- Dec 5, 2014
- 3,358
- 944
- Windsor UK
- C?ID=334979
Cruise Control is not a requirement - It does paralyse variety !cruise control at 2.2k
OKCruise Control is not a requirement
Tech Doc said:Good driving conditions are:
- Low-traffic country road/highway
- Level roads
- Very constant driving cycle
- Drive with cruise control
- Engine rpm between 1900 - 2400
- Select 4th/5th gear (depending on speed)
Neither can I..... plus I already have.... twice!Cant be bothered
You show me ?
Provided it stays that way long enough to get to a smog-test station, I think you're good to go.@Uwe Nothing found via generic OBD2. Does this alter your skepticism about getting a smog check? If not, what would you suggest as next steps?
What if the car doesn't have cruise control? Yes, that's pretty much unheard of in the NAR market, where it's been standard equipment just about forever, but it's quite common in other markets, where it was always an option that had to be ordered, either stand-alone, or as part of a fancier trim package.Drive with cruise control
I think that's a great idea, question #2 in my post #11 in this thread was seeking guidance as to the most meaningful values to log. I see that I can watch MVB 104-1 along with other advanced measurement values. Unfortunately, I can't find anything NOx-related in the advanced measurement section in the engine controller. There are many lines in the picklist that are blank, so maybe this is using an incomplete label file. I found info indicating I should be looking in the Group 97-106 range but I would be grateful for any more specific info(whih I will of course continue to look for myself).Have you tried logging the NOx sensors to see if anything jumps out?
Thanks @Uwe , will proceed with fingers crossed.Provided it stays that way long enough to get to a smog-test station, I think you're good to go.
Friday,24,January,2025,16:33:07:29292
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUKJAFM2DA032998 License Plate:
Mileage: 160690km-99848mi Repair Order:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
72 77
VIN: WAUKJAFM2DA032998 Mileage: 160690km-99848miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 A HW: 03L 906 019 EJ
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number: AUX7Z0L7FN601G
Coding: 0050078
Shop #: WSC 42395 001 1048576
VCID: 2C01086DBA0C11AAD33-8078
VINID: 9D195B69159D0944400C224920A5628933
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required - Intermittent
Fault Frequency: 45
Mileage: 159595 km
Date: 2024.02.20
Time: 15:11:02
RPM: 828 /min
Pressure: 943.8 mbar
Temperature: 9.0°C
Mass Air / Rev.: 285.0 mg/str
Temperature: 14.4°C
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001207020171
Shop #: WSC 06314 000 00000
VCID: 1471B08D027CA96AEB3-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 1150400F492500FC881402ED92210042BF0C00
VCID: 7DA7F5291DF6482234D-8028
Reset counter: 75
Mileage: 159764 km
Date: 2024.03.02
Time: 17:03:36
Count: 3
Count: 15
Count: 4096
Count: 16390
Count: 34816
Count: 11008
Count: 253
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0180
Revision: 000195 Serial number: 8P0820043BM
VCID: 78A9E43D3ED46D0A67B-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 Q HW: 8P0 907 063 Q
Component: BCM PQ35 M 111 0719
Revision: AM111715
Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
VCID: 42DD46D52488F7DA09F-8016
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Reset counter: 74
Mileage: 159764 km
Date: 2024.03.02
Time: 17:18:00
Voltage: 7.80 V
Term 50 Off
Reset counter: 74
Mileage: 159764 km
Date: 2024.03.02
Time: 17:18:01
Voltage: 7.80 V
Term 50 Off
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7M0621430
Coding: 0000100
VCID: 36352A0574405B7AB57-8062
Reset counter: 20
Mileage: 158837 km
Date: 2024.01.22
Time: 18:02:13
01304 - Radio
Fault Frequency: 26
Reset counter: 46
Mileage: 160647 km
Date: 2025.01.24
Time: 13:37:22
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003FC001VJPK Dataset Number: 8P0909602N 0004
Coding: 303142393041303030374A55304C38503053
ROD: EV_Airba10AURB4_AU35.rod
VCID: 50F97C9DFA64154A8FB-8004
Subsystem 1 - Part No SW: 8P0 959 339 E HW: 8P0 959 339 E
Component: BF-Gewichtss. H04 0040
Serial number: 5850000R1271100A4S
Serial number: 3572DRB40000EBACB9BL
Serial number: 3582DRB40000EBD0B889
Serial number: 35128RB400006CA899E0
Serial number: 35228RB400006CA59AE%
Serial number: 35547RB400006CA22C7V
Serial number: 35647RB400006CA22C8X
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0014142
VCID: 46D55AC504A0CBFA257-8012
Component: E0221 H02 0100
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 983 L HW: 8P0 920 983 L
Component: KOMBIINSTR. VDO H03 0380
Revision: D0H03005 Serial number: 2247L005001963
Coding: 0272288
VCID: 43D343D13792FED2029-8016
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 190712F1001001
Coding: 352102
VCID: 3FDB4F21577A9A32661-806A
01304 - Radio
Reset counter: 20
Mileage: 158837 km
Date: 2024.01.22
Time: 18:02:07
Revision: D0H03005 Serial number: AUX7Z0L7FN601G
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0001181
VCID: 49CF51F915BE2482C85-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 232 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B2701734AA272AE1-8062
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158230628875
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0001181
VCID: 4ACD6EF510B82F9AC1F-801E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 120727-0002-066
Coding: 1163951010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD46D52408F7DA09F-8016
Address 56: Radio
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0001176
Shop #: WSC 06314 000 1012544
VCID: 42DD46D52888F7DA09F-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0001176
Part No SW: 8P1 862 336 A HW: 8P1 862 336
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005175360
Coding: 0001277
02503 - Output Wire to Radio
Reset counter: 20
Mileage: 158837 km
Date: 2024.01.22
Time: 18:01:04
01304 - Radio
Fault Frequency: 124
Reset counter: 46
Mileage: 158837 km
Date: 2024.01.22
Time: 18:01:04
End----------(Elapsed Time: 01:22, VBatt start/end: 13.5V/13.6V)-----------
Friday,24,January,2025,16:35:07:29292
Mileage: 160690km-99848mi Repair Order: OBD2
Mode 01 - PID 01 : Readiness -- Address 7E8
Number of DTCs stored: 0 -- MIL Status: MIL OFF
Misfire monitoring: Passed
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Passed
Heated catalyst monitoring: Passed
Evaporative system monitoring: Not installed.
Secondary air system monitoring: Passed
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Passed
Oxygen sensor heater monitoring: Passed
Exhaust Gas Recirculation: Passed
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Mode 07: Pending emission related fault codes
Readiness Status: 00000000 00001111 11101011 00000000
MIL Status: MIL OFF
Fuel System: Passed
Number of EOBD-related DTC(s): 0
Address 01: Engine (03L 997 030 A)
16:34:10 Group 104: Emissions re-treatment
0xFF01 Emissions re-treatment operation mode
0xFF21 Emissions re-treatment operation mode lowest stage
00000000 Bin. Bits
00000000 Bin. Bits
Nope. Go for it.With the smog check behind me is there any reason not to clear codes to see if the intermittent goes away?
Friday,24,January,2025,17:42:38:29292
Mileage: 160690km-99848mi Repair Order: ClesredCodesPostSmog
72 77
Coding: 0050078
Revision: 00H31001
Revision: AM111715
Coding: 00DD13
Coding: 0000100
Reset counter: 46
Mileage: 160690 km
Date: 2025.01.24
Time: 17:38:53
01304 - Radio
Reset counter: 46
Mileage: 160690 km
Date: 2025.01.24
Time: 17:38:48
Coding: 0014142
01304 - Radio
Coding: 0272288
Coding: 352102
01304 - Radio
Reset counter: 46
Mileage: 160690 km
Date: 2025.01.24
Time: 17:38:22
Coding: 0001181
Revision: 00H22000
Coding: 0001181
Address 56: Radio
Coding: 0001176
Coding: 0001176
Coding: 0001277
Reset counter: 46
Mileage: 160690 km
Date: 2025.01.24
Time: 17:39:25
01304 - Radio
Reset counter: 46
Mileage: 160690 km
Date: 2025.01.24
Time: 17:39:25
End----------(Elapsed Time: 01:22, VBatt start/end: 13.9V/13.6V)-----------
Readiness Status: 00000000 00011111 11101011 11101011
MIL Status: MIL OFF
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Misfire monitoring: Failed or Incomplete
Fuel System: Passed
Catalyst monitoring: Failed or Incomplete
Heated catalyst monitoring: Failed or Incomplete
Secondary air system monitoring: Failed or Incomplete
Oxygen sensor monitoring: Failed or Incomplete
Oxygen sensor heater monitoring: Failed or Incomplete
Now you see why I suggested not clearing DTCs before the smog check. With all those "Failed or Incomplete" Readiness bits, you would never have passed.OBD2 readiness and OBD2 03/07 codes for posterity.
Not just Readiness, but:after talking with the smog tech I realized that that is pretty much the test... plus a visual.
