Front Assist Long Coding Help (2019 A7)
Adrian1871
C?ID=573462
anyone able too advise what byte 11 bit 7 is active for or relates too in A5 front driver assist module recently had software update on mmi/service and apparent adas calibration due too replacement side mirrors was hoping this would sort my ongoing issue with a recurring fault in instruments 17 considering its been on dealer computer system i thought i might get a fix for this but its not the case so upon looking at auto scan logs and using debug folder i can see 1 potential issue with coding in A5 no label file or documents for this byte anyone able too advise?
Wednesday,08,January,2025,20:08:58:33420
Workshop Code: 006 20574 000200
VIN: WAUZZZF28KN016685   License Plate: X31ADA
Mileage: 85912km-53383mi   Repair Order:
Chassis Type: F2-AU58 (4N2)
Scan: 01 02 03 09 13 15 16 17 19 1B 2B 36 3C 42 44 46 47 52 5F 61
          69 6D 74 81 82 A5 AC BB BC C4 CA CB CC CD CF D6 D7 DB DC DD
          DE
VIN: WAUZZZF28KN016685   Mileage: 85912km-53383miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
Address 01: Engine (J623-DDVB)       Labels: Redir Fail!
   Part No SW: 4K0 907 401 K    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0003
   Revision: CAH26---    CVN: 17249E2E7965F614755A21138947E11D00000000D6C3ECFE
   Coding: 122A4012057E050334286000000400000000000000000000
   Shop #: WSC 20574 006 1048576
   ASAM Dataset: EV_ECM30TDI0114K0907401K 001003
   ROD: EV_ECM30TDI0114K0907401J.rod
   VCID: 2F3B036D379564B2FE9-807A
   VINID: 9D196AAAA58221B780046188141C9BD136
4814 - Voltage Supply 1 for Control Module
          U3501 00 [00100110] - Too Low
                    Mileage: 85912 km
                    Date: 2025.01.08
                    Time: 20:05:40
                    Engine RPM: 0.00 /min
                    Coolant temperature: 0 °C
                    Intake air temperature: 1 °C
                    Voltage terminal 30: 10.940 V
                    Engine status: COENG_READY
   Part No SW: 4K0 927 158 AP    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 0001
   Revision: --H05---    CVN: 7D0A815600009238
   Coding: 100000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011.rod
   VCID: 005990D1DA8B2BCA573-8054
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H01 0705
   Serial number: 1807050570
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4N0 907 379 AC    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0850
   Dataset Number: 4K0909504H  0001 CVN: D11B0B40
   Coding: 1CAA329731A30B9C51A44C991882D1E2F5B9C9384C8CD08A32188B47AF9D93
   Shop #: WSC 20574 006 00200
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 79AFFD35B9517A0210D-802C
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0652
   Dataset Number: 4K0909514B  0023
   Coding: 07000B43C13900DD074C57889FFF8C68131B33100406009781010A001B3316810A450A0290100000000001000041081A0802000044010100000000000000000000
           07000143C13900DD074C57889FEF8C68131B33100406009781030A001B3316810A450A0280100000000001000041081A0802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 74B1CC019E33076A43B-8020
   Subsystem 1 - Part No SW: 4K2 955 119     HW: 4K2 955 119
   Component: J400FRWISCH  063 0730
   Serial number: 00000001712010400656
   Coding: 7DC727
   Serial number: 21575373X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K2 941 501 A    HW: 4K2 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 13S19.06.1800300877
   Serial number: GX1CE101051823810556
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 H    HW: 4K0 947 135 H
   Component: Dachmodul  H42 0413
   Serial number: C00047361
   Coding: 0D0101
   Front windshield washer pump:
   Subsystem 6 - Part No SW: 4N0 907 605     HW: 4N0 907 605
   Component: J1100/SWP  H09 0005
   Serial number: 00000000001811600041
   Coding: 020000
67736 - Databus
          [Camera sensor blocked]
                    Reset counter: 160
                    Mileage: 85577 km
                    Date: 2024.12.14
                    Time: 11:11:39
                    average_Voltage_terminals: 12.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 8.00 °C
                    interior_temperature: 27.00 °C
                    Vehicle speed: 109.36 km/h
405507 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function limitation due to energy management system]
                    Reset counter: 163
                    Mileage: 85912 km
                    Date: 2024.12.28
                    Time: 01:56:58
                    average_Voltage_terminals: 11.60 V
                    Outside air temperature sensor-Resistance: 2.56 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 3.50 °C
                    interior_temperature: Temperature not available
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: Not available
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: Not available
   Part No SW: 4K0 907 561 E    HW: 760 907 561 A
   Component: LRR4R         H04 0332
   Dataset Number: 4K1909863L  0001
   Coding: 5265FF5C78082C00010360E0000000BE4A1246484481009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X.rod
   VCID: 303900112AAB7B4AE73-8064
2344 - Databus
          [FAULT_CAMERA_DIRT_OBJ]
                    Reset counter: 160
                    Mileage: 85577 km
                    Date: 2024.12.14
                    Time: 11:11:28
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 12.7 V
                    Vehicle speed: 30.20 m/s
                    Longitudinal acceleration: 0.07 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
                    Steering_angle-Data: 3.500 °
                    Yaw_rate-Data: 0.123 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.214 °
                    Misalignment angle: horiz: fast algorithm: 0.232 °
                    Congestion pilot: status: OFF
                    Outside temperature: 8.50 °C
                    Sensor blindness: radar: no blindness detected
2343 - Databus
          [FAULT_CAMERA_DIRT_PEDEST]
                    Reset counter: 160
                    Mileage: 85577 km
                    Date: 2024.12.14
                    Time: 11:11:28
   Part No SW: 4N0 959 655 R    HW: 4N0 959 655 H
   Component: AirbagVW31    H35 2710
   Serial number: 003U1M00AHKH Dataset Number: 4K0909602AC 0003
   Coding: AACCF0C00CC00000985400FFF08D41AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
   VCID: 4BC377FDA34D3892F21-801E
   Left seat belt tensioner:
   Serial number: 00AI2018169326100000
   Coding: 04F001
   Right seat belt tensioner:
   Serial number: 00AI2018177307700000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 000 207 18
   Serial number: 35700000000DF5D0113N
   Subsystem 4 - Part No SW: -----------    HW: 480 000 207 18
   Serial number: 3580000000030CD4D03L
   Subsystem 5 - Part No SW: -----------    HW: 480 031 206 18
   Serial number: 351001C103A9ED6028DF
   Subsystem 6 - Part No SW: -----------    HW: 480 031 206 18
   Serial number: 352001C103A9A0912AC4
   Subsystem 7 - Part No SW: -----------    HW: 480 030 507 18
   Serial number: 355001C107E63A60CA6F
   Subsystem 8 - Part No SW: -----------    HW: 480 030 507 18
   Serial number: 356001C107EDFC20A85S
   Subsystem 9 - Part No SW: -----------    HW: 480 032 506 18
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C10F435EB06BEG
   Subsystem 10 - Part No SW: -----------    HW: 480 002 506 18
   Serial number: I0M000000008C6106FAC
   Subsystem 11 - Part No SW: -----------    HW: 480 002 506 18
   Serial number: I0N00000000FD6106FAL
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_VW53.rod
   Part No SW: 4K0 920 790 B    HW: 4K0 920 790 B
   Component: FBenRDWACC--- H11 0211
   Dataset Number: 4K0909525B  0021
   Coding: A58D38E27C8806000193E560B080680008001000
           A58D38E27C8806000193E160B080480008001000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 2C01146106831FAADBB-8078
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Reset counter: 163
                    Mileage: 85281 km
                    Date: 2024.12.11
                    Time: 14:58:18
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 AB
   Component: Gateway       H14 0036
   Revision: 8P020004    Serial number: 0488P798418704 Dataset Number: 4K0909515B  0028
   Coding: 02010005000486408C960000005B0132DC9A004F18000000097D078E10000000
   GVL: F1517C080804020082DC88000100C800110E0070010000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186311001806090A6B
8519683 - Energy Management Active
          U140B 00 [00001000] - -
                    Reset counter: 163
                    Mileage: 85912 km
                    Date: 2024.12.28
                    Time: 01:35:43
                    EM_vehicle_state: 00 00
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
9457921 - Backup Battery
          B1916 04 [00001001] - Internal System Fault
                    Mileage: 85912 km
                    Date: 2025.01.08
                    Time: 09:47:51
                    Voltage terminal 30: 12.20 V
   Part No SW: 4N0 907 144 C    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0802
   Serial number: 30303030303030 Dataset Number: 4K0909848G  0001
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2E051E69309F6DBAF5F-807A
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 17000400504018
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 34310C01DEB3476A83B-8060
   Component: MEM-FS        009 0042
   Serial number: 00000331490072 Dataset Number: 4K8909856B  0013
   Coding: 00781A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4N0 907 566 E    HW: 4N0 907 566 A
   Component: MRR_HR H12 0265
   Dataset Number: 4K8909535D  0024
   Coding: 5FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 38293831C2DBA30AAF3-806C
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: YE007RFK26676 Dataset Number: 4K8909872B  0025
   Coding: 001DDA0152010480A009B032
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 40D950D19A0BEBCA173-8014
   Dataset Number: 4K0909852J  0004
   Coding: E1002101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D0A1924A7495A917-8066
   Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0145
   Dataset Number: 4K8909501D  0037
   Coding: 01350000EFB100406309A0046C04C80203004000804F02502F0400000504823F001F0100010F01
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008_AU58.rod
   VCID: 7EA5EE29A07F5D3A25F-802A
   ID - sensor:
   Subsystem 1 - Part No SW: 4N0 959 754 BL    HW: 4N0 959 754 BL
   Component: ID-Geber  H11 0237
   Serial number: 3622000061100024
   Serial number: 000000000ZY181502LE6
   Serial number: 00000000000099364862
   left tail lamp 1:
   Subsystem 4 - Part No SW: 4K0 945 217     HW: 4K0 945 217
   Component: SHL_li1  003 0001
   Serial number: 00000000000000151247
   Subsystem 5 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58522194
   Rear spoiler control module:
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4K5 945 093 D    HW: 4K5 945 093 D
   Component: SHL_li2  003 0001
   Serial number: 00000000000000042371
   Right rear tail lamp 1:
   Subsystem 8 - Part No SW: 4K0 945 218     HW: 4K0 945 218
   Component: SHL_re1  003 0001
   Serial number: 00000000000000149521
   Right rear tail lamp 2:
   Subsystem 9 - Part No SW: 4K5 945 094 D    HW: 4K5 945 094 D
   Component: SHL_re2  003 0001
   Serial number: 00000000000000062276
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ6S0029H. Dataset Number: 4K0909510A  0009
   Coding: 0185020000AAAA2FAA0000010000
   Shop #: WSC 00494 572 00000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411FC416E53D7EA13B-8070
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: YE007RFR12294 Dataset Number: 4K8909873B  0025
   Coding: 001DDA015E010480A009B030
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 3FDB532DE7F594326E9-806A
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 G    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   046 2873
   Dataset Number: 4K0909545E  0026
   Coding: 0185020100000000C3111102C00800302F0001E601F008008E
   VCID: 270BEB4D1F653CF2369-8072
   Subsystem 1 - Part No: V03 959 807 SR
   Component: MIB2P_EU_Q323  0690
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4K0 919 605 C    HW: 4K0 919 605 A
   Component: DU AU58x High  H42 0147
   Serial number: INX00125041800060140
   Compact disc data bank:
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004418000108473029
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4K2 919 603 B    HW: 4K2 919 603
   Component: DU AU58x Bot  H41 0147
   Serial number: INX00124041800090246
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800430849001
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290FED7509710A8220D-807C
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0554018626 Dataset Number: 4K0909527A  0004
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 35373105D5C95E62B45-8060
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0166
   Revision: --------    Serial number: 31995017900000 Dataset Number: 4K0909541A  0008
   Coding: 12F0
0056 - Databus
                    Reset counter: 156
                    Mileage: 85303 km
                    Date: 2024.12.11
                    Time: 18:04:07
0061 - Databus
                    Reset counter: 156
                    Mileage: 85303 km
                    Date: 2024.12.11
                    Time: 18:04:07
0062 - Databus
                    Reset counter: 156
                    Mileage: 85303 km
                    Date: 2024.12.11
                    Time: 18:04:07
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4K0 907 777 AS    HW: 4K0 907 777 A
   Component: Fahrwerk-SG   H51 2016
   Serial number: 0107180380  Dataset Number: 4K0909576G  0002
   Coding: F45C3838DA40
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 084988F1F2BB138A1F3-805C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130350223
   Coding: 303030
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4K2 713 041 L    HW: 4K2 713 041 H
   Component: GSM-LL H14 0056
   Serial number: 18.166 40087
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2D0719653D9916A2CC5-8078
Address 82: Head Up Display (J898)       Labels:| 4Nx-919-617-V1.clb
   Part No SW: 4K2 919 617 A    HW: 4K2 919 617 A
   Component: HeadupDisplay H05 1808
   Coding: 4700E2
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 33330F1DDBBD40529A1-8066
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0291
   Dataset Number: 4K0909466J  0041
   Coding: 04C184000000000000FFD60100F0D60C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
           04C184000000000000FFD60000F0D40C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001005
   ROD: EV_ZFASAU516_001.rod
2117711 - Internal Fault
          B200F F9 [00001000] - Unknown Error Elaboration
          [ZGT Überwachung am SRH fehlgeschlagen]
                    Reset counter: 155
                    Mileage: 85281 km
                    Date: 2024.12.11
                    Time: 14:56:06
                    Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 01 00 48 11 93 11 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SRH-ErrorHandlerSRH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [00001000] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 160
                    Mileage: 85312 km
                    Date: 2024.12.12
                    Time: 16:01:03
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 16 °C
                    Vehicle speed: 24.12 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: No
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
81922 - Matrix Headlamps
          C1299 F0 [00001000] - Fog Mode Active
                    Reset counter: 157
                    Mileage: 85307 km
                    Date: 2024.12.11
                    Time: 18:12:25
Address AC: Reductant Control (J880)       Labels: 80A-907-355.clb
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0004
   Dataset Number: 4K0909571D  0003
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: YE007RG429833 Dataset Number: 4K8909897B  0025
   Coding: 000DD80100010480A008B020
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: 42DD5AD99407F9DA017-8016
   Component: TSG HBFS003 0188
   Serial number: YE007RG425699 Dataset Number: 4K8909896B  0025
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   Dataset Number: 4K0909475A  0007
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2D2239FCD7B11A597-806E
   Component: SAD_STG_1     005 0002
   Dataset Number: 4K0909469F  0014
   Coding: 768040058203
   VCID: 75B7F10595491E62745-8020
Address CB: Rear Axle Steering (J1019)       Labels:* 4M0-909-145.clb
   Part No SW: 4N0 909 145 L    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0399
   Revision: --------    Serial number: CCC_099_B_9056_ Dataset Number: 4K0909904K  0001
   Coding: 42246200
   Shop #: WSC 38833 005 1048576
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 10071800020262
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 C    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0205
   Dataset Number: 4KA909639F  0005
   ASAM Dataset: EV_LaserScannAU651 013017
   ROD: EV_LaserScannAU651_013.rod
   VCID: 36353609C8CF557ABDF-8062
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0265
   Dataset Number: 4K8909468D  0024
   Coding: 5FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0032
   ROD: EV_LMSLeftHELLAAU58X_AU58.rod
   VCID: 72BDCA19E427095A517-8026
   Dynamic left front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 035     HW: 4K0 941 035
   Component: M134DynTurnFL  003 0004
   Serial number: 06122100075268001011
   Component: LMS_MLBevo    H10 0030
   Dataset Number: 4K0909472H  0014
   ROD: EV_LMSRightHELLAAU58X_AU58.rod
   Dynamic right front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 036     HW: 4K0 941 036
   Component: M135DynTurnFR  003 0004
   Serial number: 27111700001122001011
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 E    HW: 4N0 907 669 A
   Component: MRR_VR H12 0265
   Dataset Number: 4K8909482C  0017
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
   VCID: 3C212421F6E38F2A4BB-8068
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0265
   Dataset Number: 4K8909483C  0018
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     005 0002
   Dataset Number: 4K0909581C  0010
   Coding: 729000058204
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623_VW37.rod
   VCID: 76B5F609884F157A7DF-8022
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4K0 035 502 A    HW: 4K0 035 502 A
   Component: WLC Front     H10 0061
   Coding: 400000
   ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
   VCID: 1F1BF3AD4735F4324E9-804A
End----------(Elapsed Time: 02:23, VBatt start/end: 15.2V/15.2V)-----------
There's nothing for Bytes 11 and 12 in the data I have access to either. It skips straight from 10 to 13. :confused:
Adrian1871
C?ID=573462
uwe another question if you don't mind i see in can gateway i made an l change (installation list) 19 can gateway from the coding it looks ok it states F1517C080804020002DC to F1517C080804020082DC can you confirm with above scan weather this is back too original
and below is engine 01 no label file, not sure if it was me messing or its picked up coding from dealer who coded tow bar using ODIS SVM
Address 01,4K0 907 401 K,recoded (Long Coding),from,122A4012056E050334286000000400000000000000000000,to,122A4012057E050334286000000400000000000000000000,(23208/004/1048576),Sunday,03,March,2024,11:35:47:07763
AINils
Germany (AIB)
C?ID=56975
Agree wit Uwe in your A5 Byte 11 isn't used.
I believe the issue in your case is thsi fault:
