- Nov 20, 2024
- 16
- 4
- Boulder Creek, CA, USA
- C?ID=535647
FYI since this is my first post here I'll say that I am not an auto tech but a longtime gearhead with most of my history involving carburetors, mechanical timing and injection. I have a very good understanding of closed-loop control systems and quite a bit of experience on the industrial side but less with OBD2 even less with VCDS. Learning... FWIW I have worked with Bosch CIS, L-Jet, K-Lambda, and a few more modern systems like MAP/MAF systems. Since my wife bought this A3(and named it Frau Blau) it is now incumbent upon me to learn the system so here I am.
I have been working this problem on and off since mid-November '24 due to various other priorities. It was around that time that the DPF icon appeared on the dash. We tried a couple of things, like running at high RPM for a half-hour freeway drive first without then with a DPF cleaning additive, to no apparent effect. As of right now all readiness bits are zeroed, so I believe the conditions for NOx regen have been achieved but I still have the icon and the DTC. More details follow, after I get to the JPPSG stuff:
1)
2) Car is stock AFAIK, I did pick around trying to enable all windows up/down via remote over a year ago but do not recall the specifics. Hope to circle back on that after the matter at hand.
3) Auto-Scan -- The last of a few scans I performed around the same time, performed one after the other with the car hot and idling. This is my most recent of all auto-scans. Two of these most recent scans I did following the instructions in this video to capture measuring values and adaptations in both pre-label file and hex mode so I can post any of that upon request.
4) No recent repairs, was last in shop for oil change back in April. There is apparently a leaky turbo seal on the inlet that is causing seepage around where the center housing meets the compressor housing, I doubt it is relevant but including in case I'm wrong -- it's the only actual problem I have observed with/around the engine.
5) No parts changes on powertrain since purchased ~26K miles ago
6) Recent low voltage/battery related issues shown in the scan due to my leaving things on while working inside one of the back doors on/around Dec 2. Since then charging system works and battery load tested good. Steering wheel/radio codes due to aftermarket radio install and reassignment of steering wheel controls some years back. These may be ignored AFAIK but as an aside would welcome help clearing the individual codes in a way that won't impact readiness.
Main issue at hand is DPF icon showing on dash, NOx/P1A58 code found in VCDS even after seeing readiness bits all zeroed. Unfortunately I did not capture this readiness state with VCDS first time around but having reset all DTCs and cleared all readiness bits again the DTC persists. On or about Nov. 23 I reset the DTC and it came right back with a new date in the freeze frame, that date being approx. 307 days prior to the current date. It did not register with me right away that it had changed, my mind read it as "a long time ago".
Many experiments later I realized that this was not the case, when the DTC is reset and reappears it shows this date stamp ~307 days in the past. However, I found that the instrument cluster clock was set to about 308 days in the past. So I set out to confirm that this caused the "way in the past" value. I tried running an auto-scan, then resetting the date via the cluster, then shut down the car/VCDS Hex and VCDS software down for 15 minutes, set it all up and ran another scan and the date is unchanged. My guess is it is stored as an absolute date, not a relative-to-today date. I am guessing that if I reset the DTC again with the clock set properly it should give a correct date, but I am reluctant to do so since I do not want to have to go through the long process of clearing readiness bits again. I want to consult with the experts here as to the best way forward from the current state. I suppose it is also possible that the ECU has its own clock that is just way off but it would be an odd coincidence that the cluster would be off by about the same amount.
FWIW, since trying to understand both VCDS and the system drive cycles we have driven and observed regen-like behavior, as in high temps up to ~750° between catalysts at times. All of the exhaust/catalyst temp readings seem sane, heating and cooling with load as expected, some up to ~450° some up to ~750°+ and I think I have seen over 800°. Apologies for the sparse data from early experiments, but IIRC we were getting very low soot readings. We were monitoring G100(Particle Filter Differential) and G108(oil ash volume ml) and we were seeing G100 numbers like 5mg at idle, up to 20mbar at high speed uphill where IIRC ~40 differential is problem territory, G108 is locked at 108. I now believe, after the fact, that the PA0158 is telling me it's NOT the DPF... but I wanted to share this info for whatever value it may have in confirming that.
For me the big question is, given where I am at based on the data given(and any further data which I am happy to provide if able) what line of investigation or what actions should I take to either:
* Perform a proper diagnosis of the DTC and DPF icon on the dash so I can perform a repair, thus clearing the DTC
* Clear the DTC properly in the event it is not an actual malfunction but a series of conditions I have not yet met.
This is the last readiness dump, performed after the last auto-scan that day(above):
1)
Sunday,19,January,2025,16:08:37:29292
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUKJAFM2DA032998 License Plate:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
72 77
VIN: WAUKJAFM2DA032998 Mileage: 160170km-99525miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.CLB
Part No SW: 03L 997 030 A HW: 03L 906 019 EJ
Component: R4 2.0l TDI G000AG 9983
Revision: 12H15--- Serial number: AUX7Z0L7FN601G
Coding: 0050078
Shop #: WSC 42395 001 1048576
VCID: 2C01086DBA0C11AAD33-8078
VINID: 9D195B69159D0944400C224920A5628933
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required
Fault Frequency: 43
Mileage: 159595 km
Date: 2024.02.20
Time: 15:11:02
RPM: 828 /min
Pressure: 943.8 mbar
Temperature: 9.0░C
Mass Air / Rev.: 285.0 mg/str
Temperature: 14.4░C
Address 02: Auto Trans Labels: 02E-927-770.CLB
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001207020171
Shop #: WSC 06314 000 00000
VCID: 1471B08D027CA96AEB3-8040
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.CLB
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 1150400F492500FC881402ED92210042BF0C00
VCID: 7DA7F5291DF6482234D-8028
Reset counter: 75
Mileage: 159764 km
Date: 2024.03.02
Time: 17:03:36
Count: 3
Count: 15
Count: 4096
Count: 16390
Count: 34816
Count: 11008
Count: 253
Address 08: Auto HVAC Labels: 8P0-820-043.LBL
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0180
Revision: 000195 Serial number: 8P0820043BM
VCID: 78A9E43D3ED46D0A67B-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.CLB
Part No SW: 8P0 907 063 Q HW: 8P0 907 063 Q
Component: BCM PQ35 M 111 0719
Revision: AM111715
Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
VCID: 42DD46D52488F7DA09F-8016
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Reset counter: 74
Mileage: 159764 km
Date: 2024.03.02
Time: 17:18:00
Voltage: 7.80 V
Term 50 Off
Reset counter: 74
Mileage: 159764 km
Date: 2024.03.02
Time: 17:18:01
Voltage: 7.80 V
Term 50 Off
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.LBL
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7M0621430
Coding: 0000100
VCID: 36352A0574405B7AB57-8062
Reset counter: 20
Mileage: 158837 km
Date: 2024.01.22
Time: 18:02:13
01304 - Radio
Fault Frequency: 23
Mileage: 160169 km
Date: 2024.03.19
Time: 13:48:24
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003FC001VJPK Dataset Number: 8P0909602N 0004
Coding: 303142393041303030374A55304C38503053
ROD: EV_Airba10AURB4_AU35.rod
VCID: 50F97C9DFA64154A8FB-8004
Subsystem 1 - Part No SW: 8P0 959 339 E HW: 8P0 959 339 E
Component: BF-Gewichtss. H04 0040
Serial number: 5850000R1271100A4S
Serial number: 3572DRB40000EBACB9BL
Serial number: 3582DRB40000EBD0B889
Serial number: 35128RB400006CA899E0
Serial number: 35228RB400006CA59AE%
Serial number: 35547RB400006CA22C7V
Serial number: 35647RB400006CA22C8X
Address 16: Steering wheel Labels: 8P0-953-549.LBL
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0014142
VCID: 46D55AC504A0CBFA257-8012
Component: E0221 H02 0100
01304 - Radio
Address 17: Instruments Labels: 8P0-920-XXX-17-MY8.CLB
Part No SW: 8P0 920 983 L HW: 8P0 920 983 L
Component: KOMBIINSTR. VDO H03 0380
Revision: D0H03005 Serial number: 2247L005001963
Coding: 0272288
VCID: 43D343D13792FED2029-8016
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.CLB
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 190712F1001001
Coding: 352102
VCID: 3FDB4F21577A9A32661-806A
01304 - Radio
Reset counter: 20
Mileage: 158837 km
Date: 2024.01.22
Time: 18:02:07
Address 25: Immobilizer Labels: 1K0-920-XXX-25.CLB
Revision: D0H03005 Serial number: AUX7Z0L7FN601G
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.LBL
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0001181
VCID: 49CF51F915BE2482C85-801C
Address 44: Steering Assist Labels: 1K0-909-14X-GEN3.CLB
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 232 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B2701734AA272AE1-8062
Address 47: Sound System Labels: 8PX-035-382.LBL
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158230628875
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.CLB
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0001181
VCID: 4ACD6EF510B82F9AC1F-801E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 120727-0002-066
Coding: 1163951010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD46D52408F7DA09F-8016
Address 56: Radio
Address 62: Door, Rear Left Labels: 8P4-959-801.LBL
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0001176
Shop #: WSC 06314 000 1012544
VCID: 42DD46D52888F7DA09F-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.LBL
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0001176
Address 77: Telephone Labels: 8P0-862-335.LBL
Part No SW: 8P1 862 336 A HW: 8P1 862 336
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005175360
Coding: 0001277
02503 - Output Wire to Radio
Reset counter: 20
Mileage: 158837 km
Date: 2024.01.22
Time: 18:01:04
01304 - Radio
Fault Frequency: 101
Reset counter: 41
Mileage: 158837 km
Date: 2024.01.22
Time: 18:01:04
End----------(Elapsed Time: 46:12, VBatt start/end: 13.8V/13.8V)-----------
Sunday,19,January,2025,16:18:52:29292
VIN: WAUKJAFM2DA032998 License Plate: 1
Mileage: 160170km-99525mi Repair Order:
Readiness Status: 00000000 00001111 11101011 00000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Passed
Number of EOBD-related DTC(s): 0
