Crank sensor/oil pressure sensor
Arlon
Holliston, MA, USA
C?ID=601671
As a complete Noob I got this software to diagnose my 2011 golf TDI. It said my crank position sensor was intermittently communicating, so as a low dollar item, I replaced it. At this point I realize I should have done a scan before I started, but I'm at where I'm at.
The car now runs and drives, but the turbo doesn't spool, and it begrudgingly shifts. Not limp mode, but more like Datsun B210 mode. I'm getting a live graph output from "G28" sensor, but the fault says it's incomunicato". The other issue is the oil light comes on intermittently. These are both sensors that I removed and reinstalled. Because of their location the wires and accompanying harness were pretty funky with grease and oil or whatever. I cleaned them and inspected for cuts/chaffing, pronounced them within parameters, and re-assembled.
Is my next step to go back and trace the whole circuit? The sensor was bought as an OEM, so I'm thinking that's not it.
Any input is appreciated,
Wednesday,22,January,2025,11:31:18:25971
VIN: WVWDM7AJ2BW197677   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWDM7AJ2BW197677   Mileage: 333030km-206935miles
77-Telephone -- Status: Sporadic communication error 1000
   Part No SW: 03L 997 030 B    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 46132 001 1048576
   VCID: 2D00D16F61176952C4D-8078
   VINID: 9E69D474745A0929C12471871C170D01E7
000802 - Engine Speed Sensor (G28)
               P0322 - 000 - No Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 333028 km
                    Date: 2019.06.15.
                    Time: 18:57:37
                    RPM: 920 /min
                    Voltage: 14.21 V
                    Temperature: 58.5°C
                    Idle Stabilization: 0.0°KW
                    RPM: 456 /min
                    (no units): 60.0
Readiness: 1 1 0 1 1
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351112    Serial number: 00001012161588
   VCID: 176C1387F38BF3828E1-8042
17100 - Transmission Input Speed Sensor (G182)
            P0716 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 255
                    Mileage: 333028 km
                    Date: 2019.06.15.
                    Time: 13:51:44
18115 - Interference in Mechatronic Module
            P1707 - 006 -  - Intermittent
                    Fault Status: 00100110
                    Mileage: 333028 km
                    Date: 2019.06.15.
                    Time: 13:51:46
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B400C492B0001881102EB92200042B70000
   VCID: 78AE303BD2D51CFA67B-802C
   Part No SW: 7N0 907 426 AB    HW: 7N0 907 426 AB
   Component: AC Manuell    H18 0303
   Revision: 00013001
   Coding: 0000001002
   VCID: 74B6040BCE3D789A4B3-8020
9474577 - Motor for Recirculation Flap
          B1092 11 [00001001] - Short to Ground
                    Reset counter: 130
                    Mileage: 303391 km
                    Date: 2025.01.22.
                    Time: 17:54:05
          B10AB F0 [00001001] - Too Low
                    Reset counter: 152
                    Mileage: 328492 km
                    Date: 2025.01.22.
                    Time: 11:53:21
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R01JXBO   Dataset Number: 5K0003v__B_ 0058
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3928F53FA9DFC5F2585-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00059RWL00
   Serial number: 3572MSME2055345AZZZR
   Serial number: 3582MSME6F627259ZZZ3
   Serial number: 3512QSME08567B5CZZZ2
   Serial number: 3522QSME36566E64ZZZ%
   Serial number: 35527SME26183725ZZZA
   Serial number: 35627SME24087624ZZZA
   Revision: --------    Serial number:  90440KA300186 Dataset Number: 5K0953507AH D005
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B23E03D8416A8A757-8022
   Serial number: 50000000000000274326
   Coding: E30000
   Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
   Coding: 270F01
   VCID: 2F3CCB67679B1B42F61-807A
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 120111F2001709
   Coding: 350002
   VCID: 303EC81B7A2504BAEFB-8064
                    Fault Status: 00110100
                    Reset counter: 84
                    Mileage: 307944 km
                    Date: 2019.06.15.
                    Time: 20:56:44
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RBHSB06
   Coding: 0000002
   VCID: 7EA22623FCF122CA2D7-802A
   Component: IMMO          H20 0420
   VCID: 6A8A1A739CF9BE6AE1F-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669194279
   VCID: 280E207B42F54C7A37B-807C
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 3138CD1F7D2F0DB2E05-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 3436C40B823D389A8B3-8060
Address 46: Central Conv.
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2151
   Coding: 0001204
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H15 0043
   Revision: -----27S    Serial number: VWZ4Z7K1176287
   Coding: 0100040004
   VCID: 61987D5F614FFD32305-8034
                    Reset counter: 44
                    Mileage: 284443 km
                    Date: 2019.06.15.
                    Time: 03:30:43
                    Reset counter: 84
                    Mileage: 307944 km
                    Date: 2019.06.15.
                    Time: 20:57:03
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 3530F90F89472192BCD-8060
   Coding: 0001168
   VCID: 3632FE0394412A8AB57-8062
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669117805 Dataset Number: 5K0035730   0001
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 629A725364C9E62A29F-8036
End----------(Elapsed Time: 01:10, VBatt start/end: 12.7V/12.7V)-----------
First of all, get validated.
Clear the fault, cycle the key, check again to see if it comes back, post new scan.
Arlon
Holliston, MA, USA
C?ID=601671
Cleared it twice, but I'll do it again, thanks (did validate)
Check the connector then... it's clearly reading since the FF data shows RPM, so I'd suspect a flaky connection that just vibrates enough to throw a fault under certain conditions.
Arlon
Holliston, MA, USA
C?ID=601671
rescan:
Wednesday,22,January,2025,13:55:21:25971
   Coding: 0050078
                    Mileage: 333028 km
                    Date: 2019.06.15.
                    Time: 18:57:37
                    RPM: 920 /min
                    Voltage: 14.21 V
                    Temperature: 58.5°C
                    RPM: 456 /min
                    (no units): 60.0
   Revision: 00H31001
   Revision: 00013001
   Coding: 0000001002
   Coding: 00003031
   Coding: 189A140000
   Coding: E30000
   Coding: 270F01
   Coding: 350002
   Coding: 0000002
   Coding: 0001204
   Revision: 00H20000
   Coding: 0001204
   Coding: 0100040004
                    Reset counter: 44
                    Mileage: 333031 km
                    Date: 2019.06.15.
                    Time: 13:52:38
   Coding: 0001168
   Coding: 0001168
   ROD: UHVNA.rod
9457425 - Left audio channel for speech/telephone
          B104F 11 [00000001] - Short to GND
9457169 - Right audio channel for speech/telephone
          B104E 11 [00000001] - Short to GND
End----------(Elapsed Time: 01:05, VBatt start/end: 14.6V/14.6V)-----------
Arlon
Holliston, MA, USA
C?ID=601671
That was my thinking, but how can I get LD graphing out of a sensor that is not working?
Describe exactly what you did, as to me, it look like it's the same code and FF data (so you didn't clear anything)
Arlon
Holliston, MA, USA
C?ID=601671
I really don't know anything about this, But there was also a code for a transmission speed sensor.
is the G28 sensor signal split and one circuit gets data and the other doesn't?
Arlon
Holliston, MA, USA
C?ID=601671
Just now..... Started the car, scanned, cleared the faults, rescanned, posted
How did you clear the faults?
Arlon
Holliston, MA, USA
C?ID=601671
It said I should fix it first before I cleared the faults.........duh.
Arlon
Holliston, MA, USA
C?ID=601671
from the scan screen when it was finished
Arlon
Holliston, MA, USA
C?ID=601671
Do I have to do it from somewhere else?
Arlon
Holliston, MA, USA
C?ID=601671
Do you think taking it out for another drive about would help?
Go into engine controller and clear it there.
Do a key cycle.
Go back into engine controller and check if the code is still there.
Report back.
Arlon
Holliston, MA, USA
C?ID=601671
Cleared from controller, it came right back. Did about a 4 mile drive, cleared and came right back. don't know if it factors in , but the glowplug indicator is flashing, but that started after the sensor replacement
NZDubNurd
New Zealand
C?ID=230482
WHERE did the "OEM" sensor come from?
Arlon
Holliston, MA, USA
C?ID=601671
ID Parts
Hingham Ma.
I also own an 08 Sprinter I bought new . They are my only supplier of Parts
Arlon
Holliston, MA, USA
C?ID=601671
How can the ecm say no communication with the G28 sensor, then proceed to produce a live graph from the same sensor?
Do a key cycle.
Report back.
Do this several times to see if it clears.... also try clearing it from OBDII section.
