Control Module - Incorrect Chassis (VIN) Number
midwboss
C?ID=264552
I just picked up a 2004 s4 sedan with a few issues. Some i have ironed out but stumped on a few hope someone can lead me down the correct path.
1. The dome lights do not work nor do the visor lights- i do however have the footwell lights when the doors are opened and the all others seem to function.
2. my alarm does not work from the key fob nor does the horn chirp when I lock the key manually with the key. I do hear the doors lock though.
I have done a auto scan and there seems to be some modules that are reading incorrect vin numbers. Im new to the vag system but not new to flashing etc. I mainly have worked with hp tuners and EFi Live. any help would be greatly appreciated .
 Tuesday,01,December,2015,15:07:55:22465
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUPL68E54A069501   License Plate: FNS1998
Mileage: 219750km-136546mi   Repair Order:
          67 69 75 76 77
VIN: WAUPL68E54A069501   Mileage: 219750km-136546miles
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8E0 910 560 C    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0010
   Coding: 0007771
   Shop #: WSC 22705 444 58975
   VCID: 25419305EFB6C71638-5124
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit
17985 - Right Engine Mount Solenoid Valve (N145)
            P1577 - 004 - Open Circuit
16815 - Warm Up Catalyst; Bank 2
            P0431 - 001 - Efficiency Below Threshold - Intermittent - MIL ON
   Part No SW: 8E0 910 156     HW: 09L 927 156
   Component: AG6 09L 4.2L5V USA  0020
   Revision: 00000001    Serial number:        0001404
   Coding: 0000002
   Shop #: WSC 63351 000 00000
   VCID: 63C5CD1DA102792616-5124
18141 - Tiptronic Down Switch (F189)
            P1733 - 000 - Short to Ground
                    RPM: 768 /min
                    RPM: 736 /min
                    (no units): 30.0
                    (no units): 23.0
                    Temperature: 54.0°C
                    T.B. Angle: 0.0°
                    Voltage: 12.80 V
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 Q
   Component: ABS/ESP allrad      3033
   Coding: 04597
   Shop #: WSC 06435
   VCID: 366344491210BC8E81-5124
   Part No: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 62CBC819EE18702E1D-5140
No Faults Found
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   Shop #: WSC 01116
   VCID: 356143450F16B79688-4B00
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 -  -
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        3001
   Coding: 0010607
   VCID: 377D494D451A45869A-5140
            000 -  -  - Intermittent
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0611
   Coding: 01141
   Shop #: WSC 63351
   VCID: 3E735C693A2074CE59-4B00
            127-10 - Unknown Error Elaboration - Intermittent
            35-00 -  -
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 980 M
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 03200
   Shop #: WSC 01115
   VCID: 366344491210BC8E81-5140
   Subsystem 1 - Part No: 69501
   Component: AUZ6Z0C0196202
   69501     AUZ6Z0C0196202
01304 - Radio
            49-00 - No Communications
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71E9B7553BFEDBB694-4AE8
            06-10 - Signal too High - Intermittent
            35-00 -  -
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1411
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72EBB8593EF8E0AE6D-4B1A
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0003
13 Faults Found:
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
01374 - Alarm triggered by Terminal 15
            35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -  -
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 -  -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 -  -
00958 - Key 4
            35-10 -  -  - Intermittent
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
01562 - Rear right door
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00060
   Shop #: WSC 63351
   VCID: 0407EE81144CDE1E4F-4B1A
            30-00 - Open or Short to Plus
Address 75: Telematics        Labels: 8E0-035-616.lbl
   Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
   Component: Telematik USA1
   Coding: 0005003
   Shop #: WSC 00000 785 00200
   VCID: 23458D1DE182392656-5124
01528 - Auxiliary Antenna for Telematic (R90)
01304 - Radio
01531 - Emergency Battery
            002 - Lower Limit Exceeded - MIL ON
End-------------------------(Elapsed Time: 06:21)--------------------------
Gone But Not Forgotten
I can help fix all those inaccurate VIN #s.......... provided you have your papers in order.........
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please see the last special note for this DTC 01794 in the 8E in our WIKI (Uwe already posted the link). This is a known bug with those instrument clusters, no need to "background search" VINs here or "fix all those". Only the cluster needs to be fixed, any Audi dealer should be able to do that - the other VINs are still programmed correctly but the control modules are complaining since the "master VIN" in the cluster is corrupted. This perfectly matches the examples shown in the WIKI as well.
If an alternate VIN is present than what is on the data plate; it should always be checked out further by being authenticated with the national crime database.
Yeah there is a bug in this controller, however, it takes seconds to see if there are multiple VINS and check them.
https://www.nicb.org/theft_and_fraud_awareness/vincheck
It takes hardly any effort........
I mean hell........if taking the "Wizards" stance.......... why adhere to the warnings of the actual DTC's & the reason it was created in the first place seems a bit ........DUMB!
midwboss
C?ID=264552
Sorry I have been away on vacation and just getting back to the headache in my driveway. Thanks for all of the replies. So I checked the vin and it did not come back stolen. So what I gather here is that I should take it to the audi dealer to have them fix the cluster? Are they the only ones who can write the script of the vin into the instrument cluster?
