Vcds login 11 problem
senna1
C?ID=231631
Hi,
problem when trying to login 11 to adapt key,, it is greyed out you cant select login, so therefore cant code the key for immobilizer, here is a full autoscan.
1 other question, the instrument cluster immob 3 i would say, 2004,, and dona ecu 2005, we tried just using skc codes, but that did not work, although immob status in the engine check adaption channel showed 4 immobilizer matched (system ok ) used the cluster as the original for pin and the dona ecu as used pin, but the original chassis vin number were not the same, as they should of been, now the vin are the same,
The immobilizer is still flashing, the original key that was matched to the original cluster should of worked,, so now new transponder fitted id 48, and going to use the same code pin as for the cluster, & engine ecu, and i cant login 11.
Thursday,03,December,2015,13:35:55:46146
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN:
                Address 01: Engine       Labels: 03G-906-016-BDJ.clb
Control Module Part Number: 03G 906 016 GP    HW: 028 101 216 8
  Component and/or Version: R4 2,0L EDC 0000SG  7001
           Software Coding: 0053031
            Work Shop Code: WSC 35110 377 00162
                      VCID: 77FDC7E6067906866C-8022
8 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
            P3102 - 000 - No Signal
                    RPM: 189 /min
                    Torque: -98.0 Nm
                    Voltage: 7.83 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 0.0 Nm
18051 - Please check DTC Memory of Electric Load Controller
            P1643 - 000 -  - Intermittent
                    RPM: 1344 /min
                    Torque: 62.0 Nm
                    Load: 16.9 %
                    Voltage: 14.36 V
                    Bin. Bits: 11000100
                    Torque: 156.0 Nm
                    Bin. Bits:  1 00  0
17848 - EGR Valve (N18)
            P1440 - 000 - Open Circuit
                    Torque: 116.0 Nm
                    Voltage: 12.54 V
                    Bin. Bits: 00000100
                    Mass Air / Rev.: 850.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - MIL ON
                    Torque: 114.0 Nm
                    Voltage: 12.62 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    (no units): 0.0
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -
                    Torque: 114.0 Nm
                    Voltage: 12.62 V
                    Temperature: 17.1°C
                    Temperature: 16.2°C
                    Temperature: 17.1°C
16497 - Intake Air Temp. Sensor (G42)
            P0113 - 000 - Signal too High
                    Torque: 118.0 Nm
                    Voltage: 12.54 V
                    Temperature: 133.2°C
                    Temperature: 13.5°C
                    Temperature: 14.4°C
17563 - Manifold Pressure Sensor (G71)
            P1155 - 000 - Short to Plus
                    Torque: 116.0 Nm
                    Voltage: 12.54 V
                    Bin. Bits: 00000100
                    Absolute Pres.: 183.6 mbar
                    Absolute Pres.: 979.2 mbar
18048 - Internal Control Module
            P1640 - 000 - EEPROM Error
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Use Security Access (16) instead and post a complete Auto-Scan as well as Advanced ID Information from #01 and #25.
Gone But Not Forgotten
Beware of your dark side..........18048 - Internal Control Module
senna1
C?ID=231631
jack.
my info software for 18048 indicates it maybe a tuned file,, or faulty ecu,, the guy i had the skc's from said he has not touched that, only the immobilizer,, never had this dtc on the previous full scan i have, before going for the skc's, only immob problem, that was to be expected as Dona Ecu.
senna1
C?ID=231631
Hi Seb,
Are you saying use as before instruments 17,, then 16 security Access , and use this to login pin for the key do it ,and then 10 adapt it, same procedure as if i had used login 11 at 17 instruments. I think the van is Can protocol. not kwp 2000 i need to be sure of correct procedure as the key transponder can only be programmed once, i have 5 digit pin,
Maybe bad tuner math?.........and what is Immo status in VCDS please........ post 0x01-10-091
Jef
HQ
SKC = pet peeve :mad:
7 digit codes based on PIN, date and WSC has not been issues for a long time. 10 years now? That acronym needs to die.
[Login - 11] and [Security Access -16] are, more or less, the same function, or rather, the end results are the same. FYI, sometimes function 11 will be [Coding II - 11]. I think it has to do with what protocol a control module uses as to what you will see VCDS display for your button options (getting out of my comfort zone now).
Before I get parts of me stuck in a ceiling fan due to things being unclear:
  • Full Auto-Scan please
  • What year and model?
  • What control modules (electronics) have been replaced?
  • Are these new keys, or existing keys that were matched up to this car?
senna1
C?ID=231631
The only info i have at the moment for immobilizer is channel 91 of ecu is 4, anywhere else i can look for information, here are two auto scans since the early scan the airbag module replaced, & the steering control module fault has been found, the second auto scan is the present one, VW caddy van 2004 2.0 Sdi. The van has it original cluster, and key, the ecu is the Dona,, i thought we would just need the SKC'S and job complete, but it did not work, the vin in the ecu stayed the same as the vehicle it came from, so took the ecu and cluster back to the person who did the skc's and he said he had to put in new files,, and i would have to replace the key transponder, i replaced it but as i said above,, cant login 11 under 17, instruments,
i thought i would not need to change the key pin as it was the original matched to the cluster ? and now have 18048 - Internal Control Module fault,
Friday,06,November,2015,16:32:21:46146
VIN: WV1ZZZ2KZ5X058358
Mileage: 339700km-211079mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZ5X058358 Mileage: 339700km-211079miles
44-Steering Assist -- Status: Cannot be reached 1100
Part No SW: 03G 906 016 GP HW: 028 101 216 8
Component: R4 2,0L EDC 0000SG 7001
Revision: 12345678 Serial number: VWZ7Z0D1006870
Coding: 0053031
Shop #: WSC 35110 377 00162
P1654 - 000 -
Torque: 116.0 Nm
Voltage: 11.32 V
Temperature: 15.3°C
Temperature: 13.5°C
Temperature: 14.4°C
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 2K0 907 379 A
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 08192
VCID: 316939FEA89D18B6E2-8064
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00H30000 Serial number: 00000001183502
Coding: 00884F0200041000000000000000000000
Shop #: WSC 00162 210 120669
VCID: 3F8D6FC66EC9FEC664-806A
Subsystem 1 - Part No: 1T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 260210 021 0512
Coding: 00038805
Shop #: WSC 00162
9 Faults Found:
01834 - Bulb for Side-Blinkers; Left (M18)
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 2Q AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR06WUV-
Coding: 0012881
Shop #: WSC 35110 377 00155
VCID: 7DF1D5CE24452CD636-8028
Part No SW: 1K0 953 549 E HW: 1K0 953 549 E
Component: Lenksäulenmodul 021 0050
Coding: 0000002
VCID: 346730EA578F2D9E89-8060
Part No: 2K0 920 941 C
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0016403
Shop #: WSC 00252 067 57207
VCID: 2959D19E804D60762A-807C
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B2101AD
Coding: 3D0F0140079001
Shop #: WSC 35110 377 00158
Reset counter: 229
Mileage: 339707 km
Time: 00:20:52
Reset counter: 229
Mileage: 339707 km
Time: 00:20:52
01304 - Radio
Reset counter: 229
Mileage: 339707 km
Time: 00:20:57
Component: IMMO VDD 0716
02241 - Engine Control Module; Immobilizer Data not Adapted
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0160
Coding: 0000000
VCID: 76E3CAE201737F8E77-8022
Address 44: Steering Assist
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 808A04087F2D84040858010010
VCID: 7BF5DBD63A5122E608-802E
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75E1CDEE1C7574967E-8020
Address 56: Radio
End-------------------------(Elapsed Time: 01:13)--------------------------
up to date Auto scan
Thursday,03,December,2015,14:54:20:46146
Coding: 0053031
P1640 - 000 - EEPROM Error - MIL ON
Torque: 120.0 Nm
Bin. Bits: 10110010
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
P1654 - 000 -
Torque: 120.0 Nm
Voltage: 12.31 V
Temperature: 11.7°C
Temperature: 10.8°C
Temperature: 11.7°C
Readiness: 1 1 0 1 1
Coding: 0017106
Coding: 00038805
Shop #: WSC 00162
9 Faults Found:
Coding: 0012881
Coding: 0000002
Coding: 0016403
Reset counter: 230
Mileage: 339707 km
Time: 01:26:04
01304 - Radio
Reset counter: 230
Mileage: 339707 km
Time: 01:26:08
01176 - Key
Coding: 0000000
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.11 1502
02546 - Steering Limit Stop
Mileage: 8880 km
Temperature: 19.0°C
Voltage: 12.20 V
Voltage: 12.10 V
Coding: 0000000
Address 56: Radio
End-------------------------(Elapsed Time: 01:14)--------------------------
The eeprom error will have to be corrected and RFID issue, before you can preform an 050 alignment in most cases.
senna1
C?ID=231631
Jack,, all sorted now,, we tried to login 11, tried security 16 and pin no joy,, yet we knew we had a key immobilizer problem,, the eeprom fault as you can see was on the latest scan.
the transponder i bought was pre programmed, and we checked the Id on that 48,, but i needed to know by whatever we were trying that the rest of the key program was complete,
so the guy who did the skc's etc, used his key program tool,, but it is strange as we did not type in the pin for the key,, just went into the key tool adaption program click click etc and the immobilizer went off, maybe it comms with the cluster, and we started the engine, and now no eeprom Dtc, we read all the cluster and ecu hex info for the vin and immob details and you could see both had the same vin number as it should, and same pin, so a bit of a mystery who knows. i did find this in immobilizer 25 while looking Advance Id cant remember if i look in 01 25 after what has gone on tonight. label file. i will post a new scan monday all going well.
Saturday,05,December,2015,16:15:40:46146
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN:
Control Module Part Number: 2K0 920 941 C
Component and/or Version: IMMO VDD 0716
Software Coding:
Work Shop Code: WSC 00162
VCID: 2959D19E804D60761C-807C
Misc.
VCDS Info:
Labels: 1K0-920-XXX-25.CLB
senna1
C?ID=231631
Hi Seb
as written below, i cant remember if i checked 01, 25 in advance ID, but i did find this label file which maybe of no use to you, i tried security 16 in instruments 17 and 25 immob no joy with the key pin, but as said below to jack all is sorted fingers crossed,
VIN:
Software Coding:
Misc.
VCDS Info:
