;SW:8K5-907-401-AC HW:4G0-907-401-E --- Engine
;Component:3.0TDI FSA H14 0010, Coding:2A2A4012053603050000
;EV_ECM30TDI0118K5907401AC,002010,EV_ECM30TDI0118K5907401AC_002.rod
;Wednesday,22,January,2025,17:20:47:13347
;VCDS Version: Release 24.7.1 (x64) Data version: 20240919 DS356.3
;VCID: 71B80D31912A58B2A05-8024
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WA1CMAFP0FA096740,
IDE00019,Voltage terminal 30,14.180, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine RPM,699, /min
IDE00022,Transmission input speed,668.0, /min
IDE00025,Coolant temperature,33, °C
IDE00078,Time since engine start,123, s
IDE00083,Throttle valve position (absolute),82.4, %
IDE00085,Normed load value,31.4, %
IDE00086,Accelerator pedal position,14.9, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,55.1, Nm
IDE00102,Control Module temperature,30.3, °C
IDE00151,Oil fill level,46.512, mm
IDE00152,Oil warning threshold,33.588, mm
IDE00167,Exhaust temperature 1 bank 1,61.4, °C
IDE00169,Exhaust temperature 2 bank 1,22.4, °C
IDE00172,A/C compressor torque,25.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00182,Camshaft adaptation intake bank 1: phase position,-3.89, °
IDE00188,Fuel high-pressure: actual value,249700, hPa
IDE00190,Charge air pressure: specified value,1000, hPa
IDE00191,Charge air pressure: actual value,1010, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,20.8, °C
IDE00194,Coolant temperature at radiator output: specified value,90.0, °C
IDE00196,Engine oil temperature,31.3, °C
IDE00201,High fuel pressure: specified value,250000, hPa
IDE00304,Fuel level,75.00, l
IDE00323,Security Access: Number of invalid keys,1,
IDE00347,Air mass: actual value:,10.94, g/s
IDE00348,Intake air temperature,19, °C
IDE00349,Throttle valve position: normed,97.6, %
IDE00350,Air mass: specified value,285.0, mg/stroke
IDE00351,Main injection: start of activation,1.98, °
IDE00352,Main injection: duration of activation,0.0, µs
IDE00353,Engine start: start quantity,24.25, mg/stroke
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,44,
IDE00356-ENG188621,Cruise Control System (CCS): switch position-Bits 0-7,129,
IDE00357,Fuel temperature,21.1, °C
IDE00358,Limitation: torque,184.2, Nm
IDE00359,Limitation: smoke,183.2, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,1013, hPa
IDE00362,Charge Pressure Actuator: activation,99.62, %
IDE00363-ENG188621,Glow status-Bits 0-7,0,
IDE00363-ENG188621,Glow status-Bits 0-7,255,
IDE00365,Injection quantity deviation cylinder 1,-0.02, mg/stroke
IDE00366,Injection quantity deviation cylinder 2,-0.06, mg/stroke
IDE00367,Injection quantity deviation cylinder 3,0.10, mg/stroke
IDE00368,Injection quantity deviation cylinder 4,0.22, mg/stroke
IDE00369,Injection quantity deviation cylinder 5,-0.16, mg/stroke
IDE00370,Injection quantity deviation cylinder 6,-0.06, mg/stroke
IDE00371,Fuel consumption,1.07, l/h
IDE00373-ENG188621,Electric auxiliary heater: shut-off conditions-Bits 0-7,128,
IDE00373-ENG188621,Electric auxiliary heater: shut-off conditions-Bits 0-7,2,
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,43.13, %
IDE00381,Coolant fan 2: activation,36.31, %
IDE00383,Pre-injection 1: activation start,7.89, °
IDE00384,Pre-injection 1: activation duration,0.0, µs
IDE00385,Pre-injection 2: activation start,15.14, °
IDE00386,Pre-injection 2: activation duration,0.0, µs
IDE00387,Post-injection 1: activation start,0.00, °
IDE00388,Post-injection 1: activation duration,0.0, µs
IDE00389,Post-injection 2: activation start,0.00, °
IDE00390,Post-injection 2: activation duration,0.0, µs
IDE00392,Accelerator pedal: sensor voltage 1,757.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,381.0, mV
IDE00394,Camshaft position: start of phase window,183.58, °
IDE00395,Camshaft position: end of phase window,218.01, °
IDE00396,Charge air pressure actuator: acknowledgment,99.29, %
IDE00399,Regulation factor: total,1.0000,
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,99.79, %
IDE00404,Throttle valve: activation,7.16, %
IDE00405,Crankshaft speed (RPM),698.0, /min
IDE00406,Camshaft RPM,349.8, /min
IDE00407-ENG188621,Rail pressure regulation: status-Bits 0-7,5,
IDE00408-ENG188621,Engine mount 1-Bits 0-7,0,
IDE00409-ENG188621,Engine mount 2-Bits 0-7,0,
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00420,Service regeneration: current duration,0.00, s
IDE00422-ENG188621,Service regeneration: release conditions 1-Bits 0-7,0,
IDE00424-ENG188621,Service regeneration: cancel conditions-Bits 0-7,255,
IDE00424-ENG188621,Service regeneration: cancel conditions-Bits 0-7,251,
IDE00424-ENG188621,Service regeneration: cancel conditions-Bits 0-7,249,
IDE00425-ENG188621,Service regeneration: phase-Bits 0-7,0,
IDE00425-ENG188621,Service regeneration: phase-Bits 0-7,1,
IDE00427,Particle filter: difference pressure,5, hPa
IDE00428,DPF: offset for differential pressure,0, hPa
IDE00430-ENG188621,Particle filter: field regeneration request status-Bits 0-7,0,
IDE00431-ENG188621,Particle filter: field regeneration lock status-Bits 0-7,0,
IDE00432,Particle filter: time since last regeneration,50403, s
IDE00433,Particle filter: oil ash volume,0.07, l
IDE00434,Particle filter: soot mass calculated,21.30, g
IDE00435,Particle filter: soot mass measured,3.03, g
IDE00436,Particle filter: kilometers since last regeneration,308378, m
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,7.33, mg/stroke
IDE00473,EGR Vacuum Regulator Solen.val.: activation,87.46, %
IDE00474,Ambient air pressure,101, kPa abs
IDE00475,Fuel Pressure Regulator Valve,22.08, %
IDE00476,Fuel Metering Valve,43.22, %
IDE00477,Torque request: sum of auxiliary aggregate,7.5, Nm
IDE00478,Engine-drag torque,59.2, Nm
IDE00481-ENG188621,Limitation: status of clutch protection-Bits 0-7,0,
IDE00482,Limitation: torque of clutch protection,50000.0, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,0,
IDE00497-ENG188621,Status of oil pressure switches-Bits 0-7,3,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,18, °C
IDE00558,Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor),0.000 Lambda / 0.000 V,
IDE00583,Throttle valve specified value,97.6, %
IDE00584,Distance driven since erasing DTC memory,291, km
IDE00595,Allocation of oxygen sensors,B1S1 ,
IDE00600,Conversion factors,Max eq. ratio 32 / Max V O2s 0 V,
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,19,
IDE00608,Fuel type,Diesel,
IDE00699,ESI: minimum oil level in service interval,2.556, mm
IDE00700,ESI: maximum oil level in service interval,24.672, mm
IDE00784,Current test step,0,
IDE00973,Outside temperature,18.0, °C
IDE01076,Time since ignition off,33804, s
IDE01259,EGR Solen.val.: actual value,86.51, %
IDE01260,Generator performance,499.513, W
IDE01266-ENG188621,Coolant shut-off valve-Bits 0-7,2,
IDE01361,exh.gas recirc. (EGR) cooler pump: specified value,0.00, %
IDE01363-ENG188621,exh.gas recirc.: shut-off conditions-Bits 0-7,0,
IDE01363-ENG188621,exh.gas recirc.: shut-off conditions-Bits 0-7,37,
IDE01363-ENG188621,exh.gas recirc.: shut-off conditions-Bits 0-7,44,
IDE01367,Turbocharger boost control: offset closed,0.00, %
IDE01368,Turbocharger boost control: offset open,0.00, %
IDE01369,Intake manifold runner control (IMRC): offset closed,0.00, %
IDE01370,Intake manifold runner control (IMRC): offset open,0.00, %
IDE01373,EGR valve: offset closed,0.24, %
IDE01374,EGR valve: offset open,-0.24, %
IDE01375,Throttle valve adapter: offset closed,-0.31, %
IDE01376,Throttle valve adapter: offset open,0.31, %
IDE01377,Throttle valve adapter: actual value,97.68, %
IDE01378,Fuel high pressure: control deviation,300, hPa
IDE01380,Pre-injection 3: activation start,26.17, °
IDE01381,Pre-injection 3: activation duration,0.0, µs
IDE01382,Post-injection 3: activation start,0.00, °
IDE01383,Post-injection 3: activation duration,0.0, µs
IDE01384,Map controlled engine cooling thermostat: specified value,-1.00, %
IDE01385,Wear index,7, m
IDE01386,Soot index,0, m
IDE01387,Injector 1: rail pressure calibration point 1,-12.80, µs
IDE01388,Injector 1: rail pressure calibration point 2,-9.20, µs
IDE01389,Injector 1: rail pressure calibration point 3,0.80, µs
IDE01390,Injector 2: rail pressure calibration point 1,-3.20, µs
IDE01391,Injector 2: rail pressure calibration point 2,-1.60, µs
IDE01392,Injector 2: rail pressure calibration point 3,4.80, µs
IDE01393,Injector 3: rail pressure calibration point 1,-11.60, µs
IDE01394,Injector 3: rail pressure calibration point 2,-8.40, µs
IDE01395,Injector 3: rail pressure calibration point 3,-1.20, µs
IDE01396,Injector 4: rail pressure calibration point 1,4.40, µs
IDE01397,Injector 4: rail pressure calibration point 2,-2.00, µs
IDE01398,Injector 4: rail pressure calibration point 3,1.20, µs
IDE01399,Injector 5: rail pressure calibration point 1,-1.20, µs
IDE01400,Injector 5: rail pressure calibration point 2,4.40, µs
IDE01401,Injector 5: rail pressure calibration point 3,8.00, µs
IDE01402,Injector 6: rail pressure calibration point 1,-1.20, µs
IDE01403,Injector 6: rail pressure calibration point 2,-8.00, µs
IDE01404,Injector 6: rail pressure calibration point 3,0.80, µs
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01406-ENG188621,Service regeneration: status-Bits 0-7,0,
IDE01407,Particle filter: fuel consumption since last regeneration,33.03, l
IDE01408,Charge limit for field regeneration,26.82, g
IDE01409,Charge limit for service regeneration,38.32, g
IDE01410,Charge limit over-charge,57.48, g
IDE01834,Battery voltage,14220, mV
IDE01880,Accelerator pedal position 2,14.9, %
IDE01922,Vehicle distance driven,241926, km
IDE02228,Fuel pressure regulator valve: specified value rail pressure,580700, hPa
IDE02229,Exhaust gas temperature sensor 1,109.8, °C
IDE02230,Torque reduction due to exhaust temperature,1.0000,
IDE02233,Exhaust gas temperature sensor 2,84.3, °C
IDE02234,Exhaust gas temperature sensor 3,70.9, °C
IDE02236,Exhaust gas temperature sensor 4,37.4, °C
IDE02247,Static maximum speed limit,300.00, km/h
IDE02248,Individually adjustable top speed limit,300.00, km/h
IDE02632,Activation of static maximum speed limit,0,
IDE02756-ENG188621,Number of manual engine starts-Bits 0-7,41,
IDE02756-ENG188621,Number of manual engine starts-Bits 0-7,49,
IDE02756-ENG188621,Number of manual engine starts-Bits 0-7,0,
IDE02757-ENG188621,Number of automatic engine starts-Bits 0-7,0,
IDE02757-ENG188621,Number of automatic engine starts-Bits 0-7,154,
IDE03129,Reducing agent pump: activation,0.00, %
IDE03131,Reducing agent injector: activation,0.00, %
IDE03132,Pressure sensor for reducing agent: measured pressure,-25, hPa
IDE03133,Reducing agent metering system heating circuit 1: actual current,0.0, A
IDE03134,Reducing agent metering system heating circuit 2: actual current,0.0, A
IDE03135,Sensor for reducing agent tank temperature: temperature,19.1, °C
IDE03139,Reducing agent injector: resistance,13890, mOhm
IDE03140,NOx sensor 1: NOx concentration,0, ppm
IDE03141,NOx sensor 2: NOx concentration,0, ppm
IDE03142,Remaining vehicle distance until reducing agent deficiency,7442.25, km
IDE03143-ENG188621,Remaining engine starts until reducing agent deficiency-Bits 0-7,25,
IDE03144,Used reducing agent since last service,227759.773, g
IDE03145,NOx sensor 2: offset for correction factor,14, ppm
IDE03146,Pressure sensor for reducing agent: voltage,700.0, mV
IDE03147,Sensor for reducing agent tank temperature: voltage,1180, mV
IDE03148,Sensor for reducing agent fill level: voltage,3100.0, mV
IDE03149,NOx sensor 1: offset for correction factor,15, ppm
IDE03187,Checksum of flash,079E,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,0, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,0, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,0,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG114942,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Super SCR Control,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG112104,Number of requested start processes (statistics)-SSEUI Day Start Desired By Super SCR Control,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG112105,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Super SCR Control,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG112101,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Super SCR Control,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG114943,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Super SCR Control,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG112103,Number of requested start processes (statistics)-SSEUI Month Start Desired By Super SCR Control,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG112102,Number of requested start processes (statistics)-SSEUI Year Start Desired By Super SCR Control,0,
IDE03241-ENG188621,Status of reduction agent level-Bits 0-7,7,
IDE03242,Injector for reduction agent: current holding phase,903, mA
IDE03243,Reducing agent injector: current saturation phase,889, mA
IDE03248,Pressure control valve adaptation factor,1.1198,
IDE03266,Fuel temperature: unconditioned voltage,2179.6, mV
IDE03267,Intake air temperature: unconditioned voltage,2722.2, mV
IDE03269,Exhaust temp. EGR: unconditioned voltage,1016.4, mV
IDE03270,Exh.gas temp.sen 1: unconditioned voltage,1100.0, mV
IDE03271,Exh.gas temp.sen 2: unconditioned voltage,1042.6, mV
IDE03273,Exh.gas temp.sen 3: unconditioned voltage,1012.0, mV
IDE03275,Exh.gas temp.sen 4: unconditioned voltage,930.2, mV
IDE03276,Charge air pressure sensor: unconditioned voltage,1630.6, mV
IDE03288-ENG188621,Heating circuit 1 for reducing agent metering: activation-Bits 0-7,0,
IDE03289-ENG188621,Heating circuit 2 for reducing agent metering: activation-Bits 0-7,0,
IDE03353,Particle filter differential press. sensor: uncond. voltage,524.6, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3543.2, mV
IDE03383,Exhaust mass flow of EGR,23.5, kg/h
IDE03386,Long-term adaptation of reduction agent dosage,0.86,
IDE03387,Duration of overtemperature at the reduction agent injector,412, s
IDE03405-ENG188621,Particle filter field regeneration: cancel conditions-Bits 0-7,0,
IDE03577,Group run time cylinder pressure sensor 2,0.4, µs
IDE03582,Temperature sensor for engine temperature management,39.0, °C
IDE03583-ENG188621,Engine shut-down overrides-Bits 0-7,5,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,1,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-ENG188621,Stopping requirements for active participants-Bits 0-7,0,
IDE03587-ENG188621,Stopping requirements for active participants-Bits 0-7,2,
IDE03588-ENG188621,System malfunctions for active participants start/stop-Bits 0-7,0,
IDE03589-ENG188621,Error status for start-stop related sensors-Bits 0-7,10,
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,255,
IDE03765-ENG188621,NOx Sensor 1: Status-Bits 0-7,0,
IDE03766-ENG188621,NOx sensor 2: status-Bits 0-7,0,
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03768,NOx sensor 1: feed voltage,0, mV
IDE03769,NOx sensor 2: feed voltage,0, mV
IDE03892,Fuel high pressure sensor: unconditioned voltage,948.0, mV
IDE03949,Air mass: actual value (mg/stroke),290.4, mg/stroke
IDE04002,Charge air pressure control,BP_A cmd/act:100.0/101.0, kPa
IDE04007,Start of injection,1.98, °
IDE04008,Fuel consumption per hour,1.05, L/h
IDE04009,Driver's desired torque,-9.0, %
IDE04010,Engine torque: normalized,1.0, %
IDE04011,Nominal torque,580, Nm
IDE04015,Exhaust gas recirculation,EGR A:12/12/-3 % / EGR B:---/---/--- %,
IDE04016,Fuel Pressure Regulation,FRP CMD:25000/--- kPa / FRP ACT:24690/--- kPa,
IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:72/--- °C / EGRTemp 21/22:---/--- °C,
IDE04083,Coolant temperatures,ECT 1:34 °C / ECT 2:20 °C,
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:99.6/99.2 % / VGT_B cmd/act:---/--- %,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4: / 109/84/72/37 °C,
IDE04092,Particulate filter bank 1,0.40/---/---, kPa
IDE04095,Engine running time,Total:713H3092s,
IDE04096,Engine running time w. additional exhaust gas ctrl device 1-5,0H380s / 0H1307s / 17H2716s / 0H309s ,
IDE04097,Engine running time w. additional exhaust gas ctrl device 6-10,0H473s / 0H00s,
IDE04098,NOx-sensor,NOx11:65535 ppm / NOx21:65535 ppm,
IDE04099,Reduction agent dosing,ReAg Rate/Demand:---/--- / Reag Tnk Lvl:75.7 %,
IDE04110,Additional inputs and outputs, / GPL_STAT:OFF ,
IDE04255,Temp sensor for EGR after cooler: raw value,73.3, °C
IDE04256,Temp sensor for engine coolant: unconditioned voltage,2966.6, mV
IDE04257,High pressure EGR actuator: activation,-15.36, %
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,0,
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,55,
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,4,
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,66,
IDE04259,High press EGR actuator: actual unconditioned volt val,1202.2, mV
IDE04260-ENG188621,Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7,14,
IDE04260-ENG188621,Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7,188,
IDE04261-ENG188621,Lrn cyc cntr of zro quan calib: mid press. point-Bits 0-7,5,
IDE04261-ENG188621,Lrn cyc cntr of zro quan calib: mid press. point-Bits 0-7,89,
IDE04262-ENG188621,Learning cycle counter of zero quant calib: top press pt-Bits 0-7,90,
IDE04262-ENG188621,Learning cycle counter of zero quant calib: top press pt-Bits 0-7,5,
IDE04263,Sensor for particle filter differential press: raw value,4, hPa
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,55,
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,66,
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,8,
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,4,
IDE04265,Throttle valve adapter: uncond voltage actual value,4125.8, mV
IDE04266,High press turbocharger actuator: activation,0.00, %
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,2,
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,4,
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,0,
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,55,
IDE04268,High press turbocharger actuator: actual uncond volt value,4232.6, mV
IDE04269,Intake manifold runner actuator: activation,0.00, %
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,2,
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,4,
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,8,
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,55,
IDE04271,Intake manif runner actuator: uncond volt actual value,4193.4, mV
IDE04272,Counter for regeneration time of particulate filter,0.00, s
IDE04468,Air mass at air mass meter 1,35.6, kg/h
IDE04604,Accelerator pedal travel,0.00, %
IDE04623,Kick-down threshold,4125.2, mV
IDE04637,Engine temperature control actuator,0.00, %
IDE04638,Transmission coolant valve,0,
IDE04651,Torque request: A/C compressor,0.7, Nm
IDE04652,Exhaust gas jet volume in particle filter,34.0, m³/h
IDE04653,Simulated particle filter surface temperature,54.1, °C
IDE04654-ENG188621,CAN status - engine control module-Bits 0-7,0,
IDE04655-ENG188621,CAN status - transmission control module-Bits 0-7,0,
IDE04656-ENG188621,CAN status - brake control module 1-Bits 0-7,0,
IDE04657-ENG188621,CAN status - brake control module 2-Bits 0-7,0,
IDE04663-ENG188621,Cruise control switch-off: irreversible-Bits 0-7,255,
IDE04664-ENG188621,Cruise control switch-off: reversible-Bits 0-7,255,
IDE04665-ENG188621,Cruise control switch-off: irreversible w. brake intervention-Bits 0-7,0,
IDE04666,Heat delivery temperature in cooling system,19.6, °C
IDE04667-ENG188621,Bypass valve for EGR cooler: status-Bits 0-7,0,
IDE04668-ENG188621,EGR cooling function: status-Bits 0-7,2,
IDE04669,Camshaft slope position,0.00, °
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04671,Fuel volume adaptation correction volume,0.00, mg/stroke
IDE04673,O2 sensor 1 bank 1: duty cycle O2 heater,1.66, %
IDE04674,O2 sensor 1 bank 1: adjusted oxygen value,0.00725,
IDE04675,O2 sensor 1 bank 1: air flow volume,0.0, g
IDE04676,Oxygen sensor 1 bank 1: Ri calibration value,7.5, Ohm
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,2.690,
IDE04678-ENG188621,Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7,1,
IDE04679-ENG188621,O2 sensor 1: bank 1: status O2 signal: validity-Bits 0-7,0,
IDE04680,Oxygen sensor 1 bank 1: voltage raw value O2 signal,-6.8, mV
IDE04681,Oxygen sensor 1 bank 1: voltage value Ri-signal filtered,3299.8, mV
IDE04682-ENG188621,Allowed number of injections-Bits 0-7,6,
IDE04683-ENG188621,Injection release status-Bits 0-7,56,
IDE04684-ENG188621,Desired injection characteristic-Bits 0-7,63,
IDE04685,Setpoint generation interior torque,55.1, Nm
IDE04686,Calculated clutch limit torque,-57.9, Nm
IDE04687,Mean temperature of SCR catalyst,27.3, °C
IDE04688-ENG188621,Engine control module reset status-Bits 0-7,0,
IDE04689,Starter control: Start interruption status,Correct result,
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04690-ENG188621,Transmission torque intervention status-Bits 0-7,0,
IDE04690-ENG188621,Transmission torque intervention status-Bits 0-7,8,
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,255,
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04706-ENG188621,Activation condition ACC interface-Bits 0-7,8,
IDE04707-ENG188621,Status of reversible shut-off conditions ACC 2-Bits 0-7,4,
IDE04708-ENG188621,Status of reversible shut-off conditions ACC 3-Bits 0-7,64,
IDE04709-ENG188621,Status of ACC/CCS acceleration interface-Bits 0-7,0,
IDE04710-ENG188621,ACC control module: received status-Bits 0-7,6,
IDE04712-ENG188621,Active brake system error status-Bits 0-7,1,
IDE04814,Transmission oil cooler valve,0,
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,1,
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,169,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,9,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,85,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,254,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,10,
IDE04937,Sensor for engine block temperature: raw value,34.7, °C
IDE04938,Sensor for temp after charge air cooler: raw value,19.4, °C
IDE05134,ACC specified acceleration,0.000, m/s²
IDE05135-ENG188621,Status of compressor release-Bits 0-7,0,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,64,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,16,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,14,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,0,
IDE05137-ENG188621,Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7,0,
IDE05138,Shut-off timer: last engine shut-off time,33804, s
IDE05139,Shut-off timer: last ECM after-run time,123, s
IDE05343-ENG188621,Target value of heating temperature of NOx sensor 2-Bits 0-7,0,
IDE05344,Air mass to enable NOx sensor 2 offset test,0.0, g
IDE05346,NOx Emission NOx-Sensor 2,0, ppm
IDE05347,NOx Emission NOx Sensor,0, ppm
IDE05348,NOx-Sensor 2: O2-Concentration,0.20950,
IDE05349-ENG188621,Status of electrical malfunction of NOx sensor 2-Bits 0-7,0,
IDE05350-ENG188621,Status of electrical malfunction of NOx sensor 1-Bits 0-7,0,
IDE05353,Measured NOx conversion,0.000,
IDE05354,Calculated efficiency of NOx conversion,0.000,
IDE05355,Efficiency threshold of NOx conversion,0.000,
IDE05356,Calculated NOx concentration behind turbocharger,247, ppm
IDE05357,Current temperature with NOx Reduction CAT,27.4, °C
IDE05361,Maximum cylinder 2 cylinder pressure,51.945, bar
IDE05365-ENG188621,Malfunction status of combustion chamber pressure of cylinder 2-Bits 0-7,0,
IDE05369,Corrected inner torque from combustion chamb press of cyl 2,59.3, Nm
IDE05386,Exhaust gas model temperature 0,106.3, °C
IDE05387,Exhaust gas model temperature 1,74.8, °C
IDE05388,Exhaust gas model temperature 2,79.3, °C
IDE05389,Exhaust gas model temperature 3,46.4, °C
IDE05390,Exhaust gas model temperature 4,89.8, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000050,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0527,
IDE05443,Acceleration interface braking torque specified value,0.0, Nm
IDE05520,Pump for reducing agent: speed,0.0, /min
IDE05521,Correction factor of the eng temp for eng protection,1.0000,
IDE05522,Correction factor of the oil temp for eng protection,1.0000,
IDE05523,Correction factor of the fuel temp for eng protection,1.0000,
IDE05524,Charge air press temp correction factor for engine prot,1.0000,
IDE05623,Measured NOx conversion range 1,0.000,
IDE05624,Efficiency threshold of NOx conversion range 1,0.000,
IDE05625,Speed regulation requested torque,-867.1, Nm
IDE05626,Calculated temperature at reduction agent injection valve,17.1, °C
IDE05627,Activation of presupply pump duty cycle,35.31, %
IDE05797,Throttle valve adapter: specified value,97.73, %
IDE05801,Cylinder 2 max pressure position in deceleration mode,0.00, °
IDE05846,DPF statistics: current average speed,21.34, km/h
IDE05849,DPF statistics: current average torque gradient,8.7, Nm/s
IDE05851,DPF statistics: current average RPM,1216.5, /min
IDE05853,DPF statistics: current avg temperature after part filter,165.8, °C
IDE05855,DPF statistics: current regeneration time slice not possible,0.0000,
IDE05857,DPF statistics: current measured charging rate,-0.0020, g/km
IDE05859,DPF statistics: current calculated charging rate,-0.0164, g/km
IDE05861-ENG188621,DPF statistics: number of interrupted regenerations-Bits 0-7,0,
IDE05863,DPF statistics: soot mass at start of regeneration,0.00, g
IDE05865,DPF statistics: soot mass measured at start of regeneration,0.00, g
IDE05867,DPF statistics: soot mass calculated at start of regen,0.00, g
IDE05869,DPF statistics: current average speed in charge cycle,0.00, km/h
IDE05871,DPF statistics: current avg torque gradient in charge cycle,0.0, Nm/s
IDE05873,DPF statistics: average RPM in charge cycle,0.0, /min
IDE05875,DPF statistics: average temp after DPF in charge cycle,-273.1, °C
IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.0000,
IDE05879,DPF statistics: measured charging rate in charge cycle,0.0000, g/km
IDE05881,DPF statistics: calculated charging rate in charge cycle,0.0000, g/km
IDE05883,DPF statistics: regeneration time,0.00, s
IDE05885,DPF statistics: soot mass measured at end of regeneration,0.00, g
IDE05887,DPF statistics: soot mass calculated at end of regeneration,0.00, g
IDE05889,DPF statistics: max temperature before DPF during regen,-273.1, °C
IDE05891,DPF statistics: max temperature after DPF during regen,-273.1, °C
IDE05893,DPF statistics: average soot burn-off during regeneration,0.0000,
IDE05895,DPF statistics: average speed during regeneration,0.00, km/h
IDE05897,DPF statistics: average RPM during regeneration,0.0, /min
IDE05899,DPF statistics: average torque gradient during regeneration,0.0, Nm/s
IDE05901,DPF statistics: route in charge cycle,0, m
IDE05903,DPF statistics: avg driv cycle time during charge cycle,0.00, s
IDE05906,DPF statistics: route since successful regeneration,291217, m
IDE05908-ENG188621,DPF statistics: regeneration request-Bits 0-7,0,
IDE05910,DPF statistics: exhaust temperature regulation average value,0.000,
IDE05912-ENG188621,DPF statistics: reason for regeneration interruption-Bits 0-7,0,
IDE05914-ENG188621,DPF statistics: reason 2 for regeneration interruption-Bits 0-7,0,
IDE05916-ENG188621,DPF statistics: regeneration end status-Bits 0-7,0,
IDE05918-ENG188621,DPF statistics: regeneration blocked status-Bits 0-7,0,
IDE05920-ENG188621,DPF statistics: regeneration data index-Bits 0-7,0,
IDE05922-ENG188621,DPF statistics: error status-Bits 0-7,0,
IDE06013,Engine start: start synchronization 2,EPM_FULL_SYNC,
IDE06013-ENG127375,Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE,30,
IDE06060,Particulate filter ash load limit,327.67, g
IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,0.000,
IDE06237,Glow-control unit: activation voltage,14120, mV
IDE06238,Glow-control unit: calculated glow voltage,0, mV
IDE06254-ENG188621,Status of a reducing agent warning-Bits 0-7,0,
IDE06298-ENG188621,Status of engine during start-Bits 0-7,0,
IDE06386,Oil level: static measurement,14.612, mm
IDE06387,Oil level: last valid dynamic value,14.516, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06391,Oil temperature sensor 2,34.4, °C
IDE06392,Oil temperature sensor 2: raw value,2966.6, mV
IDE06393,Oil level: dynamic average value,131.068, mm
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,2697.8, mV
IDE06405,Engine oil temperature_SAE,34, °C
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06567-ENG188621,Frequency counter deactivate start/stop function-Bits 0-7,128,
IDE06567-ENG188621,Frequency counter deactivate start/stop function-Bits 0-7,105,
IDE06568-ENG188621,Stop prevention by driver frequency counter-Bits 0-7,0,
IDE06568-ENG188621,Stop prevention by driver frequency counter-Bits 0-7,2,
IDE06569-ENG188621,Frequency counter vehicle standstill-Bits 0-7,105,
IDE06569-ENG188621,Frequency counter vehicle standstill-Bits 0-7,135,
IDE06610-ENG188621,Frequency counter vehicle standstill with stop-Bits 0-7,3,
IDE06610-ENG188621,Frequency counter vehicle standstill with stop-Bits 0-7,0,
IDE06647-ENG188621,Start-stop switch status-Bits 0-7,0,
IDE06834-ENG188621,Heating circuit 2 for red. agent metering: diag. status-Bits 0-7,0,
IDE06835-ENG188621,Reducing agent pressure sensor: diag. status-Bits 0-7,0,
IDE06836-ENG188621,Heating circuit 1 for red. agent metering: diag. status-Bits 0-7,0,
IDE06837-ENG188621,Reducing agent pump: diag. status-Bits 0-7,0,
IDE06839-ENG188621,Reducing agent fill level sensor: diag. status-Bits 0-7,0,
IDE06840-ENG188621,Reducing agent tank temperature sensor: diag. status-Bits 0-7,0,
IDE06866-ENG188621,Range limit cancellation due to red. agent metering sys. fault-Bits 0-7,0,
IDE06928-ENG188621,Auxiliary air heater: activation-Bits 0-7,0,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,available.,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,available.,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,100.0, %
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,available.,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,available.,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,259, km
IDE06988,Reducing agent efficiency diagnosis progress,0.00, g
IDE06989-ENG188621,Reducing agent efficiency-diagnosis release status-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,98,
IDE07081,Reducing agent efficiency diagnosis progress 2,0.00, g
IDE07082-ENG188621,Reducing agent efficiency-diagnosis release status 2-Bits 0-7,0,
IDE07087-ENG188621,Target value of heating temperature of NOx sensor 1-Bits 0-7,0,
IDE07088,NOx sensor 1: oxygen concentration,0.20950,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,2,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,0,
IDE07091,NOx-Raw emission model value before reduction catalyst,257, ppm
IDE07197,Average reducing agent since lest filling,0.97, l/1000 km
IDE07374,Cylinder mass flow: act. value calculated,59.4, kg/h
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,143,
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,205,
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,113,
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,66,
IDE07538,Intake manifold press. sensor: act. value calculated,1002, hPa
IDE07724,Coolant temperature at engine outlet: calculated,35.1, °C
IDE07979,Particle filter: unburned fuel calculated,1.628,
IDE07980,SCR efficiency test 1,0.000,
IDE07981,SCR efficiency test 2,0.000,
IDE07982,SCR efficiency test overall,0.00, %
IDE07983,SCR error threshold of efficiency test,0.00, %
IDE07984,Particle sensor: cleaning deviation reaction time,0.000,
IDE07986,Particle sensor: soot volume in exhaust,0.87, mg/m³
IDE07987,Particle sensor: exhaust temperature,22.7, °C
IDE07988,Particle sensor: exhust speed,2.80, m/s
IDE07989,Particle sensor: heat voltage,1.99, V
IDE07990,Particle sensor: surface temperature,199.85, °C
IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,15,
IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,15,
IDE08132-ENG176596,SCR error notification reset status-SCR Inducement Tester DFCC Five,16777215,
IDE08132-ENG176595,SCR error notification reset status-SCR Inducement Tester DFCC Four,16777215,
IDE08132-ENG176592,SCR error notification reset status-SCR Inducement Tester DFCC One,16777215,
IDE08132-ENG176594,SCR error notification reset status-SCR Inducement Tester DFCC Three,16777215,
IDE08132-ENG176593,SCR error notification reset status-SCR Inducement Tester DFCC Two,16777215,
IDE08212,Standardized air flow ratio,1.5502,
IDE08213-ENG188621,Standardised airflow ratio plausibility-Bits 0-7,136,
IDE08721,Particle sensor: time in op. mode measurement,0.0, s
IDE08723-ENG188621,Checking red. medium quality: condition of next proof step-Bits 0-7,139,
IDE08723-ENG188621,Checking red. medium quality: condition of next proof step-Bits 0-7,246,
IDE08724-ENG188621,Checking red. medium quality: reason for cancel-Bits 0-7,0,
IDE08725-ENG188621,Checking red. medium quality: status-Bits 0-7,1,
IDE08726,Checking red. medium quality: remaining time of test,0, s
IDE08727,Checking red. med. quality: remaining time of current test step,0, s
IDE09164,Efficiency of the SCR catalytic converter,0.000,
IDE09976,Coolant fan 1: activation,43.13, %
IDE09977,Control module temp.: max. value,85.7, °C
IDE10256,Intake manifold 1 bank 1: pos. contr. spec. value,0.00, %
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE11061,Odometer reading when changing oxidation cat. converter,179396, km
IDE11062,Odometer reading when changing particulate filter,179386, km
IDE11063,Odometer reading when changing SCR cat. convert.,696, km
IDE11220,Reducing agent system: current status,COSCR_NOPRESSURECTL,
IDE11220-ENG127431,Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE,2,
IDE11222,Reducing agent system: current substatus,Unknown (255),
IDE11222-ENG127432,Reducing agent system: current substatus-Test_Program_SCR Con State 02 UBYTE,255,
IDE11854,Mileage of the oxidation catalytic converter,62530, km
IDE11856,Mileage of the SCR catalytic converter,241230, km
MAS16689,Reducing agent pump: differential speed calculated,0.0, /min
ENG105033,Acc Mon trq Gov,0.0, Nm
ENG105034,Acc Mon trq Lim,0.0, Nm
ENG105135,Actual charge pressure,1010, hPa
ENG119898,Actual_section_of_standard_test,0,
ENG105090-ENG188621,AF Vlv st Ps-Bits 0-7,0,
ENG105098,AFS dm Sens,38.2, kg/h
ENG105131-ENG188621,Air Ctl st Air Ctl Bits-Bits 0-7,0,
ENG105131-ENG188621,Air Ctl st Air Ctl Bits-Bits 0-7,1,
ENG105133-ENG188621,Air Ctl st Mon-Bits 0-7,0,
ENG105142,Air t EGR Clr Ds,73.2, °C
ENG110882-ENG188621,Air_filter_flap_state-Bits 0-7,0,
ENG106231,Ambient temperature,15.0, °C
ENG105192,APP r,0.00, %
ENG105204,AS Mod dm Exh Mnf Ds,36.3, kg/h
ENG122779,AS Mod t EGR Ds,62.9, °C
ENG105359-ENG188621,Brk st Mn Raw-Bits 0-7,0,
ENG122780,C Thmst r Ps,0.00, %
ENG101413,Calibration Identifications,8K5401AC0010BVAB,
ENG99697,Calibration Verification Numbers,86 1D D3 10,
ENG109599,Charge pressure adjuster activation,99.62, %
ENG105483-ENG188621,Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7,0,
ENG105528-ENG188621,Co EOM st Op Mode Short-Bits 0-7,134,
ENG122787,Com i PP Ds IDE Raw,0.000, µA
ENG105580,Com r Lam Lin Rec Cat2 Ds,0.0000,
ENG105581,Com r Lam Lin Rec Ds,0.0000,
ENG105591-ENG188621,Com st N Ox Vld Cat2 Ds-Bits 0-7,0,
ENG105592-ENG188621,Com st N Ox Vld Ds-Bits 0-7,0,
ENG110877,Cpp p Cyl Min 4,0.914, bar
ENG105660,Cpp phi Pos MC 4,-1.27, °
ENG110878,Cpp phi Pres Cyl Max 4,-5.80, °
ENG124605,Cpp phi TDC Cor,0.53, °
ENG110876-ENG188621,Cpp st Cyl Dia Cyl4-Bits 0-7,0,
ENG122781,Ct T t Eng Des,90.0, °C
ENG113333,Cylinder_pressure_offset_cylinder_2,1.211, bar
ENG125279,Dew Det rat Dew Det Finshd[0],0.000, %
ENG125280,Dew Det rat Dew Det Finshd[1],0.000, %
ENG125281,Dew Det rat Dew Det Finshd[2],0.000, %
ENG125282,Dew Det rat Dew Det Finshd[3],0.000, %
ENG105862-ENG188621,DIUMPR ct Gen Denom-Bits 0-7,76,
ENG105862-ENG188621,DIUMPR ct Gen Denom-Bits 0-7,4,
ENG105863-ENG188621,DIUMPR ct Ign-Bits 0-7,13,
ENG105863-ENG188621,DIUMPR ct Ign-Bits 0-7,8,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG106050-ENG188621,EEM st Wt Htr Stp-Bits 0-7,0,
ENG122782,EGR Clg dm Egr Mon Heat Avg,0.0, kg/h
ENG112277-ENG188621,EGR Clg st EGR Clg Bits-Bits 0-7,4,
ENG112277-ENG188621,EGR Clg st EGR Clg Bits-Bits 0-7,0,
ENG122783,EGR Clg t Egr Ds De Mon Heat Avg,0.0, K
ENG122784,EGR Clg t Turbn Us Mon Avg,-0.0, °C
ENG106065,EGR valve feedback,12.34, %
ENG106069,EGR Vlv r Des Val,12.13, %
ENG106084,EGR_governor_deviation,3.5, mg/stroke
ENG106085,EGR_governor_deviation_lower_limit,-61.4, mg/stroke
ENG106086-ENG188621,EGR_governor_deviation_monitoring_enabling-Bits 0-7,1,
ENG106087,EGR_governor_deviation_upper_limit,3000.0, mg/stroke
ENG106186,Eng Da l Run In,1001, km
ENG106187,Eng Da st Eng Frst Run Cond,0,
ENG106188,Eng Da st Eng Run In Tstr,0,
ENG112279,Eng Prt t Pre Trbn,109.2, °C
ENG106223,Engine_torque_limitation_mechanical,329.9, Nm
ENG105968-ENG188621,EOBD data D-Bits 0-7,15,
ENG105968-ENG188621,EOBD data D-Bits 0-7,0,
ENG105968-ENG188621,EOBD data D-Bits 0-7,235,
ENG105968-ENG188621,EOBD data D-Bits 0-7,64,
ENG122788,Exh i PP Ds IDE Shnt Circ,0.0, µA
ENG112280,Exh p Diff Ofs Val Old,0, hPa
ENG106394,Exh r N Ox Pres Comp No Cat2 Ds,0, ppm
ENG106395,Exh r N Ox Pres Comp NSC Ds,0, ppm
ENG113334-ENG188621,Exh st Lam Stat No Cat2 Ds-Bits 0-7,1,
ENG110880-ENG188621,Exh st Lam Stat NSC Ds-Bits 0-7,1,
ENG122789-ENG188621,Exh st PP Ds St Ma-Bits 0-7,0,
ENG106416,Exh t Adap T Oxi Cat Ds,75.0, °C
ENG106417,Exh t Adap T Trbn Us,109.2, °C
ENG106420,Exh t Adap TP Flt Ds,37.8, °C
ENG122790,Exh u PP Ds Batt Snsr Raw,14.1, V
ENG106510,Fan r2 Ps,36.31, %
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,240,
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,52,
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,0,
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,227,
ENG112282,FMO n Adap Map Pnt,2000.0, /min
ENG112283,FMO q Adap Map,-1.07, mg/stroke
ENG112284,FMO q Adap Map Pnt,35.00, mg/stroke
ENG106694,Fuel temperature,21.1, °C
ENG106696,Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_1,0.0187,
ENG106697,Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_2,0.0084,
ENG106698,Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_3,0.0137,
ENG106699,Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_4,0.0300,
ENG106700,Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_5,0.0300,
ENG106701,Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_6,0.0282,
ENG106774-ENG188621,General_rail_press_calibr_ctrl_duration_enble_stat-Bits 0-7,255,
ENG111022,Glow_period_control_unit_calculated_glow_voltage,0, mV
ENG111025,Glow_period_control_unit_energy_integrator_calculated_value,218.6, V²s
ENG111024,Glow_period_control_unit_energy_integrator_input_voltage,0, mV
ENG111026,Glow_period_control_unit_engine_temperature,34.0, °C
ENG111023,Glow_period_control_unit_ground_offset_voltage,-500, mV
ENG106877-ENG188621,High_press_EGR_vlv_cnter_strtd_jam_off_trial-Bits 0-7,0,
ENG106877-ENG188621,High_press_EGR_vlv_cnter_strtd_jam_off_trial-Bits 0-7,5,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,106,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,0,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,5,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,105,
ENG112940,Inj Crv ti Pi IET 0,203.6, µs
ENG112941,Inj Crv ti Pi IET 1,210.0, µs
ENG112942,Inj Crv ti Pi IET 2,177.2, µs
ENG107015,Inj Ctl q Curr,6.52, mg/stroke
ENG107036-ENG188621,Injctr_spec_rail_press_calibr_ctrl_dur_enbl_stat-Bits 0-7,63,
ENG105141,Intake air temperature,19.4, °C
ENG107046-ENG188621,Intake_manifold_runner_counter_of_mechanic_hitting-Bits 0-7,0,
ENG107047-ENG188621,Intake_manifold_runner_counter_started_jam_off_trial-Bits 0-7,0,
ENG107047-ENG188621,Intake_manifold_runner_counter_started_jam_off_trial-Bits 0-7,1,
ENG103875-ENG99452,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Completion Condition Counts,367, counts
ENG103875-ENG103994,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,1100, counts
ENG103875-ENG125935,In-use Performance Tracking: 16 counters-Counters 17-18,|Fuel Monitor Completion Condition Counts,Fuel Monitor Conditions Encountered Counts|601,1100|, counts
ENG103875-ENG100817,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,0, counts
ENG103875-ENG101113,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG104133,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,0, counts
ENG103875-ENG104165,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG102823,In-use Performance Tracking: 16 counters-Ignition Cycle Counter,19456, counts
ENG103875-ENG99234,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG99167,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG101363,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
ENG103875-ENG103522,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG125933,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG125934,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG99988,In-use Performance Tracking: 16 counters-OBD Monitoring Conditions Encountered Counts,22788, counts
ENG103875-ENG100240,In-use Performance Tracking: 16 counters-PM Filter Monitor Completion Condition Counts,0, counts
ENG103875-ENG103730,In-use Performance Tracking: 16 counters-PM Filter Monitor Conditions Encountered Counts,0, counts
ENG110883,IUMPR_minimum_ratio_group_0,3.0571,
ENG110884,IUMPR_minimum_ratio_group_1,0.7063,
ENG110885,IUMPR_minimum_ratio_group_2,0.0000,
ENG110886,IUMPR_minimum_ratio_group_3,7.9999,
ENG110887,IUMPR_minimum_ratio_group_4,0.4354,
ENG110888,IUMPR_minimum_ratio_group_5,0.8445,
ENG110889,IUMPR_minimum_ratio_group_6,0.3336,
ENG110890,IUMPR_minimum_ratio_group_7,0.5463,
ENG107087,IV Actr u Dis Ch Stop 0,14.33, V
ENG107088,IV Actr u Dis Ch Stop 1,11.57, V
ENG107089,IV Actr u Dis Ch Stop 2,13.78, V
ENG107090,IV Actr u Dis Ch Stop 3,11.30, V
ENG107091,IV Actr u Dis Ch Stop 4,14.60, V
ENG107092,IV Actr u Dis Ch Stop 5,12.12, V
ENG112944-ENG188621,IV Adj ct NVC Ena 0-Bits 0-7,255,
ENG112945-ENG188621,IV Adj ct NVC Ena 1-Bits 0-7,255,
ENG112946-ENG188621,IV Adj ct NVC Ena 2-Bits 0-7,255,
ENG112947-ENG188621,IV Adj ct NVC Ena 3-Bits 0-7,255,
ENG112948-ENG188621,IV Adj ct NVC Ena 4-Bits 0-7,255,
ENG112949-ENG188621,IV Adj ct NVC Ena 5-Bits 0-7,255,
ENG107457-ENG188621,Lambda probe electronics-Bits 0-7,0,
ENG107457-ENG188621,Lambda probe electronics-Bits 0-7,200,
ENG107447,LSU r O2 Adap 0,0.00093,
ENG107569,Main_injection_quantity,3.75, mg/stroke
ENG107596,Me Un dvol Set,900, mm³/s
ENG107654-ENG188621,Mo F Brk st-Bits 0-7,0,
ENG107655,Mo F Inj Dat ti TDC Avrg,1105.2, µs
ENG107656-ENG188621,Mo F Veh Acc st-Bits 0-7,0,
ENG107671,Model_corr._factor_of_effective_cross_section_of_EGR_valve,0.8920,
ENG107673,Model_corr._factor_of_exh._mass_flow_rate_into_exh._manifold,1.0000,
ENG107672,Model_correction_factor_of_exhaust_gas_temperature_1,1.0000,
ENG107674,Model_correction_factor_of_volumetric_efficiency,1.0000,
ENG107675,Model_correction_factor_of_volumetric_efficiency_including_variable_swirl_correction,1.0219,
ENG112943,Oil t Sens PULS,28.3, °C
ENG107969,P Flt Ld fac Ash Cor,0.9580,
ENG135342,P Flt Ld len Snce P Flt Chng,62540, km
ENG108011-ENG188621,P Flt Srv st Rgn Suc-Bits 0-7,0,
ENG108162,Particle_filter_service_regeneration_duration_with_headup,0.00, s
ENG106384,Particul.filter diff.pressure,4, hPa
ENG127252-ENG151857,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 1 Sensor 1,not active,
ENG127252-ENG151859,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 2 Sensor 1,not active,
ENG127252-ENG151855,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 1 Sensor 1,-0.01, %
ENG127252-ENG151856,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 2 Sensor 1,0.00, %
ENG127252-ENG151861,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 1 Sensor 1 supported,available.,
ENG127252-ENG151863,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 2 Sensor 1 supported,Not available,
ENG127252-ENG151858,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 1 Sensor 1,not active,
ENG127252-ENG151860,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 2 Sensor 1,not active,
ENG127252-ENG151862,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 1 Sensor 1 supported,available.,
ENG127252-ENG151864,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 2 Sensor 1 supported,Not available,
ENG108181-ENG188621,PCR st Mon-Bits 0-7,0,
ENG108227-ENG188621,Pos MC Ctl st Lim 4-Bits 0-7,1,
ENG108252,Postinjection_1_quantity,0.00, mg/stroke
ENG108253,Postinjection_2_quantity,1.61, mg/stroke
ENG108254,Postinjection_3_quantity,0.00, mg/stroke
ENG108270,Preinjection_1_quantity,0.00, mg/stroke
ENG108271,Preinjection_2_quantity,0.83, mg/stroke
ENG108272,Preinjection_3_quantity,0.88, mg/stroke
ENG110382-ENG151591,SCR inducem system status-deviation of reagent consumption,Unknown (0),
ENG110382-ENG151584,SCR inducem system status-Distance traveled in current 10K block,8526, km
ENG110382-ENG151585,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
ENG110382-ENG151586,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
ENG110382-ENG151587,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
ENG110382-ENG151583,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
ENG110382-ENG151590,SCR inducem system status-incorrect reagent,Unknown (0),
ENG110382-ENG151588,SCR inducem system status-inducement system active,not_active,
ENG110382-ENG151592,SCR inducem system status-NOx emissions too high,Unknown (0),
ENG110382-ENG151589,SCR inducem system status-reagent level too low,Unknown (0),
ENG108629,SCR Mod fac Eff SCR Age,0.223,
ENG108640,SCRFFC eta Pre Ctl Mode2,0.000,
ENG108641,SCRFFC st Pre Ctl Mode Actv,0,
ENG108949-ENG188621,Shtrp ct Remain-Bits 0-7,0,
ENG108950-ENG188621,Shtrp num Curr Tst-Bits 0-7,0,
ENG108951-ENG188621,Shtrp num Fault-Bits 0-7,0,
ENG108952-ENG188621,Shtrp st Vehv DC-Bits 0-7,1,
ENG108953-ENG188621,Shtrp txt Msg-Bits 0-7,0,
ENG108954-ENG188621,Shtrp txt State-Bits 0-7,0,
ENG108990,Smk Lim q Lim Smk,22.02, mg/stroke
ENG113332,Standard_deviation_of_main_combustion_cylinder_2,0.04, °
ENG109106-ENG188621,Status_of_adaption_of_toothed_speed-Bits 0-7,1,
ENG109108-ENG188621,Status_tooth_angle_adaption_learning-Bits 0-7,1,
ENG124606,Thm Pmp r Ps,0.00, %
ENG109419,Throttle valve activation,2.39, %
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,0,
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,213,
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,18,
ENG109432-ENG188621,Thrttle_vlv_cntr_strtd_jam_off_trial-Bits 0-7,0,
ENG109657-ENG188621,Trbochrgr_press_postionr_cnter_strtd_jam_off_trial-Bits 0-7,0,
ENG109727,V Sw Vlv r Act,0.21, %
ENG109861,Vehicle speed,0.00, km/h
ENG121956-ENG188621,Wa Ht nr Htr Cnt-Bits 0-7,0,
Elapsed Time: 01:02
