Hi got an Audi A1 2011 1.6TDI that has lost its ABS long code after remoal of body control unit and ECU. Is there anyone on here able to recover the code or codes needed to reprogram the ABS back to this vehicle. thank you
Thursday,23,January,2025,14:25:22:28791
VCDS Version: 24.7.1.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WAUZZZ8X0BB052042 License Plate:
Chassis Type: 8X-AU21 (8X0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X0BB052042 Mileage: 150590km-93572miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KN HW: 03L 906 023 KM
Component: R4 1.6l TDI H53 9979
Revision: --H53--- Serial number: CVN: C5CD4672
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KN 003018
ROD: EV_ECM16TDI02103L906023KM_003.rod
VCID: 7CAA9A18B66C609A033-8028
VINID: 9D196AAAA2280124801420040849A612A2
10446 - Neutral Gear Sensor
P15A0 00 [00100101] - Electrical Malfunction
[Transmission Neutral Position Sensor Electrical malfunction]
Mileage: 150595 km
Date: 2025.01.09
Time: 20:51:52
Engine RPM: 0.00 /min
Coolant temperature: 4 °C
Intake air temperature: 6 °C
Voltage terminal 30: 11.633 V
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 10.7 V
Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 20.001 °
Neutral position sensor: adapted transmission angle-ANG_NEUT_GEAR_AD_NEUT: -180.000 °
Engaged gear: calculated-DRI_MT_BAS: 0
Clutch Position Sensor-Starter control: clutch switch: 00000000
Starter control: clutch switch-Starter control: interlock switch: 00000000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AH HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0004
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 00046 000 00000
VCID: 045AE2F8CE5C185A7B3-8050
03306 - Coding Not Valid
Fault Frequency: 12
Reset counter: 174
Mileage: 150595 km
Date: 2025.01.09
Time: 20:53:17
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1495
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Frequency: 9
Reset counter: 174
Mileage: 150595 km
Date: 2025.01.09
Time: 20:53:17
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x1495
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030003472444
VCID: 343A7238D23C68DA8B3-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 D HW: 8X0 907 063 D
Component: BCM PQ35 M 108 0621
Revision: 00108 AB
Coding: 0E000A2FA005F100201841E000000154430B6C0A00CF4122DC0087830041
VCID: 3D2C571CED76A99274D-8068
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0010
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ000K9WG Dataset Number: 8X0909602B 0004
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 48C236C8B234FC3AD7B-801C
Serial number: 3554VRB4059060GK60G$
Serial number: 3575HRB405908V2MCOM%
Serial number: 3585HRB405908V2MC1DB
Rear end impact crash sensor:
Serial number: 3515ZRB40610891I907L
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 H
Component: LENKS.MODUL 009 0136
Revision: FF010015 Serial number: 20101215101191
Coding: 1184004000
VCID: 3924430CF9DE95B2585-806C
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels:| 8X0-920-KOM-V1.clb-SRI1
Part No SW: 8X0 920 980 A HW: 8X0 920 980 A
Component: KOMBI H07 0124
Coding: 41DE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
VCID: 3D2C571CEDF6A99274D-8068
Address 19: CAN Gateway (J533) Labels:. 8X0-907-468.clb
Part No SW: 8X0 907 468 A HW: 8X0 907 468 A
Component: GAT 4CAN 1L M H04 0083
Revision: 1C060023 Serial number: 2341C10C0300CB
Coding: FBCF005A000100010153
VCID: 43D821E48B92DF62029-8016
Subsystem 1 - Part No SW: 8K0 915 181 G HW: 8K0 915 181 G
Component: J367-BDM H07 0150
Serial number: 00000000009370218819
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 10347000130011200181
Reset counter: 214
Mileage: 150595 km
Date: 2025.01.10
Time: 02:28:00
Bin. Bits: 00000
Voltage: 11.90 V
Count: 18
Component: IMMO H07 0124
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 B HW: 8X0 959 793 B
Component: TSG FA H09 0409
Coding: 011802200101120102
VCID: 4CCA0AD8A6CC101AF33-8018
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F307D543E5A4B02F61-807A
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 B HW: 8X0 959 792 B
Component: TSG BF H09 0409
Coding: 011002200101120102
VCID: 4BC809C4A3C21722FA9-801E
Part No SW: 8X0 035 183 HW: 8X0 035 182 A
Component: RMC Cnct H45 0530
Coding: 01010000000051070023000103010000010000
VCID: 74BAB2389EBC28DA4B3-8020
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462LY0A0045862
End----(Elapsed Time: 01:31, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
