Changelog for 15.7.2
Sebastian
Magdeburg, Germany
HN0-nnnnnn
15.7.2 was primarily pushed to add support for the 2016 VW Touran (5T1).
Enriquez
Poland
C?ID=72075
What about MIB 5F units in MQB.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
There will be a 15.7.3 which adresses those shortly.
Enriquez
Poland
C?ID=72075
Fine. Thank You.
ZEAL
Japan
C?ID=33670
Hi, I updated VCDS 15.7.3 for my Golf mk7(Japanese) from 15.7.2 but I can not see any long coding helper on STG 5F information electronics.
And also I can not see STG 09 label file too. Until 15.7.2, I personally edited comment out of my STG09 module name of "5Q0 937 085 Q" to display long coding helper but from 15.7.3, 5Q-09.lbl file was changed from text file to binary file of 5Q-09.cbl file that I can not edit myself.
Will you please support my STG 09 module of 5Q0 937 085 Q on 15.7.3 also. Thank you.
Below is my autoscan result.
Friday,18,December,2015,09:37:19:49058
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WVWZZZAUZEWxxxxxx    License Plate:
Mileage: 10026km-6229mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 13 14 15 16 17 19 42 44 52 55 5F A5
VIN: WVWZZZAUZEW119852   Mileage: 10026km-6229miles
Address 01: Engine (J623-CPTA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 CH    HW: 04E 907 309 G
   Component: 1,4l R4 TSI   H02 5759
   Revision: WKH02---
   Coding: 01250012236405082000
   ASAM Dataset: EV_ECM14TFS01104E906016CH 002004
   ROD: EV_ECM14TFS01104E906016CH.rod
   VCID: 6AFDEFDF8DC04B6ECF-803E
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4531
   Revision: 00043014    Serial number: CU501308275307
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 76C5CBAFC9789F8E5B-8022
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6247300000067E
   Coding: 01FA8AA134212975037F060581C52980512C94C0608194F3F82250B8C106
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7CD1D987F754C5DE2D-8028
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0912
   Revision: 00001K06
   Coding: 00120014100100011105004011101800
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 66E59BEF99D86F0EEB-8032
   Part No SW: 5Q0 937 085 Q    HW: 5Q0 937 085 Q
   Component: BCM MQBAB HNA H14 0112
   Serial number: 00011323900304
   Coding: 03101B46424122FB49E44000000C0728100A000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 47BB766BFE125606F0-8012
   Slave 1:
   Component: WWS    130816  042 0551
   Serial number:         130902160433
   Coding: 3DEBFD
   Slave 2:
   Component: RLFS  024 0042
   Serial number: Y13M09D09H04M10S25S1
   Coding: 34E866
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO23472800
   Coding: 181901
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H03 0141
   Serial number: 17071376510658
   Coding: 021C1700FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 35470CA394FED49692-8060
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0114
   Serial number: 07081341353768
   ROD: EV_DRCONTITEMIC.rod
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR009HW2
   Coding: 98FCC0C0000000005C5400CF00C800000065
   VCID: 7F2B2E8BE642DEC608-802A
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B10091350587
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B10091340720
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 608 13
   Serial number: 3576700000077880CD0/
   Subsystem 4 - Part No SW: -----------    HW: 480 002 608 13
   Serial number: 358670000008DC7DDD0M
   Subsystem 5 - Part No SW: -----------    HW: 480 400 609 13
   Serial number: 3516502AF111871031B
   Subsystem 6 - Part No SW: -----------    HW: 480 400 609 13
   Serial number: 3526502A51118715B1F3
   Subsystem 7 - Part No SW: -----------    HW: 480 400 209 13
   Serial number: 3556502AD1088B156148
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 05091304400312
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 7BD3DA9BF25AC2E624-802E
   Part No SW: 5G0 920 861 B    HW: 5G0 920 861 B
   Component: KOMBI         204 3390
   Coding: 27AD19087F84000E02887A03040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_SK37.rod
   VCID: 2879D5D7534CB97E19-807C
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000898242
   Coding: 030100042B086400FF00065E9C0F00010001000000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 3B531A9BB2DA02E664-806E
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H14 0035
   Serial number: 02130001613170083156
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 0555991103
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 19081302091348
   Coding: 003B0320D001048000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 3FAB6E8BA6C21EC648-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000002629007
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 91
   ROD: EV_SteerAssisMQB.rod
   VCID: 3D571483ACCE0CD65A-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 24081303110144
   Coding: 003B0120DE01048000801000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 3E55138FA1C817CE43-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000002567500
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029602000F010200
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 050 A    HW: 5G0 035 050
   Component: MU-H-N-JP     H41 0258
   Serial number: K5F AW74A00640
   Coding: 02730006FF00000021330001001000001F0200360100010077
   ASAM Dataset: EV_MUHig4CAW7 001105
   ROD: EV_MUHig4CAW7_VW37.rod
   VCID: 1A1DFF1F1D201BEE9F-804E
   Media Player Position 1:
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9N2300UPS
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 802 NP    HW: -----------
   Component: JPN 2016  --- 7521
   Door Electronics Driver Side:
   Subsystem 3 - Part No SW: 8V0 919 813     HW: 8V0 919 813
   Component: DSRC UNIT  H04 0001
   Serial number: 502030045201
   Brake Assistance:
   Subsystem 4 - Part No SW: 8V0 035 504 A    HW: 8V0 035 504 A
   Component: VICS Antenna  H03 0001
   Serial number: 503040050101
          B201A 00 [009] -  -
                    Reset counter: 12
                    Mileage: 9894 km
                    Date: 2015.12.12
                    Time: 15:51:22
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000109825
   Coding: 0101010100020303000401000101010100
   ROD: EV_MFKBoschAU370_AU37.rod
   VCID: 3A5D1F9FBDE03BEE7F-806E
End-------------------------(Elapsed Time: 04:21)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Hello ZEAL,
While changing files yourself was always an option - one thing we noticed was that often customers didn't provide feedback which then resultet in us not being able to make the necessary changes as well. >This is part of why we appreciate Auto-Scans being sent in, they help us a lot to improve the product. Thanks for your scan, I've made the necessary changes and both modules will be covered with the next update.
ZEAL
Japan
C?ID=33670
Sebastian, Thank you. I will expect for next update which will support my Golf 7.
ZEAL
Japan
C?ID=33670
Hi,Sebastian.
I just downloaded VCDS 15.7.4 and confirmed long coding helper are activated on STG09 and STG5F in my Golf mk7(Japan).
Thank you very much for your help to reflect my request.
NitrousOxide
Jamaica
C?ID=269481
Is there a way to see a change log for 15.7.4? I downloaded and installed it, but I don't know if I get any supported benefits for my 2008 MK5 Glof GTI for the DSG transmission. I want to be able to make changes to the shift points in the transmission (or at least get some sort of long coding support).
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Ross-Tech usually doesn't supply a changelog for minor versions. The changes were rather minor, a coding related issue effecting MY 2016 vehicles was fixed and some tweaks regarding HEX-NET support were implemented (both, thanks to Eric). documentation wise, there were some quite a few and additions going back as far as MY 2002. So updating is always recommended.
As far as shift point changes go, this would be something you'd need to talk to a tuner about. VCDS was never and will never be able to make these kind of modifications. Long coding support requires the control module itself to support that type of coding. The 6-Speed DSG (02E) in your GTI is simply too old for that kinda stuff (meaning this isn't a limitation of VCDS, but one of the control module in question)...
