Skoda superb 2024 crash in ecu
aceton
Poland
C?ID=437068
I'm looking for sec acces. 20103 not working
  • Disagree
Reactions: TTT
Jef
HQ
aceton
Poland
C?ID=437068
Adres 01: Silnik (J623-DXDB) Plik etykiet:. 04E-907-309-V1.clb
Oznaczenie elementu SW: 05E 906 019 EB HW: 05E 907 309 CA
Komponent: R4 1.5l TFS H80 3511
Weryfikacja: KNH80000 Numer zestawu danych: V03935404LB 0001 CVN: 8A642ABE
Kodowanie: 0125003223641D0830086000001000000000000000000000
Kod serwisu: WSC 31414 790 00422
Zbiór danych ASAM: EV_ECM15TFS01105E906019EB 001004
ROD: EV_ECM15TFS01105E906019EB.rod
VCID: 6A8DC8D0FCF9571AE1F-803E SFD
VINID: 91D4917887AA2624C00491C91C4C8B6EA7
45423 - Zadziałało wyłączanie na skutek zderzenia
P1609 00 [10101111] - -
[Crash shut-off was triggered]
myounus
Northwest UK
C?ID=321059
Can you post this in English please and a FULL auto scan. Thanks
aceton
Poland
C?ID=437068
Why should I send the full scan? What will this change?
I sent what was important.
I described the problem in the title of the post.
Does it matter what language the scan is in?
year, controller data, error code. everything is there
Dr Sheldon
Windsor UK
C?ID=334979
That will change the reply and help you get here - See !! Easy to understand ?
It matters. The rules dictate that it MUST be from the English Version of VCDS - You may need to download it
Please and Thank you need to be in English too !!
Clearly not there !!
aceton
Messages53 Reaction score15
You're not new here - You do know the rules !!
myounus
Northwest UK
C?ID=321059
As you’ve been advised, these are the rules. I asked for the scan in English so I can understand the error and try to help you. I’m sorry you feel aggrieved but we only want to help.
Hope this helps clarify.
What exactly do you intended to do with a Security Access code on an ECU that has SFD?
Jef
HQ
FYI, some of our ground rules:
We want full scans for various reasons, but two big ones are:
  1. When helping diagnose for problem [blah blah blah] in the [whatever] module, there might be addition clues in other modules.
  2. We can use complete Auto-Scans as references. Example, I might use your [whatever] from an Auto-Scan as a plausible example to help some one else 4 years from now.
You are not on a 1993 cell phone data plan where every text cost you money, so it isn't a financial concern to post a complete Auto-Scan. And we want it in English because that is the most common language we are all using. All Ross-Tech customers have access to download and install the English version of VCDS from our web site.
Regards.
nigxls
C?ID=271113
Surely a 2024 car is covered by warranty, not even your problem.
Dr Sheldon
Windsor UK
C?ID=334979
It has been smashed up - Hence the Crash Data in Airbag Module
Jef
HQ
