Reset counter: 150
                    Mileage: 477347 km
                    Date: 2019.05.14.
                    Time: 17:54:40
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1642
   Coding: 030F1859
   VCID: 71BF283EA1A96722A05-8024
   Component: J367-BDM  H07 0180
   Serial number: 40179801311491604664
End----------(Elapsed Time: 01:32, VBatt start/end: 14.8V/14.8V)-----------
Jef
HQ
Well, here is something similar that some one posted in 2018:
In that complete Auto-Scan with matching ECM part number, manual trans, AWD module we see the following:
Coding: 0000005
