Resolved 2014 Jetta SE 1.8 TSI CPRA: P2006 P2015
Resolved
BBvr6
C?ID=570111
Having a hard time trying to fix codes for Intake Manifold Flap Stuck Closed (p2006) and Intake Manifold Flap Position Sensor: Implausible Signal (p2015). I did some research and noticed that the actuator arm was not moving when throttle was being applied, supposed to open up above ~3.5k rpms. Assuming the diaphragm was bad I went and purchased a new intake manifold from UroTuning. It came with new actuator mechanism, flap position sensor, and control valve + plus new gaskets for manifold and throttle body. Installed new manifold and cleared codes.
Even after replacing said components I'm still getting these codes as soon as the car starts up. The flap arm is however moving now when revved up. I've read that once replacing the intake or any of the IMRC sensors, adaptation is required in basic setting. It's also different for new chain driven engines since those have to be adapted while idling because of the vacuum operation. The issue I'm having is that there is no IMRC basic setting adaption showing up for me in VCDS.
I even tried replacing the flap position sensor back to the oem one from the old intake manifold but results are still the same. I'm completely stumped on what to try next. I feel like It's going to be something simple that's right under my nose. Hoping someone can chime in and see what I'm doing wrong.
P.S The camshaft is an intermittent unrelated issue (I hope) that I'm sure is a faulty camshaft adjuster magnet. The car will occasional idle rough and jerk the car if i put it in drive. Goes away when I rev the engine. Other than these two known issues the car drives great, has good power.
Tuesday,14,January,2025,22:10:24:58671
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: 3VWD17AJ4EM302231   License Plate:
                Address 01: Engine       Labels: 06K-907-425-V2.CLB
Control Module Part Number: 06K 906 070 F    HW: 06K 907 425
  Component and/or Version: Simos12.2     H09 8052
           Software Coding: 001A0012242400170000
            Work Shop Code: WSC 00066 790 00184
              ASAM Dataset: EV_ECM18TFS02006K906070F 001012 (VW36)
                       ROD: EV_ECM18TFS02006K906070F.rod
                      VCID: 2D0C647ADD9F6C92C4D-8078
15200 - Intake Manifold Flap; Bank 1
          P2006 00 [00100111] - Stuck Closed
                    Mileage: 254097 km
                    Date: 2115.14.26
                    Time: 03:09:41
                    Engine RPM: 995.75 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 50 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 870 mbar
                    Voltage terminal 30: 14.375 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 6 s
                    MAP_MES_SAE: 34 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.051 V
                    FAC_TPS_1_SAE: 12.890625 %
                    FUP_H_SAE: 12150.0 kPa
15195 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [00100111] - Implausible Signal
                    Mileage: 254097 km
                    Date: 2115.14.26
                    Time: 03:09:42
                    Engine RPM: 984.50 /min
                    Normed load value: 12.5 %
                    Voltage terminal 30: 14.394 V
                    T_AST_SAE: 6 s
                    MAP_MES_SAE: 34 kPa
                    FUP_H_SAE: 11950.0 kPa
14868 - Camshaft Position Sensor (G40)
          P0341 00 [00100111] - Implausible Signal
                    Mileage: 254097 km
                    Date: 2115.14.26
                    Time: 03:09:34
                    Engine RPM: 1000.50 /min
                    Normed load value: 9.4 %
                    Coolant temperature: 52 °C
                    Voltage terminal 30: 12.011 V
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 34 kPa
                    FAC_TPS_1_SAE: 11.718750 %
                    FUP_H_SAE: 12310.0 kPa
Readiness: 1110 1101
Wednesday,15,January,2025,15:22:49:58671
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 070 F    HW: 06K 907 425
   Component: Simos12.2     H09 8052
   Revision: --H09---    Serial number: 00000000000000 CVN: 788F8E62
   Shop #: WSC 00066 790 00184
   VINID: 0E69D404745A11574300208304B63EFDB8
          P2006 00 [01100101] - Stuck Closed
                    Mileage: 254097 km
                    Date: 2115.14.26
                    Time: 20:23:50
                    Engine RPM: 962.25 /min
                    Normed load value: 16.5 %
                    Coolant temperature: 14 °C
                    Intake air temperature: 3 °C
                    Voltage terminal 30: 14.531 V
                    T_AST_SAE: 72 s
                    MAP_MES_SAE: 36 kPa
                    FUP_H_SAE: 5630.0 kPa
          P2015 00 [01100101] - Implausible Signal
                    Mileage: 254097 km
                    Date: 2115.14.26
                    Time: 20:23:51
                    Engine RPM: 953.75 /min
                    Voltage terminal 30: 14.511 V
                    T_AST_SAE: 72 s
                    MAP_MES_SAE: 36 kPa
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 5490.0 kPa
Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
   Part No SW: 09G 927 749 A    HW: 09G 927 749 A
   Component: AISIN AG6 G3  109 2856
   CVN: 481EBFD0
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 001004
   ROD: EV_TCMAQ250031_001_VW25.rod
   VCID: 372046122FC3D642AE1-8062
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492200FC850D02E7921A0041A1100012
   Shop #: WSC 11558 002 1048576
   VCID: 045AE1DE2E154DDA7B3-8050
                    Fault Status: 00101101
                    Reset counter: 203
                    Mileage: 225917 km
                    Date: 2032.14.01
                    Time: 21:30:51
                    Count: 3
                    Count: 32769
                    Count: 4608
                    Count: 8266
                    Count: 33100
                    Count: 1
                    Count: 1533
                    Reset counter: 203
                    Mileage: 254013 km
                    Date: 2048.14.22
                    Time: 00:44:60
                    Count: 16386
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 42752
                    Count: 778
                    Count: 1280
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Status: 00101100
                    Reset counter: 203
                    Mileage: 254013 km
                    Date: 2051.14.17
                    Time: 00:00:01
                    Count: 16387
                    Count: 12
                    Count: 512
                    Count: 32
                    Count: 42752
                    Count: 1024
                    Reset counter: 203
                    Mileage: 253737 km
                    Date: 2047.14.07
                    Time: 11:59:30
                    Count: 14
                    Count: 29184
                    Count: 8196
                    Count: 50432
                    Count: 512
                    Count: 512
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 8
                    Reset counter: 24
                    Mileage: 180812 km
                    Date: 2010.14.26
                    Time: 05:34:58
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 51839
                    Count: 1023
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BK    HW: 5C0 820 047 BK
   Component: J301  Klimaanlage   0204
   Revision: 2001001S    Serial number: 00000002153030
   Shop #: WSC 00066 000 00000
   VCID: 6A86AF662071BBAAE1F-803E
00229 - Refrigerant Pressure
                    Reset counter: 203
   Part No SW: 5C0 937 087 J    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H34 0411
   Revision: B2034001    Serial number: 08013125141221
   Coding: 7B994B1808AB0B0000302000240884D400C2502E60004000300010002000
   VCID: 343A711E3E353D5A8B3-8060
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585140404171039
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584140410222808
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14202587140414113914
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586140409214327
   Coding: 800000
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 209
                    Mileage: 254073 km
                    Date: 2051.14.24
                    Time: 21:27:39
                    Reset counter: 203
                    Fault Frequency: 15
                    Reset counter: 203
                    Mileage: 254013 km
                    Date: 2049.14.20
                    Time: 18:48:08
02660 - Radio Remote Control not Matched/Adapted
                    Reset counter: 201
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD04DZ91   Dataset Number: 160003v____ 0219
   Coding: 00004138
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74BAB11E7E357D5A4B3-8020
   Serial number: 6940000Y14000150J906
   Coding: 303037
   Serial number: 3572MSME7956607EZZZ4
   Serial number: 3582MSME44541D43ZZZW
   Serial number: 3516KSME12223C2CZZZP
   Serial number: 3526KSME2E393C2CZZZ4
   Serial number: 3556LSME625A0E2CZZZ2
   Serial number: 3566LSME2C500E2CZZZ%
Address 17: Instruments
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H34 0411
   Revision: B2034001
   Coding: 102200
   VCID: 70B2BD0E0AAD417AAFB-8024
   Component: IMMO          H04 0809
   VCID: 6A86AF662CF1BBAAE1F-803E
9456681 - Key
          B104C 29 [00001000] - Implausible Signal
                    Mileage: 178745 km
                    Date: 2072.14.06
                    Time: 00:03:47
   Revision: A1001003    Serial number: 7665833706
   Coding: 010100
   VCID: 2B086A62E30B62A2DA9-807E
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 69     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3924402A1557C032585-806C
                    Reset counter: 203
                    Mileage: 254013 km
                    Date: 2051.14.17
                    Time: 00:01:25
                    Voltage: 14.38 V
                        DU
                    Temperature: 5.0°C
                    RPM: 922 /min
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H04 0005
   Revision: -----08S    Serial number: VWZ4Z6P3778891
   Coding: 01000400020006
   VCID: 251C9C5A85EF54D20CD-8070
                    Reset counter: 194
                    Mileage: 74411 km
                    Date: 2030.14.28
                    Time: 01:27:30
End----(Elapsed Time: 01:38, VBatt start/end: 12.4V/12.0V. VIgn 11.9V)-----
Dr Sheldon
Windsor UK
C?ID=334979
That should be a 3 wire affair - Is it ?
With it plugged in (Ign on) What voltage readings are you getting on all 3 wires ? (backprobe the connector)
Then if you move the flaps from one stop to the other - What voltages ?
Is there a MVB for Flap Voltage - If so Graph it - end to end - and post a picture.
If possible look at the MVB while running an Output Test.
BBvr6
C?ID=570111
I finally found the issue. There was a small pinhole on the brake booster vacuum hose. I didn't find it sooner because I was only testing the vacuum lines going to the intake. 🫢
Funny thing is I found it accidentally. I was going to remove the brake booster hose to check if the booster was holding any vacuum. When I grabbed the hose I felt the hole on the underside of it. I visually checked this hose prior and it "looked" fine from the top.
Also, I believe the reason the CEL came on so quick is because the ECM does a flapper sweep type deal on startup. In VCDS I can see that it commands the control valve a few times but the position of the flap wasn't moving due to the lack of a strong vacuum. Explains the implausable signal code.
