Audi SQ7 17277 - SCR NOx Catalyst Bank 1
Jinxgj
C?ID=443755
Hi all,
New to me 2017 Audi SQ7 has developed a fault yesterday....Engine emission control warning light illuminated and a slight misfire at med revs.
Scanned last night and got the results below. Anyone got any thoughts?.....i think it is either the SCR injector clogged up or faulty NOx sensor. My money is on the NOx sensor but thought i would ask you good people if you think it is more likely to be anything else?
Gaz
Thursday,23,January,2025,13:35:45:54210
VIN: WAUZZZ4M6HD028076   License Plate: J111 NXJ
Mileage: 135712km-84327mi   Repair Order: Fault 22/01/25
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 3C 42 44 46
          47 50 52 5F 61 6C 6D 74 81 82 84 8B A5 A9 AC BA BB BC C0 C4
          CF D6 D7
VIN: WAUZZZ4M6HD028076   Mileage: 135712km-84327miles
50-Seat Adj. 3rd row -- Status: OK 0000
84-Night Vision -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
Address 01: Engine (J623-CZAC)       Labels: Redir Fail!
   Part No SW: 4M0 997 409     HW: 057 907 309
   Component: 4.0l V8 TDI   H44 1004
   Revision: D1H44---    CVN: A4E63F1A1ED2D78531AEE35031AEE3506853D65A
   Coding: 2A2A4032056E050334380400000000000000000000000000
   Shop #: WSC 62075 004 1048576
   ASAM Dataset: EV_ECM40TDI0114M0997409 001005
   ROD: EV_ECM40TDI0114M0997409.rod
   VCID: 77ABE5A53F4078926E1-8022
   VINID: 9D196AAAA11D19850008800718CDA932AC
   Electrical compressor:
          P20EE 00 [10101111] - Efficiency too Low
                    Mileage: 135223 km
                    Date: 2025.01.21
                    Time: 17:46:22
                    Engine RPM: 1491.50 /min
                    Normed load value: 67.5 %
                    Vehicle speed: 110 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 11.680 V
                    Engine status: COENG_RUNNING
Readiness: 1 1 0 0 0
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 AD    HW: 0D6 927 156 F
   Component: 0D6  40TDIRdW H03 1007
   Revision: --H03---    CVN: 4477C21D
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 76B5E8A1384A019A757-8022
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0002 CVN: ACFBEF4F
   Coding: 2C9839B230A40A9E919E5898188352A6E6A6DA349C0C50891A184A6567655B
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45D75F6D352CDA022CD-8010
   Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
   Component: MEM-BFS       008 0031
   Serial number: 00000226593081 Dataset Number: 4M0909866C  0016
   Coding: 003832000001B2410000010101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3B23399543E89CF24A9-806E
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0093
   Coding: 6818003D5545451102220280810000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678BB5E56FE0E812FE1-8032
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000001113906
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: A6B8865800PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514R  0052
   Coding: 07501943E17940CD050D87155BAF8CF9130331009000000000000000600016810A4501AB22B70A
   VCID: 025D847164822D3A49F-8056
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160814  043 0893
   Serial number: 89565300401622700086
   Coding: 1BC7F7
   Serial number: 62393966
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 AD    HW: 4M0 941 531 AD
   Component: E1 - LDS  H06 0008
   Serial number: 01 07 2016  00537543
   Serial number: GX1CE131071611520205
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CB    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00213830
   Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000042764
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Dataset Number: 4M0909863L  0027
   Coding: 3477FFF358FFEC06747860A0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323D14B194A25DBA99F-8066
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H70 0086
   Serial number: 003L100316KC Dataset Number: 4M0909602AE 0001
   Coding: AAFCF0D80CA0000098F650F3C0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 78A9E699325E77EA67B-802C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705J0300Q00236
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0301Q00943
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 510 16
   Serial number: 3577Y00A31FD7532A220
   Subsystem 4 - Part No SW: -----------    HW: 442 061 510 16
   Serial number: 3587Y00A31FD75341392
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 310 16
   Serial number: 3517700A921E114250C+
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 310 16
   Serial number: 3527700A921E1145410X
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 109 16
   Serial number: 3557500C921ADC74327L
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 610 16
   Serial number: 3567500AB21FBEE1C1C1
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 109 16
   Serial number: 2307500A721438F3F2BC
   Subsystem 10 - Part No SW: -----------    HW: 442 420 809 16
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00991FFD13241F.
   Subsystem 11 - Part No SW: -----------    HW: 442 420 809 16
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00B71FB75F3344-
   Central crash sensor X/Y:
   Subsystem 12 - Part No SW: -----------    HW: 410 203 110 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O78009D21A82B461B6
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015F8B7D61843622505-8054
   Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
   Component: FBenRDW       H15 0302
   Coding: 248D08D07C98060001A3E9601100400000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2E0500C1809A795AFD7-807A
   Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
   Component: Gateway       H30 0308
   Revision: 5C000001    Serial number: 0185C279616A26 Dataset Number: 4M0909515K  0076
   Coding: 03010001008886407F000000005900327C130007080000000175078E10000000
   GVL: 01503C1C8844020042FCC8001002C800010C2010000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4CC16A4916462B4AF33-8018
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20161030235923 00049
   Serial number: 9020291904
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0092
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 35372FAD65CC4A82BCD-8060
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000237581011
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   Component: MEM-FS        008 0031
   Serial number: 00000226593835 Dataset Number: 4M0909856C  0018
   Coding: 003833400001B2410000010101010000110000313100000000000000000000
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------    Dataset Number: 4M0909535K  0014
   Coding: 4EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 343112A96EB6538A8B3-8060
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0055
   Serial number: 0000224520313  Dataset Number: 4M0909872F  0027
   Coding: 005F9A005E010082000030B2
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 40D94E792A0EFF2A1FB-8014
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0005
   Serial number: 0000326315 Dataset Number: 4M0909852P  0001
   Coding: B4110101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0342
   Dataset Number: 4M0909501G  0060
   Coding: 01351E002F9100406309A0000600180203000004004F06502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 00598E796A8E3F2A5FB-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1624939AE
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000067480594
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4M0 907 133     HW: 4M0 907 133
   Component: J505-FSH  H04 0050
   Serial number: 00000000000000017677
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000002647 Dataset Number: 4M1909510E  0011
   Coding: 01355608008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2313E1F5DB58C432629-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0015
   Serial number: 00000177223605 Dataset Number: 4M0909467B  0014
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C213A8946E69BCA433-8068
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0055
   Serial number: 0000225141327  Dataset Number: 4M0909873F  0027
   Coding: 005F9A005E010082000030B0
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 3FDB4D8557F080D2661-806A
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035     HW: 4M1 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A641J0GB005374 Dataset Number: 4M0909545H  0037
   Coding: 013756010000000053111102000A00332F001CE7017001009E
   VCID: 629DA4F184C28D3A29F-8036
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M1 919 605     HW: 4M1 919 605
   Component: AU536_DU_HIGH  H44 0008
   Serial number: AUZ8Z9GJM00782
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 26101600000000000158
   Compact disc data bank:
   Component: Gracenote2  --- 1015
Address 61: Battery Regul. (J1120)       Labels: 4M0-915-105.clb
   Part No SW: 4M0 915 105 B    HW: 4M0 915 105 B
   Component: BMS_48V_LiIon H06 0102
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   VCID: 2809F6D9A27E276A37B-807C
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG005165 Dataset Number: 4M1909460G  0022
   Coding: 02350601BE0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31006981200000 Dataset Number: 4M0909541G  0025
   Coding: 0050
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M0 907 777 G    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H34 1213
   Serial number: 2910160008  Dataset Number: 4M0909576M  0044
   Coding: 18507048F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 3D27378D5DFC92C274D-8068
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130088965
   Coding: 303030
   Part No SW: 4M2 713 041 F    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20161012000513
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736_AU72.rod
   VCID: 290FF3DDB9741E62285-807C
Address 82: Head Up Display (J898)       Labels:| 4M0-919-617-V1.clb
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H27 1603
   Coding: 5F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736_AU73.rod
Address 84: Night Vision (J853)       Labels:* 4M0-907-547.clb
   Part No SW: 4M0 907 547 B    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H10 0037
   Serial number: 635868600201641
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   VCID: 333311B56BB854B2929-8066
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1626000280
16389 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
                    Reset counter: 251
                    Mileage: 134971 km
                    Date: 2025.01.20
                    Time: 20:01:37
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0022
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 30391EB99AAE6FAAEFB-8064
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Dataset Number: 4M0909466K  0041
   Coding: 0407030600000404024023B6CD0000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F3B1DC587907052F61-807A
   Part No SW: 4M0 907 159     HW: 4H0 907 159 A
   Serial number: 161013201761
   VCID: 70B9DEB95A2E2FAAAFB-8024
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0005
   Dataset Number: 4M0909571H  0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
   Component: AEMevo        H09 0111
   Dataset Number: 4M0909578G  0014
   ASAM Dataset: EV_AEMZFAU736 006012
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0055
   Serial number: 0000224896372  Dataset Number: 4M0909897F  0028
   Coding: 004F980000010082000030A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 42DD44712402ED3A09F-8016
   Component: TSG HBFS      009 0055
   Serial number: 0000224896040  Dataset Number: 4M0909896F  0028
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4M0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0001
   Serial number: 160930202560
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 6889B6D962FEE76AF7B-803C
Address C4: DC/DC Converter (J519)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 B    HW: 4M0 959 663 B
   Component: PCU10         022 0317
   Dataset Number: 4M0909475B  0015
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 392F239D49D4AEE2585-806C
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 4EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   VCID: 313F1BBD91A466A2E05-8064
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1675C821180AA19A957-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----------(Elapsed Time: 02:48, VBatt start/end: 12.8V/12.8V)-----------
Go into Address AC and locate the reductant pump (sometimes called reducing agent) pressure and see if it is -0.5Bar. We have done a LOT of these and usually it requires revised AdBlue tank 4M0 131 878 CQ (to replace the delivery unit), filer line 4M0 131 963 B, ECU 4M0 907 355 H and engine ECU software update XCHGACA015.
Jinxgj
C?ID=443755
Hello all,
Done as Crasher suggested and the results are in:
With engine off, ignition on the Reductant measured pressure fluctuates between 0.100 and 0.122 bar rapidly.
With the engine on it is pretty steady at 4.977 bar.
Any further thoughts?
Thanks everyone
Gaz
Pressure should be 5Bar so nothing wrong in that respect.
Jinxgj
C?ID=443755
So...it is unlikely that the fault is requires new tank, ecu, filler etc?
I wonder if the standby pressure is less than 500 mbar and normal operating pressure is 5 Bar that this represents a normal operating condition?
If it is not the tank, filler etc what else might it be?.....bad NOx sensor?
Is there a way to test NOx sensors on VCDS?
What would that tell you? The code is for the CATALYST not the sensors.
Probably needs a good rip to do its job.... have you been short-tripping it lately?
Why is your running voltage so poor?
Jinxgj
C?ID=443755
Hi
No...the fault appeared after 250 miles of motorway driving at 70mph (ish) during another motorway drive of 250 miles at 70 mph (ish).
I am not sure why my running voltage is low. Didnt even notice it to be honest......mmmm...i am going to go and measure the voltage at the battery with the engine on. Although thinking about it Terminal 30 would be regulated to 12v wouldnt it?....you wouldn't have 13 or 14v directly from the alternator on the Terminal 30 would you?
Ultimately i am not going to be repairing this myself - the car is under warranty and is booked in next Thursday for diag and repair. However, when i searched the internet for this code there was little information about it and i thought i would start a thread here to garner opinion and a possible fix for others who may encounter this - and not have the luxury of a warranty repair on the horizon.
I did consider some low gear high revs driving for a while to try and help it out a bit but am concerned about causing more damage by doing so. I am quite wary of driving it anywhere apart from to the garage next week.
The code relates to Catalyst efficiency as you said and (please correct me if i am wrong) the way i understand the system works is that there are 2 NOx sensors one upstream of the Cat and one downstream. The ECU compares the NOx reading between these 2 sensors and decides how much SCR fluid to add based on these values - to reduce the NOx value in the downstream sensor to acceptable levels. So i think that there are essentially 4 things that can be causing the low efficiency:
1. The upstream NOx sensor is faulty and is telling the ECU that there is less NOx in the exhaust gas than there actually is. The ECU adds SCR fluid - but not enough and the downstream NOx sensor is reading higher than is calculated as a result and the system is flagged as being inefficient?
2. The downstrean NOx sensor is faulty and the SCR system is adding what it thinks is the correct amount of fluid based on the upstream reading but the downstream sensor reads the amount of NOx reduction incorrectly (more than the ecu calculates it should be) and it is flagged as ineffcient.
3. There is a fault in the delivery of the SCR fluid - The NOx sensors are fine and the SCR delivery is underperforming and therefore the NOX is not being reduced enough - hence inefficient.
4. Software or ECU problem....then who knows....out of my wheelhouse completely in the land of angry pixies and 1s and 0s.
I suppose it could be something as in depth as Crasher says above or as simple as a crystalised SCR injector and anything in between.
Who said AdBlue was a good idea!!?
Gaz
dareckim11
Glasgow Scotland
C?ID=404683
Unscrew the Adblue injector, clear it. Do the same with a nest in SRC. Perform the injector test. Make sure the AdBlue tank is full. You must be sure that there is only AdBlue in the tank.
On Monday I had a Ford with the same mistake, the reason was Adblue mixed with Screen Wash
Jinxgj
C?ID=443755
They must have literally added some blue!
I have only had the car 1 week so i am not 100% sure that it is ONLY AdBlue in the tank....but...i did top it off the other day with about 1 litre of fluid that was definately AdBlue.
If i were fixing this myself then that is 100% what i would do first - clean the adble injector and do the test. I had a similar issue with a BMW 730D i owned and the adblue injector in there looked like it had been filled with polyfilla - there was a cake of crytalised adblue over the face of the injector. Removing it cleared the code and all was well again.
As i say - week old purchase so the garage can fix it - i really dont want to interfere and jeopardize the warranty claim. Thanks for the good suggestion though - i hope someone else can have some benefit in the future - after all thats what forums are about isnt it...a record of peoples experiences and frustrations for the future to assist others.
Of course - any other suggestions are welcome for discussion - and when the garage have fixed it i will come back here and let you all know what they did and what (if anything) was replaced.
Thanks everyone.
Gaz
Jinxgj
C?ID=443755
Oh...BTW...14.95v Alternator voltage at the battery with the engine running. I assume 11-12v out of Terminal 30 is usual then?
Yes, you would. "Terminal 30" is un-switched battery voltage. It will actually be just a tad lower than battery voltage due to resistance-induced voltage drops between the battery and wherever it's being measured, but that drop shouldn't be more than a fraction of a volt.
Where are you seeing 11-12V at the same time that you're showing 14.95V at the battery?
Jinxgj
C?ID=443755
Hi all....Voltages:
Ignition off battery voltage at the battery terminals: 12.7V
Ignition on battery voltage at the battery terminals: 11.66V
Engine on battery voltage at the battery terminals: 14.95V
Also looked in VCDS for Terminal 30 Voltages in 09-Cent Elec and got between 11.88 and 12.04V on all Terminal 30 selections - Key On Engine Off.
With Engine ON:
09- Cent Elec between 14.6 and 14.77V
I looked in Battery Regulator and got 15.0V at Terminal 30.
So - i suppose the question is why does the fault log for the NOx fault above show a terminal 30 voltage of 11.68V? Is this the voltage recorded at the time the fault occurred? If it is not that then what is it?
Sorry for so many questions.
Gaz
MasterTommy
Amsterdam
C?ID=295586
Please do not dismiss potential available TPI/TSB’s for adblue problems on an SQ7, before you go reinvent the wheel. There where some issues in the first few years with adblue systems on these, with various possible symptoms and various possible solutions. @Crashers reply is very helpful but it’s also not really doable for anyone to include rhe full details of any potential TPI/TSB in their reply.
That seems like a lot of droop. How long long was the ignition on for before you made that measurement?
Yes, but at the same time, the RPM was 1491.50 /min, so there's really no excuse for such a low voltage.
With Engine ON:
Please check Terminal 30 voltage in 01-Engine and AC -- Reductant Control, because one of them is the module that recorded the really low voltage when voltage should have been higher.
Jinxgj
C?ID=443755
Hi...
2/3 seconds max.
Voltages as requested.
Key on engine off
T30 Voltage in 01 Engine 11.62V
T30 Voltage in AC Reductant Control T30A 11.78V, T30B 11.79V
Engine ON
T30 Voltage in 01 Engine 14.76V
T30 Voltage in AC Reductant Control T30A 14.74V, T30B 14.79V
When the light came on i did notice the car seemed to misfire quite hevily for a second (might this be a symptom of the low voltage - or the cause of the fault?) and sometimes when i start the car the idle is really rough until a little throttle is applied and it smoothes out. I tried several times to recreate this just now and it was fine on every start - the plan being to try to log the voltages as the car is misbehaving, but to no avail. It did it this afternoon once when i had to move it out of the way of the wifes car.
Whilst i was in there just now i was looking through some more of the advanced measuring values just to have a look around and i noticed that both NOx Sensor 1 and NOx Sensor 2 both had a value of 0ppm. Is this normal? In my naive mind - surely they should be different - ie downstream being better than upstream?
I suspect your battery is a bit weak / past its prime, but that shouldn't cause any of this.
Was the engine and exhaust warmed up at that point? I doubt those sensors work immediately after a cold start.
Jinxgj
C?ID=443755
Yes...engine at operating temp.
Then I would say 0 ppm is not normal. Looking at the data for your ECU, it's a bit strange. It appears to have two sets of values for the NOx sensors:
IDE03140 -- NOx sensor 1: NOx concentration (ppm)
IDE03141 -- NOx sensor 2: NOx concentration (ppm)
IDE05346 -- NOx Emission NOx-Sensor 2 (ppm)
IDE05347 -- NOx Emission NOx Sensor (ppm)
You might want to do some logging of these to see what's up with them. And this one might be interesting too:
IDE05356 -- Calculated NOx concentration behind turbocharger (ppm)
Jinxgj
C?ID=443755
Hi
Took car to garage today and on way logged parameters as requested...did a few more too out of curiosity:
Not sure this is the best format -sorry.
IDE00019IDE03140IDE03141IDE05346IDE05347IDE05356IDE03768IDE03769IDE04098IDE05348IDE05353
Time (sec)Time (min)Voltage T30NOX Sens 1 Nox ConcNOX Sens 2 Nox ConcNOx SensorNOx Emmission NOx SensorNOx Behind TurboNOx 1 Feed VoltageNOx 2 Feed VoltageNOx-SensorNOx 2 O2 ConcMeasured NOx Conversion
0.970.0214.48000008100NOx11:0 ppm / NOx21:0 ppm0.209500.000
2.430.0414.64000008100NOx11:0 ppm / NOx21:0 ppm0.209500.000
3.950.0714.48000008100NOx11:0 ppm / NOx21:0 ppm0.209500.000
5.470.0914.60000008100NOx11:0 ppm / NOx21:0 ppm0.209500.000
6.950.1214.60000008100NOx11:0 ppm / NOx21:0 ppm0.209500.000
8.470.1414.460000011600NOx11:0 ppm / NOx21:0 ppm0.209500.000
9.960.1714.64000007300NOx11:0 ppm / NOx21:0 ppm0.209500.000
11.480.1914.50000007200NOx11:0 ppm / NOx21:0 ppm0.209500.000
13.010.2214.64000006900NOx11:0 ppm / NOx21:0 ppm0.209500.000
14.520.2414.64000006900NOx11:0 ppm / NOx21:0 ppm0.209500.000
16.010.2714.58000006300NOx11:0 ppm / NOx21:0 ppm0.209500.000
17.530.2914.76000006700NOx11:0 ppm / NOx21:0 ppm0.209500.000
18.990.3214.62000005200NOx11:0 ppm / NOx21:0 ppm0.209500.000
20.510.3414.60000005600NOx11:0 ppm / NOx21:0 ppm0.209500.000
21.990.3714.74000006000NOx11:0 ppm / NOx21:0 ppm0.209500.000
23.530.3914.66000006500NOx11:0 ppm / NOx21:0 ppm0.209500.000
25.010.4214.74000005400NOx11:0 ppm / NOx21:0 ppm0.209500.000
26.510.4414.66000005900NOx11:0 ppm / NOx21:0 ppm0.209500.000
27.990.4714.74000005200NOx11:0 ppm / NOx21:0 ppm0.209500.000
29.510.4914.66000005400NOx11:0 ppm / NOx21:0 ppm0.209500.000
31.020.5214.62000006800NOx11:0 ppm / NOx21:0 ppm0.209500.000
32.530.5414.54000007500NOx11:0 ppm / NOx21:0 ppm0.209500.000
34.040.5714.64000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
35.530.5914.66000006100NOx11:0 ppm / NOx21:0 ppm0.209500.000
37.040.6214.68000008700NOx11:0 ppm / NOx21:0 ppm0.209500.000
38.500.6414.68000008000NOx11:0 ppm / NOx21:0 ppm0.209500.000
40.010.6714.70000005900NOx11:0 ppm / NOx21:0 ppm0.209500.000
41.530.6914.72000004400NOx11:0 ppm / NOx21:0 ppm0.209500.000
43.040.7214.74000003600NOx11:0 ppm / NOx21:0 ppm0.209500.000
44.490.7414.720000011900NOx11:0 ppm / NOx21:0 ppm0.209500.000
46.000.7714.720000011700NOx11:0 ppm / NOx21:0 ppm0.209500.000
47.510.7914.72000002000NOx11:0 ppm / NOx21:0 ppm0.209500.000
49.010.8214.7400000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
50.500.8414.760000012400NOx11:0 ppm / NOx21:0 ppm0.209500.000
52.010.8714.740000012600NOx11:0 ppm / NOx21:0 ppm0.209500.000
53.530.8914.76000004700NOx11:0 ppm / NOx21:0 ppm0.209500.000
55.040.9214.74000005600NOx11:0 ppm / NOx21:0 ppm0.209500.000
56.540.9414.74000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
58.060.9714.72000005000NOx11:0 ppm / NOx21:0 ppm0.209500.000
59.550.9914.68000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
61.021.0214.76000005300NOx11:0 ppm / NOx21:0 ppm0.209500.000
62.501.0414.74000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
64.031.0714.74000005200NOx11:0 ppm / NOx21:0 ppm0.209500.000
65.521.0914.74000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
66.991.1214.74000005000NOx11:0 ppm / NOx21:0 ppm0.209500.000
68.491.1414.76000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
70.021.1714.74000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
71.501.1914.74000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
73.011.2214.76000005200NOx11:0 ppm / NOx21:0 ppm0.209500.000
74.511.2414.76000004700NOx11:0 ppm / NOx21:0 ppm0.209500.000
76.001.2714.74000004700NOx11:0 ppm / NOx21:0 ppm0.209500.000
77.531.2914.76000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
79.041.3214.74000005000NOx11:0 ppm / NOx21:0 ppm0.209500.000
80.511.3414.76000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
82.011.3714.74000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
83.511.3914.74000004700NOx11:0 ppm / NOx21:0 ppm0.209500.000
84.981.4214.72000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
86.511.4414.72000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
88.001.4714.74000004700NOx11:0 ppm / NOx21:0 ppm0.209500.000
89.471.4914.72000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
90.991.5214.76000004500NOx11:0 ppm / NOx21:0 ppm0.209500.000
92.461.5414.74000004500NOx11:0 ppm / NOx21:0 ppm0.209500.000
93.991.5714.68000007400NOx11:0 ppm / NOx21:0 ppm0.209500.000
95.531.5914.74000005100NOx11:0 ppm / NOx21:0 ppm0.209500.000
97.021.6214.700000021800NOx11:0 ppm / NOx21:0 ppm0.209500.000
98.541.6414.76000005800NOx11:0 ppm / NOx21:0 ppm0.209500.000
100.051.6714.760000010300NOx11:0 ppm / NOx21:0 ppm0.209500.000
101.521.6914.6600000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
103.041.7214.740000017700NOx11:0 ppm / NOx21:0 ppm0.209500.000
104.521.7414.66000006200NOx11:0 ppm / NOx21:0 ppm0.209500.000
106.051.7714.72000001500NOx11:0 ppm / NOx21:0 ppm0.209500.000
107.541.7914.720000016400NOx11:0 ppm / NOx21:0 ppm0.209500.000
109.081.8214.740000083600NOx11:0 ppm / NOx21:0 ppm0.209500.000
110.571.8414.540000050000NOx11:0 ppm / NOx21:0 ppm0.209500.000
112.061.8714.72000006400NOx11:0 ppm / NOx21:0 ppm0.209500.000
113.561.8914.6600000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
115.041.9214.64000003500NOx11:0 ppm / NOx21:0 ppm0.209500.000
116.551.9414.66000007300NOx11:0 ppm / NOx21:0 ppm0.209500.000
118.071.9714.66000005800NOx11:0 ppm / NOx21:0 ppm0.209500.000
119.561.9914.66000005200NOx11:0 ppm / NOx21:0 ppm0.209500.000
121.072.0214.6200000400NOx11:0 ppm / NOx21:0 ppm0.209500.000
122.562.0414.7000000400NOx11:0 ppm / NOx21:0 ppm0.209500.000
124.082.0714.6600000100NOx11:0 ppm / NOx21:0 ppm0.209500.000
125.572.0914.740000020100NOx11:0 ppm / NOx21:0 ppm0.209500.000
127.062.1214.72000008900NOx11:0 ppm / NOx21:0 ppm0.209500.000
128.572.1414.74000004800NOx11:0 ppm / NOx21:0 ppm0.209500.000
130.092.1714.74000004200NOx11:0 ppm / NOx21:0 ppm0.209500.000
131.552.1914.74000003700NOx11:0 ppm / NOx21:0 ppm0.209500.000
133.062.2214.70000003900NOx11:0 ppm / NOx21:0 ppm0.209500.000
134.562.2414.72000003800NOx11:0 ppm / NOx21:0 ppm0.209500.000
136.102.2714.74000003800NOx11:0 ppm / NOx21:0 ppm0.209500.000
137.582.2914.74000003800NOx11:0 ppm / NOx21:0 ppm0.209500.000
139.072.3214.70000003500NOx11:0 ppm / NOx21:0 ppm0.209500.000
140.582.3414.70000003500NOx11:0 ppm / NOx21:0 ppm0.209500.000
142.102.3714.66000004200NOx11:0 ppm / NOx21:0 ppm0.209500.000
143.622.3914.68000002900NOx11:0 ppm / NOx21:0 ppm0.209500.000
145.132.4214.70000001900NOx11:0 ppm / NOx21:0 ppm0.209500.000
146.672.4414.72000003400NOx11:0 ppm / NOx21:0 ppm0.209500.000
148.232.4714.72000002900NOx11:0 ppm / NOx21:0 ppm0.209500.000
149.742.5014.74000001400NOx11:0 ppm / NOx21:0 ppm0.209500.000
151.262.5214.68000007000NOx11:0 ppm / NOx21:0 ppm0.209500.000
152.802.5514.680000011500NOx11:0 ppm / NOx21:0 ppm0.209500.000
154.332.5714.66000004800NOx11:0 ppm / NOx21:0 ppm0.209500.000
155.822.6014.680000014100NOx11:0 ppm / NOx21:0 ppm0.209500.000
157.392.6214.700000013800NOx11:0 ppm / NOx21:0 ppm0.209500.000
158.862.6514.68000004500NOx11:0 ppm / NOx21:0 ppm0.209500.000
160.412.6714.66000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
161.972.7014.66000005800NOx11:0 ppm / NOx21:0 ppm0.209500.000
163.482.7214.660000013000NOx11:0 ppm / NOx21:0 ppm0.209500.000
164.992.7514.660000013100NOx11:0 ppm / NOx21:0 ppm0.209500.000
166.452.7714.68000008000NOx11:0 ppm / NOx21:0 ppm0.209500.000
167.982.8014.64000003700NOx11:0 ppm / NOx21:0 ppm0.209500.000
169.532.8314.68000006000NOx11:0 ppm / NOx21:0 ppm0.209500.000
171.072.8514.62000006800NOx11:0 ppm / NOx21:0 ppm0.209500.000
172.582.8814.64000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
174.092.9014.68000007500NOx11:0 ppm / NOx21:0 ppm0.209500.000
175.612.9314.66000007300NOx11:0 ppm / NOx21:0 ppm0.209500.000
177.082.9514.70000007500NOx11:0 ppm / NOx21:0 ppm0.209500.000
178.622.9814.64000006700NOx11:0 ppm / NOx21:0 ppm0.209500.000
180.143.0014.640000014200NOx11:0 ppm / NOx21:0 ppm0.209500.000
181.653.0314.680000016200NOx11:0 ppm / NOx21:0 ppm0.209500.000
183.173.0514.64000004100NOx11:0 ppm / NOx21:0 ppm0.209500.000
184.693.0814.68000006400NOx11:0 ppm / NOx21:0 ppm0.209500.000
186.223.1014.66000004700NOx11:0 ppm / NOx21:0 ppm0.209500.000
187.753.1314.66000004400NOx11:0 ppm / NOx21:0 ppm0.209500.000
189.263.1514.64000006600NOx11:0 ppm / NOx21:0 ppm0.209500.000
190.803.1814.66000006900NOx11:0 ppm / NOx21:0 ppm0.209500.000
192.313.2114.64000003000NOx11:0 ppm / NOx21:0 ppm0.209500.000
193.803.2314.64000006600NOx11:0 ppm / NOx21:0 ppm0.209500.000
195.343.2614.66000006900NOx11:0 ppm / NOx21:0 ppm0.209500.000
196.853.2814.68000007400NOx11:0 ppm / NOx21:0 ppm0.209500.000
198.423.3114.64000007200NOx11:0 ppm / NOx21:0 ppm0.209500.000
199.913.3314.7000000
63​
201.503.3614.640000011900NOx11:0 ppm / NOx21:0 ppm0.209500.000
203.013.3814.64000006300NOx11:0 ppm / NOx21:0 ppm0.209500.000
204.523.4114.660000012900NOx11:0 ppm / NOx21:0 ppm0.209500.000
206.023.4314.680000010200NOx11:0 ppm / NOx21:0 ppm0.209500.000
207.533.4614.66000006300NOx11:0 ppm / NOx21:0 ppm0.209500.000
209.023.4814.68000006500NOx11:0 ppm / NOx21:0 ppm0.209500.000
210.523.5114.680000013900NOx11:0 ppm / NOx21:0 ppm0.209500.000
212.063.5314.640000044300NOx11:0 ppm / NOx21:0 ppm0.209500.000
213.643.5614.680000024700NOx11:0 ppm / NOx21:0 ppm0.209500.000
215.153.5914.66000005700NOx11:0 ppm / NOx21:0 ppm0.209500.000
216.693.6114.66000003400NOx11:0 ppm / NOx21:0 ppm0.209500.000
218.243.6414.70000008100NOx11:0 ppm / NOx21:0 ppm0.209500.000
219.813.6614.66000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
221.323.6914.70000002800NOx11:0 ppm / NOx21:0 ppm0.209500.000
222.833.7114.7000000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
224.333.7414.66000001800NOx11:0 ppm / NOx21:0 ppm0.209500.000
225.893.7614.68000003300NOx11:0 ppm / NOx21:0 ppm0.209500.000
227.383.7914.62000003100NOx11:0 ppm / NOx21:0 ppm0.209500.000
228.903.8214.64000007100NOx11:0 ppm / NOx21:0 ppm0.209500.000
230.423.8414.660000055100NOx11:0 ppm / NOx21:0 ppm0.209500.000
231.953.8714.640000012100NOx11:0 ppm / NOx21:0 ppm0.209500.000
233.463.8914.640000010500NOx11:0 ppm / NOx21:0 ppm0.209500.000
234.993.9214.64000001800NOx11:0 ppm / NOx21:0 ppm0.209500.000
236.563.9414.66000004200NOx11:0 ppm / NOx21:0 ppm0.209500.000
238.083.9714.66000007200NOx11:0 ppm / NOx21:0 ppm0.209500.000
239.633.9914.640000052300NOx11:0 ppm / NOx21:0 ppm0.209500.000
241.114.0214.600000061000NOx11:0 ppm / NOx21:0 ppm0.209500.000
242.604.0414.32000006300NOx11:0 ppm / NOx21:0 ppm0.209500.000
244.104.0714.68000005200NOx11:0 ppm / NOx21:0 ppm0.209500.000
245.644.0914.7200000100NOx11:0 ppm / NOx21:0 ppm0.209500.000
247.144.1214.7000000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
248.634.1414.7200000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
250.174.1714.7200000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
251.714.2014.7400000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
253.234.2214.7200000000NOx11:0 ppm / NOx21:0 ppm0.209500.000
254.744.2514.72000001900NOx11:0 ppm / NOx21:0 ppm0.209500.000
256.264.2714.70000005000NOx11:0 ppm / NOx21:0 ppm0.209500.000
257.864.3014.720000025200NOx11:0 ppm / NOx21:0 ppm0.209500.000
259.394.3214.740000010700NOx11:0 ppm / NOx21:0 ppm0.209500.000
260.914.3514.76000008300NOx11:0 ppm / NOx21:0 ppm0.209500.000
262.424.3714.72000005400NOx11:0 ppm / NOx21:0 ppm0.209500.000
263.964.4014.72000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
265.484.4214.70000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
267.024.4514.76000004500NOx11:0 ppm / NOx21:0 ppm0.209500.000
268.574.4814.70000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
270.114.5014.70000004400NOx11:0 ppm / NOx21:0 ppm0.209500.000
271.674.5314.72000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
273.234.5514.78000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
274.784.5814.72000004500NOx11:0 ppm / NOx21:0 ppm0.209500.000
276.224.6014.74000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
277.764.6314.72000004200NOx11:0 ppm / NOx21:0 ppm0.209500.000
279.304.6614.70000004400NOx11:0 ppm / NOx21:0 ppm0.209500.000
280.814.6814.74000004000NOx11:0 ppm / NOx21:0 ppm0.209500.000
282.344.7114.78000004500NOx11:0 ppm / NOx21:0 ppm0.209500.000
283.864.7314.70000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
285.364.7614.72000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
286.844.7814.72000004900NOx11:0 ppm / NOx21:0 ppm0.209500.000
288.354.8114.72000004600NOx11:0 ppm / NOx21:0 ppm0.209500.000
289.874.8314.72000004300NOx11:0 ppm / NOx21:0 ppm0.209500.000
291.384.8614.76000004000NOx11:0 ppm / NOx21:0 ppm0.209500.000
292.904.8814.74000002000NOx11:0 ppm / NOx21:0 ppm0.209500.000
294.414.9114.72000001000NOx11:0 ppm / NOx21:0 ppm0.209500.000
295.954.9314.7600000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
297.494.9614.7600000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
299.014.9814.7400000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
300.555.0114.7600000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
302.035.0314.7400000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
303.615.0614.7600000400NOx11:0 ppm / NOx21:0 ppm0.209500.000
305.125.0914.7400000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
306.665.1114.7600000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
308.175.1414.7200000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
309.695.1614.7400000500NOx11:0 ppm / NOx21:0 ppm0.209500.000
311.325.1914.74000007200NOx11:0 ppm / NOx21:0 ppm0.209500.000
312.845.2114.74000005400NOx11:0 ppm / NOx21:0 ppm0.209500.000
314.355.2414.70000007600NOx11:0 ppm / NOx21:0 ppm0.209500.000
315.855.2614.72000008600NOx11:0 ppm / NOx21:0 ppm0.209500.000
317.365.2914.72000003900NOx11:0 ppm / NOx21:0 ppm0.209500.000
318.895.3114.660000011000NOx11:0 ppm / NOx21:0 ppm0.209500.000
320.405.3414.620000097000NOx11:0 ppm / NOx21:0 ppm0.209500.000
321.925.3714.580000062600NOx11:0 ppm / NOx21:0 ppm0.209500.000
323.465.3914.540000050200NOx11:0 ppm / NOx21:0 ppm0.209500.000
324.985.4214.560000040600NOx11:0 ppm / NOx21:0 ppm0.209500.000
326.505.4414.68000009600NOx11:0 ppm / NOx21:0 ppm0.209500.000
328.015.4714.640000014600NOx11:0 ppm / NOx21:0 ppm0.209500.000
329.535.4914.600-7000179145600NOx11:0 ppm / NOx21:0 ppm0.209500.000
331.095.5214.640-700073145600NOx11:0 ppm / NOx21:0 ppm0.209500.000
332.645.5414.640-700083144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
334.175.5714.640-700052144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
335.725.6014.540-700066144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
337.255.6214.560-700038144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
338.765.6514.500-70000144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
340.305.6714.520-7000209144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
341.815.7014.600-700025144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
343.335.7214.520-700033144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
344.845.7514.600-70004144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
346.325.7714.540-700020144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
347.855.8014.580-70006145600NOx11:0 ppm / NOx21:0 ppm0.209500.000
349.355.8214.540-70000144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
350.835.8514.520-7000392144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
352.365.8714.600-100001620100144000NOx11:1650 ppm / NOx21:0 ppm0.209500.000
353.895.9014.600-10000063144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
355.445.9214.600-100002215145600NOx11:55 ppm / NOx21:0 ppm0.209500.000
356.965.9514.600130000144000NOx11:0 ppm / NOx21:0 ppm0.209500.000
358.455.9714.5805900420144000NOx11:35 ppm / NOx21:0 ppm0.209500.000
359.986.0014.5201020088460144000NOx11:72 ppm / NOx21:0 ppm0.209500.000
361.446.0214.56010200112122144000NOx11:104 ppm / NOx21:0 ppm0.209500.000
362.966.0514.540900010294144000NOx11:98 ppm / NOx21:0 ppm0.209500.000
364.476.0714.54082009155144000NOx11:87 ppm / NOx21:0 ppm0.209500.000
365.996.1014.56066008558144000NOx11:81 ppm / NOx21:0 ppm0.209500.000
367.466.1214.56048005741144000NOx11:55 ppm / NOx21:0 ppm0.209500.000
368.986.1514.56043005056144000NOx11:47 ppm / NOx21:0 ppm0.209500.000
370.466.1714.58036004046144000NOx11:39 ppm / NOx21:0 ppm0.209500.000
371.966.2014.54029003546144000NOx11:33 ppm / NOx21:0 ppm0.209500.000
373.506.2314.56030003042145600NOx11:30 ppm / NOx21:0 ppm0.209500.000
375.076.2514.580200015122144000NOx11:18 ppm / NOx21:0 ppm0.209500.000
376.576.2814.52019002018144000NOx11:24 ppm / NOx21:0 ppm0.209500.000
378.146.3014.6001600160144000NOx11:17 ppm / NOx21:0 ppm0.209500.000
379.646.3314.60017001756144000NOx11:16 ppm / NOx21:0 ppm0.209500.000
381.136.3514.6001700170145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
382.696.3814.660220018225145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
384.236.4014.66024002854145600NOx11:26 ppm / NOx21:0 ppm0.209500.000
385.746.4314.64021002122145600NOx11:22 ppm / NOx21:0 ppm0.209500.000
387.286.4514.62018002129145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
388.866.4814.60016001814145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
390.416.5114.60016001614145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
391.946.5314.66013001415145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
393.486.5614.60013001519145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
394.976.5814.60014001520145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
396.466.6114.56012001317145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
397.986.6314.66014001321145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
399.406.6614.68013001316145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
400.966.6814.58013001314145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
402.576.7114.60011001417145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
404.096.7314.64013001218145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
405.606.7614.68014001420145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
407.126.7914.68015001318145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
408.636.8114.68014001319145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
410.156.8414.66014001315145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
411.686.8614.58014001314145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
413.226.8914.64012001317145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
414.766.9114.64013001318145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
416.276.9414.60012001317145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
417.836.9614.64012001520145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
419.356.9914.60012001420145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
420.857.0114.62021001438145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
422.377.0414.56021002287144000NOx11:22 ppm / NOx21:0 ppm0.209500.000
423.887.0614.60039003191145600NOx11:29 ppm / NOx21:0 ppm0.209500.000
425.407.0914.64045003649145600NOx11:28 ppm / NOx21:0 ppm0.209500.000
426.937.1214.64041004550145600NOx11:50 ppm / NOx21:0 ppm0.209500.000
428.507.1414.60035004338145600NOx11:42 ppm / NOx21:0 ppm0.209500.000
430.077.1714.60040003793144000NOx11:31 ppm / NOx21:0 ppm0.209500.000
431.587.1914.58039004331144000NOx11:41 ppm / NOx21:0 ppm0.209500.000
433.097.2214.6401070051423144000NOx11:45 ppm / NOx21:0 ppm0.209500.000
434.687.2414.3401010075327144000NOx11:83 ppm / NOx21:0 ppm0.209500.000
436.217.2714.540770074412144000NOx11:63 ppm / NOx21:0 ppm0.209500.000
437.657.2914.540510063116144000NOx11:65 ppm / NOx21:0 ppm0.209500.000
439.197.3214.54048004342144000NOx11:44 ppm / NOx21:0 ppm0.209500.000
440.707.3514.560610063143144000NOx11:60 ppm / NOx21:0 ppm0.209500.000
442.247.3714.58040003346144000NOx11:53 ppm / NOx21:0 ppm0.209500.000
443.747.4014.580570042286144000NOx11:38 ppm / NOx21:0 ppm0.209500.000
445.257.4214.56048006671145600NOx11:64 ppm / NOx21:0 ppm0.209500.000
446.787.4514.600490051165144000NOx11:49 ppm / NOx21:0 ppm0.209500.000
448.307.4714.560107006044144000NOx11:56 ppm / NOx21:0 ppm0.209500.000
449.817.5014.500750099204144000NOx11:105 ppm / NOx21:0 ppm0.209500.000
451.327.5214.500440048125144000NOx11:45 ppm / NOx21:0 ppm0.209500.000
452.857.5514.50046004668144000NOx11:43 ppm / NOx21:0 ppm0.209500.000
454.387.5714.52033002557144000NOx11:42 ppm / NOx21:0 ppm0.209500.000
455.887.6014.520720054435144000NOx11:42 ppm / NOx21:0 ppm0.209500.000
457.417.6214.5001360086264144000NOx11:76 ppm / NOx21:0 ppm0.209500.000
458.947.6514.54016200193265144000NOx11:186 ppm / NOx21:0 ppm0.209500.000
460.467.6714.5009100154261145600NOx11:154 ppm / NOx21:0 ppm0.209500.000
461.977.7014.540920075331144000NOx11:50 ppm / NOx21:0 ppm0.209500.000
463.557.7314.56060008084144000NOx11:81 ppm / NOx21:0 ppm0.209500.000
465.127.7514.20051005228144000NOx11:50 ppm / NOx21:0 ppm0.209500.000
466.637.7814.56044002659144000NOx11:30 ppm / NOx21:0 ppm0.209500.000
468.147.8014.540430056209144000NOx11:53 ppm / NOx21:0 ppm0.209500.000
469.687.8314.22029003437144000NOx11:34 ppm / NOx21:0 ppm0.209500.000
471.217.8514.54018003275144000NOx11:33 ppm / NOx21:0 ppm0.209500.000
472.727.8814.5401500152144000NOx11:13 ppm / NOx21:0 ppm0.209500.000
474.237.9014.5801200140144000NOx11:14 ppm / NOx21:0 ppm0.209500.000
475.777.9314.5601100130144000NOx11:14 ppm / NOx21:0 ppm0.209500.000
477.277.9514.540800110144000NOx11:10 ppm / NOx21:0 ppm0.209500.000
478.777.9814.540900100144000NOx11:10 ppm / NOx21:0 ppm0.209500.000
480.218.0014.54070090144000NOx11:9 ppm / NOx21:0 ppm0.209500.000
481.728.0314.50070070144000NOx11:6 ppm / NOx21:0 ppm0.209500.000
483.228.0514.54050050144000NOx11:7 ppm / NOx21:0 ppm0.209500.000
484.818.0814.5607001099144000NOx11:4 ppm / NOx21:0 ppm0.209500.000
486.348.1114.600700625144000NOx11:5 ppm / NOx21:0 ppm0.209500.000
487.858.1314.58050088144000NOx11:12 ppm / NOx21:0 ppm0.209500.000
489.398.1614.52070050144000NOx11:4 ppm / NOx21:0 ppm0.209500.000
490.958.1814.5201000556144000NOx11:5 ppm / NOx21:0 ppm0.209500.000
492.488.2114.40080080144000NOx11:8 ppm / NOx21:0 ppm0.209500.000
494.008.2314.520160014291144000NOx11:10 ppm / NOx21:0 ppm0.209500.000
495.528.2614.62017002258145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
497.048.2814.62010001334145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
498.558.3114.60011001143145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
500.058.3314.66011001141145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
501.558.3614.66010001039144000NOx11:12 ppm / NOx21:0 ppm0.209500.000
503.168.3914.68011001058145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
504.688.4114.58012001139145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
506.208.4414.66011001213145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
507.758.4614.6801200115145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
509.338.4914.660800115145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
510.948.5214.700100093145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
512.488.5414.58090073145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
513.998.5714.58090074145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
515.518.5914.620100084145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
517.058.6214.6001000124145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
518.578.6414.640900115145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
520.098.6714.66090096145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
521.608.6914.680100099145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
523.148.7214.62090097145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
524.668.7414.60090085145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
526.188.7714.60090094145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
527.678.7914.60080096145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
529.188.8214.620900812145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
530.698.8414.560900916145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
532.218.8714.60010001018145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
533.738.9014.60011001010144000NOx11:10 ppm / NOx21:0 ppm0.209500.000
535.248.9214.6201000115145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
536.738.9514.6401100104144000NOx11:10 ppm / NOx21:0 ppm0.209500.000
538.258.9714.660100095145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
539.769.0014.580100095145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
541.319.0214.600900105145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
542.829.0514.60090093145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
544.349.0714.66090095145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
545.859.1014.620100086145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
547.439.1214.680900810145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
548.959.1514.6408001010144000NOx11:10 ppm / NOx21:0 ppm0.209500.000
550.469.1714.5808001010145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
551.989.2014.60010001010145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
553.499.2214.6001200910145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
555.019.2514.600900107145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
556.509.2814.64014001232145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
558.019.3014.60012001263145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
559.559.3314.58011001160145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
561.089.3514.6004000145145600NOx11:0 ppm / NOx21:0 ppm0.209500.000
562.659.3814.62090085145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
564.169.4014.660190015203145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
565.689.4314.68019001767145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
567.229.4514.62017001742145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
568.739.4814.64014001639145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
570.259.5014.60015001539145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
571.769.5314.62013001341145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
573.319.5614.62013001246145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
574.809.5814.68012001337145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
576.309.6114.64012001420145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
577.829.6314.6401100128145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
579.349.6614.6801100105145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
580.859.6814.600110085145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
582.379.7114.58070085145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
583.819.7314.560900811145600NOx11:6 ppm / NOx21:0 ppm0.209500.000
585.329.7614.620900818144000NOx11:7 ppm / NOx21:0 ppm0.209500.000
586.869.7814.620700822145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
588.439.8114.660800927145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
589.989.8314.6601000930145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
591.509.8614.620900732145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
593.029.8814.600800832145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
594.569.9114.600600930145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
596.049.9314.680700629145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
597.569.9614.600900728145600NOx11:6 ppm / NOx21:0 ppm0.209500.000
599.079.9814.600800625145600NOx11:6 ppm / NOx21:0 ppm0.209500.000
600.5610.0114.6001000817145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
602.0410.0314.640900915145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
603.5610.0614.600700916145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
605.0510.0814.600700718145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
606.5410.1114.680900854145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
608.0710.1314.5808001178145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
609.5910.1614.600700840145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
611.1010.1914.5408001058145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
612.6210.2114.620700964145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
614.1710.2414.60013001087145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
615.6710.2614.64011001161145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
617.1910.2914.62011001148145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
618.7010.3114.58013001053145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
620.2210.3414.58011001042145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
621.7310.3614.60010001026145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
623.2410.3914.62012001212145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
624.7110.4114.6601000118145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
626.2310.4414.680800108145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
627.7310.4614.640100086144000NOx11:9 ppm / NOx21:0 ppm0.209500.000
629.2510.4914.52080098145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
630.7610.5114.54090087145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
632.2910.5414.58090083145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
633.7910.5614.60090083144000NOx11:9 ppm / NOx21:0 ppm0.209500.000
635.2910.5914.6201000103144000NOx11:11 ppm / NOx21:0 ppm0.209500.000
636.7710.6114.64090082144000NOx11:9 ppm / NOx21:0 ppm0.209500.000
638.3110.6414.60090073145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
639.8010.6614.64080074145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
641.3610.6914.58080074145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
642.9110.7214.64080076145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
644.4310.7414.6001000910145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
645.9310.7714.66018001024145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
647.4510.7914.64019001174145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
648.9610.8214.5807001763144000NOx11:19 ppm / NOx21:0 ppm0.209500.000
650.5210.8414.48013001175145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
652.0410.8714.64011001024145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
653.5510.8914.62014001595145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
655.0810.9214.68015001530145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
656.5810.9414.66013001445145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
658.0910.9714.64015001454145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
659.6010.9914.66013001252145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
661.1211.0214.66012001231145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
662.6511.0414.66012001214145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
664.1211.0714.6001200115145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
665.6211.0914.60016001922145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
667.1611.1214.66021001878145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
668.6811.1414.6605002076145600NOx11:22 ppm / NOx21:0 ppm0.209500.000
670.1811.1714.660230015104145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
671.6911.1914.660220023168145600NOx11:23 ppm / NOx21:0 ppm0.209500.000
673.1811.2214.640230023127145600NOx11:23 ppm / NOx21:0 ppm0.209500.000
674.6911.2414.66022002235145600NOx11:23 ppm / NOx21:0 ppm0.209500.000
676.2411.2714.60023002046145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
677.7411.3014.68024002337145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
679.2611.3214.62021002356145600NOx11:23 ppm / NOx21:0 ppm0.209500.000
680.7711.3514.62020002149145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
682.4411.3714.60018001939145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
683.9711.4014.58016001658145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
685.5511.4314.70090016156145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
687.0711.4514.620160011202145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
688.5911.4814.660170016119145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
690.0911.5014.68018001780145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
691.6011.5314.66016001620145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
693.1011.5514.6001500156145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
694.6011.5814.62019002417145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
696.0811.6014.64020001944145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
697.6211.6314.58021002030145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
699.1611.6514.66015001956145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
700.6711.6814.6601000752145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
702.1011.7014.6601600148145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
703.6211.7314.580250021169145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
705.0811.7514.60031002679145600NOx11:28 ppm / NOx21:0 ppm0.209500.000
706.6111.7814.62025002544145600NOx11:25 ppm / NOx21:0 ppm0.209500.000
708.1811.8014.64022002456145600NOx11:25 ppm / NOx21:0 ppm0.209500.000
709.7011.8314.66026002657145600NOx11:24 ppm / NOx21:0 ppm0.209500.000
711.2111.8514.60020001764145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
712.7111.8814.62015001968145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
714.2111.9014.580110091145600NOx11:8 ppm / NOx21:0 ppm0.209500.000
715.7711.9314.640180016170145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
717.2311.9514.66018001977145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
718.7211.9814.66017001860145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
720.2312.0014.60017001792145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
721.7412.0314.680160017104145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
723.2212.0514.600160015101145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
724.7112.0814.62015001595145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
726.2312.1014.62012001586145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
727.8012.1314.70014001490145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
729.3412.1614.66012001481144000NOx11:16 ppm / NOx21:0 ppm0.209500.000
730.8512.1814.6801100950145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
732.3512.2114.600170014157145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
733.8212.2314.64015001455145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
735.3012.2614.62014001467145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
736.8112.2814.62015001469145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
738.3612.3114.56016001575145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
739.9112.3314.66016001590145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
741.4312.3614.66017001783145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
742.9412.3814.62015001669145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
744.4712.4114.62016001580145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
746.0012.4314.62016001480145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
747.4812.4614.66014001575145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
748.9912.4814.66013001369145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
750.5112.5114.64012001566145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
752.0312.5314.60015001463145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
753.5712.5614.60014001470145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
755.0912.5814.74014001573145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
756.6112.6114.700140014112145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
758.1412.6414.74013001588145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
759.6812.6614.70015001590145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
761.1912.6914.72015001599145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
762.6912.7114.70016001599145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
764.1912.7414.74016001687145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
765.7712.7614.68016001676145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
767.3212.7914.70018001788145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
768.8212.8114.70016001640145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
770.3612.8414.68015001617145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
771.9312.8714.6601600167145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
773.4712.8914.6801400154145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
774.9812.9214.7801400163145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
776.5212.9414.70014001520145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
777.9912.9714.7001600148145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
779.5112.9914.66015001413145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
781.0713.0214.64019001557145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
782.6113.0414.64019002147145600NOx11:23 ppm / NOx21:0 ppm0.209500.000
784.1413.0714.70014002143145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
785.6513.0914.68016001382145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
787.1713.1214.76017001679145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
788.6913.1414.70016001666145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
790.2013.1714.760160017104145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
791.7013.2014.74017001664145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
793.2013.2214.70020001698145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
794.7413.2514.74016001736145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
796.2413.2714.72015001713147200NOx11:16 ppm / NOx21:0 ppm0.209500.000
797.7613.3014.7001400165145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
799.2713.3214.7801500164147200NOx11:17 ppm / NOx21:0 ppm0.209500.000
800.8613.3514.6601500163147200NOx11:15 ppm / NOx21:0 ppm0.209500.000
802.3713.3714.7201400153145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
803.8813.4014.7201300143147200NOx11:14 ppm / NOx21:0 ppm0.209500.000
805.4213.4214.7601300133145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
806.8913.4514.7201400143145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
808.4213.4714.70016001559145600NOx11:15 ppm / NOx21:0 ppm0.209500.000
809.9413.5014.68025002075145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
811.4913.5214.700510031286145600NOx11:24 ppm / NOx21:0 ppm0.209500.000
813.0313.5514.70020003852145600NOx11:44 ppm / NOx21:0 ppm0.209500.000
814.5413.5814.700360031121145600NOx11:33 ppm / NOx21:0 ppm0.209500.000
816.0913.6014.6602300292145600NOx11:30 ppm / NOx21:0 ppm0.209500.000
817.5813.6314.6601900220145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
819.1313.6514.72017001615145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
820.6913.6814.680250020172145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
822.2113.7014.68028002968145600NOx11:27 ppm / NOx21:0 ppm0.209500.000
823.7113.7314.66025002669145600NOx11:26 ppm / NOx21:0 ppm0.209500.000
825.2313.7514.70024002472145600NOx11:26 ppm / NOx21:0 ppm0.209500.000
826.7313.7814.76025002471145600NOx11:24 ppm / NOx21:0 ppm0.209500.000
828.2513.8014.74023002270145600NOx11:22 ppm / NOx21:0 ppm0.209500.000
829.7613.8314.70023002270145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
831.2613.8514.66023002369145600NOx11:22 ppm / NOx21:0 ppm0.209500.000
832.7813.8814.70022002168145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
834.2913.9014.70023002266145600NOx11:21 ppm / NOx21:0 ppm0.209500.000
835.8613.9314.74021002268145600NOx11:22 ppm / NOx21:0 ppm0.209500.000
837.3413.9614.72022002288147200NOx11:23 ppm / NOx21:0 ppm0.209500.000
838.8513.9814.740200019107145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
840.3714.0114.76018002080145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
841.8814.0314.74018001881145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
843.3814.0614.74018001881145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
844.9014.0814.74017001885145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
846.4214.1114.72017001890145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
847.8814.1314.68018001796145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
849.4014.1614.72017001890145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
850.8714.1814.76018001877145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
852.4014.2114.68018001875145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
853.9014.2314.74017001869147200NOx11:18 ppm / NOx21:0 ppm0.209500.000
855.4614.2614.68019001876145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
856.9914.2814.70018001768145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
858.4914.3114.72018001632145600NOx11:17 ppm / NOx21:0 ppm0.209500.000
860.0114.3314.72017001813145600NOx11:19 ppm / NOx21:0 ppm0.209500.000
861.5314.3614.7001600186145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
863.0214.3814.72018001720145600NOx11:18 ppm / NOx21:0 ppm0.209500.000
864.5114.4114.78023003229147200NOx11:28 ppm / NOx21:0 ppm0.209500.000
866.0914.4314.740500067137147200NOx11:58 ppm / NOx21:0 ppm0.209500.000
867.5114.4614.780530055238147200NOx11:33 ppm / NOx21:0 ppm0.209500.000
869.0214.4814.80056004380147200NOx11:38 ppm / NOx21:0 ppm0.209500.000
870.5414.5114.82034004615147200NOx11:50 ppm / NOx21:0 ppm0.209500.000
872.0914.5314.8602300320147200NOx11:32 ppm / NOx21:0 ppm0.209500.000
873.6614.5614.8401700200147200NOx11:21 ppm / NOx21:0 ppm0.209500.000
875.2214.5914.8601200150147200NOx11:17 ppm / NOx21:0 ppm0.209500.000
876.7214.6114.7201000120145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
878.2414.6414.7401100825147200NOx11:8 ppm / NOx21:0 ppm0.209500.000
879.7614.6614.76015001098147200NOx11:8 ppm / NOx21:0 ppm0.209500.000
881.2614.6914.700210018143147200NOx11:17 ppm / NOx21:0 ppm0.209500.000
882.7414.7114.70028002497145600NOx11:24 ppm / NOx21:0 ppm0.209500.000
884.2714.7414.70025002556147200NOx11:26 ppm / NOx21:0 ppm0.209500.000
885.8014.7614.72022002325147200NOx11:24 ppm / NOx21:0 ppm0.209500.000
887.2714.7914.74018001911147200NOx11:20 ppm / NOx21:0 ppm0.209500.000
888.7814.8114.7601900186145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
890.3314.8414.7201800173147200NOx11:17 ppm / NOx21:0 ppm0.209500.000
891.8114.8614.7801600162145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
893.3214.8914.7601600161147200NOx11:16 ppm / NOx21:0 ppm0.209500.000
894.8814.9114.7401500151145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
896.4014.9414.7401400142147200NOx11:15 ppm / NOx21:0 ppm0.209500.000
897.8914.9614.7201200141147200NOx11:14 ppm / NOx21:0 ppm0.209500.000
899.3914.9914.7401300131147200NOx11:13 ppm / NOx21:0 ppm0.209500.000
900.9015.0214.7601100122145600NOx11:13 ppm / NOx21:0 ppm0.209500.000
902.4215.0414.7401000131145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
903.9515.0714.7001200111145600NOx11:12 ppm / NOx21:0 ppm0.209500.000
905.4015.0914.7201100111145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
906.8815.1114.7201000111145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
908.4115.1414.7201000102145600NOx11:10 ppm / NOx21:0 ppm0.209500.000
909.9315.1714.70090091147200NOx11:10 ppm / NOx21:0 ppm0.209500.000
911.4915.1914.7001200104145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
913.0015.2214.66034002536145600NOx11:20 ppm / NOx21:0 ppm0.209500.000
914.5115.2414.7001040066186145600NOx11:60 ppm / NOx21:0 ppm0.209500.000
916.0615.2714.580370080378145600NOx11:91 ppm / NOx21:0 ppm0.209500.000
917.5915.2914.70056003883145600NOx11:33 ppm / NOx21:0 ppm0.209500.000
919.1515.3214.74036004815145600NOx11:50 ppm / NOx21:0 ppm0.209500.000
920.6615.3414.7602400310145600NOx11:32 ppm / NOx21:0 ppm0.209500.000
922.1915.3714.7401900220145600NOx11:23 ppm / NOx21:0 ppm0.209500.000
923.7015.4014.74018001552145600NOx11:14 ppm / NOx21:0 ppm0.209500.000
925.2615.4214.7001100140147200NOx11:12 ppm / NOx21:0 ppm0.209500.000
926.7815.4514.760190014145147200NOx11:12 ppm / NOx21:0 ppm0.209500.000
928.2715.4714.740240021119147200NOx11:22 ppm / NOx21:0 ppm0.209500.000
929.7915.5014.74022002194147200NOx11:23 ppm / NOx21:0 ppm0.209500.000
931.2915.5214.74018001835147200NOx11:18 ppm / NOx21:0 ppm0.209500.000
932.8315.5514.74013001613145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
934.3015.5714.7401200146147200NOx11:15 ppm / NOx21:0 ppm0.209500.000
935.8215.6014.7401100113147200NOx11:12 ppm / NOx21:0 ppm0.209500.000
937.2715.6214.7201000122145600NOx11:11 ppm / NOx21:0 ppm0.209500.000
938.7915.6514.72090092147200NOx11:9 ppm / NOx21:0 ppm0.209500.000
940.3015.6714.700900101145600NOx11:9 ppm / NOx21:0 ppm0.209500.000
941.8215.7014.720110082145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
943.3615.7214.76080072147200NOx11:7 ppm / NOx21:0 ppm0.209500.000
944.9415.7514.66080092147200NOx11:9 ppm / NOx21:0 ppm0.209500.000
946.4515.7714.74060072145600NOx11:7 ppm / NOx21:0 ppm0.209500.000
947.9415.8014.70060072147200NOx11:7 ppm / NOx21:0 ppm0.209500.000
949.4915.8214.72060082147200NOx11:8 ppm / NOx21:0 ppm0.209500.000
951.0615.8514.74060052147200NOx11:6 ppm / NOx21:0 ppm0.209500.000
952.5915.8814.74060052145600NOx11:5 ppm / NOx21:0 ppm0.209500.000
954.1615.9014.74070052147200NOx11:6 ppm / NOx21:0 ppm0.209500.000
955.7015.9314.74070052145600NOx11:5 ppm / NOx21:0 ppm0.209500.000
957.2315.9514.72080062147200NOx11:4 ppm / NOx21:0 ppm0.209500.000
958.7615.9814.76050062147200NOx11:7 ppm / NOx21:0 ppm0.209500.000
960.3016.0114.76060042147200NOx11:4 ppm / NOx21:0 ppm0.209500.000
961.8216.0314.72060042145600NOx11:5 ppm / NOx21:0 ppm0.209500.000
963.3116.0614.74040052145600NOx11:4 ppm / NOx21:0 ppm0.209500.000
964.8216.0814.74060042145600NOx11:4 ppm / NOx21:0 ppm0.209500.000
966.3616.1114.74040032147200NOx11:3 ppm / NOx21:0 ppm0.209500.000
967.8616.1314.72040053147200NOx11:4 ppm / NOx21:0 ppm0.209500.000
969.3716.1614.76060033147200NOx11:4 ppm / NOx21:0 ppm0.209500.000
970.8916.1814.76040042145600NOx11:4 ppm / NOx21:0 ppm0.209500.000
972.4016.2114.76040042145600NOx11:3 ppm / NOx21:0 ppm0.209500.000
973.9316.2314.70040032147200NOx11:4 ppm / NOx21:0 ppm0.209500.000
975.4616.2614.70050041147200NOx11:4 ppm / NOx21:0 ppm0.209500.000
976.9716.2814.70050022147200NOx11:2 ppm / NOx21:0 ppm0.209500.000
978.4816.3114.74050032145600NOx11:3 ppm / NOx21:0 ppm0.209500.000
980.0016.3314.74050032145600NOx11:3 ppm / NOx21:0 ppm0.209500.000
981.5416.3614.7401300322145600NOx11:3 ppm / NOx21:0 ppm0.209500.000
983.0516.3814.70027001751145600NOx11:16 ppm / NOx21:0 ppm0.209500.000
984.5716.4114.680510059172145600NOx11:49 ppm / NOx21:0 ppm0.209500.000
986.0916.4314.68012500481102145600NOx11:32 ppm / NOx21:0 ppm0.209500.000
987.5816.4614.70010400114677145600NOx11:116 ppm / NOx21:0 ppm0.209500.000
989.1116.4914.7009900108600145600NOx11:104 ppm / NOx21:0 ppm0.209500.000
990.6016.5114.72066007159145600NOx11:67 ppm / NOx21:0 ppm0.209500.000
992.0716.5314.68048006890145600NOx11:71 ppm / NOx21:0 ppm0.209500.000
993.5616.5614.720660069113145600NOx11:65 ppm / NOx21:0 ppm0.209500.000
995.0616.5814.720620051197145600NOx11:43 ppm / NOx21:0 ppm0.209500.000
996.5816.6114.70066005023145600NOx11:47 ppm / NOx21:0 ppm0.209500.000
998.0716.6314.66044006127145600NOx11:62 ppm / NOx21:0 ppm0.209500.000
999.5816.6614.700440048355145600NOx11:54 ppm / NOx21:0 ppm0.209500.000
1001.1016.6914.680420049156145600NOx11:47 ppm / NOx21:0 ppm0.209500.000
1002.6416.7114.74043004483145600NOx11:42 ppm / NOx21:0 ppm0.209500.000
1004.1216.7414.76039004368145600NOx11:44 ppm / NOx21:0 ppm0.209500.000
1005.6416.7614.72037004148145600NOx11:41 ppm / NOx21:0 ppm0.209500.000
1007.1616.7914.76034003649145600NOx11:36 ppm / NOx21:0 ppm0.209500.000
1008.7016.8114.74033003652147200NOx11:34 ppm / NOx21:0 ppm0.209500.000
1010.2116.8414.70029003354145600NOx11:31 ppm / NOx21:0 ppm0.209500.000
1011.7316.8614.74033003458145600NOx11:32 ppm / NOx21:0 ppm0.209500.000
1013.2416.8914.74031003360145600NOx11:33 ppm / NOx21:0 ppm0.209500.000
1014.7816.9114.66060-6040551456014560NOx11:33 ppm / NOx21:0 ppm0.000400.000
1016.2916.9414.52094-60801391456014560NOx11:75 ppm / NOx21:0 ppm0.000390.000
1017.8516.9614.66096-601292451456014400NOx11:113 ppm / NOx21:0 ppm0.000390.000
1019.3916.9914.680117-60895441456014400NOx11:89 ppm / NOx21:0 ppm0.000390.000
1020.9717.0214.70057-60881071456014400NOx11:96 ppm / NOx21:0 ppm0.000390.000
1022.4517.0414.74048-6055801456014400NOx11:54 ppm / NOx21:0 ppm0.000390.000
1023.9317.0714.74038-6046761456014400NOx11:43 ppm / NOx21:0 ppm0.000390.000
1025.4617.0914.70037-6040761456014400NOx11:38 ppm / NOx21:0 ppm0.000390.000
1026.9817.1214.74036-6038741456014400NOx11:35 ppm / NOx21:0 ppm0.000390.000
1028.5417.1414.66052-6040491456014400NOx11:36 ppm / NOx21:0 ppm0.000390.000
1030.0517.1714.680124-60855051456014400NOx11:75 ppm / NOx21:0 ppm0.000390.000
1031.5817.1914.6800-601134881456014560NOx11:115 ppm / NOx21:0 ppm0.000390.000
1033.0917.2214.720163-6001211456014560NOx11:177 ppm / NOx21:0 ppm0.000390.000
1034.6117.2414.68059-60962671456014560NOx11:95 ppm / NOx21:0 ppm0.000390.000
1036.1217.2714.68024-100052781456014560NOx11:53 ppm / NOx21:0 ppm0.103140.000
1037.6417.2914.74031-10002981456014560NOx11:30 ppm / NOx21:0 ppm0.222090.000
1039.1517.3214.70061-360583951456014560NOx11:38 ppm / NOx21:0 ppm0.080920.000
1040.7017.3514.7203244044661456014560NOx11:47 ppm / NOx21:0 ppm0.056060.000
1042.2317.3714.74029-100022871456014560NOx11:19 ppm / NOx21:0 ppm0.107350.000
1043.7417.4014.72033-100034611456014560NOx11:35 ppm / NOx21:0 ppm0.066370.000
1045.1917.4214.74030-67032561456014560NOx11:30 ppm / NOx21:0 ppm0.054420.000
1046.7517.4514.6602510028481456014560NOx11:25 ppm / NOx21:0 ppm0.048030.000
1048.3017.4714.72024622626511456014560NOx11:26 ppm / NOx21:24 ppm0.049390.000
1049.8217.5014.740231007422461456014560NOx11:22 ppm / NOx21:74 ppm0.054670.000
1051.3317.5214.6001813711223421456014560NOx11:24 ppm / NOx21:110 ppm0.053740.000
1052.8417.5514.7605991581351456014560NOx11:8 ppm / NOx21:157 ppm0.151300.000
1054.3517.5714.74026291401456014560NOx11:1 ppm / NOx21:96 ppm0.197440.000
1055.8717.6014.76015058401456014560NOx11:4 ppm / NOx21:59 ppm0.201180.000
1057.3917.6214.74024348201456014560NOx11:3 ppm / NOx21:48 ppm0.202300.000
1058.9217.6514.76003841201456014560NOx11:1 ppm / NOx21:42 ppm0.202900.000
1060.4917.6714.74013537101456014400NOx11:2 ppm / NOx21:37 ppm0.203230.000
1062.0117.7014.70015253601321456014560NOx11:2 ppm / NOx21:35 ppm0.202070.000
1063.5917.7314.74041440451431456014560NOx11:35 ppm / NOx21:0 ppm0.071430.000
1065.1117.7514.74018676228571456014560NOx11:32 ppm / NOx21:61 ppm0.112650.000
1066.6217.7814.700454346376581456014560NOx11:36 ppm / NOx21:49 ppm0.123510.000
1068.1717.8014.700501422451051456014560NOx11:47 ppm / NOx21:24 ppm0.088860.000
1069.7217.8314.720576135521781456014560NOx11:51 ppm / NOx21:33 ppm0.045550.000
1071.2317.8514.740606356592401456014560NOx11:59 ppm / NOx21:55 ppm0.050190.000
1072.7517.8814.7603212162571911456014560NOx11:56 ppm / NOx21:61 ppm0.051010.000
1074.2617.9014.74033467544291456014560NOx11:39 ppm / NOx21:74 ppm0.179390.000
1075.8017.9314.7602039432331456014560NOx11:29 ppm / NOx21:46 ppm0.199520.000
1077.3417.9614.740938401501456014560NOx11:14 ppm / NOx21:41 ppm0.201350.000
1078.9217.9814.740244396541456014560NOx11:6 ppm / NOx21:40 ppm0.193770.000
1080.4718.0114.7201545465901456014560NOx11:6 ppm / NOx21:43 ppm0.200650.000
1081.9818.0314.720843485341456014560NOx11:4 ppm / NOx21:47 ppm0.200280.000
1083.5018.0614.74013284091821472014560NOx11:10 ppm / NOx21:41 ppm0.174480.000
1085.0018.0814.740133128131351456014560NOx11:13 ppm / NOx21:27 ppm0.161220.000
1086.5118.1114.740113625131061456014560NOx11:14 ppm / NOx21:25 ppm0.146380.000
1088.0118.1314.740103234111111456014560NOx11:10 ppm / NOx21:34 ppm0.144560.000
1089.5318.1614.72093132101201456014560NOx11:10 ppm / NOx21:32 ppm0.144630.000
1091.0618.1814.7608303091241472014560NOx11:8 ppm / NOx21:30 ppm0.143690.000
1092.5918.2114.780819259981472014560NOx11:8 ppm / NOx21:25 ppm0.140170.000
1094.1118.2414.740181316101291456014560NOx11:11 ppm / NOx21:16 ppm0.125820.000
1095.6418.2614.72016291615491456014560NOx11:16 ppm / NOx21:14 ppm0.074870.000
1097.1518.2914.60022523121201456014560NOx11:17 ppm / NOx21:32 ppm0.043140.000
1098.6418.3114.7801349748301472014560NOx11:12 ppm / NOx21:73 ppm0.136300.000
1100.3318.3414.78013384212231472014560NOx11:13 ppm / NOx21:42 ppm0.156930.000
1101.8718.3614.7809293311171472014560NOx11:10 ppm / NOx21:33 ppm0.183320.000
1103.3818.3914.780162426132131456014560NOx11:14 ppm / NOx21:25 ppm0.160190.000
1104.8918.4114.76013272015971472014560NOx11:13 ppm / NOx21:19 ppm0.146600.000
1106.4218.4414.72013232613921456014560NOx11:12 ppm / NOx21:27 ppm0.143700.000
1107.9218.4714.760121719141151472014560NOx11:15 ppm / NOx21:19 ppm0.122630.000
1109.4918.4914.72012221713431472014560NOx11:15 ppm / NOx21:18 ppm0.106790.000
1111.0318.5214.72018232312631456014560NOx11:11 ppm / NOx21:23 ppm0.096950.000
1112.5818.5414.760114427151001456014560NOx11:19 ppm / NOx21:26 ppm0.069840.000
1114.1018.5714.7006435751071456014560NOx11:4 ppm / NOx21:54 ppm0.145590.000
1115.6218.5914.740132740121801472014560NOx11:12 ppm / NOx21:42 ppm0.158670.000
1117.1118.6214.740172226141591456014560NOx11:15 ppm / NOx21:27 ppm0.144300.000
1118.6618.6414.72016122116841472014560NOx11:15 ppm / NOx21:21 ppm0.119160.000
1120.1818.6714.72028251814381456014560NOx11:14 ppm / NOx21:18 ppm0.102040.000
1121.7318.7014.78010514528584351456014560NOx11:44 ppm / NOx21:13 ppm0.054360.000
1123.2418.7214.700691031511102551456014560NOx11:110 ppm / NOx21:145 ppm0.065940.000
1124.7618.7514.700741161461102681456014560NOx11:98 ppm / NOx21:160 ppm0.049910.000
1126.2818.7714.680120341153895911456014560NOx11:74 ppm / NOx21:146 ppm0.026310.000
1127.8218.8014.6601183843511216241456014560NOx11:122 ppm / NOx21:350 ppm0.025380.000
1129.3418.8214.680822943621212871456014560NOx11:116 ppm / NOx21:367 ppm0.031470.000
1130.8618.8514.7201723903711626021456014560NOx11:149 ppm / NOx21:356 ppm0.058020.000
1132.3718.8714.7201402234821745011456014560NOx11:183 ppm / NOx21:489 ppm0.106830.000
1133.8818.9015.0409756123100271488014720NOx11:101 ppm / NOx21:131 ppm0.192440.000
1135.4018.9214.88011042511131361472014720NOx11:105 ppm / NOx21:54 ppm0.172570.000
1136.9218.9514.82011029391171311472014720NOx11:110 ppm / NOx21:39 ppm0.169150.000
1138.4618.9714.74011022271141311472014560NOx11:108 ppm / NOx21:28 ppm0.165170.000
1140.0019.0014.72011118201151101472014560NOx11:107 ppm / NOx21:21 ppm0.160900.000
1141.5519.0314.7801101313118971472014560NOx11:111 ppm / NOx21:14 ppm0.154470.000
1143.0619.0514.7801101413117881472014560NOx11:111 ppm / NOx21:12 ppm0.150880.000
1144.5919.0814.82010414111181141472014560NOx11:112 ppm / NOx21:11 ppm0.138450.000
1146.1119.1014.7805719268131472014560NOx11:81 ppm / NOx21:31 ppm0.197210.000
1147.6419.1314.8203514174701472014560NOx11:49 ppm / NOx21:17 ppm0.201730.000
1149.1519.1514.8002315163001472014560NOx11:31 ppm / NOx21:15 ppm0.202880.000
1150.6619.1814.8001112132101472014560NOx11:21 ppm / NOx21:12 ppm0.203330.000
1152.2119.2014.8001014131201472014560NOx11:14 ppm / NOx21:12 ppm0.203760.000
1153.7319.2314.80071013601472014560NOx11:7 ppm / NOx21:13 ppm0.203970.000
1155.2419.2514.78031111501472014560NOx11:5 ppm / NOx21:11 ppm0.203950.000
1156.7119.2814.7208611411472014560NOx11:4 ppm / NOx21:12 ppm0.204020.000
1158.2319.3014.74011584261472014560NOx11:12 ppm / NOx21:13 ppm0.202490.000
1159.7419.3314.74001183171472014560NOx11:1 ppm / NOx21:5 ppm0.203120.000
1161.2419.3514.76011010381472014560NOx11:11 ppm / NOx21:10 ppm0.200180.000
1162.7619.3814.780961051391472014560NOx11:5 ppm / NOx21:10 ppm0.179880.000
1164.2519.4014.780108691821472014560NOx11:10 ppm / NOx21:5 ppm0.159810.000
1165.7219.4314.74096991291472014560NOx11:9 ppm / NOx21:10 ppm0.149730.000
1167.2519.4514.76086510871472014560NOx11:10 ppm / NOx21:5 ppm0.130310.000
1168.7719.4814.8007868731472014560NOx11:9 ppm / NOx21:7 ppm0.117220.000
1170.3219.5114.780411106601472014560NOx11:7 ppm / NOx21:9 ppm0.111580.000
1171.8219.5314.780611135571472014560NOx11:6 ppm / NOx21:13 ppm0.110580.000
1173.3319.5614.780414124501472014560NOx11:4 ppm / NOx21:11 ppm0.108900.000
1174.8819.5814.820512125491472014560NOx11:5 ppm / NOx21:11 ppm0.109850.000
1176.3419.6114.740410105501472014560NOx11:4 ppm / NOx21:11 ppm0.109340.000
1177.8419.6314.740411124451472014560NOx11:3 ppm / NOx21:12 ppm0.108330.000
1179.3519.6614.740514124461472014560NOx11:4 ppm / NOx21:12 ppm0.109360.000
1180.8719.6814.72015-9124291472014560NOx11:4 ppm / NOx21:12 ppm0.109020.000
1182.3819.7114.78021400262401456014560NOx11:21 ppm / NOx21:3 ppm0.030840.000
1183.8719.7314.760404548531681472014560NOx11:49 ppm / NOx21:45 ppm0.061710.000
1185.3519.7614.78037304534941472014560NOx11:31 ppm / NOx21:54 ppm0.108260.000
1186.8419.7814.760381932391341472014560NOx11:35 ppm / NOx21:29 ppm0.098670.000
1188.3719.8114.80036202140871472014560NOx11:38 ppm / NOx21:23 ppm0.087500.000
1189.8819.8314.78022441835311472014560NOx11:35 ppm / NOx21:19 ppm0.088410.000
1191.4019.8614.780271929251241472014560NOx11:25 ppm / NOx21:29 ppm0.152810.000
1192.9119.8814.800251114261361472014560NOx11:27 ppm / NOx21:14 ppm0.158410.000
1194.4419.9114.78033613241311472014560NOx11:26 ppm / NOx21:13 ppm0.158150.000
1196.0219.9314.7403284361291472014560NOx11:33 ppm / NOx21:5 ppm0.089640.000
1197.5419.9614.7803311636241472014560NOx11:30 ppm / NOx21:7 ppm0.050290.000
1199.0819.9814.780422923341681472014560NOx11:34 ppm / NOx21:23 ppm0.053960.000
1200.6020.0114.78051593347641472014560NOx11:42 ppm / NOx21:34 ppm0.034980.000
1202.1120.0414.76051786956121472014560NOx11:53 ppm / NOx21:68 ppm0.041460.000
1203.6120.0614.82045416941641472014560NOx11:42 ppm / NOx21:67 ppm0.062540.000
1205.1420.0914.76041414643951472014560NOx11:42 ppm / NOx21:48 ppm0.061690.000
1206.6720.1114.76029384535521472014560NOx11:35 ppm / NOx21:48 ppm0.081000.000
1208.1720.1414.800282130291061472014560NOx11:29 ppm / NOx21:28 ppm0.096950.000
1209.6820.1614.780413417284021472014560NOx11:28 ppm / NOx21:16 ppm0.066200.000
1211.1820.1914.74012817612512310321456014560NOx11:94 ppm / NOx21:116 ppm0.050390.000
1212.7020.2114.7606487143984821472014560NOx11:96 ppm / NOx21:151 ppm0.037360.000
1214.2520.2414.78055546261681456014560NOx11:62 ppm / NOx21:64 ppm0.039620.000
1215.7620.2614.6409118290752321472014560NOx11:66 ppm / NOx21:85 ppm0.036860.000
1217.2820.2914.7605211615169911472014560NOx11:73 ppm / NOx21:152 ppm0.032370.000
1218.7920.3114.760457410344611472014560NOx11:47 ppm / NOx21:109 ppm0.074510.000
1220.3320.3414.780515110145871472014560NOx11:46 ppm / NOx21:100 ppm0.152350.000
1221.8420.3614.8203617344561472014560NOx11:45 ppm / NOx21:34 ppm0.194700.000
1223.3620.3914.780321614352131472014560NOx11:35 ppm / NOx21:18 ppm0.177200.000
1224.8620.4114.82043-414312291472014560NOx11:30 ppm / NOx21:14 ppm0.168850.000
1226.3720.4414.68079990658901472014560NOx11:60 ppm / NOx21:0 ppm0.032760.000
1227.8620.4614.7601281641831347061472014560NOx11:115 ppm / NOx21:174 ppm0.050940.000
1229.3620.4914.7401322092031465181472014560NOx11:125 ppm / NOx21:195 ppm0.046440.000
1230.8720.5114.780962022351398121472014560NOx11:119 ppm / NOx21:227 ppm0.041300.000
1232.3920.5414.800741011801084081472014560NOx11:102 ppm / NOx21:181 ppm0.107340.000
1233.9020.5714.82066255878181472014560NOx11:78 ppm / NOx21:56 ppm0.189470.000
1235.4320.5914.8004011205501472014560NOx11:56 ppm / NOx21:22 ppm0.199310.000
1236.9520.6214.7802210113301472014560NOx11:33 ppm / NOx21:11 ppm0.201380.000
1238.4620.6414.82014891701472014560NOx11:19 ppm / NOx21:8 ppm0.202350.000
1240.0620.6714.74012681101472014560NOx11:12 ppm / NOx21:8 ppm0.202800.000
1241.6620.6914.7604257191472014560NOx11:16 ppm / NOx21:8 ppm0.200830.000
1243.2720.7214.78076811181472014560NOx11:0 ppm / NOx21:9 ppm0.198510.000
1244.7820.7514.800156791501472014560NOx11:10 ppm / NOx21:7 ppm0.178940.000
1246.2920.7714.7601535151651472014560NOx11:15 ppm / NOx21:4 ppm0.170410.000
1247.8220.8014.7805372331401472014560NOx11:19 ppm / NOx21:3 ppm0.090760.000
1249.3920.8214.72034643147881472014560NOx11:47 ppm / NOx21:38 ppm0.050910.000
1250.9020.8514.7606411074791091472014560NOx11:62 ppm / NOx21:61 ppm0.046900.000
1252.4220.8714.760328098471161472014560NOx11:51 ppm / NOx21:98 ppm0.051130.000
1253.9320.9014.760579086362651472014560NOx11:39 ppm / NOx21:91 ppm0.074030.000
1255.4520.9214.7802210378501011472014560NOx11:50 ppm / NOx21:75 ppm0.078020.000
1256.9620.9514.80032395835301472014560NOx11:29 ppm / NOx21:61 ppm0.176030.000
1258.4820.9714.8001613232301472014560NOx11:25 ppm / NOx21:22 ppm0.198810.000
1260.0321.0014.78057101301456014560NOx11:12 ppm / NOx21:11 ppm0.200020.000
1261.5421.0314.780671013231472014560NOx11:4 ppm / NOx21:11 ppm0.199440.000
1263.0621.0514.82079715221472014560NOx11:9 ppm / NOx21:8 ppm0.198170.000
1264.5821.0814.780479501472014560NOx11:6 ppm / NOx21:8 ppm0.201700.000
1266.1121.1014.7604474191472014560NOx11:4 ppm / NOx21:7 ppm0.199930.000
1267.6521.1314.780131691601472014560NOx11:7 ppm / NOx21:5 ppm0.178680.000
1269.1821.1514.7801232121261472014560NOx11:13 ppm / NOx21:3 ppm0.160210.000
1270.7021.1814.800122211921472014560NOx11:11 ppm / NOx21:2 ppm0.155080.000
1272.1821.2014.78013-21121071472014560NOx11:12 ppm / NOx21:1 ppm0.136050.000
1273.6721.2314.78098311831472014560NOx11:12 ppm / NOx21:3 ppm0.128200.000
1275.1821.2514.780911010821472014560NOx11:10 ppm / NOx21:10 ppm0.129780.000
1276.7021.2814.800114210801472014560NOx11:10 ppm / NOx21:2 ppm0.119020.000
1278.2421.3014.7409829701472014560NOx11:10 ppm / NOx21:1 ppm0.113290.000
1279.8021.3314.7809568661472014560NOx11:9 ppm / NOx21:5 ppm0.111730.000
1281.3321.3614.7607568631472014560NOx11:7 ppm / NOx21:7 ppm0.110340.000
1282.8621.3814.7406858581472014560NOx11:9 ppm / NOx21:6 ppm0.109420.000
1284.3221.4114.8007787601472014560NOx11:6 ppm / NOx21:7 ppm0.109920.000
1285.8821.4314.7807757621472014560NOx11:7 ppm / NOx21:5 ppm0.110140.000
1287.3921.4614.7806676641472014560NOx11:5 ppm / NOx21:8 ppm0.110670.000
1288.9021.4814.8006786611472014560NOx11:7 ppm / NOx21:8 ppm0.110170.000
1290.4421.5114.7607886611472014560NOx11:7 ppm / NOx21:9 ppm0.109950.000
1291.9521.5314.7805767611472014560NOx11:5 ppm / NOx21:5 ppm0.110240.000
1293.4721.5614.80010076621472014560NOx11:6 ppm / NOx21:6 ppm0.110510.000
1294.9821.5814.760148115781456014560NOx11:14 ppm / NOx21:1 ppm0.073030.000
1296.5221.6114.7602648228561456014560NOx11:21 ppm / NOx21:3 ppm0.042160.000
1298.0721.6314.78035413443921472014560NOx11:40 ppm / NOx21:20 ppm0.050270.000
1299.5921.6614.720506538532391472014560NOx11:45 ppm / NOx21:51 ppm0.053040.000
1301.1321.6914.780445864441651472014560NOx11:40 ppm / NOx21:69 ppm0.051330.000
1302.6421.7114.80036555944761472014560NOx11:45 ppm / NOx21:59 ppm0.054000.000
1304.1521.7414.800443945341741472014560NOx11:32 ppm / NOx21:43 ppm0.089460.000
1305.6721.7614.78039374050541472014560NOx11:46 ppm / NOx21:41 ppm0.061970.000
1307.1921.7914.78032383739321472014560NOx11:39 ppm / NOx21:38 ppm0.051770.000
1308.6721.8114.740122236706411811472014560NOx11:52 ppm / NOx21:70 ppm0.047580.000
1310.2221.8414.70010625536516310761472014560NOx11:160 ppm / NOx21:359 ppm0.031830.000
1311.7321.8614.760822122681092371472014560NOx11:108 ppm / NOx21:272 ppm0.033080.000
1313.2521.8914.7605112118371271472014560NOx11:75 ppm / NOx21:188 ppm0.038390.000
1314.7921.9114.780419512046491472014560NOx11:50 ppm / NOx21:120 ppm0.070130.000
1316.3121.9414.66047499531461472014560NOx11:31 ppm / NOx21:92 ppm0.157000.000
1317.8321.9614.780675852572571472014560NOx11:54 ppm / NOx21:52 ppm0.148310.000
1319.3421.9914.78044584564561472014560NOx11:61 ppm / NOx21:50 ppm0.118320.000
1320.9022.0214.7603518393751472014560NOx11:38 ppm / NOx21:41 ppm0.196140.000
1322.4222.0414.760321316261711472014560NOx11:27 ppm / NOx21:14 ppm0.180120.000
1323.9322.0714.760461416381171472014560NOx11:34 ppm / NOx21:16 ppm0.155280.000
1325.4222.0914.7804338063361472014560NOx11:56 ppm / NOx21:0 ppm0.059010.000
1326.9422.1214.76034384237581472014560NOx11:36 ppm / NOx21:39 ppm0.074550.000
1328.4422.1414.80029343235581472014560NOx11:34 ppm / NOx21:32 ppm0.067860.000
1329.9222.1714.76028303230591472014560NOx11:28 ppm / NOx21:31 ppm0.072770.000
1331.4422.1914.74027293231601472014560NOx11:28 ppm / NOx21:32 ppm0.070740.000
1332.9522.2214.76026323028581472014560NOx11:27 ppm / NOx21:29 ppm0.070090.000
1334.4622.2414.78018343323361472014560NOx11:22 ppm / NOx21:34 ppm0.103720.000
1335.9722.2714.78033172027941472014560NOx11:22 ppm / NOx21:22 ppm0.083760.000
1337.4922.2914.76033302737981472014560NOx11:34 ppm / NOx21:29 ppm0.065510.000
1339.0222.3214.80031293135751472014560NOx11:34 ppm / NOx21:31 ppm0.060610.000
1340.5722.3414.76031283132661472014560NOx11:30 ppm / NOx21:32 ppm0.063160.000
1342.1422.3714.78017452732691472014560NOx11:31 ppm / NOx21:27 ppm0.065380.000
1343.6722.3914.740384047231581472014560NOx11:16 ppm / NOx21:55 ppm0.134070.000
1345.1822.4214.780522136512251472014560NOx11:47 ppm / NOx21:36 ppm0.130300.000
1346.7022.4514.78045123531271472014560NOx11:51 ppm / NOx21:1 ppm0.094370.000
1348.1722.4714.76035281246291472014560NOx11:44 ppm / NOx21:8 ppm0.056280.000
1349.6922.4914.78063951945971472014560NOx11:41 ppm / NOx21:18 ppm0.041830.000
1351.2122.5214.76065107120751681472014560NOx11:70 ppm / NOx21:116 ppm0.045350.000
1352.7522.5514.7805189101641561472014560NOx11:64 ppm / NOx21:100 ppm0.045930.000
1354.3022.5714.76045748346871472014560NOx11:44 ppm / NOx21:86 ppm0.124930.000
1355.8122.6014.740563952582321456014560NOx11:55 ppm / NOx21:54 ppm0.164380.000
1357.3122.6214.740641831633531456014560NOx11:58 ppm / NOx21:33 ppm0.136030.000
1358.8222.6514.7605332069721472014560NOx11:65 ppm / NOx21:0 ppm0.070490.000
1360.3222.6714.74041353646491472014560NOx11:45 ppm / NOx21:36 ppm0.060240.000
1361.8522.7014.78039383741391472014560NOx11:41 ppm / NOx21:38 ppm0.057310.000
1363.3822.7214.74036413939331472014560NOx11:39 ppm / NOx21:40 ppm0.057010.000
1364.9222.7514.74037434237301472014560NOx11:37 ppm / NOx21:42 ppm0.056530.000
1366.4322.7714.78025464635381472014560NOx11:35 ppm / NOx21:45 ppm0.063250.000
1367.9322.8014.74029374024661472014560NOx11:23 ppm / NOx21:39 ppm0.117140.000
1369.4522.8214.78025163927221472014560NOx11:28 ppm / NOx21:40 ppm0.158600.000
1370.9622.8514.78024614281211472014560NOx11:26 ppm / NOx21:13 ppm0.164010.000
1372.4822.8714.760236425931472014560NOx11:24 ppm / NOx21:4 ppm0.157770.000
1374.0022.9014.800191422921472014560NOx11:22 ppm / NOx21:5 ppm0.153380.000
1375.5322.9314.780162319821472014560NOx11:17 ppm / NOx21:4 ppm0.151320.000
1377.0422.9514.780153317831472014560NOx11:16 ppm / NOx21:3 ppm0.150400.000
1378.6422.9814.780180214821472014560NOx11:14 ppm / NOx21:3 ppm0.150330.000
1380.1923.0014.74039-1030591472014560NOx11:21 ppm / NOx21:0 ppm0.074380.000
1381.6623.0314.76037383042411472014560NOx11:38 ppm / NOx21:32 ppm0.057990.000
1383.2223.0514.80028453939401472014560NOx11:36 ppm / NOx21:38 ppm0.059080.000
1384.7523.0814.74027293730871472014560NOx11:29 ppm / NOx21:34 ppm0.082680.000
1386.3023.1114.78020353223451472014560NOx11:24 ppm / NOx21:30 ppm0.120220.000
1387.8223.1314.78022102520661472014560NOx11:19 ppm / NOx21:25 ppm0.167660.000
1389.3523.1614.7802307221121472014560NOx11:21 ppm / NOx21:6 ppm0.158910.000
1390.9023.1814.7001614318171472014560NOx11:20 ppm / NOx21:9 ppm0.177430.000
1392.4123.2114.800589481472014560NOx11:4 ppm / NOx21:11 ppm0.200510.000
1393.9123.2314.760255401472014560NOx11:4 ppm / NOx21:6 ppm0.201400.000
1395.5223.2614.800277201472014560NOx11:1 ppm / NOx21:7 ppm0.201980.000
1397.0523.2814.800166101472014560NOx11:1 ppm / NOx21:6 ppm0.201750.000
1398.5523.3114.780147001472014560NOx11:1 ppm / NOx21:7 ppm0.202940.000
1400.0723.3314.800045001472014560NOx11:0 ppm / NOx21:6 ppm0.203360.000
1401.5923.3614.800034001472014560NOx11:1 ppm / NOx21:4 ppm0.203520.000
1403.1323.3914.780052001472014560NOx11:0 ppm / NOx21:2 ppm0.203770.000
1404.6523.4114.740133001456014560NOx11:0 ppm / NOx21:3 ppm0.203900.000
1406.1723.4414.76070102211472014560NOx11:2 ppm / NOx21:2 ppm0.193000.000
1407.6923.4614.78026-90202301472014560NOx11:17 ppm / NOx21:0 ppm0.127970.000
1409.2023.4914.760252029811472014560NOx11:26 ppm / NOx21:0 ppm0.088280.000
1410.7623.5114.8009414261471472014560NOx11:22 ppm / NOx21:3 ppm0.097330.000
1412.3123.5414.7801052112381472014560NOx11:12 ppm / NOx21:23 ppm0.187570.000
1413.8223.5614.800549801472014560NOx11:9 ppm / NOx21:9 ppm0.199630.000
1415.3223.5914.7801087561472014560NOx11:6 ppm / NOx21:7 ppm0.201710.000
1416.8323.6114.72010-1061181472014560NOx11:5 ppm / NOx21:0 ppm0.192240.000
1418.3823.6414.76015-22102441472014560NOx11:10 ppm / NOx21:2 ppm0.160260.000
1419.9123.6714.76017-30181391456014560NOx11:17 ppm / NOx21:0 ppm0.141480.000
1421.4223.6914.78019-1020881472014560NOx11:18 ppm / NOx21:0 ppm0.125550.000
1422.9323.7214.780204022671472014560NOx11:21 ppm / NOx21:0 ppm0.116550.000
1424.4523.7414.760213521681472014560NOx11:21 ppm / NOx21:5 ppm0.115200.000
1425.9623.7714.780215524651472014560NOx11:23 ppm / NOx21:5 ppm0.112910.000
1427.4723.7914.780215525651472014560NOx11:24 ppm / NOx21:6 ppm0.112670.000
1429.0623.8214.780233423611472014560NOx11:23 ppm / NOx21:4 ppm0.112110.000
1430.5723.8414.780234423621472014560NOx11:21 ppm / NOx21:4 ppm0.112390.000
1432.0723.8714.780233623631472014560NOx11:20 ppm / NOx21:6 ppm0.112950.000
1433.5823.8914.780211423621456014560NOx11:21 ppm / NOx21:5 ppm0.112690.000
1435.1723.9214.7006470037371456014560NOx11:35 ppm / NOx21:0 ppm0.049610.000
1436.6823.9414.74013134414511811251456014560NOx11:92 ppm / NOx21:139 ppm0.032070.000
1438.1823.9714.680863063621156741456014560NOx11:119 ppm / NOx21:361 ppm0.020510.000
1439.6923.9914.7201723143341064541456014560NOx11:102 ppm / NOx21:305 ppm0.082390.000
1441.2724.0214.80084106321108901472014560NOx11:117 ppm / NOx21:315 ppm0.167370.000
1442.8324.0514.7403321605711472014560NOx11:58 ppm / NOx21:60 ppm0.199030.000
1444.3624.0714.76058754049521472014560NOx11:45 ppm / NOx21:44 ppm0.156800.000
1445.9024.1014.80056545860871472014560NOx11:58 ppm / NOx21:55 ppm0.149780.000
1447.4024.1214.80051475459991472014560NOx11:56 ppm / NOx21:56 ppm0.144330.000
1448.9124.1514.760462841531091472014560NOx11:50 ppm / NOx21:40 ppm0.140850.000
1450.4324.1714.80037172445641472014560NOx11:44 ppm / NOx21:25 ppm0.131870.000
1452.0024.2014.78036171837711472014560NOx11:37 ppm / NOx21:18 ppm0.134370.000
1453.5624.2314.78030151634591472014560NOx11:33 ppm / NOx21:16 ppm0.131030.000
1455.1524.2514.76035118351281472014560NOx11:32 ppm / NOx21:10 ppm0.110720.000
1456.6724.2814.80015451829411472014560NOx11:29 ppm / NOx21:16 ppm0.102500.000
1458.1624.3014.78011173615101472014560NOx11:15 ppm / NOx21:36 ppm0.189560.000
1459.6824.3314.7805612901472014560NOx11:10 ppm / NOx21:14 ppm0.200190.000
1461.1824.3514.800368401472014560NOx11:6 ppm / NOx21:9 ppm0.202130.000
1462.7024.3814.80021274111472014560NOx11:3 ppm / NOx21:6 ppm0.202800.000
1464.1924.4014.800164231472014560NOx11:2 ppm / NOx21:0 ppm0.202870.000
1465.7124.4314.820036001472014560NOx11:0 ppm / NOx21:6 ppm0.203370.000
1467.1924.4514.780-137001456014560NOx11:0 ppm / NOx21:6 ppm0.203660.000
1468.7124.4814.68011440271472014560NOx11:0 ppm / NOx21:4 ppm0.203170.000
1470.2324.5014.7600321611472014560NOx11:2 ppm / NOx21:2 ppm0.193560.000
1471.7424.5314.800062101472014560NOx11:0 ppm / NOx21:1 ppm0.203180.000
1473.2924.5514.760-153001472014560NOx11:0 ppm / NOx21:3 ppm0.203610.000
1474.8024.5814.78010221481472014560NOx11:2 ppm / NOx21:2 ppm0.188480.000
1476.3224.6114.8208-7131671472014560NOx11:4 ppm / NOx21:0 ppm0.167670.000
1477.8224.6314.8007007961472014560NOx11:7 ppm / NOx21:0 ppm0.158210.000
1479.3324.6614.76063061001472014560NOx11:6 ppm / NOx21:0 ppm0.155210.000
1480.8624.6814.8006-4161091472014560NOx11:5 ppm / NOx21:0 ppm0.142520.000
1482.4424.7114.76020-40151841472014560NOx11:8 ppm / NOx21:0 ppm0.110080.000
1483.9724.7314.78015202231071472014560NOx11:20 ppm / NOx21:0 ppm0.084320.000
1485.4624.7614.78015183913541472014560NOx11:12 ppm / NOx21:40 ppm0.154430.000
1486.9824.7814.800181011171501472014560NOx11:16 ppm / NOx21:11 ppm0.156670.000
1488.4424.8114.8001758201021472014560NOx11:18 ppm / NOx21:8 ppm0.153870.000
1489.9624.8314.7801845201071472014560NOx11:18 ppm / NOx21:5 ppm0.146060.000
1491.4324.8614.8002124211021472014560NOx11:20 ppm / NOx21:4 ppm0.133790.000
1492.9624.8814.7802610241161472014560NOx11:23 ppm / NOx21:0 ppm0.117450.000
1494.4924.9114.7802320424721472014560NOx11:23 ppm / NOx21:3 ppm0.121430.000
1496.0024.9314.76022121823761472014560NOx11:23 ppm / NOx21:18 ppm0.141900.000
1497.5324.9614.7802391124781472014560NOx11:23 ppm / NOx21:10 ppm0.147540.000
1499.0724.9814.780248724811472014560NOx11:22 ppm / NOx21:7 ppm0.149380.000
1500.5925.0114.80042-299301481472014560NOx11:26 ppm / NOx21:9 ppm0.124990.000
1502.0525.0314.7804251947491472014560NOx11:49 ppm / NOx21:6 ppm0.068920.000
1503.6125.0614.76030535235881472014560NOx11:33 ppm / NOx21:54 ppm0.094150.000
1505.1725.0914.80027295429491472014560NOx11:24 ppm / NOx21:58 ppm0.170500.000
1506.6825.1114.7801716232101472014560NOx11:21 ppm / NOx21:23 ppm0.196730.000
1508.2125.1414.8001410141701472014560NOx11:17 ppm / NOx21:15 ppm0.198700.000
1509.7525.1614.800177814441472014560NOx11:15 ppm / NOx21:9 ppm0.194500.000
1511.3025.1914.80033-232231941472014560NOx11:23 ppm / NOx21:3 ppm0.138440.000
1512.8425.2114.8003611038971472014560NOx11:36 ppm / NOx21:0 ppm0.103120.000
1514.3525.2414.760732820452031472014560NOx11:40 ppm / NOx21:19 ppm0.080400.000
1515.8725.2614.7806816862612081472014560NOx11:66 ppm / NOx21:58 ppm0.004290.000
1517.4225.2914.74079145226772121472014560NOx11:73 ppm / NOx21:223 ppm-0.000860.000
1518.9525.3214.820719873871071472014560NOx11:84 ppm / NOx21:98 ppm-0.003460.000
1520.4725.3414.800532012550111472014560NOx11:53 ppm / NOx21:137 ppm0.178120.000
1521.9825.3714.760451118501751472014560NOx11:48 ppm / NOx21:19 ppm0.186630.000
1523.4925.3914.78041-313451741472014560NOx11:45 ppm / NOx21:13 ppm0.138140.000
1525.0125.4214.8002523034431472014560NOx11:37 ppm / NOx21:0 ppm0.110900.000
1526.6025.4414.820141625271071472014560NOx11:24 ppm / NOx21:25 ppm0.154610.000
1528.0925.4714.780109141221472014560NOx11:12 ppm / NOx21:14 ppm0.196130.000
1529.6125.4914.780668901472014560NOx11:11 ppm / NOx21:9 ppm0.199150.000
1531.1225.5214.78010648171472014560NOx11:9 ppm / NOx21:4 ppm0.198280.000
1532.6325.5414.7601324111751472014560NOx11:9 ppm / NOx21:4 ppm0.167190.000
1534.1525.5714.780100112881472014560NOx11:12 ppm / NOx21:1 ppm0.156760.000
1535.7125.6014.7609419871472014560NOx11:10 ppm / NOx21:0 ppm0.153910.000
1537.2025.6214.8208569871472014560NOx11:10 ppm / NOx21:7 ppm0.151370.000
1538.7325.6514.8208449871472014560NOx11:8 ppm / NOx21:3 ppm0.150600.000
1540.2525.6714.7807557881472014560NOx11:7 ppm / NOx21:5 ppm0.150480.000
1541.7625.7014.7809386971472014560NOx11:8 ppm / NOx21:8 ppm0.149340.000
1543.2625.7214.80094471071472014560NOx11:7 ppm / NOx21:4 ppm0.140450.000
1544.7825.7514.76029-31471631456014560NOx11:6 ppm / NOx21:4 ppm0.136060.000
1546.2625.7714.76049540361121472014560NOx11:35 ppm / NOx21:0 ppm0.055440.000
1547.7425.8014.760486759331271456014560NOx11:31 ppm / NOx21:66 ppm0.068210.000
1549.2625.8214.82023628136541472014560NOx11:45 ppm / NOx21:80 ppm0.112790.000
1550.7925.8514.78021193427121472014560NOx11:22 ppm / NOx21:36 ppm0.187750.000
1552.3425.8714.8001312131601472014560NOx11:18 ppm / NOx21:14 ppm0.198180.000
1553.8525.9014.7608481001472014560NOx11:11 ppm / NOx21:8 ppm0.200190.000
1555.3725.9214.78032-233184361472014560NOx11:15 ppm / NOx21:4 ppm0.149190.000
1556.9525.9514.800264031871472014560NOx11:30 ppm / NOx21:0 ppm0.089940.000
1558.4725.9714.7602571024881472014560NOx11:24 ppm / NOx21:10 ppm0.081840.000
1559.9826.0014.66070131103210741456014560NOx11:29 ppm / NOx21:8 ppm0.028620.000
1561.5026.0314.7807397241911881472014560NOx11:104 ppm / NOx21:239 ppm0.153340.000
1563.0126.0514.80049296562191472014560NOx11:68 ppm / NOx21:68 ppm0.193710.000
1564.5326.0814.8002515243701472014560NOx11:39 ppm / NOx21:25 ppm0.199880.000
1566.0426.1014.78023613211101472014560NOx11:28 ppm / NOx21:14 ppm0.198950.000
1567.5526.1314.78050-78412561472014560NOx11:33 ppm / NOx21:8 ppm0.124980.000
1569.0926.1514.82029640651891472014560NOx11:64 ppm / NOx21:0 ppm0.015760.000
1570.6026.1814.760151911313151472014560NOx11:13 ppm / NOx21:113 ppm0.175330.000
1572.1426.2014.740115131401472014560NOx11:14 ppm / NOx21:16 ppm0.195550.000
1573.6526.2314.740757801472014560NOx11:6 ppm / NOx21:7 ppm0.197780.000
1575.1526.2514.780434641472014560NOx11:7 ppm / NOx21:5 ppm0.195100.000
1576.6826.2814.780433661472014560NOx11:6 ppm / NOx21:2 ppm0.199230.000
1578.1926.3014.7407-1271621472014560NOx11:6 ppm / NOx21:2 ppm0.188380.000
1579.7126.3314.820120091061472014560NOx11:9 ppm / NOx21:0 ppm0.155630.000
1581.2326.3512.4407-30111081232012320NOx11:10 ppm / NOx21:0 ppm0.135870.000
1582.7526.3812.4005-1081101232012160NOx11:9 ppm / NOx21:0 ppm0.133610.000
1584.2626.4012.3606225661216012000NOx11:5 ppm / NOx21:2 ppm0.131160.000
1585.7826.4312.2807236391200012000NOx11:7 ppm / NOx21:3 ppm0.129220.000
1587.2926.4512.2007457231200011840NOx11:6 ppm / NOx21:5 ppm0.127860.000
1588.8426.4812.14010447131200011840NOx11:8 ppm / NOx21:4 ppm0.126910.000
1590.3826.5112.0801336881184011840NOx11:8 ppm / NOx21:6 ppm0.126100.000
1592.0026.5312.02017651241184011840NOx11:12 ppm / NOx21:5 ppm0.125470.000
1593.4926.5612.02021661821184011680NOx11:18 ppm / NOx21:7 ppm0.125090.000
1595.0126.5811.98029462511184011680NOx11:24 ppm / NOx21:6 ppm0.124780.000
1596.6126.6111.94038373201168011680NOx11:32 ppm / NOx21:7 ppm0.124620.000
1598.1026.6411.94049574201168011680NOx11:42 ppm / NOx21:7 ppm0.124420.000
1599.6226.6611.94061755501168011680NOx11:53 ppm / NOx21:6 ppm0.124370.000
1601.1226.6911.90078476901168011680NOx11:68 ppm / NOx21:8 ppm0.124320.000
1602.6426.7111.88094748501168011680NOx11:83 ppm / NOx21:4 ppm0.124250.000
1604.1526.7411.8601106710101168011680NOx11:100 ppm / NOx21:6 ppm0.124280.000
1605.6926.7611.8801278712001168011680NOx11:117 ppm / NOx21:8 ppm0.124300.000
1607.1926.7911.9001426713501168011680NOx11:134 ppm / NOx21:7 ppm0.124250.000
1608.7326.8111.9001545614801168011680NOx11:147 ppm / NOx21:6 ppm0.124240.000
1610.2426.8411.8801628515801168011680NOx11:156 ppm / NOx21:6 ppm0.124230.000
1611.8026.8611.8801715416601168011520NOx11:166 ppm / NOx21:4 ppm0.124230.000
1613.3126.8911.8401816617801168011680NOx11:176 ppm / NOx21:6 ppm0.124230.000
1614.8526.9111.8401897518701168011520NOx11:184 ppm / NOx21:4 ppm0.124190.000
1616.3626.9411.8601945519101168011520NOx11:189 ppm / NOx21:4 ppm0.124210.000
1617.8726.9611.8402015719701168011520NOx11:195 ppm / NOx21:6 ppm0.124250.000
1619.3926.9911.8802067720101168011520NOx11:199 ppm / NOx21:8 ppm0.124200.000
1620.9027.0211.860208782080116809600NOx11:205 ppm / NOx21:8 ppm0.124220.000
1622.4427.0411.4201741721001120011200NOx11:211 ppm / NOx21:8 ppm0.124560.000
1623.9127.0711.580701491072881152011680NOx11:118 ppm / NOx21:6 ppm0.140340.000
1625.4627.0913.94048712561041472014560NOx11:60 ppm / NOx21:13 ppm0.140870.000
1626.9627.1214.80035-2642511472014560NOx11:43 ppm / NOx21:7 ppm0.124560.000
1628.5427.1414.860273030261472014720NOx11:31 ppm / NOx21:0 ppm0.110360.000
1630.0427.1714.740214424141472014560NOx11:25 ppm / NOx21:4 ppm0.107710.000
1631.5527.1914.720195520141472014560NOx11:20 ppm / NOx21:5 ppm0.107750.000
1633.0527.2214.740166617131472014560NOx11:17 ppm / NOx21:6 ppm0.107580.000
1634.5927.2414.780147415121472014560NOx11:16 ppm / NOx21:4 ppm0.106630.000
1636.1227.2714.720136513141472014560NOx11:13 ppm / NOx21:5 ppm0.107020.000
1637.6327.2914.780103413131472014560NOx11:12 ppm / NOx21:5 ppm0.106510.000
1639.2127.3214.76026-1022811472014560NOx11:15 ppm / NOx21:0 ppm0.076580.000
1640.7327.3514.760701362383441472014560NOx11:40 ppm / NOx21:0 ppm0.003400.000
1642.2427.3714.7604672197535401472014560NOx11:67 ppm / NOx21:201 ppm0.077840.000
1643.7427.4014.840392756432691472014720NOx11:44 ppm / NOx21:56 ppm0.088080.000
1645.2227.4214.80023422337681472014560NOx11:40 ppm / NOx21:22 ppm0.102090.000
1646.7427.4514.82035526243121472014720NOx11:23 ppm / NOx21:27 ppm0.160370.000
1648.2827.4714.8603020361021472014720NOx11:36 ppm / NOx21:0 ppm0.085220.000
1649.8327.5014.84023151427871472014720NOx11:27 ppm / NOx21:15 ppm0.084710.000
1651.3727.5214.84072815191791472014720NOx11:21 ppm / NOx21:12 ppm0.132390.000
1652.8827.5514.80015915102041472014720NOx11:5 ppm / NOx21:15 ppm0.175790.000
1654.4027.5714.74058-80352351456014560NOx11:28 ppm / NOx21:0 ppm0.084440.000
1655.9527.6014.68012025711410912571456014560NOx11:95 ppm / NOx21:90 ppm0.045480.000
1657.4327.6214.740792542781165851456014560NOx11:119 ppm / NOx21:274 ppm0.030720.000
1658.9427.6514.760355215969871472014560NOx11:83 ppm / NOx21:166 ppm0.165720.000
1660.4727.6714.7801518342311472014560NOx11:26 ppm / NOx21:34 ppm0.198890.000
1661.9727.7014.780711151001472014560NOx11:11 ppm / NOx21:15 ppm0.201140.000
1663.4927.7214.760499601456014560NOx11:7 ppm / NOx21:10 ppm0.201800.000
1664.9727.7514.720202610851456014560NOx11:6 ppm / NOx21:8 ppm0.179870.000
1666.4927.7714.72063-90462621456014560NOx11:41 ppm / NOx21:0 ppm0.107050.000
1668.0127.8014.7401121167592541456014560NOx11:52 ppm / NOx21:6 ppm0.006740.000
1669.5327.8314.74074-521791032761456014560NOx11:107 ppm / NOx21:178 ppm-0.001190.000
1671.0427.8514.7606732304702401472014560NOx11:68 ppm / NOx21:339 ppm-0.005760.000
1672.5627.8814.74043340492281456014560NOx11:52 ppm / NOx21:0 ppm0.063600.000
1674.1327.9014.78038918391401472014560NOx11:39 ppm / NOx21:17 ppm0.088280.000
1675.6727.9314.7802516834641472014560NOx11:36 ppm / NOx21:7 ppm0.079870.000
1677.2027.9514.7602472223811472014560NOx11:23 ppm / NOx21:23 ppm0.124770.000
1678.7427.9814.80015177241341456014560NOx11:22 ppm / NOx21:7 ppm0.144960.000
1680.2628.0014.80011471481472014560NOx11:12 ppm / NOx21:7 ppm0.195020.000
1681.7728.0314.7809241101472014560NOx11:11 ppm / NOx21:4 ppm0.199480.000
1683.2628.0514.780653811472014560NOx11:13 ppm / NOx21:3 ppm0.200790.000
1684.7728.0814.7608334231472014560NOx11:5 ppm / NOx21:3 ppm0.201810.000
1686.2928.1014.74020-22112381472014560NOx11:10 ppm / NOx21:1 ppm0.169460.000
1687.8328.1314.76021-70231221472014560NOx11:22 ppm / NOx21:0 ppm0.120270.000
1689.3728.1614.7802510151071472014560NOx11:16 ppm / NOx21:0 ppm0.108680.000
1690.9028.1814.740198023971472014560NOx11:24 ppm / NOx21:0 ppm0.064830.000
1692.4428.2114.7602091021561472014560NOx11:22 ppm / NOx21:9 ppm0.064240.000
1693.9528.2314.74022141222491472014560NOx11:21 ppm / NOx21:11 ppm0.066370.000
1695.4828.2614.76019141421581472014560NOx11:20 ppm / NOx21:14 ppm0.071090.000
1696.9828.2814.80024271726721472014560NOx11:24 ppm / NOx21:21 ppm0.066020.000
1698.4728.3114.780912517491472014560NOx11:7 ppm / NOx21:47 ppm0.158610.000
1699.9928.3314.8205513911472014560NOx11:9 ppm / NOx21:15 ppm0.195430.000
1701.5128.3614.760255701472014560NOx11:7 ppm / NOx21:5 ppm0.199560.000
1703.0028.3814.740324201472014560NOx11:5 ppm / NOx21:4 ppm0.200820.000
1704.4728.4114.76052451731472014560NOx11:6 ppm / NOx21:5 ppm0.185080.000
1705.9828.4314.78031-340142611472014560NOx11:12 ppm / NOx21:0 ppm0.143520.000
1707.4628.4614.7405436040811472014560NOx11:39 ppm / NOx21:0 ppm0.053230.000
1708.9928.4814.78064847074681472014560NOx11:71 ppm / NOx21:67 ppm0.051400.000
1710.5128.5114.76047848349891456014560NOx11:53 ppm / NOx21:84 ppm0.044520.000
1711.9928.5314.74038519925771472014560NOx11:37 ppm / NOx21:97 ppm0.108980.000
1713.4828.5614.38030444738531472014560NOx11:38 ppm / NOx21:46 ppm0.116340.000
1715.0028.5814.78037133334461472014560NOx11:33 ppm / NOx21:37 ppm0.149620.000
1716.5128.6114.780331911282041472014560NOx11:15 ppm / NOx21:11 ppm0.154010.000
1718.0528.6314.780115171631472014560NOx11:19 ppm / NOx21:22 ppm0.198270.000
1719.6328.6614.800546701472014560NOx11:8 ppm / NOx21:7 ppm0.201200.000
1721.1628.6914.800436501472014560NOx11:5 ppm / NOx21:6 ppm0.200580.000
1722.6928.7114.78019-4351871472014560NOx11:4 ppm / NOx21:3 ppm0.193800.000
1724.2128.7414.76036-70371561472014560NOx11:33 ppm / NOx21:0 ppm0.100410.000
1725.7328.7614.7602711032761472014560NOx11:31 ppm / NOx21:0 ppm0.075530.000
1727.2428.7914.7602491124731472014560NOx11:26 ppm / NOx21:11 ppm0.075610.000
1728.7828.8114.780218921691472014560NOx11:22 ppm / NOx21:9 ppm0.082010.000
1730.2928.8414.820841523891472014560NOx11:23 ppm / NOx21:7 ppm0.075110.000
1731.8128.8614.7601282612131472014560NOx11:16 ppm / NOx21:26 ppm0.180370.000
1733.3528.8914.780716951472014560NOx11:17 ppm / NOx21:9 ppm0.195780.000
1734.8728.9114.780214401472014560NOx11:4 ppm / NOx21:5 ppm0.200810.000
1736.3828.9414.780211201472014560NOx11:3 ppm / NOx21:1 ppm0.201870.000
1737.9028.9714.800512101456014560NOx11:0 ppm / NOx21:2 ppm0.202450.000
1739.4428.9914.8001112291472014560NOx11:0 ppm / NOx21:1 ppm0.202090.000
1740.9429.0214.78043141281472014560NOx11:1 ppm / NOx21:1 ppm0.190030.000
1742.4729.0414.7409-4051191472014560NOx11:3 ppm / NOx21:0 ppm0.172680.000
1744.1129.0714.78023-100121031472014560NOx11:13 ppm / NOx21:0 ppm0.135220.000
1745.6029.0914.720219026751472014560NOx11:28 ppm / NOx21:0 ppm0.085820.000
1747.1229.1214.7802010921811472014560NOx11:21 ppm / NOx21:8 ppm0.091250.000
1748.6629.1414.80020313201281472014560NOx11:18 ppm / NOx21:15 ppm0.097810.000
1750.1929.1714.780270324831472014560NOx11:23 ppm / NOx21:2 ppm0.081060.000
1751.7029.2014.7802512925781472014560NOx11:25 ppm / NOx21:9 ppm0.070020.000
1753.2329.2214.76024171224671472014560NOx11:25 ppm / NOx21:11 ppm0.076620.000
1754.7829.2514.74030181825691456014560NOx11:24 ppm / NOx21:17 ppm0.080190.000
1756.3329.2714.78018263323301472014560NOx11:25 ppm / NOx21:34 ppm0.112480.000
1757.8729.3014.78020122120801472014560NOx11:21 ppm / NOx21:22 ppm0.134830.000
1759.3829.3214.7802191118901456014560NOx11:22 ppm / NOx21:13 ppm0.182280.000
1760.8729.3514.7203506232031472014560NOx11:22 ppm / NOx21:7 ppm0.152190.000
1762.3429.3714.780383040991472014560NOx11:36 ppm / NOx21:0 ppm0.090950.000
1763.8629.4014.76035211136461472014560NOx11:36 ppm / NOx21:11 ppm0.069460.000
1765.4129.4214.78037392737411472014560NOx11:38 ppm / NOx21:21 ppm0.058150.000
1766.9929.4514.78038474633401472014560NOx11:31 ppm / NOx21:45 ppm0.064090.000
1768.5029.4814.78040684541811472014560NOx11:42 ppm / NOx21:40 ppm0.057980.000
1770.0129.5014.76033238120471472014560NOx11:19 ppm / NOx21:84 ppm0.162090.000
1771.5329.5314.7601912232611472014560NOx11:28 ppm / NOx21:24 ppm0.194110.000
1773.0429.5514.7801310121701456014560NOx11:18 ppm / NOx21:11 ppm0.199210.000
1774.5529.5814.78015369771472014560NOx11:10 ppm / NOx21:6 ppm0.200290.000
1776.1029.6014.78055110411431472014560NOx11:34 ppm / NOx21:0 ppm0.084520.000
1777.6229.6314.74045563153711472014560NOx11:53 ppm / NOx21:26 ppm0.057110.000
1779.1329.6514.74036595742621472014560NOx11:43 ppm / NOx21:57 ppm0.056970.000
1780.6529.6814.780415050351641472014560NOx11:34 ppm / NOx21:51 ppm0.062850.000
1782.1729.7014.780446962451111472014560NOx11:43 ppm / NOx21:64 ppm0.054610.000
1783.6829.7314.780457169441211472014560NOx11:44 ppm / NOx21:69 ppm0.052820.000
1785.1629.7514.780285068261101472014560NOx11:39 ppm / NOx21:67 ppm0.138680.000
1786.6929.7814.5802713292711472014560NOx11:26 ppm / NOx21:27 ppm0.188890.000
1788.1829.8014.780166152051472014560NOx11:28 ppm / NOx21:18 ppm0.195910.000
1789.7329.8314.7809361101472014560NOx11:11 ppm / NOx21:7 ppm0.200250.000
1791.2429.8514.7409247361472014560NOx11:10 ppm / NOx21:4 ppm0.201090.000
1792.7529.8814.78022-33152571472014560NOx11:14 ppm / NOx21:3 ppm0.159910.000
1794.2529.9014.76024-50231351472014560NOx11:24 ppm / NOx21:0 ppm0.134790.000
1795.7629.9314.7802000231101472014560NOx11:23 ppm / NOx21:0 ppm0.124720.000
1797.3029.9614.78011256201571472014560NOx11:16 ppm / NOx21:6 ppm0.127690.000
1798.8029.9814.7807714841472014560NOx11:8 ppm / NOx21:15 ppm0.193720.000
1800.3130.0114.800247501472014560NOx11:8 ppm / NOx21:8 ppm0.199590.000
1801.8230.0314.780233421472014560NOx11:6 ppm / NOx21:4 ppm0.201290.000
1803.3430.0614.780033101472014560NOx11:2 ppm / NOx21:4 ppm0.202600.000
1804.9130.0814.800023101472014560NOx11:1 ppm / NOx21:3 ppm0.203100.000
1806.4130.1114.780042021472014560NOx11:0 ppm / NOx21:2 ppm0.203270.000
1807.9530.1314.760032331472014560NOx11:6 ppm / NOx21:2 ppm0.201170.000
1809.4030.1614.780022001472014560NOx11:0 ppm / NOx21:2 ppm0.203210.000
1810.9130.1814.7804-1131591472014560NOx11:1 ppm / NOx21:0 ppm0.185830.000
1812.4430.2114.7608-105991472014560NOx11:4 ppm / NOx21:0 ppm0.164650.000
1813.9930.2314.78010-6091291472014560NOx11:8 ppm / NOx21:0 ppm0.147970.000
1815.5330.2614.7808-308841472014560NOx11:9 ppm / NOx21:0 ppm0.128980.000
1817.0430.2814.7406106781472014560NOx11:7 ppm / NOx21:0 ppm0.123080.000
1818.5630.3114.76013067521472014560NOx11:8 ppm / NOx21:6 ppm0.120510.000
1820.0730.3314.760197018651472014560NOx11:17 ppm / NOx21:0 ppm0.085240.000
1821.5530.3614.7802012319911472014560NOx11:18 ppm / NOx21:4 ppm0.088470.000
1823.0730.3814.80022231620711472014560NOx11:20 ppm / NOx21:14 ppm0.094720.000
1824.5330.4114.76029392725731472014560NOx11:23 ppm / NOx21:26 ppm0.109780.000
1826.0130.4314.74023195817731472014560NOx11:19 ppm / NOx21:58 ppm0.165010.000
1827.5330.4614.78014151820341472014560NOx11:22 ppm / NOx21:17 ppm0.175400.000
1829.0530.4814.7801391210371472014560NOx11:13 ppm / NOx21:12 ppm0.196830.000
1830.5630.5114.7602264131531472014560NOx11:12 ppm / NOx21:3 ppm0.169420.000
1832.0830.5314.78034-143261051472014560NOx11:25 ppm / NOx21:1 ppm0.142790.000
1833.5930.5614.7803512040671472014560NOx11:39 ppm / NOx21:0 ppm0.101690.000
1835.1330.5914.78032252034681472014560NOx11:34 ppm / NOx21:20 ppm0.096440.000
1836.6130.6114.80030252730781472014560NOx11:30 ppm / NOx21:27 ppm0.105150.000
1838.1030.6414.80025213026691472014560NOx11:25 ppm / NOx21:29 ppm0.121730.000
1839.6330.6614.80025172625781472014560NOx11:24 ppm / NOx21:28 ppm0.143320.000
1841.1630.6914.78024121325801472014560NOx11:25 ppm / NOx21:13 ppm0.146050.000
1842.6930.7114.82026111225921472014560NOx11:26 ppm / NOx21:12 ppm0.145250.000
1844.2030.7414.7602591225981472014560NOx11:26 ppm / NOx21:12 ppm0.148010.000
1845.7630.7614.78033-69311391472014560NOx11:30 ppm / NOx21:8 ppm0.117520.000
1847.2630.7914.7803929833861472014560NOx11:34 ppm / NOx21:8 ppm0.103000.000
1848.7530.8114.80018225321811472014560NOx11:24 ppm / NOx21:52 ppm0.173630.000
1850.2730.8414.7801310191701472014560NOx11:19 ppm / NOx21:20 ppm0.196690.000
1851.7730.8614.780125101141472014560NOx11:12 ppm / NOx21:9 ppm0.196530.000
1853.2930.8914.7801426121791472014560NOx11:12 ppm / NOx21:7 ppm0.185680.000
1854.8030.9114.7802012181301472014560NOx11:17 ppm / NOx21:1 ppm0.158950.000
1856.2630.9414.8202044201081472014560NOx11:19 ppm / NOx21:3 ppm0.159280.000
1857.7730.9614.7802222211281472014560NOx11:21 ppm / NOx21:3 ppm0.151390.000
1859.2930.9914.780221023931472014560NOx11:23 ppm / NOx21:0 ppm0.132380.000
1860.7631.0114.780221122881472014560NOx11:22 ppm / NOx21:1 ppm0.123360.000
1862.3331.0414.800224621811472014560NOx11:23 ppm / NOx21:6 ppm0.119760.000
1863.8331.0614.760207620761472014560NOx11:21 ppm / NOx21:6 ppm0.118030.000
1865.3631.0914.780217820761472014560NOx11:20 ppm / NOx21:8 ppm0.118690.000
1866.9031.1214.780194721731472014560NOx11:21 ppm / NOx21:8 ppm0.117370.000
1868.4331.1414.760204520711472014560NOx11:19 ppm / NOx21:5 ppm0.116990.000
1869.9531.1714.7602714127731472014560NOx11:26 ppm / NOx21:0 ppm0.079610.000
1871.4831.1914.76025311628801472014560NOx11:27 ppm / NOx21:18 ppm0.069220.000
1873.0131.2214.740313537291331472014560NOx11:26 ppm / NOx21:37 ppm0.078250.000
1874.5231.2414.76028334226851472014560NOx11:26 ppm / NOx21:43 ppm0.100270.000
1876.0331.2714.740693930312611472014560NOx11:30 ppm / NOx21:25 ppm0.085180.000
1877.5431.2914.7605811584633001472014560NOx11:65 ppm / NOx21:83 ppm-0.000270.000
1879.0631.3214.740571460552191472014560NOx11:57 ppm / NOx21:0 ppm-0.009070.000
1880.5731.3414.7604038179593441472014560NOx11:60 ppm / NOx21:175 ppm0.018300.000
1882.0931.3714.760361941401101472014560NOx11:40 ppm / NOx21:39 ppm0.084770.000
1883.6131.3914.78033222336881472014560NOx11:36 ppm / NOx21:24 ppm0.074340.000
1885.1231.4214.78030271931521472014560NOx11:30 ppm / NOx21:21 ppm0.069190.000
1886.6031.4414.78031282528661472014560NOx11:29 ppm / NOx21:26 ppm0.074740.000
1888.0831.4714.74031383030721472014560NOx11:31 ppm / NOx21:30 ppm0.080710.000
1889.5731.4914.76019225017471472014560NOx11:19 ppm / NOx21:45 ppm0.155490.000
1891.0931.5214.820241116211861472014560NOx11:23 ppm / NOx21:16 ppm0.172770.000
1892.6031.5414.8001410112151472014560NOx11:30 ppm / NOx21:12 ppm0.191770.000
1894.1031.5714.78010591301472014560NOx11:13 ppm / NOx21:10 ppm0.198090.000
1895.5731.5914.8008551201472014560NOx11:11 ppm / NOx21:5 ppm0.200180.000
1897.0831.6214.760444601472014560NOx11:5 ppm / NOx21:5 ppm0.201520.000
1898.5931.6414.7804234341472014560NOx11:3 ppm / NOx21:3 ppm0.197040.000
1900.0831.6714.780224401472014560NOx11:4 ppm / NOx21:5 ppm0.201640.000
1901.6131.6914.76051-80444571472014560NOx11:2 ppm / NOx21:4 ppm0.188980.000
1903.0731.7214.6801452214511716051456014560NOx11:102 ppm / NOx21:39 ppm0.034690.000
1904.5731.7414.700621222181051701472014560NOx11:118 ppm / NOx21:226 ppm0.051690.000
1906.0931.7714.560409799501231472014560NOx11:53 ppm / NOx21:100 ppm0.052650.000
1907.5731.7914.780283310928641472014560NOx11:33 ppm / NOx21:106 ppm0.165850.000
1909.1431.8214.78023222930261472014560NOx11:26 ppm / NOx21:31 ppm0.189760.000
1910.6831.8414.820119121501472014560NOx11:17 ppm / NOx21:12 ppm0.199400.000
1912.2031.8714.820637901472014560NOx11:7 ppm / NOx21:8 ppm0.201240.000
1913.7131.9014.8004046271472014560NOx11:5 ppm / NOx21:5 ppm0.200610.000
1915.2831.9214.7804423261472014560NOx11:8 ppm / NOx21:3 ppm0.202130.000
1916.7831.9514.780110301472014560NOx11:3 ppm / NOx21:0 ppm0.201750.000
1918.2931.9714.7806-1241271472014560NOx11:4 ppm / NOx21:1 ppm0.182570.000
1919.8032.0014.8008-7091501472014560NOx11:9 ppm / NOx21:1 ppm0.163780.000
1921.3232.0214.76010-8091161472014560NOx11:9 ppm / NOx21:0 ppm0.156680.000
1922.8432.0514.74011-4091101472014560NOx11:10 ppm / NOx21:0 ppm0.135090.000
1924.3532.0714.7607009921472014560NOx11:10 ppm / NOx21:0 ppm0.125730.000
1925.8332.1014.7807106831472014560NOx11:7 ppm / NOx21:0 ppm0.122720.000
1927.3532.1214.8006337771472014560NOx11:7 ppm / NOx21:3 ppm0.121040.000
1928.8532.1514.8207127781472014560NOx11:8 ppm / NOx21:2 ppm0.121530.000
1930.3732.1714.8206217751472014560NOx11:5 ppm / NOx21:0 ppm0.120650.000
1931.8832.2014.8006237761472014560NOx11:7 ppm / NOx21:3 ppm0.121020.000
1933.4732.2214.7606227761472014560NOx11:6 ppm / NOx21:2 ppm0.120800.000
1935.0632.2514.8007017761472014560NOx11:7 ppm / NOx21:2 ppm0.120490.000
1936.6132.2814.7807116741472014560NOx11:7 ppm / NOx21:0 ppm0.119700.000
1938.1432.3014.7807328781472014560NOx11:8 ppm / NOx21:1 ppm0.120310.000
1939.7432.3314.7607236781472014560NOx11:7 ppm / NOx21:2 ppm0.119760.000
1941.2732.3514.7807037781472014560NOx11:8 ppm / NOx21:3 ppm0.119980.000
1942.7932.3814.78021-163101451472014560NOx11:8 ppm / NOx21:2 ppm0.099370.000
1944.3032.4114.72071984343511472014560NOx11:27 ppm / NOx21:8 ppm0.033870.000
1945.8232.4314.7605291125811461472014560NOx11:87 ppm / NOx21:131 ppm0.085980.000
1947.3132.4614.740606393521791456014560NOx11:52 ppm / NOx21:92 ppm0.087820.000
1948.8232.4814.76055725954861472014560NOx11:55 ppm / NOx21:59 ppm0.061370.000
1950.3232.5114.78040767447691472014560NOx11:50 ppm / NOx21:74 ppm0.056550.000
1951.8232.5314.760434859411161472014560NOx11:40 ppm / NOx21:48 ppm0.074460.000
1953.4632.5614.80036395040691472014560NOx11:38 ppm / NOx21:51 ppm0.074560.000
1955.0132.5814.82020503933761472014560NOx11:34 ppm / NOx21:40 ppm0.084980.000
1956.5432.6114.7602017452391472014560NOx11:18 ppm / NOx21:49 ppm0.176200.000
1958.0632.6314.800148121701472014560NOx11:20 ppm / NOx21:12 ppm0.195540.000
1959.5932.6614.7808641101472014560NOx11:13 ppm / NOx21:5 ppm0.198600.000
1961.1032.6914.7608645141472014560NOx11:9 ppm / NOx21:4 ppm0.196130.000
1962.6232.7114.8003143221472014560NOx11:4 ppm / NOx21:4 ppm0.200310.000
1964.0732.7314.720444201472014560NOx11:4 ppm / NOx21:5 ppm0.201750.000
1965.5532.7614.7808331331472014560NOx11:1 ppm / NOx21:3 ppm0.198760.000
1967.0732.7814.760233101472014560NOx11:2 ppm / NOx21:2 ppm0.201270.000
1968.5732.8114.7605-2131491472014560NOx11:3 ppm / NOx21:1 ppm0.187660.000
1970.0832.8314.78010-7351421472014560NOx11:5 ppm / NOx21:2 ppm0.163400.000
1971.6032.8614.78012-50111101472014560NOx11:13 ppm / NOx21:0 ppm0.140400.000
1973.1032.8914.7608-309861472014560NOx11:9 ppm / NOx21:0 ppm0.128270.000
1974.5932.9114.8007009841472014560NOx11:9 ppm / NOx21:0 ppm0.124280.000
1976.1132.9414.7408258731472014560NOx11:8 ppm / NOx21:4 ppm0.121420.000
1977.6232.9614.7407328751472014560NOx11:7 ppm / NOx21:2 ppm0.120190.000
1979.2032.9914.7807338751472014560NOx11:8 ppm / NOx21:4 ppm0.119420.000
1980.7133.0114.7606328731472014560NOx11:9 ppm / NOx21:2 ppm0.118840.000
1982.2333.0414.7608237711472014560NOx11:9 ppm / NOx21:2 ppm0.118010.000
1983.7433.0614.7608028771472014560NOx11:7 ppm / NOx21:2 ppm0.118730.000
1985.2333.0914.76010148761472014560NOx11:8 ppm / NOx21:4 ppm0.118520.000
1986.7433.1114.8006337761472014560NOx11:7 ppm / NOx21:3 ppm0.118280.000
1988.2933.1414.7807349781472014560NOx11:8 ppm / NOx21:4 ppm0.118950.000
1989.8133.1614.8008328761472014720NOx11:8 ppm / NOx21:3 ppm0.118470.000
1991.3233.1914.7607128761472014560NOx11:8 ppm / NOx21:2 ppm0.118300.000
1992.8033.2114.7808229761472014560NOx11:9 ppm / NOx21:2 ppm0.118340.000
1994.3133.2414.7807218751472014560NOx11:9 ppm / NOx21:0 ppm0.118220.000
1995.8033.2614.7808227741472014560NOx11:8 ppm / NOx21:3 ppm0.117610.000
1997.3033.2914.7809619761472014560NOx11:9 ppm / NOx21:1 ppm0.117500.000
1998.8033.3114.76010228751472014560NOx11:9 ppm / NOx21:2 ppm0.116630.000
2000.3333.3414.7608427761472014560NOx11:8 ppm / NOx21:2 ppm0.116940.000
2001.8633.3614.8008029751472014560NOx11:9 ppm / NOx21:2 ppm0.117800.000
2003.3733.3914.8409417741472014560NOx11:9 ppm / NOx21:1 ppm0.117430.000
2004.8933.4114.8009338751472014560NOx11:8 ppm / NOx21:3 ppm0.117670.000
2006.4333.4414.78011358741472014560NOx11:8 ppm / NOx21:5 ppm0.117950.000
2007.9533.4714.7408067711472014560NOx11:8 ppm / NOx21:5 ppm0.117430.000
2009.4733.4914.7809259781472014560NOx11:9 ppm / NOx21:5 ppm0.117890.000
2010.9833.5214.80093210741472014560NOx11:9 ppm / NOx21:2 ppm0.117280.000
2012.5233.5414.8009248761472014560NOx11:9 ppm / NOx21:4 ppm0.117240.000
2013.9333.5714.780111210801472014560NOx11:11 ppm / NOx21:3 ppm0.117740.000
2015.4533.5914.7609349741472014560NOx11:9 ppm / NOx21:3 ppm0.117700.000
2016.9433.6214.76092311751472014720NOx11:9 ppm / NOx21:3 ppm0.116970.000
2018.4533.6414.82010439741472014560NOx11:8 ppm / NOx21:2 ppm0.116950.000
2019.9633.6714.7402715017841456014560NOx11:13 ppm / NOx21:0 ppm0.082200.000
2021.4833.6914.760326421321171472014560NOx11:30 ppm / NOx21:17 ppm0.058870.000
2023.0233.7214.80037664743831472014560NOx11:40 ppm / NOx21:34 ppm0.060520.000
2024.5533.7414.800444947362181472014560NOx11:35 ppm / NOx21:53 ppm0.088690.000
2026.0533.7714.78041565244641472014560NOx11:43 ppm / NOx21:52 ppm0.070600.000
2027.5433.7914.80035415936671472014560NOx11:39 ppm / NOx21:59 ppm0.083310.000
2029.0733.8214.74039514139401472014560NOx11:40 ppm / NOx21:41 ppm0.059170.000
2030.5933.8414.74039857040691472014560NOx11:41 ppm / NOx21:74 ppm0.051550.000
2032.1033.8714.780499989472501472014560NOx11:47 ppm / NOx21:84 ppm0.060200.000
2033.6533.8914.82040728949561472014560NOx11:50 ppm / NOx21:85 ppm0.064470.000
2035.2433.9214.80028418726341472014560NOx11:27 ppm / NOx21:88 ppm0.150540.000
2036.8033.9514.7802116342611472014560NOx11:24 ppm / NOx21:35 ppm0.192060.000
2038.3533.9714.76052-513365111472014560NOx11:30 ppm / NOx21:14 ppm0.135080.000
2039.8834.0014.7804341054321472014560NOx11:54 ppm / NOx21:0 ppm0.065550.000
2041.3734.0214.74039524741381472014560NOx11:42 ppm / NOx21:48 ppm0.063730.000
2042.8834.0514.740739453427541472014560NOx11:44 ppm / NOx21:53 ppm0.062360.000
2044.4134.0714.7801462121511273741472014560NOx11:98 ppm / NOx21:133 ppm-0.000680.000
2045.9134.1014.780112139581344531472014560NOx11:138 ppm / NOx21:0 ppm-0.005630.000
2047.4234.1214.760958115710312901472014560NOx11:106 ppm / NOx21:173 ppm0.031290.000
2048.9534.1514.760675671801161472014560NOx11:84 ppm / NOx21:70 ppm0.049550.000
2050.4334.1714.76052585260971472014560NOx11:61 ppm / NOx21:53 ppm0.051920.000
2051.9434.2014.740546159423991472014560NOx11:42 ppm / NOx21:61 ppm0.097330.000
2053.4434.2214.800603675623801472014560NOx11:61 ppm / NOx21:77 ppm0.112850.000
2054.9934.2514.80042212852871472014560NOx11:55 ppm / NOx21:29 ppm0.086460.000
2056.5634.2814.7603671837721472014560NOx11:38 ppm / NOx21:18 ppm0.080860.000
2058.0534.3014.76033251333361472014560NOx11:35 ppm / NOx21:16 ppm0.063760.000
2059.5534.3314.74026262531461472014560NOx11:30 ppm / NOx21:26 ppm0.067280.000
2061.1034.3514.78023182326761472014560NOx11:25 ppm / NOx21:23 ppm0.086560.000
2062.6034.3814.76024121623781472014560NOx11:23 ppm / NOx21:16 ppm0.094310.000
2064.1134.4014.7802391222821472014560NOx11:23 ppm / NOx21:11 ppm0.092460.000
2065.6234.4314.7601991121821472014560NOx11:21 ppm / NOx21:10 ppm0.093240.000
2067.1334.4514.780199920791472014560NOx11:21 ppm / NOx21:9 ppm0.093100.000
2068.6934.4814.780219819781472014560NOx11:19 ppm / NOx21:9 ppm0.093210.000
2070.2434.5014.740189718781472014560NOx11:18 ppm / NOx21:8 ppm0.093270.000
2071.7534.5314.780198718781472014560NOx11:18 ppm / NOx21:7 ppm0.094990.000
2073.2934.5514.780185817771472014560NOx11:18 ppm / NOx21:8 ppm0.095760.000
2074.8134.5814.780209418801472014560NOx11:17 ppm / NOx21:5 ppm0.093120.000
2076.3634.6114.800196617841472014560NOx11:17 ppm / NOx21:6 ppm0.092910.000
2077.8534.6314.760178918811472014560NOx11:19 ppm / NOx21:9 ppm0.094570.000
2079.3734.6614.760195718781472014560NOx11:19 ppm / NOx21:7 ppm0.097770.000
2080.9134.6814.760177519791472014560NOx11:18 ppm / NOx21:5 ppm0.094270.000
2082.5234.7114.780184619831472014560NOx11:18 ppm / NOx21:5 ppm0.093470.000
2084.0634.7314.780195717821472014560NOx11:17 ppm / NOx21:6 ppm0.093910.000
2085.5834.7614.8001841019801472014560NOx11:17 ppm / NOx21:10 ppm0.096050.000
2087.0934.7814.780197619771472014560NOx11:18 ppm / NOx21:6 ppm0.093190.000
2088.6334.8114.760188619831472014560NOx11:19 ppm / NOx21:5 ppm0.093980.000
2090.1434.8414.7601910620821472014560NOx11:19 ppm / NOx21:5 ppm0.093140.000
2091.6834.8614.760196820811472014560NOx11:20 ppm / NOx21:8 ppm0.095280.000
2093.1834.8914.780187521781472014560NOx11:20 ppm / NOx21:5 ppm0.094780.000
2094.6734.9114.800216520801472014560NOx11:19 ppm / NOx21:5 ppm0.093840.000
2096.1834.9414.760185420811472014560NOx11:20 ppm / NOx21:4 ppm0.092790.000
2097.6634.9614.760217520801472014560NOx11:20 ppm / NOx21:6 ppm0.095220.000
2099.2334.9914.7401395191201472014560NOx11:18 ppm / NOx21:5 ppm0.132510.000
2100.8035.0114.76062280681821472014560NOx11:60 ppm / NOx21:0 ppm0.072820.000
2102.3435.0414.76052393558941456014560NOx11:59 ppm / NOx21:38 ppm0.055750.000
2103.8735.0614.760484437521121472014560NOx11:51 ppm / NOx21:37 ppm0.055760.000
2105.3635.0914.80029304835381472014560NOx11:44 ppm / NOx21:45 ppm0.134260.000
2106.8835.1114.800236173041472014560NOx11:28 ppm / NOx21:20 ppm0.192570.000
2108.3835.1414.7802834252481472014560NOx11:24 ppm / NOx21:4 ppm0.170480.000
2109.9135.1714.7802910301161472014560NOx11:31 ppm / NOx21:0 ppm0.146290.000
2111.4135.1914.72032-30311381472014560NOx11:32 ppm / NOx21:0 ppm0.118200.000
2112.9535.2214.800260030981472014560NOx11:29 ppm / NOx21:0 ppm0.097470.000
2114.4635.2414.820214024901472014560NOx11:24 ppm / NOx21:0 ppm0.090710.000
2115.9735.2714.780194321931472014560NOx11:21 ppm / NOx21:4 ppm0.090870.000
2117.5335.2914.760180318921472014560NOx11:19 ppm / NOx21:2 ppm0.093380.000
2119.0535.3214.800159217921472014560NOx11:18 ppm / NOx21:3 ppm0.095370.000
2120.5835.3414.78069266421472014560NOx11:6 ppm / NOx21:21 ppm0.161950.000
2122.0835.3714.800436501472014560NOx11:7 ppm / NOx21:7 ppm0.196120.000
2123.6035.3914.780223301472014560NOx11:1 ppm / NOx21:2 ppm0.200190.000
2125.1035.4214.780032001472014560NOx11:0 ppm / NOx21:3 ppm0.201480.000
2126.6935.4414.760023001472014560NOx11:0 ppm / NOx21:3 ppm0.202590.000
2128.1935.4714.760032001472014560NOx11:0 ppm / NOx21:1 ppm0.203090.000
2129.7035.5014.760-321001472014560NOx11:0 ppm / NOx21:2 ppm0.203430.000
2131.2135.5214.740-2-120251472014560NOx11:0 ppm / NOx21:1 ppm0.199900.000
2132.7335.5514.760-1000111472014560NOx11:0 ppm / NOx21:0 ppm0.201630.000
2134.2335.5714.780-231001472014560NOx11:0 ppm / NOx21:2 ppm0.203570.000
2135.7735.6014.780-1-110221472014560NOx11:0 ppm / NOx21:1 ppm0.199370.000
2137.3335.6214.7803-120911472014560NOx11:0 ppm / NOx21:2 ppm0.199160.000
2138.8235.6514.7607-12051841472014560NOx11:4 ppm / NOx21:0 ppm0.165370.000
2140.3335.6714.7009-5091171472014560NOx11:8 ppm / NOx21:0 ppm0.143080.000
2141.8535.7014.7807-209891472014560NOx11:9 ppm / NOx21:0 ppm0.131080.000
2143.3835.7214.7806007821472014560NOx11:6 ppm / NOx21:0 ppm0.125020.000
2144.9535.7514.76022-6110971472014560NOx11:6 ppm / NOx21:1 ppm0.102030.000
2146.5635.7814.7403422028901472014560NOx11:28 ppm / NOx21:0 ppm0.069050.000
2148.0935.8014.74039453349921472014560NOx11:47 ppm / NOx21:34 ppm0.068590.000
2149.6035.8314.78033233835591472014560NOx11:36 ppm / NOx21:41 ppm0.115240.000
2151.0935.8514.78041812381661472014560NOx11:36 ppm / NOx21:14 ppm0.110590.000
2152.5935.8814.7604836050311456014560NOx11:47 ppm / NOx21:0 ppm0.052620.000
2154.1035.9014.740681135962411472014560NOx11:61 ppm / NOx21:54 ppm0.052540.000
2155.6235.9314.72057110113611151472014560NOx11:63 ppm / NOx21:115 ppm0.053280.000
2157.1435.9514.780499712734891472014560NOx11:49 ppm / NOx21:128 ppm0.091590.000
2158.6035.9814.76049467150651472014560NOx11:43 ppm / NOx21:70 ppm0.134370.000
2160.1236.0014.760501138511191472014560NOx11:51 ppm / NOx21:40 ppm0.119290.000
2161.5836.0314.78042171346971472014560NOx11:45 ppm / NOx21:11 ppm0.095990.000
2163.1336.0514.76036172435751472014560NOx11:35 ppm / NOx21:23 ppm0.086420.000
2164.7036.0814.74030293032911472014560NOx11:32 ppm / NOx21:32 ppm0.081820.000
2166.2536.1014.800301925301181472014560NOx11:30 ppm / NOx21:27 ppm0.091620.000
2167.7736.1314.78026122029991472014560NOx11:29 ppm / NOx21:20 ppm0.096030.000
2169.3136.1614.80020131325591472014560NOx11:25 ppm / NOx21:14 ppm0.100200.000
2170.8836.1814.8001424919661472014560NOx11:22 ppm / NOx21:9 ppm0.125770.000
2172.3936.2114.7809912911472014560NOx11:10 ppm / NOx21:8 ppm0.190970.000
2173.9136.2314.7801165731472014560NOx11:8 ppm / NOx21:5 ppm0.197220.000
2175.4436.2614.80090351041472014560NOx11:8 ppm / NOx21:1 ppm0.199450.000
2176.9836.2814.80029-160192271472014560NOx11:18 ppm / NOx21:0 ppm0.141710.000
2178.4736.3114.8002311028891472014560NOx11:30 ppm / NOx21:0 ppm0.116550.000
2179.9836.3314.74024426181621472014560NOx11:18 ppm / NOx21:28 ppm0.166370.000
2181.5036.3614.780253211371781456014560NOx11:35 ppm / NOx21:8 ppm0.148660.000
2183.0536.3814.6602082122411472014560NOx11:24 ppm / NOx21:23 ppm0.193810.000
2184.5536.4114.7801648121311472014560NOx11:13 ppm / NOx21:8 ppm0.192700.000
2186.0736.4314.8001901172011472014560NOx11:17 ppm / NOx21:0 ppm0.163290.000
2187.5736.4614.78018-20191281472014560NOx11:18 ppm / NOx21:0 ppm0.146850.000
2189.1436.4914.78017-40191021472014560NOx11:19 ppm / NOx21:0 ppm0.129110.000
2190.6936.5114.780161116831472014560NOx11:18 ppm / NOx21:1 ppm0.122820.000
2192.2336.5414.740153316811472014560NOx11:15 ppm / NOx21:4 ppm0.121620.000
2193.7436.5614.780143213791472014560NOx11:13 ppm / NOx21:2 ppm0.120950.000
2195.2636.5914.800102012781472014560NOx11:11 ppm / NOx21:0 ppm0.120770.000
2196.8136.6114.780112411811472014720NOx11:10 ppm / NOx21:3 ppm0.121300.000
2198.3036.6414.800113310791472014560NOx11:11 ppm / NOx21:2 ppm0.120800.000
2199.8236.6614.7809329781472014560NOx11:10 ppm / NOx21:2 ppm0.120360.000
2201.3336.6914.78092410781472014560NOx11:10 ppm / NOx21:4 ppm0.122370.000
2202.8436.7114.7608148811472014560NOx11:9 ppm / NOx21:3 ppm0.122880.000
2204.3536.7414.7809339771472014560NOx11:7 ppm / NOx21:3 ppm0.121740.000
2205.8336.7614.7609239801472014560NOx11:9 ppm / NOx21:4 ppm0.121800.000
2207.3536.7914.7808238811472014560NOx11:8 ppm / NOx21:3 ppm0.121680.000
2208.8636.8114.8007558801472014560NOx11:9 ppm / NOx21:4 ppm0.121860.000
2210.3736.8414.8208229831472014560NOx11:9 ppm / NOx21:3 ppm0.122860.000
2211.8836.8614.78083210811472014560NOx11:9 ppm / NOx21:2 ppm0.122740.000
2213.4036.8914.7408329811472014560NOx11:8 ppm / NOx21:2 ppm0.122700.000
2214.9236.9214.7809429811472014560NOx11:9 ppm / NOx21:0 ppm0.122680.000
2216.4636.9414.8009219811472014560NOx11:8 ppm / NOx21:1 ppm0.122540.000
2217.9536.9714.7808238781472014560NOx11:7 ppm / NOx21:3 ppm0.121940.000
2219.5236.9914.7609439811472014560NOx11:9 ppm / NOx21:4 ppm0.122140.000
2221.0837.0214.7608319821472014560NOx11:10 ppm / NOx21:1 ppm0.122090.000
2222.6137.0414.7408429811472014560NOx11:7 ppm / NOx21:3 ppm0.121640.000
2224.1237.0714.7609349831472014560NOx11:8 ppm / NOx21:4 ppm0.122260.000
2225.6337.0914.78082411811472014560NOx11:10 ppm / NOx21:4 ppm0.121550.000
2227.1537.1214.800103310801472014560NOx11:10 ppm / NOx21:3 ppm0.121630.000
2228.7437.1514.72095310811472014560NOx11:9 ppm / NOx21:4 ppm0.122430.000
2230.2737.1714.8009239811472014560NOx11:10 ppm / NOx21:3 ppm0.122750.000
2231.8037.2014.820105210791472014560NOx11:10 ppm / NOx21:2 ppm0.121860.000
2233.3237.2214.78092410821472014560NOx11:10 ppm / NOx21:3 ppm0.122370.000
2234.8237.2514.800112310821472014560NOx11:10 ppm / NOx21:3 ppm0.121870.000
2236.3337.2714.76094410811472014560NOx11:10 ppm / NOx21:4 ppm0.122150.000
2237.8237.3014.780102510831472014560NOx11:11 ppm / NOx21:5 ppm0.122330.000
2239.3537.3214.820102611811472014560NOx11:10 ppm / NOx21:6 ppm0.122380.000
2240.8737.3514.78095310811472014560NOx11:9 ppm / NOx21:4 ppm0.122160.000
2242.3937.3714.74031-20310811456014560NOx11:11 ppm / NOx21:2 ppm0.122700.000
2243.9237.4014.740641440713241456014560NOx11:68 ppm / NOx21:0 ppm0.004620.000
2245.4637.4214.76083190118942251472014560NOx11:93 ppm / NOx21:138 ppm-0.004080.000
2246.9937.4514.7606045158621341456014560NOx11:62 ppm / NOx21:148 ppm0.126470.000
2248.5037.4814.78048383060911472014560NOx11:62 ppm / NOx21:32 ppm0.080890.000
2250.0137.5014.78040293845751472014560NOx11:46 ppm / NOx21:36 ppm0.106470.000
2251.5937.5314.76035151341951472014560NOx11:40 ppm / NOx21:14 ppm0.093900.000
2253.0737.5514.76031171535801472014560NOx11:35 ppm / NOx21:16 ppm0.086200.000
2254.5837.5814.76028171831821472014560NOx11:31 ppm / NOx21:19 ppm0.097340.000
2256.1137.6014.70028121627971472014560NOx11:29 ppm / NOx21:16 ppm0.102210.000
2257.5937.6314.78023151127801472014560NOx11:27 ppm / NOx21:10 ppm0.099470.000
2259.1137.6514.76025111024631472014560NOx11:24 ppm / NOx21:11 ppm0.104730.000
2260.6437.6814.8001825923431472014560NOx11:23 ppm / NOx21:9 ppm0.107310.000
2262.1737.7014.7801881715691472014560NOx11:15 ppm / NOx21:16 ppm0.158530.000
2263.7037.7314.7602816201361472014560NOx11:21 ppm / NOx21:4 ppm0.149520.000
2265.2437.7514.800284929831472014560NOx11:28 ppm / NOx21:8 ppm0.119560.000
2266.7637.7814.8002410926741472014560NOx11:26 ppm / NOx21:8 ppm0.115140.000
2268.2837.8014.800227724641472014560NOx11:24 ppm / NOx21:8 ppm0.114080.000
2269.8337.8314.8001616718691472014560NOx11:19 ppm / NOx21:6 ppm0.130800.000
2271.3537.8614.8201461116891472014560NOx11:16 ppm / NOx21:11 ppm0.157020.000
2272.8637.8814.7602126171621472014560NOx11:14 ppm / NOx21:6 ppm0.165500.000
2274.3737.9114.76028-131261341472014560NOx11:25 ppm / NOx21:1 ppm0.122080.000
2275.8937.9314.8009171614311472014560NOx11:17 ppm / NOx21:7 ppm0.166520.000
2277.4037.9614.780107118341472014560NOx11:11 ppm / NOx21:10 ppm0.196370.000
2278.9437.9814.80021-13102171472014560NOx11:10 ppm / NOx21:3 ppm0.177760.000
2280.4638.0114.78031-20301241472014560NOx11:30 ppm / NOx21:0 ppm0.108220.000
2281.9938.0314.7602812032811472014560NOx11:32 ppm / NOx21:0 ppm0.080010.000
2283.5338.0614.80017151425901472014560NOx11:26 ppm / NOx21:12 ppm0.090070.000
2285.1138.0914.78017112117801472014560NOx11:17 ppm / NOx21:21 ppm0.126340.000
2286.6238.1114.800197717801472014560NOx11:18 ppm / NOx21:7 ppm0.131100.000
2288.1638.1414.780186518801472014560NOx11:17 ppm / NOx21:6 ppm0.133150.000
2289.7238.1614.800202718771472014560NOx11:18 ppm / NOx21:6 ppm0.133030.000
2291.2638.1914.780213420741472014560NOx11:19 ppm / NOx21:4 ppm0.130140.000
2292.7738.2114.78010148191121472014560NOx11:22 ppm / NOx21:7 ppm0.161680.000
2294.3838.2414.7804514641472014560NOx11:5 ppm / NOx21:15 ppm0.198040.000
2295.9638.2714.800113781621472014560NOx11:9 ppm / NOx21:10 ppm0.180840.000
2297.4938.2914.74034-261222081472014560NOx11:19 ppm / NOx21:1 ppm0.133130.000
2299.0138.3214.7601933030451472014560NOx11:31 ppm / NOx21:0 ppm0.115030.000
2300.5338.3414.820892411171472014560NOx11:12 ppm / NOx21:27 ppm0.194140.000
2302.0538.3714.800477601472014560NOx11:6 ppm / NOx21:8 ppm0.200330.000
2303.5838.3914.820244201472014560NOx11:3 ppm / NOx21:4 ppm0.202130.000
2305.0938.4214.760033201472014560NOx11:1 ppm / NOx21:3 ppm0.202980.000
2306.5938.4414.80020-1363721472014560NOx11:4 ppm / NOx21:2 ppm0.182230.000
2308.0938.4714.80034-50351111472014560NOx11:31 ppm / NOx21:0 ppm0.099140.000
2309.6738.4914.8001925029521472014560NOx11:31 ppm / NOx21:0 ppm0.087230.000
2311.2338.5214.78016823181171472014560NOx11:18 ppm / NOx21:23 ppm0.147420.000
2312.7438.5514.760166716981472014560NOx11:17 ppm / NOx21:7 ppm0.161020.000
2314.2638.5714.74030-12202221472014560NOx11:19 ppm / NOx21:3 ppm0.140870.000
2315.7738.6014.780330032931472014560NOx11:32 ppm / NOx21:0 ppm0.111180.000
2317.2638.6214.800319434821472014560NOx11:31 ppm / NOx21:3 ppm0.099680.000
2318.8438.6514.7603012832751456014560NOx11:32 ppm / NOx21:10 ppm0.091310.000
2320.3838.6714.76027181727681472014560NOx11:28 ppm / NOx21:17 ppm0.109730.000
2321.8938.7014.760309930861472014560NOx11:28 ppm / NOx21:9 ppm0.098180.000
2323.3938.7214.80024261629461472014560NOx11:30 ppm / NOx21:16 ppm0.103140.000
2324.8938.7514.78025141825741472014560NOx11:25 ppm / NOx21:19 ppm0.127400.000
2326.4038.7714.820141616191051456014560NOx11:21 ppm / NOx21:15 ppm0.173940.000
2327.9038.8014.7601751314731472014560NOx11:13 ppm / NOx21:15 ppm0.195630.000
2329.4238.8214.78037-34252381472014560NOx11:23 ppm / NOx21:4 ppm0.138770.000
2330.9238.8514.7604415048871472014560NOx11:46 ppm / NOx21:0 ppm0.082910.000
2332.4238.8714.80027491841851472014560NOx11:42 ppm / NOx21:17 ppm0.087390.000
2333.9038.9014.78021174227171472014560NOx11:30 ppm / NOx21:41 ppm0.184490.000
2335.4438.9214.760128151801472014560NOx11:20 ppm / NOx21:15 ppm0.197270.000
2337.0138.9514.80014551451472014560NOx11:9 ppm / NOx21:6 ppm0.195000.000
2338.5338.9814.74071-190403991472014560NOx11:27 ppm / NOx21:0 ppm0.095700.000
2340.0639.0014.7809217525659041472014560NOx11:67 ppm / NOx21:30 ppm0.040790.000
2341.6439.0314.720651782831012901456014560NOx11:120 ppm / NOx21:286 ppm0.058120.000
2343.2039.0514.7605710715256831472014560NOx11:56 ppm / NOx21:164 ppm0.101410.000
2344.7639.0814.78054639257591472014560NOx11:56 ppm / NOx21:94 ppm0.125600.000
2346.2739.1014.78045385452611472014560NOx11:52 ppm / NOx21:55 ppm0.131790.000
2347.7639.1314.78038273443731472014560NOx11:43 ppm / NOx21:34 ppm0.140820.000
2349.2939.1514.76033212637801472014560NOx11:38 ppm / NOx21:27 ppm0.141950.000
2350.8539.1814.78026171729731472014560NOx11:30 ppm / NOx21:17 ppm0.146020.000
2352.3739.2114.78030111426981472014560NOx11:27 ppm / NOx21:14 ppm0.142910.000
2353.8939.2314.8003266301181472014560NOx11:29 ppm / NOx21:10 ppm0.110230.000
2355.4039.2614.78029251130851472014560NOx11:31 ppm / NOx21:10 ppm0.083810.000
2356.9239.2814.82019382822391472014560NOx11:25 ppm / NOx21:27 ppm0.120130.000
2358.4039.3114.78081321971472014560NOx11:12 ppm / NOx21:22 ppm0.192780.000
2359.8839.3314.780697601472014560NOx11:7 ppm / NOx21:7 ppm0.198990.000
2361.3939.3614.8006554131472014560NOx11:5 ppm / NOx21:5 ppm0.200950.000
2362.9639.3814.800265201472014560NOx11:1 ppm / NOx21:4 ppm0.202000.000
2364.5039.4114.7803630141472014560NOx11:2 ppm / NOx21:3 ppm0.202800.000
2365.9939.4314.76041211291472014560NOx11:1 ppm / NOx21:1 ppm0.189150.000
2367.5039.4614.7208-4052081472014560NOx11:4 ppm / NOx21:0 ppm0.162470.000
2369.0139.4814.78023-100151551472014560NOx11:12 ppm / NOx21:0 ppm0.132040.000
2370.4939.5114.8001916020851456014560NOx11:23 ppm / NOx21:0 ppm0.090590.000
2371.9939.5314.74029298251071456014560NOx11:23 ppm / NOx21:10 ppm0.072510.000
2373.5139.5614.74033573732561472014560NOx11:32 ppm / NOx21:37 ppm0.061650.000
2375.0239.5814.7606113467592251472014560NOx11:52 ppm / NOx21:70 ppm0.058340.000
2376.5439.6114.7405915012557541456014560NOx11:52 ppm / NOx21:130 ppm0.054470.000
2377.9839.6314.780449214349701472014560NOx11:51 ppm / NOx21:145 ppm0.080880.000
2379.5339.6614.78040688939711472014560NOx11:38 ppm / NOx21:98 ppm0.116130.000
2381.0439.6814.80040395843721472014560NOx11:43 ppm / NOx21:59 ppm0.133420.000
2382.5239.7114.78034223339711472014560NOx11:37 ppm / NOx21:34 ppm0.157440.000
2384.0539.7314.820381320371421472014560NOx11:34 ppm / NOx21:21 ppm0.140300.000
2385.5839.7614.78038241243691472014560NOx11:42 ppm / NOx21:15 ppm0.088190.000
2387.1339.7914.76029363032851472014560NOx11:34 ppm / NOx21:28 ppm0.089990.000
2388.6639.8114.80024323626651472014560NOx11:26 ppm / NOx21:35 ppm0.113920.000
2390.1739.8414.82014212820201472014560NOx11:23 ppm / NOx21:28 ppm0.157060.000
2391.6939.8614.80087151201472014560NOx11:12 ppm / NOx21:16 ppm0.195230.000
2393.2039.8914.76010378881472014560NOx11:8 ppm / NOx21:6 ppm0.196220.000
2394.7139.9114.76027-12162661472014560NOx11:14 ppm / NOx21:2 ppm0.154650.000
2396.2639.9414.780321033821472014560NOx11:30 ppm / NOx21:0 ppm0.098360.000
2397.7639.9614.7802822832811472014560NOx11:31 ppm / NOx21:7 ppm0.078380.000
2399.3139.9914.78026272727751472014560NOx11:28 ppm / NOx21:26 ppm0.073640.000
2400.9040.0214.80023282826901472014560NOx11:26 ppm / NOx21:28 ppm0.073460.000
2402.4140.0414.76023272326881472014560NOx11:25 ppm / NOx21:23 ppm0.077570.000
2403.9440.0714.740645623352611472014560NOx11:28 ppm / NOx21:25 ppm0.042690.000
2405.4640.0914.7601083361501192151472014560NOx11:106 ppm / NOx21:129 ppm0.000620.000
2407.0240.1214.80083199220108941472014560NOx11:108 ppm / NOx21:216 ppm-0.000190.000
2408.5640.1414.7606036107702681472014560NOx11:72 ppm / NOx21:112 ppm0.134920.000
2410.0740.1714.78046927541461472014560NOx11:55 ppm / NOx21:27 ppm0.113990.000
2411.5940.1914.7804012042981456014560NOx11:42 ppm / NOx21:0 ppm0.082640.000
2413.1540.2214.74037401735851472014560NOx11:35 ppm / NOx21:14 ppm0.057780.000
2414.6740.2414.74046674243931472014560NOx11:41 ppm / NOx21:40 ppm0.058850.000
2416.1840.2714.76044627346781472014560NOx11:44 ppm / NOx21:72 ppm0.066240.000
2417.6940.2914.76035435641761472014560NOx11:41 ppm / NOx21:58 ppm0.071320.000
2419.2540.3214.64029293732661472014560NOx11:34 ppm / NOx21:37 ppm0.093860.000
2420.8440.3514.80015232721531472014560NOx11:25 ppm / NOx21:26 ppm0.132760.000
2422.4040.3714.76098201221472014560NOx11:11 ppm / NOx21:22 ppm0.194120.000
2423.9240.4014.74066259138361472014560NOx11:11 ppm / NOx21:7 ppm0.158470.000
2425.4540.4214.660496413711171456014560NOx11:70 ppm / NOx21:13 ppm0.060780.000
2427.0240.4514.70020435842371456014560NOx11:44 ppm / NOx21:60 ppm0.120560.000
2428.5640.4814.7001710272261456014400NOx11:24 ppm / NOx21:28 ppm0.191220.000
2430.0740.5014.6601429131391456014400NOx11:17 ppm / NOx21:10 ppm0.196860.000
2431.5740.5314.66057140531681456014400NOx11:44 ppm / NOx21:0 ppm0.081740.000
2433.0940.5514.70026752552641456014560NOx11:53 ppm / NOx21:22 ppm0.079690.000
2434.6040.5814.68020134026171456014560NOx11:30 ppm / NOx21:43 ppm0.185410.000
2436.1440.6014.62050-1012226741456014560NOx11:21 ppm / NOx21:12 ppm0.165130.000
2437.6440.6314.7004621054601456014560NOx11:54 ppm / NOx21:0 ppm0.071450.000
2439.1740.6514.68031443933791456014560NOx11:40 ppm / NOx21:40 ppm0.107770.000
2440.6840.6814.640331735301931456014400NOx11:30 ppm / NOx21:39 ppm0.169570.000
2442.2040.7014.68041111363171456014560NOx11:33 ppm / NOx21:10 ppm0.148970.000
2443.7140.7314.6802925041661456014560NOx11:41 ppm / NOx21:0 ppm0.107190.000
2445.1940.7514.62021132228701456014560NOx11:26 ppm / NOx21:24 ppm0.174660.000
2446.7740.7814.680135102031456014560NOx11:22 ppm / NOx21:10 ppm0.194110.000
2448.3140.8114.7006551001456014560NOx11:11 ppm / NOx21:6 ppm0.200070.000
2449.8240.8314.700113501456014560NOx11:6 ppm / NOx21:2 ppm0.201500.000
2451.3440.8614.6404044391456014560NOx11:8 ppm / NOx21:4 ppm0.201620.000
2452.8340.8814.64040351581456014560NOx11:3 ppm / NOx21:4 ppm0.190610.000
2454.3340.9114.66010-3052031456014560NOx11:6 ppm / NOx21:0 ppm0.166710.000
2455.9440.9314.70012-30121201456014560NOx11:12 ppm / NOx21:0 ppm0.146530.000
2457.4740.9614.72010-2011951456014560NOx11:10 ppm / NOx21:0 ppm0.138070.000
2458.9740.9814.72027-8291641456014560NOx11:8 ppm / NOx21:2 ppm0.129250.000
2460.5241.0114.6604140736761456014560NOx11:31 ppm / NOx21:4 ppm0.062630.000
2462.0941.0314.68035355535611456014560NOx11:41 ppm / NOx21:52 ppm0.094300.000
2463.6041.0614.72032485234871456014560NOx11:33 ppm / NOx21:52 ppm0.116800.000
2465.0941.0814.70027204034461456014560NOx11:31 ppm / NOx21:40 ppm0.177100.000
2466.5941.1114.7001711172101456014560NOx11:23 ppm / NOx21:16 ppm0.196190.000
2468.1041.1414.70015371781456014560NOx11:17 ppm / NOx21:7 ppm0.197910.000
2469.5541.1614.6801803151961456014560NOx11:15 ppm / NOx21:4 ppm0.174140.000
2471.0641.1814.6601921201311456014400NOx11:19 ppm / NOx21:0 ppm0.158970.000
2472.5741.2114.66025-12252541456014400NOx11:24 ppm / NOx21:3 ppm0.144520.000
2474.0941.2314.680216323831456014560NOx11:22 ppm / NOx21:4 ppm0.143710.000
2475.5941.2614.6802116211341456014560NOx11:20 ppm / NOx21:7 ppm0.147510.000
2477.1041.2914.68021-10211001456014400NOx11:22 ppm / NOx21:0 ppm0.128560.000
2478.6641.3114.640384018981456014720NOx11:19 ppm / NOx21:0 ppm0.122020.000
2480.1841.3414.82058760592611472014720NOx11:48 ppm / NOx21:0 ppm0.018170.000
2481.6941.3614.84016716930661472014560NOx11:45 ppm / NOx21:70 ppm0.037910.000
2483.2141.3914.760211952171681472014560NOx11:18 ppm / NOx21:57 ppm0.145210.000
2484.7141.4114.66018616201051456014400NOx11:19 ppm / NOx21:16 ppm0.150030.000
2486.2141.4414.6401766161031456014400NOx11:17 ppm / NOx21:6 ppm0.147420.000
2487.7341.4614.6401331151101456014560NOx11:15 ppm / NOx21:2 ppm0.142590.000
2489.2541.4914.6801552141201456014400NOx11:12 ppm / NOx21:2 ppm0.136910.000
2490.7941.5114.6601330161021456014560NOx11:16 ppm / NOx21:0 ppm0.110930.000
2492.3141.5414.6601294111001456014560NOx11:13 ppm / NOx21:3 ppm0.113690.000
2493.8041.5614.600108129871456014400NOx11:10 ppm / NOx21:12 ppm0.129370.000
2495.3041.5914.96090311951488014720NOx11:10 ppm / NOx21:2 ppm0.126830.000
2496.8041.6114.8609608821472014720NOx11:8 ppm / NOx21:0 ppm0.126900.000
2498.2941.6414.80010268901472014560NOx11:8 ppm / NOx21:7 ppm0.131070.000
2499.8141.6614.9208208881488014720NOx11:5 ppm / NOx21:0 ppm0.121710.000
2501.3241.6914.86071027711488014720NOx11:6 ppm / NOx21:1 ppm0.124210.000
2502.8241.7114.8607-347681488014720NOx11:7 ppm / NOx21:5 ppm0.122600.000
2504.4241.7414.8807118781488014720NOx11:7 ppm / NOx21:1 ppm0.119470.000
2505.9541.7714.8608337781472014720NOx11:7 ppm / NOx21:3 ppm0.118050.000
2507.4741.7914.9808137801472014720NOx11:7 ppm / NOx21:3 ppm0.118480.000
2508.9641.8214.8807426761472014720NOx11:7 ppm / NOx21:2 ppm0.117040.000
2510.4641.8414.8608328751472014720NOx11:7 ppm / NOx21:1 ppm0.117030.000
2511.9441.8714.9409346751488014720NOx11:6 ppm / NOx21:3 ppm0.116870.000
2513.4441.8914.8807447681472014720NOx11:6 ppm / NOx21:4 ppm0.116010.000
2514.9541.9214.8007437681472014560NOx11:7 ppm / NOx21:4 ppm0.115290.000
2516.4841.9414.7807458741472014880NOx11:6 ppm / NOx21:6 ppm0.117530.000
2518.0041.9714.8807168761488014720NOx11:8 ppm / NOx21:7 ppm0.117850.000
2519.5541.9914.8006336771472014560NOx11:6 ppm / NOx21:3 ppm0.117820.000
2521.0642.0214.8007458801472014560NOx11:5 ppm / NOx21:4 ppm0.118590.000
2522.5742.0414.6808237781456014560NOx11:9 ppm / NOx21:3 ppm0.118020.000
2524.0942.0714.6606557761440014560NOx11:8 ppm / NOx21:6 ppm0.118100.000
2525.5742.0914.6803746741440014560NOx11:7 ppm / NOx21:4 ppm0.118560.000
2527.0742.1214.70058145821456014560NOx11:6 ppm / NOx21:14 ppm0.144220.000
2528.5442.1414.6804565921456014560NOx11:4 ppm / NOx21:7 ppm0.150580.000
2530.0542.1714.6806545961456014560NOx11:5 ppm / NOx21:4 ppm0.150440.000
Jinxgj
C?ID=443755
Update from garage.
They have determined that it is a NOx sensor at fault (not sure which one pre or post Cat and will find out when i collect it).
Car not going to be ready until Friday-ish as they are waiting for the new sensor to be delivered (Bosch one apparently) which should be fine as i would imagine either Bosch or Continental make Audi OEM ones.
Will be back Friday with the verdict and let you all knwo if the car is improved.
Thanks all
Gaz
