Fuse 15 after sunroof leak
ktm500mx
C?ID=495546
looking for direction after sunroof leak drivers side removed 2+ gallons of water .
car will not start ignition turns on but as you push the button the car turns off .
will post scan tomorrow.
09-Cent. Elect. -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 40942 003 1048576
   VCID: 30391855B627BFAAEFB-8064
   VINID: 0E69E070745A0937461480091C24EB3B7B
001025 - EGR System
               P0401 - 001 - Insufficient Flow - MIL ON
                    Fault Status: 11100001
                    Fault Frequency: 255
                    Mileage: 278048 km
                    Date: 2042.14.29
                    Time: 15:46:13
                    RPM: 828 /min
                    Voltage: 13.76 V
                    Load: 73.3 %
                    Load: 100.0 %
                    Mass Air / Rev.: 225.0 mg/str
                    Mass Air / Rev.: 355.0 mg/str
009231 - Exhaust Gas Recirculation System
               P240F - 000 - Response too Slow - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 26
                    Mileage: 278053 km
                    Date: 2042.14.29
                    Time: 16:18:49
                    RPM: 1564 /min
                    Speed: 49.0 km/h
                    Load: 82.4 %
                    Mass Air / Rev.: 0.0 mg/str
                    Mass Air / Rev.: 45.0 mg/str
                    Mass Air / Rev.: 315.0 mg/str
                    Mass Air / Rev.: 420.0 mg/str
008194 - Particulate Trap Bank 1
               P2002 - 007 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100111
                    Mileage: 278921 km
                    Date: 2043.14.11
                    Time: 10:29:42
                    RPM: 1840 /min
                    Speed: 93.0 km/h
                    (no units): 86.7
                    (no units): 15.3
                    (no units): 2.75
                    Pressure: 303 mbar
                    Pressure: 31 mbar
008198 - Intake Manifold Flap; Bank 1
               P2006 - 000 - Stuck Closed - Intermittent
                    Fault Frequency: 83
                    Mileage: 322140 km
                    Date: 2057.14.09
                    Time: 11:52:01
                    RPM: 1012 /min
                    Speed: 20.0 km/h
                    Load: 9.8 %
                    Lambda: 21.3 %
                    Mass Air / Rev.: 460.0 mg/str
                    Temperature: 91.8°C
008196 - Intake Manifold Flap; Bank 1
               P2004 - 000 - Stuck Open - Intermittent
                    Mileage: 322140 km
                    Date: 2057.14.09
                    Time: 11:52:02
                    RPM: 1012 /min
                    Speed: 17.0 km/h
                    Load: 100.0 %
                    Lambda: 92.3 %
                    Mass Air / Rev.: 470.0 mg/str
                    Temperature: 91.8°C
Readiness: 1 5 0 0 0
   Component: GSG DSG AG6     511 9430
   Revision: 05351113    Serial number: 00001110070909
   Shop #: WSC 00066 000 00000
   VCID: 1471B4C5227F638AEB3-8040
   Revision: 00H31001
   Coding: 114B600C49270002880B06ED92200042B70000
   VCID: 7DA7F1613DF582C234D-8028
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2063.14.05
                    Time: 00:18:25
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 16390
                    Count: 42240
                    Count: 253
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0155773423 Dataset Number: 5K0116v____ 1K06
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 343114454EBF838A8B3-8060
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001016
   Coding: 0000001002
   Shop #: WSC 00066 000 00119
   VCID: 005988954A87EF2A5FB-8054
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA0S9MH   Dataset Number: 1KM003v__B_ 0035
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FDB4B6977F950D2661-806A
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002G1000
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME04715164ZZZL
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME26225264ZZZN
   Serial number: 3511HSME22013C29ZZZC
   Serial number: 3521HSME1D0A3B29ZZZV
   Serial number: 35527SME46137128ZZZ8
   Serial number: 35627SME79451C29ZZZQ
   Part No SW: 5K0 953 569 H    HW: 5K0 953 569 H
   Revision: --X01---    Serial number: 20130529100720
   Coding: 100A140000
   Shop #: WSC 51780 000 1048576
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D2731617DF542C274D-8068
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
Address 17: Instruments
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 05121101290227
   Coding: 352002
   VCID: 3D2731617D7542C274D-8068
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2063.14.05
                    Time: 00:18:27
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2063.14.05
                    Time: 00:18:27
   Part No SW: 5K0 953 234     HW: 5K0 920 972 C
   Component: IMMO          H33 0310
   Revision: X0033006    Serial number:
   Coding: 000007
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
   VCID: 6A8DCA3D5CFB057AE1F-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000191189003
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2E05062DA093A95AFD7-807A
12665088 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Timeout Message mBSG_3]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:01:26
                    ELV State: 0C
                    Information Clamps: BB 68
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 65
12664832 - Function Restricted due to Missing Message(s)
          [Timeout Message mBSG_Kombi]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:18:25
                    ELV State: 0C
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 65
12665089 - Function Restricted due to Missing Message(s)
          [Timeout Message mZKE_4]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:18:25
                    ELV State: 0C
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 65
Address 2E: Media Player 3
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H33 0265
   Serial number: VWZAZ2L8480261
   Coding: 04000401040007000000100A
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS_VW36.rod
   VCID: 2313E719FB511432629-8076
   Component: NAR_V2  0002
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [00001001] - General Memory Failure
          [ECU defect data memory failure]
                    Mileage: 124649 km
                    Date: 2062.14.27
                    Time: 01:50:49
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0003711719
   Coding: 0004B5
   VCID: 5BE39FF983A16CF26A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1509
   Serial number: 00000006207242
   Coding: 000490
68098 - Function Restricted due to Missing Message(s)
          [Front CAN KSG]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:18:27
68100 - Function Restricted due to Missing Message(s)
          [Front CAN BSG]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:18:27
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 34311445423F838A8B3-8060
            000 - - - MIL ON
                    Mileage: 342019 km
                    Date: 2063.14.05
                    Time: 00:18:24
                    Battery Volts: 11.7 V
                        DD
                    Temperature: 22.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.
   Component: EZE_2         H40 1623
   Coding: 050B0500
   VCID: 6FBBDB296799E052B61-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0003722280
   Coding: 0004B4
   VCID: 5CE19CE586AF6BCA633-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1509
   Serial number: 00000006107347
   Coding: 000490
          [Front CAN KSG]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:18:27
          [Front CAN BSG]
                    Reset counter: 197
                    Mileage: 342019 km
                    Date: 2127.14.05
                    Time: 00:18:27
End----(Elapsed Time: 01:22, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)--
Dr Sheldon
Windsor UK
C?ID=334979
Would help if we knew what car you had ?
Was that not obvious to you when you posted ?
ktm500mx
C?ID=495546
opps 2012 vw jetta tdi sportwagen.
siLc
Tallinn, Estonia
C?ID=330192
While there's no "engine start blocked by immo" fault code inside the engine ECU, this might be an immo issue. The immo module 25 talks but the instrument cluster module 17 doesn't - they are the same physical module. The keyless module 05 doesn't complain about this but the ELV does. Perhaps try to get the clocks to talk and perhaps the engine will stay running.
ktm500mx
C?ID=495546
Removed BCM and found water intrusion. multiple damaged components. question are other models compatible
to the 12 tdi wagon? also are different years compatible
ktm500mx
C?ID=495546
just finished taking test drive after BCM module install and recoding using old scan from previous BCM. all good except for one minor issue my daytime running lights are not working and showing up on the dash and VCDS as not working I'm sure it's a coding issue and I'll continue to work on it if someone has directions for me that would be great.
thanks Mike
ps Vagcom really works very well.
EuroX
Northern NJ USA
C?ID=208579
Post vin for coding calculation. Otherwise expect lots of meme replys because no one here has a crystal ball to know how you vehicle is equipped. I do have some diagnostic dice we can use also.
EuroX
Northern NJ USA
C?ID=208579
What pat number of bcm is installed? 5K0937084J?
ktm500mx
C?ID=495546
5K0937084L
EuroX
Northern NJ USA
C?ID=208579
5K0937084L
Was it verified that the L is the correct replacement for the J? Use the following coding and report back:
6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
