I am hoping someone can help out.. I have a 2018 Passat with ACC. The car has had the ACC replaced with a used unit. I have had a local tech with access to odis to remove CP. Performed special functions, KS master gateway, control module software config, performed FES. Also updated other modules that were pertaining to the engine fault. P1647!
The EPC light for some reason wont go away.. Any clue? Cruise control, ACC won't activate via steering wheel buttons. Only error on dash is Front assist: No sensor view.
As of now the radar specs are:
Misalignment angle: 0.00
Vertical angle deviation: 0.6220
Horizontal angle: -0.253000
Adjustment angle - fast algorithm : 0.00
Sunday,26,January,2025,10:12:53:20670
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.
VIN: 1VWBA7A38JC032120 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 3C 42 44 46 4F 52
5F 61 62 72 75
VIN: 1VWBA7A38JC032120 Mileage: 100150km-62230miles
Address 01: Engine (J623-DDSA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 016 C HW: 06K 907 309
Component: R4 2.0l TSI H30 9609
Revision: 1EH30000 CVN: E4997CC0
Coding: 411A00922444000F9000
Shop #: WSC 53815 006 1048576
ASAM Dataset: EV_ECM20TFS01106K906016C 002006
ROD: EV_ECM20TFS01106K906016C_002.rod
VCID: 2A066E020C7A22BA21F-807E
VINID: 0669D244744321A4C00C2042000A6C6FBC
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [10100111] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 100142 km
Date: 2025.01.26.
Time: 09:50:17
Engine RPM: 0.00 /min
Coolant temperature: 40 °C
Intake air temperature: 16 °C
Ambient air pressure: 870 mbar
Voltage terminal 30: 11.800 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 7
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Readiness: 1010 1100
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 AB HW: 09G 927 158
Component: AISIN AG6 G3 202 3318
CVN: 19ED60D6
Coding: 010200000C000000000000000000000000000000
Shop #: WSC 06050 062 00200
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW25.rod
VCID: 73B8B3669B302372529-8026
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: C54BC0F5492500FCA30C03E69219004100F0F01A
VCID: 75BC8D7E95C43D427CD-8020
Part No SW: 5K0 959 434 K HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1403
Revision: 00093000 Serial number: 0463962533 Dataset Number: V03935267BW 0001
Coding: 132C0C
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3D2C555EEDF4A50274D-8068
Part No SW: 561 907 044 BD HW: 561 907 044 BD
Component: Climatronic H08 0910
Revision: 00001K05
Coding: 0050019092
VCID: 5AE6FEC21C9A723A71F-800E
Part No SW: 5K0 937 087 AL HW: 5K0 937 087 AL
Component: BCM PQ35 H++ 122 0186
Revision: BN122001
Coding: EF200E1B982B08D4098806013400854800F1000645A00DB0E4806200BC70
VCID: 7F506F56A7F87712261-802A
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 160118 04 47 0106
Coding: 0038DD
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 55501803905012 Dataset Number: 560039v____ 0007
Coding: 0071155011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 37204776CFC88F52AE1-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Serial number: 2103187451A190 Dataset Number: V03935263DJ 0001
Coding: 01001002FE0739
ROD: EV_ACCBEGVW361.rod
VCID: 363E4A72C8C2765AB57-8062
1807 - No Enable Identifications Active
B2032 00 [00001001] - -
[FAULT_SWAP_NO_FSID_ACTIVE]
Reset counter: 192
Mileage: 100142 km
Date: 2025.01.26.
Time: 09:50:15
Control Module temperature: 22 °C
Voltage terminal 15: 11.9 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1132 - Sensor for Automatic Distance Control
C110B F0 [00001001] - Limited Visibility
[FAULT_SYSTEM_DISTURBED]
Fault Priority: 9
Reset counter: 192
Mileage: 100143 km
Date: 2025.01.26.
Time: 09:52:17
Control Module temperature: 24 °C
Voltage terminal 15: 14.3 V
Vehicle speed: 11.52 m/s
Acceleration: -0.01 m/s²
1542 - Sensor for Automatic Distance Control
[FAULT_SENSOR_BLIND]
Reset counter: 192
Mileage: 100143 km
Date: 2025.01.26.
Time: 09:52:10
Voltage terminal 15: 14.2 V
Vehicle speed: 9.55 m/s
Acceleration: 0.41 m/s²
1545 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_BLIND]
Reset counter: 192
Mileage: 100143 km
Date: 2025.01.26.
Time: 09:52:10
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM0F9A9% Dataset Number: V03935261GJ 0001
Coding: 8CCCCC00000000005000001A020800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 6398C3262BD0B3F2229-8036
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000008S7KJ%
Coding: 30324C
Subsystem 2 - Part No SW: ----------- HW: 480 002 001 18
Serial number: 357000000004F358CA2V
Subsystem 3 - Part No SW: ----------- HW: 480 002 212 17
Serial number: 35800000000090FCD92X
Subsystem 4 - Part No SW: ----------- HW: 480 021 910 17
Component: SideSensor_Dr 000 0148
Serial number: 35100019F27B149324A1
Subsystem 5 - Part No SW: ----------- HW: 480 020 212 17
Component: SideSensor_Pr 000 0148
Serial number: 3520001BF28A2CA4156B
Subsystem 6 - Part No SW: ----------- HW: 480 021 310 18
Component: FrontSensor_D 004 0189
Serial number: 3550001022B7B5A5048-
Subsystem 7 - Part No SW: ----------- HW: 480 021 609 21
Component: FrontSensor_P 005 0189
Serial number: 3560001AEC4D4081E82J
Part No SW: 1K5 953 521 CR HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20180116200260
Coding: 0002C40008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7F506F56A7787712261-802A
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Serial number: 0131812244301151AF1B
Coding: 2C0000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 981 B HW: 561 920 981 B
Component: KOMBI H03 1109
Coding: 221E010000
VCID: 1B68BBC65320CB32AA9-804E
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 13021803010584
Coding: 461010
Shop #: WSC 00000 960 00086
VCID: 7BA89B46B3E06B320A9-802E
Component: IMMO H03 1109
Coding: 000007
VCID: 6A86AE02CCFAE2BAE1F-803E
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 17000399837002
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 3134796E21AC5162E05-8064
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0466014632 Dataset Number: 5G9764V____ 0041
Coding: 02021102
ROD: EV_HREntryHella_VW41.rod
VCID: 3C2A585AF6EEAC0A433-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0464947709
Coding: 020211
Part No SW: 561 959 701 C HW: 3C0 959 793 J
Component: TUER-SG FT 002 0637
Revision: 12100010 Serial number: 0011068126
Coding: 0404BD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1E6EB2D24032DE1A4D7-804A
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 C HW: 561 959 811 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 022 1472
Serial number: 14102746180223083601
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 311 3501
Revision: 00H22000
Shop #: WSC 19460 666 12345
VCID: 3924414EF55C9922585-806C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 01030100
VCID: 6FB0BF16F7980792B61-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011726000425
Coding: 181100
Part No SW: 561 959 702 C HW: 3C0 959 792 J
Component: TUER-SG BT 002 0637
Revision: 14100010 Serial number: 0011069418
Coding: 0405BC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1F108FD64738D712461-804A
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 C HW: 561 959 812 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 022 1472
Serial number: 14102747180219005125
Part No SW: 5C0 035 684 D HW: 5C0 035 684 D
Component: MU-S-NS-US H42 0468
Serial number: VWZAZ2U0622305 Dataset Number: V03935276K- 0001
Coding: 02140102BE00000051220001001808009F0100D400200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 261E9A32186206DA057-8072
Subsystem 1 - Part No SW: 3G0 919 866 BP HW: -----------
Component: NAR 2018 --- 0715
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: E1200859
VCID: 71B4B96EE1AC1162A05-8024
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 024 0160
Serial number: 000003554140569 Dataset Number: 561098V____ 0017
Coding: 02140102C24232107F1606000000
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 147AD0FABEFE844AEB3-8040
End----------(Elapsed Time: 01:22, VBatt start/end: 14.5V/14.4V)-----------
