- May 20, 2022
- 126
- 16
- Meridian, ID, USA
- C?ID=504168
All,
I apologize if I didn't get the scan inserted correctly...it's been a while since I've asked for help. I have what I believe is a bad ECU but I wanted to ask the forum for your opinion before buying a used one and having it cloned to my bad one. It sometimes has starting problems, the tach and speedometer don't read correctly (off a little bit), we've gone through multiple batteries, and have errors on the fuel side. Any help would be appreciated.
Monday,20,January,2025,19:22:53:41551
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WA1AV74L07D059193 License Plate:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
47 4F 52 55 56 61 62 67 6C 6D 6F 72 76 77
VIN: WA1AV74L07D059193 Mileage: 286270km-177879miles
0F-Digital Radio -- Status: Cannot be reached 1100
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine Labels:. 079-907-560-BAR.clb
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0060
Revision: 71H16--- Serial number:
Coding: 01210009190F0560
Shop #: WSC 22164 444 84353
VCID: 2809F7945EF93FBA37B-807C
VINID: 9D105198711C0075001490490C0D05D2B4
004506 - Fuel Pressure Sensor (G247)
P119A - 002 - Malfunction - Intermittent
Mileage: 286229 km
Date: 2006.08.14
Time: 00:54:38
RPM: 673 /min
Load: 39.2 %
Temperature: 64.0°C
Temperature: 39.0°C
Absolute Pres.: 920.0 mbar
Voltage: 13.081 V
005635 - Internal Control Module
P1603 - 004 - Failed Self-Test - Intermittent
Temperature: 86.0°C
Temperature: 11.0°C
Voltage: 8.509 V
008576 - Bank 2; System Too Rich off Idle
P2180 - 002 - - Intermittent
Mileage: 286264 km
Date: 2024.10.08
Time: 12:52:11
RPM: 1701 /min
Load: 57.2 %
Speed: 40.0 km/h
Temperature: 76.0°C
Temperature: 12.0°C
Voltage: 13.462 V
004105 - Mass Air Flow Sensor 1/2
P1009 - 008 - Implausible Signal from Load Calculation - Intermittent
Fault Status: 00111000
Mileage: 286273 km
Date: 2024.10.08
Time: 13:03:47
RPM: 2128 /min
Load: 51.4 %
Speed: 26.0 km/h
Temperature: 99.0°C
Temperature: 14.0°C
Voltage: 14.478 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FH HW: 09D 927 750 FH
Component: AL 750 6A 0959
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 79AFE2D0F5D37632185-802C
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0021553
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100574525
Coding: 0000135
VCID: 6393A0B8675F9CE2229-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 354JQ067513037
Coding: 0002003
VCID: 35372EE0994B5252BCD-8060
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
Address 08: Auto HVAC Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 HW: 4L0 820 043 E
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---011 Serial number: 00000000079970
Coding: 0655400
VCID: 619FAAB07D438EF2305-8034
02874 - Control Module 2 for Central Convenience (J773)
Fault Status: 01101000
Reset counter: 167
Mileage: 286275 km
Date: 2006.05.14
Time: 15:42:43
02380 - Positioning Motor for Right Side Vent (V300)
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 167
Mileage: 286275 km
Date: 2006.05.14
Time: 15:42:43
Voltage: 14.10 V
Temperature: 0.0°C
(no units): 51.0
(no units): 149.0
Temperature: -3.0°C
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0114123
VCID: 30391FF46629777AEFB-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBF1011093
VCID: 1D67D64001BBEA1254D-8048
Address 0F: Digital Radio
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD041FYI
Coding: 0014131
VCID: 2B0308984F0F14A2DA9-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME186153278
Subsystem 3 - Serial number: 6342QSME18077805C
Subsystem 4 - Serial number: 6352QSME11714667A
Subsystem 5 - Serial number: 6362QSME18672629J
Subsystem 6 - Serial number: 63734SME151A2D2D5
Subsystem 7 - Serial number: 63834SME1528394D4
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026062900208
Coding: 0012042
VCID: 6695B9AC946DE9CAC57-8032
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-920-KOM-V1.clb
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0120
Revision: 00700000 Serial number: 5HH318UA6
Coding: 2657268
Shop #: WSC 43924 002 104857
VCID: 2313E0B827DFDCE2629-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D0692680F1
Coding: F5F3FE7F347A02
VCID: 6C81CB848A81D39A933-8038
02230 - Digital Radio (DAB) (R147)
Reset counter: 167
Mileage: 286275 km
Date: 2006.05.14
Time: 15:43:37
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 C
Revision: 00---008 Serial number: 00000030008883
Coding: 0000006
VCID: 6889B7949E79FFBAF7B-803C
Reset counter: 167
Mileage: 286275 km
Date: 2006.05.14
Time: 15:42:43
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 167
Mileage: 286275 km
Date: 2006.05.14
Time: 15:42:47
Address 34: Level Control Labels: 4L0-910-553.clb
Part No SW: 4L0 910 553 B HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7550
Revision: --H03001 Serial number: 15.1528-0095.2
Coding: 0015510
VCID: 290FF29045F306B2285-807C
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Part No SW: 4E0 910 888 F HW: 4E0 919 887 L
Component: MNS US H48 0990
Revision: 00000000 Serial number: 313JE067510051
VCID: 313F1AF06D237E72E05-8064
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0000001
VCID: 2C010B844A01139AD33-8078
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F18.10.0600H0500000010256ÿ
Subsystem 4 - Serial number: 010256ÿ
16365 - Control Module - Electrical Error; CPU 2
014 - Defective
Fault Status: 01101110
Reset counter: 217
Mileage: 171396 km
Date: 2016.07.08
Time: 08:49:34
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
VCID: 2F3B1C887B176882F61-807A
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01014502840000
Coding: 7632925
02956 - Lamp in Trunk/Hatch Lid; Left
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 76
Reset counter: 167
Mileage: 285175 km
Date: 2006.06.28
Time: 09:20:05
Bin. Bits: 000 001
Fault Status: 01101100
Reset counter: 167
Mileage: 229387 km
Date: 2019.10.28
Time: 08:15:02
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000001326
Coding: 0000026
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000049101
Coding: 0012001
VCID: 5EE5914C4C3DB10A0D7-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000022
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388J0067563159
Coding: 0000002
VCID: 2E05018C7C1D618AFD7-807A
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000055755
Shop #: WSC 22186 444 84605
VCID: 6491A3A462519BDADB3-8030
Subsystem 1 - Part No: 000 030 606 6
Component: von VA0 8399603291
Coding: 303030303330363036362056413038333939363033323931
Shop #: WSC 26021 001 104857
Reset counter: 207
Mileage: 286275 km
Date: 2006.05.14
Time: 15:42:37
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000610180167
Shop #: WSC 12336 024 394758
VCID: 343113E492314B5A8B3-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8740QW
Coding: 1001001
VCID: 2411E3A422D1DBDA1B3-8070
03006 - Back-up Camera System not calibrated
Reset counter: 167
Invalid
Invalid
Invalid
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD21.10.06--H21001001A0185ÿ
Subsystem 4 - Serial number: 1A0185ÿ
02786 - Module 2 for Hatch / Trunk Lid (J756)
Fault Status: 00100001
Reset counter: 206
Mileage: 286274 km
Date: 2024.10.08
Time: 13:08:01
02072 - Control Module for Energy Management (J644)
Reset counter: 207
Mileage: 286274 km
Date: 2024.10.08
Time: 13:35:41
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002065197-----
Coding: 0003595
VCID: 2615F9AC54ED29CA057-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
02907 - Control Module for Roof Shade (J394)
Fault Status: 01100101
Reset counter: 167
Mileage: 286275 km
Date: 2006.05.14
Time: 15:42:37
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230628503572
Coding: 0021246
VCID: 270BF4A853E730C23E1-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H18 1130
Revision: 00000000 Serial number: 00000005025525
Coding: 0010900
End----------(Elapsed Time: 02:17, VBatt start/end: 14.2V/13.9V)-----------
