- Oct 18, 2024
- 3
- 1
- Durham, NC, USA
- C?ID=600189
Hello
This is my first auto scan experience. I purchased this hardware/software because I am having the ABS/Traction control/Brake/Airbag light on cluster come on. I would greatly appreciate anyone's help in trying to identify what the problem could be. Thank you in advance
Friday,24,January,2025,14:30:43:41750
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 3VWLP7AJ4DM430476 License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 47 56
VIN: 3VWLP7AJ4DM430476 Mileage: 179530km-111554miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CP HW: 07K 907 309 B
Component: 2,5l R5/4V G01 4725
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 7EA22642BCFD449A2D7-802A
VINID: 0E69DC80745A1147440C01071824F5EAD0
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal - Intermittent
Mileage: 179080 km
Date: 2019.06.17.
Time: 12:59:56
RPM: 1609 /min
Load: 33.7 %
Speed: 80.0 km/h
Temperature: 87.0°C
Temperature: 37.0°C
Absolute Pres.: 940.0 mbar
Voltage: 13.716 V
P0300 - 000 - - Intermittent
Mileage: 179319 km
Date: 2019.06.17.
Time: 20:23:33
RPM: 1611 /min
Load: 39.6 %
Temperature: 16.0°C
Temperature: 15.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.462 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Mileage: 179319 km
Date: 2019.06.17.
Time: 20:24:20
RPM: 827 /min
Load: 29.4 %
Temperature: 27.0°C
Temperature: 15.0°C
Voltage: 13.843 V
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Mileage: 179264 km
Date: 2019.06.17.
Time: 01:27:57
RPM: 1539 /min
Load: 22.3 %
Speed: 21.0 km/h
Temperature: 90.0°C
Temperature: 39.0°C
Absolute Pres.: 950.0 mbar
Voltage: 13.716 V
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2246
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 005E58BAC609326A5FB-8054
Fault Status: 00101101
Fault Frequency: 9
Reset counter: 158
Mileage: 141218 km
Date: 2014.09.13.
Time: 01:41:34
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: B14B400C492508FA8D0F02EB921F1061A71000
VCID: 7DA0214EBDFB5F8234D-8028
Reset counter: 222
Mileage: 178730 km
Date: 2019.06.17.
Time: 20:15:45
Count: 7
Count: 32768
Count: 4608
Count: 8193
Count: 50432
Count: 1023
01130 - ABS Operation
Fault Status: 01101000
Reset counter: 137
Mileage: 178185 km
Count: 2
Count: 14
Count: 12800
Count: 124
Count: 50688
Count: 248
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0196428023 Dataset Number: 5K0116v____ 1609
Coding: 030C0C
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 3436C46ACEB15ECA8B3-8060
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BA HW: 5C0 820 047 BA
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001425372
VCID: 609E783A2649926A3FB-8034
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0256
Revision: B2066001 Serial number: 04371047130448
Coding: 7B994B9A08230F0008382000240884C500C2502E6000000030A000000000
Shop #: WSC 07807 444 183199
VCID: 2F3CCB0627177D12F61-807A
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3465
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3465
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH0007WYMM
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Serial number: 0023259 FLE 20130112
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
02660 - Radio Remote Control not Matched/Adapted
Reset counter: 207
Part No SW: 5C0 959 655 Q HW: 5C0 959 655 Q
Component: AirbagVW10G 013 0851
Serial number: 003LKM03DM5N Dataset Number: 160003v____ 0202
Coding: 00004A33
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 40DE98BA8A09F26A1FB-8014
Serial number: 6940000Y130000R9FZ0E
Coding: 303041
Serial number: 3572MSME08354375ZZZS
Serial number: 3582MSME54000374ZZZH
Serial number: 3516KSME796F6D21ZZZ5
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME56455021ZZZI
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME7B391220ZZZT
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME14201220ZZZ7
B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
Fault Frequency: 150
Reset counter: 192
Mileage: 177287 km
Date: 2025.01.24.
Time: 07:37:57
Part No SW: 5C6 920 952 B HW: 5C6 920 952 B
Component: KOMBI H06 0705
Coding: 270A01
Shop #: WSC 00066 000 00122
VCID: 2B04DF16138F0132DA9-807E
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0256
Revision: B2066001
Coding: 102200
VCID: 70BE087AFAA922EAAFB-8024
Component: IMMO H06 0705
Coding: 000007
VCID: 6A8A1A12DCF5D83AE1F-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 12000012112005
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303EC87A3AA962EAEFB-8064
1048843 - Ignition Starter Switch
B11D7 11 [00001001] - Short to Ground
Reset counter: 32
Mileage: 128129 km
Date: 2019.05.25.
Time: 03:41:26
ELV State: 04
Information Clamps: 77 60
CoCo State: B0 01
WFS State: 67 1A
Vehicle speed: 0.00 km/h
Voltage: 76
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664167575
Coding: 020100
VCID: 2A0ADA121CF5183A21F-807E
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H58 0319
Serial number: VWZAZ2M0010348
Coding: 04090001010006000000100A
Shop #: WSC 01383 790 50316
ROD: EV_RNS315NARV2UDS_VW36.rod
VCID: 2510292E756B37420CD-8070
Component: NAR_V3_(0037) 0037
Reset counter: 105
Mileage: 152662 km
Date: 2021.10.18.
Time: 18:29:51
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0014742 Dataset Number: 560050v____ 1607
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 26122E22086D3C5A057-8072
End----(Elapsed Time: 01:27, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
