2004 passat wagon 1.8t 01V trans issue?
South Cove VW
Canada
C?ID=10409
hello
i am new to diagnosing automatics and i have one here that is stumbling between upshifts and sometimes flaring up a slight bit i wouldnt say a full on slip though as i did monitor the shifting with vcds and seems to go in all gears fine
it did have code 17090 for transmission range sensor implausible signal but there were no symptoms of it being faulty
any info is of great help
thanks
South Cove VW
Canada
C?ID=10409
VCDS Version: Release 15.7.2 Running on Windows 7 x86
Data version: 20151124
Thursday,03,December,2015,11:32:08:29821
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWVD63B64E015556   Mileage: 160110km-99487miles
Address 01: Engine        Labels: 06B-906-018-AWM.clb
   Part No SW: 4B0 906 018 DQ    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0060
   Revision: 00000000    Serial number: VWZ7Z0C7525450
   Coding: 0016551
   Shop #: WSC 08282 444 85764
   VCID: 73EFD39D11C155A666-4FAA
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 3B0 614 111
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00021
   Shop #: WSC 05314
   VCID: 53AF731DA18135A686-4FAA
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 05311
   VCID: 244DE0C1B4AF821E2F-4F8E
00592 - Seat Belt Switch; Passenger (E25)
            32-10 - Resistance Too High - Intermittent
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 929 B
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 15235
   VCID: 2649FAC9C293700E31-4F8E
   WVWVD63B64E015556     VWZ7Z0C7525450
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70E5DC9130D76EBE9B-4F8E
   Part No: 1C0 959 799 C
   Component: 80 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 05311
   VCID: 3777278D1539F9869A-4978
   Subsystem 1 - Part No: 1C1959801
   Component: 80 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 80 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 80 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 80 Tõrsteuer.HR KLO 0202
00912 - Window Regulator Switch; Front Left (E40)
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 E
   Component:    Radio NP2        0008
   Coding: 00031
   Shop #: WSC 05311
   VCID: 2241E6D9AEBB8C2E5D-4F8E
End-------------------------(Elapsed Time: 05:22)--------------------------
Gone But Not Forgotten
Okay so not in the scan .......did you try direct communications?
Check for Wasser in floor boards.
If you need a controller let me know I have them new and reman.
South Cove VW
Canada
C?ID=10409
thanks
i checked for water it was all dry
it will not connect to controller everytime but when it does connect i sometimes only get a minute or so and then stops responding
Are you sure there is no water inside the module.........?
No talky in auto-scan .........post manual scan data and a brief log of the blocks 1-5 to observe.
0x02-02 Please........
0x02-08-001-005 log
South Cove VW
Canada
C?ID=10409
i will double check for water
again i am still a little new with loging and such
how do you post manual scan data ?
South Cove VW
Canada
C?ID=10409
i just tried again
i got in 02 controller for minute was able to log groups 001-003 then lost comunication
saved log but cannot figure out how to post the text ? it opens up in a spreadsheet ?
i am going to lift carpert now again and check controller for water
South Cove VW
Canada
C?ID=10409
have trans controller in hand now dry as can be
the plastic case its in is dry with no signs that moisture was here
South Cove VW
Canada
C?ID=10409
is there away to safely open controller up to see if wet inside?
having trouble trying to post the logs?
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Opening the TCM is common sense.
TCM should not be missing from auto scan! Getting kicked out of TCM when logged in happens but usually re-connects.
I would also take the back of the connector to TCM apart and look for corrosion at the front of the pins and the rear.
Using a wiring diagram I would also back probe and monitor power & ground to the TCM while I log in and see if they stay present when the TCM kicks you out.
I would also provide my own constant power and ground to unit and see if it still kicks me out.
Also is this car new too you? TCM water damage is common. Could someone have already replaced the TCM in the past. You also need to check the part # to see if it is the right TCM for you car.
Good Luck
South Cove VW
Canada
C?ID=10409
thanks
i opened tcm all dry no corrosion
the vehicle is a customers so i guess it would be new to me do not know full history
i will check pins when i get it back in the shop if they all check out good i feel i maybe safe to try a known good tcm?
thanks again for your help
vwtech
Wilkes-Barre, PA
C?ID=7573
I would still check power & grounds to TCM with a headlight bulb as a test light.
This will draw a few amps and basically be a load test of power and ground.
When you do this try and log in while watching the light.
Good Luck
South Cove VW
Canada
C?ID=10409
i checked power and grounds at tcm all is good there even when it kicks me out
i was able to test drive and log but still unsure how to post the logs on here
on this test drive trans was starting in 4th gear and the gear select lights were all lit up
and code 17090was now stored, i ran another auto scan and i swore it picked up tcm but after all done still no info on tcm ?
i will post auto scan should i be looking for at the range switch now?
thanks
Monday,07,December,2015,13:17:09:29821
VIN: WVWVD63B64E015556   Mileage: 160120km-99493miles
   Coding: 0016551
18034 - Powertrain Data Bus
            P1626 - 004 - Missing Message from TCU - Intermittent
   Coding: 00021
   Shop #: WSC 05314
            P1626 - 35-10 - Missing Message from TCU - Intermittent
   Coding: 12345
   Shop #: WSC 05311
   Coding: 15235
   Coding: 00006
   Shop #: WSC 05311
   Coding: 00258
   Shop #: WSC 05311
   VCID: 3777278D1539F9869A-4990
   Coding: 00031
   Shop #: WSC 05311
End-------------------------(Elapsed Time: 05:10)--------------------------
South Cove VW
Canada
C?ID=10409
Monday,07,December,2015,11:25:20:29821-VCID:71E3D9956BDD67B694-4FAA,VCDS Version: Release 15.7.2,Data version: 20151124
3B0 927 156 AM,,AG5 01V 1.8l5VT USA 1212,
,Group A:,'001,,,,Group B:,'002,,,,Group C:,'003
,,Engine Speed,Transmission,Transmission,Current Gear,,Current Program,Accel. Pedal,Transmission,Current Gear,,Brake Light,Shift Lock,Vehicle Speed,Supply Voltage
,TIME,,Input Speed (G182),Output Speed (G195),,TIME,,Position,Output Speed (G195),,TIME,Switch (F),Solenoid (N110),,(Terminal 15)
Marker,STAMP, /min, /min, /min,,STAMP,, %, /min,,STAMP,,, km/h, V
,0.51,800,0,0,4 ,0.02,DS,0.0,0,4 ,0.25,Brakes,PN Inactive,0.0,0.00
,1.33,800,0,0,4 ,0.78,DS,0.0,0,4 ,1.05,Brakes,PN Inactive,0.0,0.06
,2.14,800,0,0,4 ,1.59,DS,0.0,0,4 ,1.87, ,PN Inactive,0.0,0.06
,2.96,800,0,0,4 ,2.42,DS,0.0,0,4 ,2.68, ,PN Inactive,0.0,0.00
,3.77,928,0,0,4 ,3.23,DS,0.0,0,4 ,3.51, ,PN Inactive,0.0,0.00
,4.60,1152,0,0,4 ,4.05,DS,11.2,0,4 ,4.32, ,PN Inactive,0.0,0.00
,5.42,1184,32,0,4 ,4.87,DS,16.0,0,4 ,5.15, ,PN Inactive,0.0,0.00
,6.24,1248,32,32,4 ,5.70,DS,18.8,0,4 ,5.96, ,PN Inactive,0.0,0.06
,7.05,1408,96,96,4 ,6.51,DS,27.6,64,4 ,6.79, ,PN Inactive,2.0,0.00
,7.88,1408,128,128,4 ,7.33,DS,29.2,96,4 ,7.60, ,PN Inactive,2.0,0.06
,8.69,1440,192,160,4 ,8.15,DS,30.0,160,4 ,8.43, ,PN Inactive,4.0,0.06
,9.52,1600,224,224,4 ,8.97,DS,36.0,192,4 ,9.24, ,PN Inactive,6.0,0.00
,10.33,1792,288,288,4 ,9.78,DS,41.6,256,4 ,10.06, ,PN Inactive,8.0,0.06
,11.16,1920,384,384,4 ,10.61,DS,44.0,320,4 ,10.88, ,PN Inactive,10.0,0.06
,11.97,1920,480,480,4 ,11.42,DS,44.0,416,4 ,11.70, ,PN Inactive,14.0,0.06
,12.79,1408,576,576,4 ,12.25,DS,37.2,512,4 ,12.51, ,PN Inactive,16.0,0.00
,13.61,864,544,544,4 ,13.06,DS,0.0,576,4 ,13.34, ,PN Inactive,18.0,0.06
,14.41,800,512,512,4 ,13.87,DS,0.0,544,4 ,14.14,Brakes,PN Inactive,18.0,0.00
,15.21,768,416,416,4 ,14.67,DS,0.0,480,4 ,14.93,Brakes,PN Inactive,16.0,0.06
,16.02,800,352,352,4 ,15.48,DS,0.0,416,4 ,15.76,Brakes,PN Inactive,12.0,0.00
,16.85,768,288,288,4 ,16.30,DS,0.0,320,4 ,16.56,Brakes,PN Inactive,10.0,0.00
,17.66,768,224,224,4 ,17.11,DS,0.0,256,4 ,17.40,Brakes,PN Inactive,8.0,0.06
,18.45,1120,256,256,4 ,17.94,DS,0.0,256,4 ,18.19, ,PN Inactive,8.0,0.00
,19.27,1568,320,320,4 ,18.72,DS,32.4,256,4 ,18.99, ,PN Inactive,8.0,0.00
,20.08,1792,384,384,4 ,19.53,DS,39.2,352,4 ,19.81, ,PN Inactive,10.0,0.00
,20.91,1920,480,480,4 ,20.36,DS,41.6,416,4 ,20.63, ,PN Inactive,12.0,0.06
,21.71,1920,576,576,4 ,21.17,DS,42.0,512,4 ,21.45, ,PN Inactive,16.0,0.06
,22.54,1920,672,672,4 ,22.00,DS,42.0,608,4 ,22.26, ,PN Inactive,18.0,0.06
,23.35,1952,768,768,4 ,22.81,DS,42.0,704,4 ,23.09, ,PN Inactive,22.0,0.00
,24.18,1984,832,832,4 ,23.64,DS,42.0,800,4 ,23.90, ,PN Inactive,24.0,0.06
,24.99,1984,928,928,4 ,24.44,DS,42.0,864,4 ,24.73, ,PN Inactive,28.0,0.00
,25.82,2016,992,992,4 ,25.27,DS,42.0,960,4 ,25.54, ,PN Inactive,30.0,0.00
,26.63,2016,1056,1056,4 ,26.08,DS,41.6,1024,4 ,26.37, ,PN Inactive,34.0,0.06
,27.46,2048,1120,1120,4 ,26.91,DS,42.0,1088,4 ,27.18, ,PN Inactive,36.0,0.00
,28.27,2080,1184,1184,4 ,27.72,DS,42.0,1152,4 ,28.00, ,PN Inactive,38.0,0.06
,29.06,2080,1216,1216,4 ,28.53,DS,42.0,1184,4 ,28.80, ,PN Inactive,38.0,0.00
,29.88,2048,1248,1248,4 ,29.33,DS,40.0,1216,4 ,29.61, ,PN Inactive,40.0,0.00
,30.70,2048,1280,1280,4 ,30.16,DS,40.4,1280,4 ,30.42, ,PN Inactive,42.0,0.00
,31.51,2048,1312,1312,4 ,30.97,DS,40.4,1312,4 ,31.25, ,PN Inactive,42.0,0.06
,32.34,2080,1312,1344,4 ,31.79,DS,40.4,1312,4 ,32.06, ,PN Inactive,44.0,0.06
,33.15,2080,1344,1344,4 ,32.61,DS,40.4,1344,4 ,32.89, ,PN Inactive,44.0,0.00
,33.98,2080,1376,1376,4 ,33.43,DS,40.4,1344,4 ,33.70, ,PN Inactive,44.0,0.06
,34.79,2112,1408,1408,4 ,34.24,DS,40.4,1376,4 ,34.52, ,PN Inactive,46.0,0.00
,35.62,2112,1440,1440,4 ,35.07,DS,40.4,1408,4 ,35.34, ,PN Inactive,46.0,0.00
,36.42,2112,1472,1472,4 ,35.88,DS,40.4,1440,4 ,36.16, ,PN Inactive,48.0,0.06
,37.25,2112,1504,1504,4 ,36.71,DS,40.4,1472,4 ,36.97, ,PN Inactive,48.0,0.00
,38.07,2144,1536,1536,4 ,37.52,DS,40.0,1504,4 ,37.80, ,PN Inactive,50.0,0.00
,38.89,2144,1568,1568,4 ,38.35,DS,40.0,1536,4 ,38.61, ,PN Inactive,50.0,0.06
,39.70,2144,1600,1600,4 ,39.16,DS,40.0,1568,4 ,39.44, ,PN Inactive,52.0,0.00
,40.53,2176,1632,1632,4 ,39.98,DS,40.0,1632,4 ,40.25, ,PN Inactive,54.0,0.00
,41.34,2176,1664,1664,4 ,40.80,DS,39.6,1664,4 ,41.08, ,PN Inactive,54.0,0.00
,42.15,2208,1696,1696,4 ,41.62,DS,39.6,1696,4 ,41.89, ,PN Inactive,56.0,0.06
,42.95,2208,1728,1728,4 ,42.42,DS,39.6,1728,4 ,42.68, ,PN Inactive,56.0,0.00
,59.43, ,PN Inactive,58.0,0.00,43.21,DS,39.6,1760,4 ,43.49, ,PN Inactive,58.0,0.00
,61.35,1792,352,352,4 ,60.79,DS,41.6,288,4 ,61.08, ,PN Inactive,10.0,0.06
,62.18,2112,448,448,4 ,61.62,DS,48.4,352,4 ,61.89, ,PN Inactive,12.0,0.06
,62.98,2144,576,576,4 ,62.44,DS,48.4,480,4 ,62.72, ,PN Inactive,14.0,0.00
,63.81,2112,672,672,4 ,63.26,DS,46.4,608,4 ,63.53, ,PN Inactive,18.0,0.06
,64.62,2112,800,800,4 ,64.08,DS,46.4,736,4 ,64.36, ,PN Inactive,22.0,0.06
,65.45,2144,896,896,4 ,64.90,DS,46.4,832,4 ,65.17, ,PN Inactive,26.0,0.06
,66.26,2208,960,960,4 ,65.71,DS,48.4,928,4 ,65.99, ,PN Inactive,30.0,0.06
,67.09,2208,992,992,4 ,66.54,DS,48.4,992,4 ,66.81, ,PN Inactive,32.0,0.00
,67.90,2240,1056,1056,4 ,67.35,DS,48.8,1024,4 ,67.63, ,PN Inactive,34.0,0.06
,68.72,2336,1120,1120,4 ,68.18,DS,51.6,1056,4 ,68.44, ,PN Inactive,34.0,0.06
,69.54,2368,1152,1152,4 ,68.99,DS,51.6,1120,4 ,69.27, ,PN Inactive,36.0,0.00
,70.36,2400,1216,1216,4 ,69.82,DS,51.6,1184,4 ,70.08, ,PN Inactive,38.0,0.06
,71.17,2400,1280,1280,4 ,70.63,DS,51.6,1248,4 ,70.91, ,PN Inactive,40.0,0.00
,72.00,2432,1344,1344,4 ,71.45,DS,51.6,1312,4 ,71.72, ,PN Inactive,42.0,0.06
,72.81,2432,1376,1408,4 ,72.27,DS,51.6,1344,4 ,72.55, ,PN Inactive,44.0,0.00
,73.64,2432,1440,1440,4 ,73.09,DS,51.6,1408,4 ,73.36, ,PN Inactive,46.0,0.00
,74.45,2432,1472,1440,4 ,73.90,DS,51.6,1440,4 ,74.18, ,PN Inactive,48.0,0.00
,75.28,2464,1504,1504,4 ,74.73,DS,51.2,1472,4 ,75.00, ,PN Inactive,48.0,0.00
,76.09,2464,1536,1536,4 ,75.54,DS,51.2,1504,4 ,75.82, ,PN Inactive,50.0,0.00
,76.91,2464,1568,1568,4 ,76.37,DS,51.2,1536,4 ,76.63, ,PN Inactive,50.0,0.00
,77.73,2464,1600,1600,4 ,77.18,DS,51.2,1568,4 ,77.46, ,PN Inactive,52.0,0.00
,78.55,2496,1632,1632,4 ,78.01,DS,51.2,1632,4 ,78.27, ,PN Inactive,54.0,0.00
,79.36,2496,1664,1664,4 ,78.82,DS,51.2,1632,4 ,79.10, ,PN Inactive,54.0,0.06
,80.19,2528,1696,1696,4 ,79.64,DS,51.2,1696,4 ,79.91, ,PN Inactive,56.0,0.00
,81.00,2496,1728,1728,4 ,80.46,DS,50.4,1696,4 ,80.74, ,PN Inactive,56.0,0.00
,81.80,2496,1728,1728,4 ,81.28,DS,50.0,1728,4 ,81.53, ,PN Inactive,56.0,0.00
,82.61,2496,1760,1760,4 ,82.06,DS,50.0,1760,4 ,82.33, ,PN Inactive,58.0,0.06
,83.42,2496,1792,1792,4 ,82.87,DS,50.0,1760,4 ,83.15, ,PN Inactive,58.0,0.00
,84.25,2432,1792,1792,4 ,83.70,DS,48.4,1792,4 ,83.97, ,PN Inactive,58.0,0.00
,85.03,2016,1792,1792,4 ,84.50,DS,34.8,1824,4 ,84.77, ,PN Inactive,60.0,0.00
,85.84,1696,1760,1760,4 ,85.30,DS,15.6,1792,4 ,85.58, ,PN Inactive,58.0,0.00
,86.67,1568,1728,1728,4 ,86.12,DS,0.0,1760,4 ,86.39, ,PN Inactive,58.0,0.00
,87.48,1248,1664,1664,4 ,86.93,DS,0.0,1728,4 ,87.22,Brakes,PN Inactive,56.0,0.06
,88.31,1408,1568,1568,4 ,87.76,DS,0.0,1632,4 ,88.03,Brakes,PN Inactive,54.0,0.06
,89.12,1312,1440,1440,4 ,88.57,DS,0.0,1536,4 ,88.85,Brakes,PN Inactive,50.0,0.00
,89.95,1152,1248,1248,4 ,89.40,DS,0.0,1376,4 ,89.66,Brakes,PN Inactive,44.0,0.06
,90.73,1024,1120,1120,4 ,90.20,DS,0.0,1216,4 ,90.46,Brakes,PN Inactive,40.0,0.06
,91.55,896,960,960,4 ,91.01,DS,0.0,1056,4 ,91.27,Brakes,PN Inactive,34.0,0.00
,92.36,832,832,832,4 ,91.82,DS,0.0,928,4 ,92.10,Brakes,PN Inactive,28.0,0.00
,93.19,768,736,736,4 ,92.64,DS,0.0,800,4 ,92.91,Brakes,PN Inactive,26.0,0.00
,94.00,736,640,640,4 ,93.46,DS,0.0,704,4 ,93.74,Brakes,PN Inactive,22.0,0.06
,94.83,736,544,544,4 ,94.28,DS,0.0,608,4 ,94.55,Brakes,PN Inactive,18.0,0.00
,95.64,736,384,384,4 ,95.09,DS,0.0,480,4 ,95.37,Brakes,PN Inactive,14.0,0.06
,96.47,768,192,192,4 ,95.92,DS,0.0,320,4 ,96.19,Brakes,PN Inactive,8.0,0.06
,97.28,736,0,0,4 ,96.73,DS,0.0,128,4 ,97.01,Brakes,PN Inactive,2.0,0.06
,98.09,768,0,0,4 ,97.56,DS,0.0,0,4 ,97.82,Brakes,PN Inactive,0.0,0.00
,98.88,768,0,0,4 ,98.35,DS,0.0,0,4 ,98.62,Brakes,PN Inactive,0.0,0.06
,99.70,768,0,0,4 ,99.15,DS,0.0,0,4 ,99.43,Brakes,PN Inactive,0.0,0.06
,100.52,768,0,0,4 ,99.98,DS,0.0,0,4 ,100.24,Brakes,PN Inactive,0.0,0.06
,101.33,800,0,0,4 ,100.78,DS,0.0,0,4 ,101.07,Brakes,PN Inactive,0.0,0.06
,102.16,768,0,0,4 ,101.61,DS,0.0,0,4 ,101.88,Brakes,PN Inactive,0.0,0.06
South Cove VW
Canada
C?ID=10409
Monday,07,December,2015,11:27:50:29821-VCID:71E3D9956BDD67B694-4FC6,VCDS Version: Release 15.7.2,Data version: 20151124
,Group A:,'004,,,,Group B:,'005,,,,Group C:, Not Running
,,Transmission Fluid,Selector Lever,Multi-Function,On-Board-Diag.,,Solenoid Valve 1,Solenoid Valve 2,Solenoid Valve 3,Current Gear,,,,,
,TIME,Temperature (G93),Position (F125),Switch (F125),(OBD) Information,TIME,(N88),(N89),(N90),,TIME,,,,
Marker,STAMP,°C,,,,STAMP,,,,,STAMP,,,,
,0.02,28.0,D ,    1011,    0111,0.27,O ,O ,O ,4 ,,,,,
,0.55,28.0,D ,    1011,    0111,0.82,O ,O ,O ,4 ,,,,,
,1.10,28.0,D ,    1011,    0111,1.36,O ,O ,O ,4 ,,,,,
,1.64,28.0,D ,    1011,    0111,1.91,O ,O ,O ,4 ,,,,,
,2.19,28.0,D ,    1011,    0111,2.45,O ,O ,O ,4 ,,,,,
,2.73,28.0,D ,    1011,    0111,3.00,O ,O ,O ,4 ,,,,,
,3.27,28.0,D ,    1011,    0111,3.53,O ,O ,O ,4 ,,,,,
,3.80,28.0,D ,    1011,    0111,4.06,O ,O ,O ,4 ,,,,,
,4.34,29.0,D ,    1011,    0111,4.61,O ,O ,O ,4 ,,,,,
,4.89,29.0,D ,    1011,    0111,5.15,O ,O ,O ,4 ,,,,,
,5.43,29.0,D ,    1011,    0111,5.70,O ,O ,O ,4 ,,,,,
,5.98,28.0,Z2,    1010,    0111,6.24,O ,O ,O ,4 ,,,,,
,6.53,29.0,P ,    1000,    0111,6.79,O ,O ,O ,4 ,,,,,
,7.07,29.0,P ,    1000,    0111,7.34,O ,O ,O ,4 ,,,,,
,7.62,29.0,P ,    1000,    0111,7.88,O ,O ,O ,4 ,,,,,
,8.16,29.0,P ,    1000,    0111,8.43,O ,O ,O ,4 ,,,,,
,8.71,29.0,N ,    1110,    0111,8.97,O ,O ,O ,4 ,,,,,
,9.26,29.0,D ,    1011,    0111,9.52,O ,O ,O ,4 ,,,,,
,9.80,29.0,D ,    1011,    0111,10.07,O ,O ,O ,4 ,,,,,
,10.35,29.0,D ,    1011,    0111,10.62,O ,O ,O ,4 ,,,,,
,10.89,29.0,D ,    1011,    0111,11.16,O ,O ,O ,4 ,,,,,
,11.44,29.0,D ,    1011,    0111,11.70,O ,O ,O ,4 ,,,,,
,11.99,29.0,D ,    1011,    0111,12.25,O ,O ,O ,4 ,,,,,
,12.53,29.0,D ,    1011,    0111,12.80,O ,O ,O ,4 ,,,,,
,13.08,29.0,D ,    1011,    0111,13.34,O ,O ,O ,4 ,,,,,
,13.62,29.0,D ,    1011,    0111,13.89,O ,O ,O ,4 ,,,,,
,14.15,29.0,D ,    1011,    0111,14.42,O ,O ,O ,4 ,,,,,
,14.68,29.0,D ,    1011,    0111,14.95,O ,O ,O ,4 ,,,,,
,15.21,29.0,D ,    1011,    0111,15.50,O ,O ,O ,4 ,,,,,
,15.76,29.0,D ,    1011,    0111,16.04,O ,O ,O ,4 ,,,,,
,16.31,29.0,D ,    1011,    0111,16.59,O ,O ,O ,4 ,,,,,
,16.85,29.0,D ,    1011,    0111,17.13,O ,O ,O ,4 ,,,,,
,17.40,29.0,D ,    1011,    0111,17.68,O ,O ,O ,4 ,,,,,
,17.94,29.0,D ,    1011,    0111,18.23,O ,O ,O ,4 ,,,,,
,18.49,29.0,D ,    1011,    0111,18.77,O ,O ,O ,4 ,,,,,
,19.04,30.0,D ,    1011,    0111,19.32,O ,O ,O ,4 ,,,,,
,19.58,30.0,D ,    1011,    0111,19.85,O ,O ,O ,4 ,,,,,
,20.11,30.0,D ,    1011,    0111,20.38,O ,O ,O ,4 ,,,,,
,20.64,30.0,D ,    1011,    0111,20.91,O ,O ,O ,4 ,,,,,
,21.19,30.0,D ,    1011,    0111,21.45,O ,O ,O ,4 ,,,,,
,21.74,30.0,D ,    1011,    0111,22.00,O ,O ,O ,4 ,,,,,
,22.28,30.0,D ,    1011,    0111,22.55,O ,O ,O ,4 ,,,,,
,22.83,30.0,D ,    1011,    0111,23.09,O ,O ,O ,4 ,,,,,
,23.37,30.0,D ,    1011,    0111,23.64,O ,O ,O ,4 ,,,,,
,23.92,30.0,D ,    1011,    0111,24.18,O ,O ,O ,4 ,,,,,
,24.47,30.0,D ,    1011,    0111,24.73,O ,O ,O ,4 ,,,,,
,25.01,30.0,D ,    1011,    0111,25.28,O ,O ,O ,4 ,,,,,
,25.56,30.0,D ,    1011,    0111,25.82,O ,O ,O ,4 ,,,,,
,26.11,30.0,D ,    1011,    0111,26.37,O ,O ,O ,4 ,,,,,
,26.65,30.0,D ,    1011,    0111,26.92,O ,O ,O ,4 ,,,,,
,27.20,32.0,D ,    1011,    0111,27.46,O ,O ,O ,4 ,,,,,
,27.74,30.0,D ,    1011,    0111,28.01,O ,O ,O ,4 ,,,,,
,28.29,32.0,D ,    1011,    0111,28.55,O ,O ,O ,4 ,,,,,
,28.84,32.0,D ,    1011,    0111,29.10,O ,O ,O ,4 ,,,,,
,29.38,32.0,D ,    1011,    0111,29.65,O ,O ,O ,4 ,,,,,
,29.93,32.0,D ,    1011,    0111,30.19,O ,O ,O ,4 ,,,,,
,30.47,32.0,D ,    1011,    0111,30.74,O ,O ,O ,4 ,,,,,
,31.02,32.0,D ,    1011,    0111,31.29,O ,O ,O ,4 ,,,,,
,31.57,32.0,D ,    1011,    0111,31.83,O ,O ,O ,4 ,,,,,
,32.11,32.0,D ,    1011,    0111,32.38,O ,O ,O ,4 ,,,,,
,32.66,32.0,D ,    1011,    0111,32.92,O ,O ,O ,4 ,,,,,
,33.20,32.0,D ,    1011,    0111,33.47,O ,O ,O ,4 ,,,,,
,33.75,32.0,D ,    1011,    0111,34.02,O ,O ,O ,4 ,,,,,
,34.30,32.0,D ,    1011,    0111,34.58,O ,O ,O ,4 ,,,,,
,34.84,32.0,D ,    1011,    0111,35.12,O ,O ,O ,4 ,,,,,
,35.39,33.0,D ,    1011,    0111,35.67,O ,O ,O ,4 ,,,,,
,35.94,33.0,D ,    1011,    0111,36.21,O ,O ,O ,4 ,,,,,
,36.48,33.0,D ,    1011,    0111,36.76,O ,O ,O ,4 ,,,,,
,37.03,33.0,D ,    1011,    0111,37.31,O ,O ,O ,4 ,,,,,
,37.57,33.0,D ,    1011,    0111,37.85,O ,O ,O ,4 ,,,,,
,38.12,33.0,D ,    1011,    0111,38.40,O ,O ,O ,4 ,,,,,
,38.67,33.0,D ,    1011,    0111,38.94,O ,O ,O ,4 ,,,,,
,39.21,33.0,D ,    1011,    0111,39.49,O ,O ,O ,4 ,,,,,
,39.76,33.0,D ,    1011,    0111,40.04,O ,O ,O ,4 ,,,,,
,40.30,33.0,D ,    1011,    0111,40.58,O ,O ,O ,4 ,,,,,
,40.85,33.0,D ,    1011,    0111,41.13,O ,O ,O ,4 ,,,,,
,41.39,33.0,D ,    1011,    0111,41.67,O ,O ,O ,4 ,,,,,
,41.94,33.0,D ,    1011,    0111,42.22,O ,O ,O ,4 ,,,,,
,42.49,33.0,D ,    1011,    0111,42.77,O ,O ,O ,4 ,,,,,
,43.02,33.0,D ,    1011,    0111,43.28,O ,O ,O ,4 ,,,,,
,43.55,34.0,D ,    1011,    0111,43.81,O ,O ,O ,4 ,,,,,
,44.09,33.0,D ,    1011,    0111,44.36,O ,O ,O ,4 ,,,,,
,44.64,33.0,D ,    1011,    0111,44.90,O ,O ,O ,4 ,,,,,
,45.18,34.0,D ,    1011,    0111,45.45,O ,O ,O ,4 ,,,,,
,45.73,34.0,D ,    1011,    0111,46.00,O ,O ,O ,4 ,,,,,
,46.28,34.0,D ,    1011,    0111,46.54,O ,O ,O ,4 ,,,,,
,46.82,34.0,D ,    1011,    0111,47.09,O ,O ,O ,4 ,,,,,
,47.37,34.0,D ,    1011,    0111,47.63,O ,O ,O ,4 ,,,,,
,47.92,34.0,D ,    1011,    0111,48.18,O ,O ,O ,4 ,,,,,
,48.46,34.0,D ,    1011,    0111,48.73,O ,O ,O ,4 ,,,,,
,49.01,34.0,D ,    1011,    0111,49.27,O ,O ,O ,4 ,,,,,
,49.55,34.0,D ,    1011,    0111,49.82,O ,O ,O ,4 ,,,,,
,50.10,34.0,D ,    1011,    0111,50.36,O ,O ,O ,4 ,,,,,
,50.64,34.0,D ,    1011,    0111,50.91,O ,O ,O ,4 ,,,,,
,51.19,34.0,D ,    1011,    0111,51.46,O ,O ,O ,4 ,,,,,
,51.74,34.0,D ,    1011,    0111,52.00,O ,O ,O ,4 ,,,,,
,52.28,34.0,D ,    1011,    0111,52.55,O ,O ,O ,4 ,,,,,
,52.83,34.0,D ,    1011,    0111,53.09,O ,O ,O ,4 ,,,,,
,53.37,34.0,D ,    1011,    0111,53.64,O ,O ,O ,4 ,,,,,
,53.92,34.0,D ,    1011,    0111,54.19,O ,O ,O ,4 ,,,,,
,54.47,35.0,D ,    1011,    0111,54.73,O ,O ,O ,4 ,,,,,
,55.02,35.0,D ,    1011,    0111,55.28,O ,O ,O ,4 ,,,,,
,55.56,35.0,D ,    1011,    0111,55.82,O ,O ,O ,4 ,,,,,
,56.09,35.0,D ,    1011,    0111,56.36,O ,O ,O ,4 ,,,,,
,56.62,35.0,D ,    1011,    0111,56.89,O ,O ,O ,4 ,,,,,
,57.16,35.0,D ,    1011,    0111,57.44,O ,O ,O ,4 ,,,,,
,57.70,35.0,D ,    1011,    0111,57.98,O ,O ,O ,4 ,,,,,
,58.25,35.0,D ,    1011,    0111,58.53,O ,O ,O ,4 ,,,,,
,58.79,35.0,D ,    1011,    0111,59.07,O ,O ,O ,4 ,,,,,
,59.34,35.0,D ,    1011,    0111,59.62,O ,O ,O ,4 ,,,,,
,59.89,35.0,D ,    1011,    0111,60.17,O ,O ,O ,4 ,,,,,
,60.43,36.0,D ,    1011,    0111,60.71,O ,O ,O ,4 ,,,,,
,60.98,35.0,D ,    1011,    0111,61.26,O ,O ,O ,4 ,,,,,
,61.52,35.0,D ,    1011,    0111,61.80,O ,O ,O ,4 ,,,,,
,62.07,35.0,D ,    1011,    0111,62.35,O ,O ,O ,4 ,,,,,
,62.62,35.0,D ,    1011,    0111,62.90,O ,O ,O ,4 ,,,,,
,63.16,35.0,D ,    1011,    0111,63.44,O ,O ,O ,4 ,,,,,
,63.71,36.0,D ,    1011,    0111,63.99,O ,O ,O ,4 ,,,,,
,64.25,36.0,D ,    1011,    0111,64.53,O ,O ,O ,4 ,,,,,
,64.80,35.0,D ,    1011,    0111,65.08,O ,O ,O ,4 ,,,,,
,65.34,36.0,D ,    1011,    0111,65.61,O ,O ,O ,4 ,,,,,
,65.87,36.0,D ,    1011,    0111,66.14,O ,O ,O ,4 ,,,,,
,66.41,36.0,D ,    1011,    0111,66.69,O ,O ,O ,4 ,,,,,
,66.95,36.0,D ,    1011,    0111,67.23,O ,O ,O ,4 ,,,,,
,67.50,36.0,D ,    1011,    0111,67.78,O ,O ,O ,4 ,,,,,
,68.04,36.0,D ,    1011,    0111,68.32,O ,O ,O ,4 ,,,,,
,68.59,36.0,D ,    1011,    0111,68.87,O ,O ,O ,4 ,,,,,
,69.14,36.0,D ,    1011,    0111,69.42,O ,O ,O ,4 ,,,,,
,69.68,36.0,D ,    1011,    0111,69.96,O ,O ,O ,4 ,,,,,
,70.23,36.0,D ,    1011,    0111,70.51,O ,O ,O ,4 ,,,,,
,70.77,36.0,D ,    1011,    0111,71.05,O ,O ,O ,4 ,,,,,
,71.32,36.0,D ,    1011,    0111,71.60,O ,O ,O ,4 ,,,,,
,71.87,36.0,D ,    1011,    0111,72.15,O ,O ,O ,4 ,,,,,
,72.40,36.0,D ,    1011,    0111,72.66,O ,O ,O ,4 ,,,,,
,72.93,36.0,D ,    1011,    0111,73.19,O ,O ,O ,4 ,,,,,
,73.47,36.0,D ,    1011,    0111,73.74,O ,O ,O ,4 ,,,,,
,74.02,36.0,D ,    1011,    0111,74.27,O ,O ,O ,4 ,,,,,
,74.53,36.0,D ,    1011,    0111,74.80,O ,O ,O ,4 ,,,,,
,75.05,37.0,D ,    1011,    0111,75.31,O ,O ,O ,4 ,,,,,
,75.58,37.0,D ,    1011,    0111,75.84,O ,O ,O ,4 ,,,,,
,76.12,37.0,D ,    1011,    0111,76.39,O ,O ,O ,4 ,,,,,
,76.67,37.0,D ,    1011,    0111,76.94,O ,O ,O ,4 ,,,,,
,77.22,37.0,D ,    1011,    0111,77.48,O ,O ,O ,4 ,,,,,
,77.76,37.0,D ,    1011,    0111,78.03,O ,O ,O ,4 ,,,,,
,78.29,37.0,D ,    1011,    0111,78.56,O ,O ,O ,4 ,,,,,
,78.82,37.0,D ,    1011,    0111,79.09,O ,O ,O ,4 ,,,,,
,79.35,37.0,D ,    1011,    0111,79.63,O ,O ,O ,4 ,,,,,
,79.90,37.0,D ,    1011,    0111,80.18,O ,O ,O ,4 ,,,,,
,80.45,37.0,D ,    1011,    0111,80.73,O ,O ,O ,4 ,,,,,
,80.99,37.0,D ,    1011,    0111,81.27,O ,O ,O ,4 ,,,,,
,81.54,37.0,Z2,    1010,    0111,81.82,O ,O ,O ,4 ,,,,,
,82.08,37.0,R ,    0100,    0111,82.36,O ,O ,O ,R ,,,,,
,82.63,37.0,R ,    0100,    0111,82.91,O ,O ,O ,R ,,,,,
,83.18,37.0,R ,    0100,    0111,83.46,O ,O ,O ,R ,,,,,
,83.72,37.0,R ,    0100,    0111,84.00,O ,O ,O ,R ,,,,,
,84.25,37.0,R ,    0100,    0111,105.83,37.0,R ,    0100,    0111,,,,,
Yes this Is very common going hand in hand with slight water damage which is hard to see and the possibility of the F125 Multi-function switch on the transmission being internally shorted or wires snagged/damaged from oil or fluids/corrosion/water!
Use an inspection magnifying mirror to see traces of damage the naked eye can't............
Waste of time to post scan data now........time to RTFB WD and trace wires while observing the block values or with meter......and I recommend a meter and load light like Stan Lee Marvel Comics is stating above.
FYI.........Direct shorts in F125 can and will smoke a driver in the controller.............J217
http://wiki.ross-tech.com/wiki/index.php/17090/P0706/001798
17090/P0706/001798 - Transmission Range Sensor (F125): Implausible Signal
Possible Symptoms
  • No Reverse Lights
  • Engine will not start
  • Incorrect Gear Selection
  • Gear Indicator Display (PRNDL) may be flashing
Possible Causes
  • Gear Selector Cable incorrectly adjusted
  • Transmission Range Sensor (F125) faulty
  • Wiring and/or Connector(s) from/to Transmission Range Sensor (F125) faulty
Possible Solutions
  • Adjust Gear Selector Cable
    • Check Measuring Value Blocks (MVB)
  • Check/Replace Transmission Range Sensor (F125)
  • Check/Repair/Replace Wiring and/or Connector(s) from/to Transmission Range Sensor (F125)
Special Notes
  • When found in 6-Speed Automatic Transmission (01J/Multitronic), the Transmission Range Sensor (F125) is part of the Transmission Control Module (J217)!
    • Check Measuring Value Block (MVB) 002 for Plausibility
    • Check all four Hall Sensor(s) / Magnets
    • Check Selector Shaft Magnet(s) for Damage
    • Check/Replace Transmission Control Module (J217)
South Cove VW
Canada
C?ID=10409
thanks
so you think double check the tcm board for burnt connections after wiggle test of range sensor ?
