- Jan 7, 2025
- 15
- 3
- Torrance, CA, USA
- C?ID=602589
Great idea. Voila!Last idea from my side, is auto-trans having cooling lines to front rad? If so, blockmap from 02 needed.
;SW:8R0-927-158-Q HW:0BK-927-156-AM --- Auto Trans
;Component:0BK 30 TDIUSA H19 1007, Coding:000001
;EV_TCMAL551211,002022,EV_TCMAL551211_002_AU48.rod
;Wednesday,22,January,2025,17:21:54:13347
;VCDS Version: Release 24.7.1 (x64) Data version: 20240919 DS356.3
;VCID: 4BC4BFD9D3465262FA9-801E
Group,Description,Actual
IDE00018,Voltage terminal 15,14.6, V
IDE00019,Voltage terminal 30,14.429, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,701, /min
IDE00022,Transmission input speed,670.00, /min
IDE00023,Transmission output speed,0.00, /min
IDE00024,ATF temperature,29, °C
IDE00025,Coolant temperature,36, °C
IDE00026,Vehicle speed from transmission,0.00, km/h
IDE00026,Vehicle speed from transmission,valid,
IDE00027-MAS00179,Status of brake signals-Brake lamp switch,Not operated,
IDE00027-MAS00180,Status of brake signals-Brake pressure switch,Not operated,
IDE00027-MAS00181,Status of brake signals-Validity of brake pressure information,valid,
IDE00027-MAS00182,Status of brake signals-Validity of brake pedal information,valid,
IDE00028,Driving resistance index,-7,
IDE00031,Torque transmitting function,valid,
IDE00031,Torque transmitting function,0.0,
IDE00085,Normed load value,27.1, %
IDE00086,Accelerator pedal position,14.9, %
IDE00087-MAS00115,Tiptronic status-Tiptronic gate,not active,
IDE00087-MAS00116,Tiptronic status-Tiptronic +,not active,
IDE00087-MAS00117,Tiptronic status-Tiptronic -,not active,
IDE00087-MAS00118,Tiptronic status-Tiptronic steering wheel +,not active,
IDE00087-MAS00119,Tiptronic status-Tiptronic steering wheel -,not active,
IDE00088-MAS00120,Status of vehicle condition influence-Traction control system,not active,
IDE00088-MAS00121,Status of vehicle condition influence-Electronic Differential Lock,Not available,
IDE00088-MAS00122,Status of vehicle condition influence-Electronic Stability Program,not active,
IDE00088-MAS00123,Status of vehicle condition influence-Engine torque towing regulation,Not available,
IDE00088-MAS00125,Status of vehicle condition influence-Cruise control system,Not available,
IDE00088-MAS00126,Status of vehicle condition influence-Kickdown,not active,
IDE00088-MAS00127,Status of vehicle condition influence-brakes,not active,
IDE00089,Driving position,P,
IDE00090,selected gear,without traction,
IDE00091,Status of starter lock,OFF,
IDE00094,Kick-down status,not active,
IDE00095,Status of selector lever lock,active,
IDE00096,Selector lever position,Automatic 2,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00098,Transmission position,P,
IDE00099-MAS00172,Driving mode sensor-Hall sensor A,not active,
IDE00099-MAS00173,Driving mode sensor-Hall sensor B,not active,
IDE00099-MAS00174,Driving mode sensor-Hall sensor C,active,
IDE00099-MAS00175,Driving mode sensor-Hall sensor D,not active,
IDE00100,Engine torque,-9, Nm
IDE00101,Engine specified torque during transmission intervention,-9, Nm
IDE00102,Control Module temperature,28, °C
IDE00109,Selector lever maximum pulse width High,3.925, ms
IDE00110,Selector lever minimum pulse width High,3.924, ms
IDE00111,Selector lever maximum pulse width Low,35.194, ms
IDE00112,Selector lever minimum pulse width Low,35.187, ms
IDE00138,Total driving time,1494.75, H
IDE00139,Economical driving time portion,98.0, %
IDE00140,Sport driving time portion,0.0, %
IDE00141,Manual driving time portion,2.0, %
IDE00540,Dynamic shift program,1,
IDE00541,Acceleration,0.0, 1/s²
IDE00542,Excessive temperature protection,0,
IDE00543,Deceleration mode / acceleration mode,Coasting,
IDE00544,Factor torque,Factor 1,
IDE00545,maximum permissible engine torque,767, Nm
IDE00546,Voltage supply of regulator valves,14.376, V
IDE00547,Torque converter amplification,0.99,
IDE00548,Converter clutch slip,30, /min
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00820,Activating and deactivating all development messages,not active,
IDE00915-MAS01183,Ambient conditions at heat shut-off-Transmission fluid temperature at heat shut-off,28, °C
IDE00915-MAS01184,Ambient conditions at heat shut-off-Control Module temperature at heat shut-off,28, °C
IDE00915-MAS01185,Ambient conditions at heat shut-off-Status of temperature sensors,0,
IDE00915-MAS01186,Ambient conditions at heat shut-off-Shut-off temperature,145, °C
IDE00920,Front left wheel speed,0.0, km/h
IDE00920,Front left wheel speed,valid,
IDE00921,Wheel speed: right front,0.0, km/h
IDE00921,Wheel speed: right front,valid,
IDE00922,Left rear wheel speed,valid,
IDE00922,Left rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,0.0, km/h
IDE00923,Right rear wheel speed,valid,
IDE01761,Route data,not active,
IDE02583,Steering wheel Tiptronic switch,active,
IDE03008-MAS03911,Stop process prevented-Oil temperature too low,not active,
IDE03008-MAS03912,Stop process prevented-Oil temperature too high,not active,
IDE03008-MAS03913,Stop process prevented-Adaptation procedure active,not active,
IDE03008-MAS03914,Stop process prevented-Pressure reservoir filling not completed,not active,
IDE03008-MAS03915,Stop process prevented-Gear 1 or 2 not engaged,not active,
IDE03009-MAS03917,Start process requested-Driver's request,not active,
IDE03010-MAS03911,Number of prevented stop processes-Oil temperature too low,2,
IDE03010-MAS03912,Number of prevented stop processes-Oil temperature too high,0,
IDE03010-MAS03913,Number of prevented stop processes-Adaptation procedure active,0,
IDE03010-MAS03914,Number of prevented stop processes-Pressure reservoir filling not completed,0,
IDE03010-MAS03915,Number of prevented stop processes-Gear 1 or 2 not engaged,0,
IDE03011-MAS03917,Number of requested start processes-Driver's request,0,
IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Oil temperature too low,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2022,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,3,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,18,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,7,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,37,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,11,
IDE03128-IDE03009,Requested start processes (ring memory)-Start process requested,Measuring value not available,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE04111,Individual gear display,D off/S off,
IDE04347-ENG102069,Expanded freeze frame conditions-Accelerator Pedal Position D,15.2, %
IDE04347-ENG159500,Expanded freeze frame conditions-ASR,not active,
IDE04347-ENG99470,Expanded freeze frame conditions-Automatic transmission input speed,0.00, /min
IDE04347-ENG100451,Expanded freeze frame conditions-Automatic transmission output speed,0.00, /min
IDE04347-ENG101851,Expanded freeze frame conditions-Automatic Transmission shift position,P,
IDE04347-ENG101095,Expanded freeze frame conditions-B008_Average Wheel Speed / Drive Shaft,0, km/h
IDE04347-ENG159357,Expanded freeze frame conditions-Brake,fault,
IDE04347-ENG101831,Expanded freeze frame conditions-C0010_Current Regulator No. 9,0.0, mA
IDE04347-ENG101867,Expanded freeze frame conditions-C009_Current Regulator No. 8,0.0, mA
IDE04347-ENG103274,Expanded freeze frame conditions-CCS,fault,
IDE04347-ENG102274,Expanded freeze frame conditions-Control Module Voltage,11.986, V
IDE04347-ENG101834,Expanded freeze frame conditions-Current N215 Pressure control valve 1,305.2, mA
IDE04347-ENG99930,Expanded freeze frame conditions-Current N216 pressure reg.valve 2,323.2, mA
IDE04347-ENG102208,Expanded freeze frame conditions-Current N217 pressure reg.valve 3,50.0, mA
IDE04347-ENG100408,Expanded freeze frame conditions-Current N218 pressure reg.valve 4,50.0, mA
IDE04347-ENG101543,Expanded freeze frame conditions-Current N233 pressure reg.valve 5,50.0, mA
IDE04347-ENG101463,Expanded freeze frame conditions-Current N371 pressure reg. valve 6 lock-up clutch,50.0, mA
IDE04347-ENG101716,Expanded freeze frame conditions-Current N443 pressure reg.valve 7 main pressure,50.0, mA
IDE04347-ENG102805,Expanded freeze frame conditions-Current solenoid,1000.0, mA
IDE04347-ENG98504,Expanded freeze frame conditions-Day,31,
IDE04347-ENG102053,Expanded freeze frame conditions-Desired State Solenoid Out 10,OFF,
IDE04347-ENG104161,Expanded freeze frame conditions-Desired State Solenoid Out 11,OFF,
IDE04347-ENG99231,Expanded freeze frame conditions-Desired State Solenoid Out 12,OFF,
IDE04347-ENG99490,Expanded freeze frame conditions-Desired State Solenoid Out 13,OFF,
IDE04347-ENG100651,Expanded freeze frame conditions-Desired State Solenoid Out 14,On,
IDE04347-ENG99228,Expanded freeze frame conditions-Diagnostic Fault Check Code,00 00 31 0A,
IDE04347-ENG159444,Expanded freeze frame conditions-EDL,Not available,
IDE04347-ENG99543,Expanded freeze frame conditions-Engine RPM,0, /min
IDE04347-ENG98585,Expanded freeze frame conditions-Engine torque,-76, Nm
IDE04347-ENG98546,Expanded freeze frame conditions-ESP,not active,
IDE04347-ENG100105,Expanded freeze frame conditions-F011_TCM_Torque_Engagement,0, Nm
IDE04347-ENG102638,Expanded freeze frame conditions-F012_State_TCM_Torque_Engagement,no requirement,
IDE04347-ENG100740,Expanded freeze frame conditions-F013_TCM_Long-term_Engine_Torque_Engagement,150, Nm
IDE04347-ENG103123,Expanded freeze frame conditions-F014_State_TCM_Torque_Engagement,State of Long-term Engine Torque Engagement - enabled,
IDE04347-ENG101750,Expanded freeze frame conditions-G001_TCM Chip Temperature,12, °C
IDE04347-ENG159321,Expanded freeze frame conditions-Hallsensor A,not active,
IDE04347-ENG159322,Expanded freeze frame conditions-Hallsensor B,not active,
IDE04347-ENG159325,Expanded freeze frame conditions-Hallsensor C,active,
IDE04347-ENG159323,Expanded freeze frame conditions-Hallsensor D,not active,
IDE04347-ENG98653,Expanded freeze frame conditions-Hour,9,
IDE04347-ENG99396,Expanded freeze frame conditions-internal error code,154,
IDE04347-ENG99127,Expanded freeze frame conditions-internal error type,0,
IDE04347-ENG159326,Expanded freeze frame conditions-Kickdown,fault,
IDE04347-ENG102357,Expanded freeze frame conditions-M014_Time Since Shift,7650, ms
IDE04347-ENG103371,Expanded freeze frame conditions-M015_Time Normal Mode,50, s
IDE04347-ENG100237,Expanded freeze frame conditions-M018_Time In Afterrun,0, s
IDE04347-ENG104072,Expanded freeze frame conditions-M019_Time Since Reset,7650, ms
IDE04347-ENG103130,Expanded freeze frame conditions-M021_KM Mileage,213287,
IDE04347-ENG98739,Expanded freeze frame conditions-Minute,57,
IDE04347-ENG98748,Expanded freeze frame conditions-Month,5,
IDE04347-ENG159517,Expanded freeze frame conditions-MSR,Not available,
IDE04347-ENG103297,Expanded freeze frame conditions-OK Byte - Snapshot valid,invalid,
IDE04347-ENG102101,Expanded freeze frame conditions-PIN In0,low,
IDE04347-ENG100393,Expanded freeze frame conditions-PIN In1,low,
IDE04347-ENG101177,Expanded freeze frame conditions-PIN In2,low,
IDE04347-ENG103794,Expanded freeze frame conditions-PIN In3,low,
IDE04347-ENG99856,Expanded freeze frame conditions-PIN KL15,high,
IDE04347-ENG98884,Expanded freeze frame conditions-Seconds,50,
IDE04347-ENG98903,Expanded freeze frame conditions-selected gear,without traction,
IDE04347-ENG101658,Expanded freeze frame conditions-Shift Type / Mode,30,
IDE04347-ENG102114,Expanded freeze frame conditions-State ATF Temperature Sensor,OK,
IDE04347-ENG104115,Expanded freeze frame conditions-State Brake Signal,not OK.,
IDE04347-ENG100649,Expanded freeze frame conditions-State Chip Temperature Sensor,OK,
IDE04347-ENG103681,Expanded freeze frame conditions-State Driving Direction,OK,
IDE04347-ENG103922,Expanded freeze frame conditions-State Engine Speed,not OK.,
IDE04347-ENG99717,Expanded freeze frame conditions-State Output Shaft Speed,OK,
IDE04347-ENG101631,Expanded freeze frame conditions-State Pedal,not OK.,
IDE04347-ENG101699,Expanded freeze frame conditions-State Plausibility Tolerance,wide,
IDE04347-ENG100193,Expanded freeze frame conditions-State Position Switch,OK,
IDE04347-ENG100953,Expanded freeze frame conditions-State Torque 1,OK,
IDE04347-ENG102844,Expanded freeze frame conditions-State Turbin Speed,OK,
IDE04347-ENG100622,Expanded freeze frame conditions-State Wheel Speed Front Left,OK,
IDE04347-ENG103645,Expanded freeze frame conditions-State Wheel Speed Front Right,OK,
IDE04347-ENG103415,Expanded freeze frame conditions-State Wheel Speed Rear Left,OK,
IDE04347-ENG100555,Expanded freeze frame conditions-State Wheel Speed Rear Right,OK,
IDE04347-ENG101226,Expanded freeze frame conditions-Status Terminal 15,On,
IDE04347-ENG159479,Expanded freeze frame conditions-Tiptronic Manual Position,not active,
IDE04347-ENG159436,Expanded freeze frame conditions-Tiptronic Minus,not active,
IDE04347-ENG159355,Expanded freeze frame conditions-Tiptronic Plus,not active,
IDE04347-ENG159542,Expanded freeze frame conditions-Tiptronik Paddle Minus,not active,
IDE04347-ENG159503,Expanded freeze frame conditions-Tiptronik Paddle Plus,not active,
IDE04347-ENG102661,Expanded freeze frame conditions-Torque Converter Lockup Clutch,Open,
IDE04347-ENG103353,Expanded freeze frame conditions-Traction/Coasting Flag,Coasting,
IDE04347-ENG98981,Expanded freeze frame conditions-Transmission fluid temperature,13, °C
IDE04347-ENG99034,Expanded freeze frame conditions-Voltage terminal 15,12.1, V
IDE04347-ENG99063,Expanded freeze frame conditions-Year,2020,
IDE04814,Transmission oil cooler valve,Open,
IDE05965,Driving time slice efficient,0.0, %
IDE06873,Forced upshift,active,
IDE06874,Neutral Idle Control (NIC),D on/S off,
IDE07063,Start/Stop Function present,activated by motor,
IDE07220,Fast adaptation: cancellation condition,Do not cancel,
IDE07437,Fill pressure: clutch A,20, mbar
IDE07438,Adaptation counter: clutch A,38,
IDE07439,Fast fill time: clutch A,-2, ms
IDE07440,Adaptation counter: fast fill time: clutch A,37,
IDE07441,Fill pressure: clutch B,60, mbar
IDE07442,Adaptation counter: clutch B,255,
IDE07443,Fast fill time: clutch B,-22, ms
IDE07444,Adaptation counter: fast fill time: clutch B,28,
IDE07445,Fill pressure: clutch C,-10, mbar
IDE07446,Adaptation counter: clutch C,54,
IDE07447,Fast fill time: clutch C,-18, ms
IDE07448,Adaptation counter: fast fill time: clutch C,53,
IDE07449,Fill pressure: clutch D,0, mbar
IDE07450,Adaptation counter: clutch D,29,
IDE07451,Fast fill time: clutch D,-10, ms
IDE07452,Adaptation counter: fast fill time: clutch D,28,
IDE07453,Fill pressure: clutch E,0, mbar
IDE07454,Adaptation counter: clutch E,50,
IDE07455,Fast fill time: clutch E,4, ms
IDE07456,Adaptation counter: fast fill time: clutch E,50,
IDE07675,Clutch B: number of adaptations,100,
IDE07676,Fill pressure clutch B during park decoupling,-250, mbar
IDE80002,Analysis 2,20, mbar
IDE80003,Analysis 3,38,
IDE80004,Analysis 4,-2, ms
IDE80005,Analysis 5,37,
IDE80006,Analysis 6,60, mbar
IDE80007,Analysis 7,255,
IDE80008,Analysis 8,-22, ms
IDE80009,Analysis 9,28,
IDE80010,Analysis 10,-10, mbar
IDE80011,Analysis 11,54,
IDE80012,Analysis 12,-18, ms
IDE80013,Analysis 13,53,
IDE80014,Analysis 14,0, mbar
IDE80015,Analysis 15,29,
IDE80016,Analysis 16,-10, ms
IDE80017,Analysis 17,28,
IDE80018,Analysis 18,0, mbar
IDE80019,Analysis 19,50,
IDE80020,Analysis 20,4, ms
IDE80021,Analysis 21,50,
ENG133554,Adaption_counter_PF_Lockup_clutch,0,
ENG133552,Adaption_counter_TSF_Lockup_clutch,0,
ENG133553-ENG98502,Adaption_inflation_current_PF_Lockup_clutch-Data,0, mA
ENG133551-ENG98502,Adaption_inflation_time_TSF_Lockup_clutch-Data,0.0, ms
ENG101095,B008_Average Wheel Speed / Drive Shaft,0, km/h
ENG105330,Bitfield for ROM Checksumerror,0,
ENG101867,C009_Current Regulator No. 8,0.0, mA
ENG105392,C010_Current Regulator No. 9,0.0, mA
ENG101413,Calibration Identifications,8R0158Q 100721 ,
ENG99697,Calibration Verification Numbers,65 36 8D FB,
ENG101834,Current N215 Pressure control valve 1,850.0, mA
ENG99930,Current N216 pressure reg.valve 2,274.1, mA
ENG102208,Current N217 pressure reg.valve 3,50.0, mA
ENG100408,Current N218 pressure reg.valve 4,50.0, mA
ENG101543,Current N233 pressure reg.valve 5,50.0, mA
ENG101463,Current N371 pressure reg. valve 6 lock-up clutch,50.0, mA
ENG101716,Current N443 pressure reg.valve 7 main pressure,735.6, mA
ENG102805,Current solenoid,1000.0, mA
ENG100152-ENG104003,ECUNAME-ECU,TCM,
ENG100152,ECUNAME,TransmisCtrl,
ENG106375,Exceptionnumber,00 00,
ENG106454,F004_Engine Friction / Auxillary_Losses,57, Nm
ENG106456,F005_Flywheel_Torque_Modified,48, Nm
ENG106457,F006_Flywheel_Torque,47, Nm
ENG106460,F007_Inexact Torque Values Over CAN,OK,
ENG106461,F008_Flywheel_Torque_Modified_Engine_Friction/Auxillary_Losses,-9, Nm
ENG106463,F009_Estimated_Flywheel_Torque,48, Nm
ENG106465,F010_Estimated_Flywheel_Torque,-9, Nm
ENG100105,F011_TCM_Torque_Engagement,-9, Nm
ENG102638,F012_State_TCM_Torque_Engagement,no requirement,
ENG100740,F013_TCM_Long-term_Engine_Torque_Engagement,767, Nm
ENG103123,F014_State_TCM_Torque_Engagement,State of Long-term Engine Torque Engagement - enabled,
ENG106470,F015_TCM_Drag_Torque,2, Nm
ENG106472,F016_TCM_Torque_Gradient_Limitation,2550, Nm/s
ENG106956-ENG101182,Immobilizer Snapshot 1-Param 0,00,
ENG106956-ENG101662,Immobilizer Snapshot 1-Param 1,00,
ENG106956-ENG100599,Immobilizer Snapshot 1-Param 2,00,
ENG106956-ENG102408,Immobilizer Snapshot 1-Param 3,00,
ENG106956-ENG99631,Immobilizer Snapshot 1-Param 4,00,
ENG106956-ENG104237,Immobilizer Snapshot 1-Param 5,00,
ENG106957-ENG101182,Immobilizer Snapshot 2-Param 0,00,
ENG106957-ENG101662,Immobilizer Snapshot 2-Param 1,00,
ENG106957-ENG100599,Immobilizer Snapshot 2-Param 2,00,
ENG106957-ENG102408,Immobilizer Snapshot 2-Param 3,00,
ENG106957-ENG99631,Immobilizer Snapshot 2-Param 4,00,
ENG106957-ENG104237,Immobilizer Snapshot 2-Param 5,00,
ENG107149,K004_Adaptive Mode,1,
ENG107153,K005_ID Of Current Driving Program,0,
ENG107154,K006_Current Type Of Driver Counter,0,
ENG107156,K007_ID Of the Active Up-shift Prevention,00 08,
ENG107158,K008_ID Of The Active Down-shift Prevention,00 00,
ENG107331-ENG101735,L001_Engine Coding Information-Emission Type,no EOBD: OBD (US),
ENG107331-ENG98541,L001_Engine Coding Information-Engine code,58,
ENG107331-ENG98980,L001_Engine Coding Information-Transmission code,AL551,
ENG106453,Losses lock-up clutch,2, Nm
ENG100291-ENG101658,M008_Torque Converter Lockup Clutch State-Shift Type / Mode,30,
ENG100291-ENG102661,M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch,Open,
ENG100291-ENG103353,M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag,Coasting,
ENG102568-ENG102114,M010_Signal State (TCM)-State ATF Temperature Sensor,OK,
ENG102568-ENG100649,M010_Signal State (TCM)-State Chip Temperature Sensor,OK,
ENG102568-ENG99717,M010_Signal State (TCM)-State Output Shaft Speed,OK,
ENG102568-ENG101699,M010_Signal State (TCM)-State Plausibility Tolerance,wide,
ENG102568-ENG100193,M010_Signal State (TCM)-State Position Switch,OK,
ENG102568-ENG102844,M010_Signal State (TCM)-State Turbin Speed,OK,
ENG102679-ENG103922,M011_Signal State Sig1 (ECU)-State Engine Speed,OK,
ENG102679-ENG101631,M011_Signal State Sig1 (ECU)-State Pedal,OK,
ENG102679-ENG100953,M011_Signal State Sig1 (ECU)-State Torque 1,OK,
ENG104023-ENG104115,M012_Signal State CAN (Brake/Direction)-State Brake Signal,OK,
ENG104023-ENG103681,M012_Signal State CAN (Brake/Direction)-State Driving Direction,OK,
ENG104023-ENG100622,M012_Signal State CAN (Brake/Direction)-State Wheel Speed Front Left,OK,
ENG104023-ENG103645,M012_Signal State CAN (Brake/Direction)-State Wheel Speed Front Right,OK,
ENG104023-ENG103415,M012_Signal State CAN (Brake/Direction)-State Wheel Speed Rear Left,OK,
ENG104023-ENG100555,M012_Signal State CAN (Brake/Direction)-State Wheel Speed Rear Right,OK,
ENG99597-ENG102101,M013_Switch-PIN In0,low,
ENG99597-ENG100393,M013_Switch-PIN In1,low,
ENG99597-ENG101177,M013_Switch-PIN In2,low,
ENG99597-ENG103794,M013_Switch-PIN In3,low,
ENG99597-ENG99856,M013_Switch-PIN KL15,high,
ENG102357,M014_Time Since Shift,7650, ms
ENG103371,M015_Time Normal Mode,206, s
ENG107503,M016_Faultcode + Faulttype Error Memory,00 00 00 00,
ENG107504,M017_Faultcode + Faulttype Backup Memory,00 9A 00 00,
ENG100237,M018_Time In Afterrun,0, s
ENG104072,M019_Time Since Reset,7650, ms
ENG102788-MAS00106,M020_Time Stamp-Year,2025,
ENG102788-MAS00107,M020_Time Stamp-Month,1,
ENG102788-MAS00108,M020_Time Stamp-Day,22,
ENG102788-MAS00109,M020_Time Stamp-Hours,17,
ENG102788-MAS00110,M020_Time Stamp-Minutes,22,
ENG102788-MAS00111,M020_Time Stamp-Seconds,11,
ENG103130-MAS00711,M021_KM Mileage-Odometer reading,241926,
ENG106726,Maximum chip temperature,95, °C
ENG107619,Microcontroller Error Enviromentcondition 1,0,
ENG107620,Microcontroller Error Enviromentcondition 2,00 00 00 00,
ENG108153,Paramter Exception Handler,00 00 00 00,
ENG108362-ENG102813,Q001_OBD Cycle And MIL State-Driving Cycle,active,
ENG108362-ENG98734,Q001_OBD Cycle And MIL State-mil,not active,
ENG108362-ENG99968,Q001_OBD Cycle And MIL State-WarmUp Cycle,not active,
ENG98909-ENG101182,Snapshot-Param 0,Series,
ENG98909-ENG101662,Snapshot-Param 1,0,
ENG98909-ENG100599,Snapshot-Param 2,0,
ENG98909-ENG102408,Snapshot-Param 3,0,
ENG98909-ENG99631,Snapshot-Param 4,0,
ENG98909-ENG104237,Snapshot-Param 5,0,
ENG98909-ENG102909,Snapshot-Param 6,0,
ENG98909-ENG103945,Snapshot-Param 7,0,
ENG98909-ENG100242,Snapshot-Param 8,212,
ENG98909-ENG102600,Snapshot-Param 9,0,
ENG107495-ENG99379,Status data bus communication diagnostic interface-State Deashboard received,received,
ENG107495-ENG101987,Status data bus communication diagnostic interface-State ECM received,received,
ENG107495-ENG102056,Status data bus communication diagnostic interface-State ESP received,received,
ENG107495-ENG103751,Status data bus communication diagnostic interface-State Gateway received,received,
ENG107495-ENG104211,Status data bus communication diagnostic interface-State Parking Brake received,received,
ENG107495-ENG101883,Status data bus communication diagnostic interface-State Steering Angle received,received,
ENG107495-ENG102283,Status data bus communication diagnostic interface-State Steering Assist received,received,
ENG103216-ENG102053,Status electric parking lock holder solenoid-Desired State Solenoid Out 10,On,
ENG103216-ENG104161,Status electric parking lock holder solenoid-Desired State Solenoid Out 11,OFF,
ENG103216-ENG99231,Status electric parking lock holder solenoid-Desired State Solenoid Out 12,OFF,
ENG103216-ENG99490,Status electric parking lock holder solenoid-Desired State Solenoid Out 13,OFF,
ENG103216-ENG100651,Status electric parking lock holder solenoid-Desired State Solenoid Out 14,OFF,
ENG107872,System Supplier Boot Software Identification (BB),bhjd0701,
ENG107872-ENG100456,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (BC),b1dc1323,
ENG107872-ENG113110,System Supplier Boot Software Identification (BB)-System Supplier Boot Software Identification (SB),bhie0101,
ENG107872-ENG100638,System Supplier Boot Software Identification (BB)-System Supplier ECU Identification,1034420222 ,
ENG107872-ENG101391,System Supplier Boot Software Identification (BB)-System Supplier HW Identification,production,
ENG107872-ENG101224,System Supplier Boot Software Identification (BB)-System Supplier HW Version,32,
ENG107872-ENG103844,System Supplier Boot Software Identification (BB)-System Supplier Manufacturer Number,0377,
ENG107872-ENG99833,System Supplier Boot Software Identification (BB)-System Supplier Modification Index 1,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG107872-ENG101511,System Supplier Boot Software Identification (BB)-System Supplier Modification Index 2,„—,
ENG107872-ENG100387,System Supplier Boot Software Identification (BB)-System Supplier Production Date,28.01.15,
ENG107872-ENG103393,System Supplier Boot Software Identification (BB)-System Supplier Production Identification,ZFS-005,
ENG107872-ENG99218,System Supplier Boot Software Identification (BB)-System Supplier Serial Number Gearbox,4640456,
ENG107872-ENG101400,System Supplier Boot Software Identification (BB)-System Supplier Serial Number Mechatronics,4273307,
ENG107872-ENG102956,System Supplier Boot Software Identification (BB)-System Supplier Software Version,1007,
ENG107872-ENG100713,System Supplier Boot Software Identification (BB)-System Supplier SW Checksum,CE 3F CD 82 37 EB EB 2E,
ENG107872-ENG100221,System Supplier Boot Software Identification (BB)-System Supplier SW Identification,ZFWX8P521007,
ENG107872-ENG103167,System Supplier Boot Software Identification (BB)-System Supplier Test Stand Number,5120,
ENG105260,Transfer speed by dash panel insert,valid,
ENG105260,Transfer speed by dash panel insert,0.00, km/h
ENG105259,Transfer speed from ESP,0.00, km/h
ENG105259,Transfer speed from ESP,valid,
ENG110105,Watchdog Error Enviromentcondition 1,00 00,
ENG110106,Watchdog Error Enviromentcondition 2,00 00,
Elapsed Time: 00:18
It is strange that it the pressure is at 0... Yeah, even though the other vehicle's blockmap had it the same way and apparently didn't have the fans on at cold startup, this is something to look into. Thank you.Might wanna investigate more that refrigerant pressure being at 0. I know that other cars whenever they have issues with coolant temp sensor (no reading) will turn the fans on the highest setting. A long shot, just an idea...
