Hi
Haved VCDS for a few years professional and a lot of experience in the repair of most euro vehicle electrical systems and this is the first time posting here.
2007 VW transporter 7HO
Engine ECU
fault code 005687 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller
Only other fault is aftermarket radio. Fault is present with radio connected or disconnected
There is no direct connection for "powertrain can bus" to the Electric Load controller(J519). CAN bus for J519 is on convenience CAN BUS and is connected to CAN gateway.
All installed modules on 'convenience CAN BUS' registering signals and communicate correctly.
All installed modules on ' power train CAN bus' registering signals and communicate correctly.
CAN gateway in instrument cluster shows all controls modules OK. 2wire communication displayed in measuring block
(centrl 1, radio 1, engine 1, ABS 1, etc) measuring blocks 120-129
All installed modules that show measuring blocks 120-129 register correct signals.
CAN BUS signal waveform ok when checked with oscilloscope.
CAN BUS Wiring from CAN gateway(instrument cluster) to engine ecu and central control module(j519) OK.
Vehicle starts, drives and runs good.
0005687 fault code in engine ecu returns immediately when cleared.
Have swapped a know good J519 module and fault is still the same
CAN gateway is suspected fault. will replacing the instrument cluster resolve the issue.
Any help much appreciated?
Auto Scan below
Engine ECU
Auto Scan below
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H048478 Mileage: 258710km-160754miles
Address 01: Engine Labels: 038-906-016-BRS.clb
Part No SW: 038 906 016 T HW: 038 906 016 T
Component: R4 1,9L EDC G000SG 9711
Revision: --H02--- Serial number: VWZ7Z0F4457983
Coding: 0151031
Shop #: WSC 00070 824 92516
VCID: 2541A2F9EF0D2BBE98-5140
VINID: 9E606AAAA1D8A8760010810720BBC3CE41
Mileage: 258717 km
Voltage: 12.24 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
Address 03: ABS Brakes Labels:. 7H0-907-37x-ABS.clb
Part No SW: 7H0 907 379 P HW: 7H0 907 379 P
Component: (M)ABS MK25E 0103
Revision: 00H12001
Coding: 0000552
Shop #: WSC 02744 790 00000
VCID: 428B19651E63FC869D-5106
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 S
Component: BORDNETZ SGVER 1.0 1101
Coding: 0000101
VCID: 428B19651E63FC869D-5122
Part No: 1C0 909 605 A
Component: 3B AIRBAG VW51 0009
Coding: 13122
Shop #: WSC 02744
VCID: 224BB9E5AE23DC86FD-5122
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 851 K
Coding: 01111
Shop #: WSC 00046
VCID: 33654CA101D9450E06-5122
WV1ZZZ7HZ7H048478 VWZ7Z0F4457983
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 02744
VCID: 70EF83AD304F3E163B-5122
01304 - Radio
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: CX5 Komfortgerát 0004
Coding: 00021
Shop #: WSC 02744
VCID: 326B49A5FEC34C060D-4B00
End-------------------------(Elapsed Time: 06:11)--------------------------
